I updated using pamac for the first time (instead of pacman). I restarted after the update and now I cannot log into my computer. When I boot I get the message:
[FAILED] Failed to start Rule-based Manager for Device Events and Files
[FAILED] Failed to start Entropy Daemon based on the HAVEGE algorithm.
[TIME] Timed out waiting for device /dev/disk/by-uuid and a bunch of numbers
[DEPEND] Dependency failed for /dev/disk/by-uuid numbers as above
[DEPEND] Dependency failed for Swap.
[TIME] Timed out waiting for device /dev/disk/by-uuid and another set of numbers
[DEPEND] Dependency failed for /boot/efi
[DEPEND] Dependency failed for Local File Systems
[DEPEND] Dependency failed for File System Check on /dev/disk/by-uuid and the second set of numbers
[FAILED] Failed to start Network Time Synchronization
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or "exit"
to boot into default mode.
Give root password for maintenance
(or press Control-D to continue):
My password does not work, nor does pressing Control-D do anything. I really have no idea how to go about fixing this and I am a bit worried that I am going to be locked out of my computer for good. Can anyone help me with this?
This issue can be several problems. Youâre not locked out of your PC. Do you have the installation media still available? If not, get a new ISO and flash it on a USB stick. Then boot up the system and chroot into your installed system.
Check the following things:
post the file /var/log/pacman.log so we see what got updated
try to check if the update had completed: either sudo pacman -Syu or pamac update
install a newer kernel like linux510 via sudo mhwd-kernel -i linux510. Note: Kernel 4.19 seems not to boot with Systemd 248 series.
Seems the issue is with systemd 248 and Kernel 4.19 series. I just tried to boot and got the same lines reported. However, I was not able to boot further to a secure terminal. So double check if youâre running that kernel.
Jun 14 20:40:35 development systemd[422]: haveged.service: Failed at step NAMESPACE spawning /usr/bin/haveged: Invalid argument
Jun 14 20:40:35 development systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
Jun 14 20:40:36 development systemd-modules-load[362]: Inserted module 'nvidia'
Jun 14 20:40:36 development systemd[1]: haveged.service: Main process exited, code=exited, status=226/NAMESPACE
Jun 14 20:40:36 development systemd[1]: haveged.service: Failed with result 'exit-code'.
Jun 14 20:40:37 development systemd[1]: haveged.service: Scheduled restart job, restart counter is at 3.
Jun 14 20:40:37 development systemd[1]: Stopped Entropy Daemon based on the HAVEGE algorithm.
Jun 14 20:40:37 development systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
Jun 14 20:40:37 development systemd[431]: haveged.service: Failed to set up mount namespacing: /run/systemd/unit-root/dev: Invalid argument
Jun 14 20:40:37 development systemd[431]: haveged.service: Failed at step NAMESPACE spawning /usr/bin/haveged: Invalid argument
Jun 14 20:40:37 development systemd[1]: haveged.service: Main process exited, code=exited, status=226/NAMESPACE
Jun 14 20:40:37 development systemd[1]: haveged.service: Failed with result 'exit-code'.
Jun 14 20:40:37 development systemd[1]: haveged.service: Scheduled restart job, restart counter is at 4.
Jun 14 20:40:38 development systemd[433]: haveged.service: Failed to set up mount namespacing: /run/systemd/unit-root/dev: Invalid argument
Jun 14 20:40:38 development systemd[433]: haveged.service: Failed at step NAMESPACE spawning /usr/bin/haveged: Invalid argument
Jun 14 20:40:38 development systemd[1]: haveged.service: Main process exited, code=exited, status=226/NAMESPACE
Jun 14 20:40:38 development systemd[1]: haveged.service: Failed with result 'exit-code'.
Jun 14 20:40:38 development systemd[1]: haveged.service: Scheduled restart job, restart counter is at 5.
Jun 14 20:40:38 development systemd[1]: Stopped Entropy Daemon based on the HAVEGE algorithm.
