I cannot add photos or links, so I assume that I need some activity first?
You are assuming correctly.
Edit:
You can always do it this way:
$ stat / | grep --ignore-case birth
Birth: 2020-09-14 13:00:31.000000000 +0200
Edit #2:
Providing terminal output
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Alternatively, paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB, causing it to render the same way as descrribed above.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
Makes sense. My registration in the forum got deleted some time back (probably for inactivity), unlike my distro.
https://i.imgur.com/Uy4hTTI.png
https://i.imgur.com/Zkl1hFj.png
more than 4 years later, very little has changedâŚ
https://i.imgur.com/kXucIwo.png
Between unstable and testing for the most part. Only resorted to chroot three (3!) times, one of which does NOT count as it was due to a GPU failure.
Birth: 2018-08-27 12:02:32.000000000 +0300
Well, Iâve showed you mine, show me yours.
See about trust levels on Understanding Discourse Trust Levels
Since you are new, you do not have access to members hub where someone showcased a 9 years old install, and still performing perfectly fine. Some have between 6 and 2 years installs.
Mine should have been older, but i did a mistake back then (all my fault) hence now is:
Birth: 2019-10-24 08:27:54.000000000 +0300
You have been registered on the https://archived.forum.manjaro.org and that got replaced in August 2020
Ah, I remember you! Onwards and upwards.
Why did @gohlip leave?
If iâm not mistaken he switched to KaOS. Other active forum members, from back then also left, most for EndeavourOS. I think that is how also life works âŚ
So, you are still on Plasma then âŚ
indeed, not changing that DE for anything. Though I am working in Gnome/mutter because of UbuntuâŚ
Macbook pro 2009.
Birth: 2018-01-05 13:15:46.000000000 +0300
KaOS seems redundant. As sleek as it sounds (âa lean KDE distribution from scratchâ), and even though it uses pacman
, it offers a âlimited repositoryâ, and itâs a hit-or-miss with PKGBUILDs and the AUR.
I can see someone getting excited with this unique âfrom scratch distroâ, only to become frustrated when they cannot seamlessly install/update certain apps that are only available via the AUR or the Arch Linux repository that hasnât be âmodified for a KaOS systemâ.
with the level of expertise that he has, that wouldnât really be an issue.
I didnât test this in practice, but one could cheat by boot into a live medium and recursive remove everything from / (I hope for that person the local /home is not mounted) and reinstall Manjaro again without formatting the partition(s).
But hey, just changing the output of LANG=C stat / | grep --ignore-case birth
before posting it in a forum is an easier cheat.
Cheating isnât the point of this discussion. Weâre talking about the longevity of a rolling release over the years and its stability and reliability.
If I hadnât donated my old system, I had an install from 2016 on it.
Every time I had issues, I would just execute
# pacman -Qqn | pacman -S -
And it would always clean up any package problem.
My laptop:
Birth: 2015-12-23 20:38:31.000000000 +0100
My desktop:
[mochobb@mocho-desktop ~]$ cat /var/log/pacman.log | head -n 1
[2015-11-27 22:44] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/livecd/pacman-gfx.conf --root / --needed -Sy xf86-video-ati mesa-dri lib32-mesa-dri'
This is a support forum, not a social network.
We have an official Telegram channel:
We also have an unofficial subreddit:
