after i recieved updates and restarted my pc i found that gui changed from default view to another view with a docker at the bottom of the desktop and the panel is at the top and i want to restore it how to do that and how to figure what happened exactly, please help
Kernel: 5.10.63-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=43c0abd3-df59-4c2f-8668-2dda7942a39e rw quiet apparmor=1
security=apparmor resume=UUID=2dd1c1df-d8d7-4658-9945-1e9c9f304c93
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: LENOVO product: 81BG v: Lenovo ideapad 320-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 320-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: 6JCN33WW date: 06/30/2020
ID-1: BAT0 charge: 24.3 Wh (100.0%) condition: 24.3/30.0 Wh (81.1%)
volts: 8.5 min: 7.6 model: SMP L17M2PB7 type: Li-poly serial: <filter>
status: Full
RAM: total: 3.62 GiB used: 1.67 GiB (46.2%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 600 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 600 2: 600 3: 600
4: 600 5: 600 6: 600 7: 600 8: 600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:4
chip-ID: 04f2:b628 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.63-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel port: 3000 bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
chip-ID: 0cf3:e500 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 40.48 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
type: HDD rpm: 5400 serial: <filter> rev: 1A04 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE0N rev: T.02
dev-links: cdrom
ID-1: / raw-size: 112.69 GiB size: 110.36 GiB (97.93%)
used: 40.48 GiB (36.7%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: 43c0abd3-df59-4c2f-8668-2dda7942a39e
used: 308 KiB (0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7 label: NO_LABEL
uuid: A694-A8A4
ID-1: swap-1 type: partition size: 4 GiB used: 1.8 MiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: 2dd1c1df-d8d7-4658-9945-1e9c9f304c93
ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 94E0-44DE
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 214.84 GiB fs: ntfs label: Windows
uuid: CE62E1E962E1D5ED
ID-4: /dev/sda4 maj-min: 8:4 size: 292.97 GiB fs: ntfs label: Work
uuid: E48AAB608AAB2E4C
ID-5: /dev/sda5 maj-min: 8:5 size: 305.26 GiB fs: ntfs label: Drive
uuid: F42A31462A3106E0
ID-6: /dev/sda6 maj-min: 8:6 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: 8C5AE3585AE33E18
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-2: 1-7:3 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
class-ID: e001
Device-3: 1-8:4 info: Chicony EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b628
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.5 C mobo: N/A
Processes: 235 Uptime: 10m wakeups: 92 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1117 lib: 310 flatpak: 0
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06 ```