Jun 14 20:40:38 development systemd[1]: haveged.service: Start request repeated too quickly.
Jun 14 20:40:38 development systemd[1]: Failed to start Entropy Daemon based on the HAVEGE algorithm.
And these
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Main process exited, code=exited, status=226/NAMESPACE
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Failed with result 'exit-code'.
Jun 14 20:40:33 development systemd[1]: Failed to start Rule-based Manager for Device Events and Files.
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 2.
Jun 14 20:40:33 development systemd[1]: Stopped Rule-based Manager for Device Events and Files.
Jun 14 20:40:33 development systemd[1]: Starting Rule-based Manager for Device Events and Files...
Jun 14 20:40:33 development systemd[392]: systemd-udevd.service: Failed to set up mount namespacing: /run/systemd/unit-root/proc/sys/kernel/hostname: Device or resource busy
Jun 14 20:40:33 development systemd[392]: systemd-udevd.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-udevd: Device or resource busy
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 3.
Jun 14 20:40:40 development ufw-init[441]: Skip starting firewall: ufw (not enabled)
Jun 14 20:40:33 development systemd[393]: systemd-udevd.service: Failed to set up mount namespacing: /run/systemd/unit-root/proc/sys/kernel/hostname: Device or resource busy
Jun 14 20:40:33 development systemd[393]: systemd-udevd.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-udevd: Device or resource busy
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 4.
Jun 14 20:40:33 development systemd[394]: systemd-udevd.service: Failed to set up mount namespacing: /run/systemd/unit-root/proc/sys/kernel/hostname: Device or resource busy
Jun 14 20:40:33 development systemd[394]: systemd-udevd.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-udevd: Device or resource busy
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 5.
Jun 14 20:40:33 development systemd[1]: systemd-udevd.service: Start request repeated too quickly.
Jun 14 20:40:33 development systemd[1]: systemd-udevd-control.socket: Failed with result 'service-start-limit-hit'.
Jun 14 20:40:33 development systemd[1]: systemd-udevd-kernel.socket: Failed with result 'service-start-limit-hit'.
Your update worked fine. Only the kernel is not working with the systemd update. Either try to use linux414 or any other kernel. We have to see if we can fix linux419 or not.
* KERNEL API INCOMPATIBILITY: Linux 4.14 introduced two new uevents
"bind" and "unbind" to the Linux device model. When this kernel
change was made, systemd-udevd was only minimally updated to handle
and propagate these new event types. The introduction of these new
uevents (which are typically generated for USB devices and devices
needing a firmware upload before being functional) resulted in a
number of issues which we so far didn't address. We hoped the kernel
maintainers would themselves address these issues in some form, but
that did not happen. To handle them properly, many (if not most) udev
rules files shipped in various packages need updating, and so do many
programs that monitor or enumerate devices with libudev or sd-device,
or otherwise process uevents. Please note that this incompatibility
is not fault of systemd or udev, but caused by an incompatible kernel
change that happened back in Linux 4.14, but is becoming more and
more visible as the new uevents are generated by more kernel drivers.
To minimize issues resulting from this kernel change (but not avoid
them entirely) starting with systemd-udevd 247 the udev "tags"
concept (which is a concept for marking and filtering devices during
enumeration and monitoring) has been reworked: udev tags are now
"sticky", meaning that once a tag is assigned to a device it will not
be removed from the device again until the device itself is removed
(i.e. unplugged). This makes sure that any application monitoring
devices that match a specific tag is guaranteed to both see uevents
where the device starts being relevant, and those where it stops
being relevant (the latter now regularly happening due to the new
"unbind" uevent type). The udev tags concept is hence now a concept
tied to a *device* instead of a device *event* â unlike for example
udev properties whose lifecycle (as before) is generally tied to a
device event, meaning that the previously determined properties are
forgotten whenever a new uevent is processed.
With the newly redefined udev tags concept, sometimes it's necessary
to determine which tags are the ones applied by the most recent
uevent/database update, in order to discern them from those
originating from earlier uevents/database updates of the same
device. To accommodate for this a new automatic property CURRENT_TAGS
has been added that works similar to the existing TAGS property but
only lists tags set by the most recent uevent/database
update. Similarly, the libudev/sd-device API has been updated with
new functions to enumerate these 'current' tags, in addition to the
existing APIs that now enumerate the 'sticky' ones.
To properly handle "bind"/"unbind" on Linux 4.14 and newer it is
essential that all udev rules files and applications are updated to
handle the new events. Specifically:
⢠All rule files that currently use a header guard similar to
ACTION!="add|change",GOTO="xyz_end" should be updated to use
ACTION=="remove",GOTO="xyz_end" instead, so that the
properties/tags they add are also applied whenever "bind" (or
"unbind") is seen. (This is most important for all physical device
types â those for which "bind" and "unbind" are currently
generated, for all other device types this change is still
recommended but not as important â but certainly prepares for
future kernel uevent type additions).
⢠Similarly, all code monitoring devices that contains an 'if' branch
discerning the "add" + "change" uevent actions from all other
uevents actions (i.e. considering devices only relevant after "add"
or "change", and irrelevant on all other events) should be reworked
to instead negatively check for "remove" only (i.e. considering
devices relevant after all event types, except for "remove", which
invalidates the device). Note that this also means that devices
should be considered relevant on "unbind", even though conceptually
this â in some form â invalidates the device. Since the precise
effect of "unbind" is not generically defined, devices should be
considered relevant even after "unbind", however I/O errors
accessing the device should then be handled gracefully.
⢠Any code that uses device tags for deciding whether a device is
relevant or not most likely needs to be updated to use the new
udev_device_has_current_tag() API (or sd_device_has_current_tag()
in case sd-device is used), to check whether the tag is set at the
moment an uevent is seen (as opposed to the existing
udev_device_has_tag() API which checks if the tag ever existed on
the device, following the API concept redefinition explained
above).
We are very sorry for this breakage and the requirement to update
packages using these interfaces. We'd again like to underline that
this is not caused by systemd/udev changes, but result of a kernel
behaviour change.
* UPCOMING INCOMPATIBILITY: So far most downstream distribution
packages have not retriggered devices once the udev package (or any
auxiliary package installing additional udev rules) is updated. We
intend to work with major distributions to change this, so that
"udevadm trigger -a change" is issued on such upgrades, ensuring that
the updated ruleset is applied to the devices already discovered, so
that (asynchronously) after the upgrade completed the udev database
is consistent with the updated rule set. This means udev rules must
be ready to be retriggered with a "change" action any time, and
result in correct and complete udev database entries. While the
majority of udev rule files known to us currently get this right,
some don't. Specifically, there are udev rules files included in
various packages that only set udev properties on the "add" action,
but do not handle the "change" action. If a device matching those
rules is retriggered with the "change" action (as is intended here)
it would suddenly lose the relevant properties. This always has been
problematic, but as soon as all udev devices are triggered on relevant
package upgrades this will become particularly so. It is strongly
recommended to fix offending rules so that they can handle a "change"
action at any time, and acquire all necessary udev properties even
then. Or in other words: the header guard mentioned above
(ACTION=="remove",GOTO="xyz_end") is the correct approach to handle
this, as it makes sure rules are rerun on "change" correctly, and
accumulate the correct and complete set of udev properties. udev rule
definitions that cannot handle "change" events being triggered at
arbitrary times should be considered buggy.
I am still having an issue. I think I managed to download a new kernel, but there seem to be issues with doing it in chroot (I get some error message). I am going to have to get back into this tomorrow.
[phil@development tmp]$ manjaro-chroot -a
[sudo] password for phil:
==> Detected systems:
--> 0) ManjaroLinux
--> 1) ManjaroLinux1
==> Select system to mount [0-1] :
