[Testing Update] 2026-02-09 - Kernel 6.19, Mesa 25.3.5, Wine 11.2
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
  • Kernel got released as 6.19.0
    • not all Nvidia proprietary drivers work with this kernel series yet
  • Mesa 25.3.5
  • Wine 11.2
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux510 5.10.249
  • linux515 5.15.199
  • linux61 6.1.162
  • linux66 6.6.123
  • linux612 6.12.69
  • linux618 6.18.9
  • linux619 6.19.0
  • linux61-rt 6.1.158_rt58
  • linux66-rt 6.6.116_rt66
  • linux612-rt 6.12.66_rt15
  • linux617-rt 6.17.5_rt7
Package Changes (2/9/26 10:15)
  • testing core x86_64: 7 new and 7 removed package(s)
  • testing extra x86_64: 176 new and 174 removed package(s)
  • testing multilib x86_64: 21 new and 21 removed package(s)
:: Different overlay package(s) in repository core x86_64
                             PACKAGE             20260208             20260209
                            linux619          6.19.0rc8-2             6.19.0-1
                    linux619-headers          6.19.0rc8-2             6.19.0-1
:: Different sync package(s) in repository core x86_64
                  libmakepkg-dropins                 18-1                 20-1
                          libp11-kit             0.26.1-1             0.26.2-1
                   linux-api-headers               6.18-1               6.19-1
                        p11-kit-docs             0.26.1-1             0.26.2-1
:: Different overlay package(s) in repository extra x86_64
                          backintime              1.5.6-2              1.6.0-1
                       backintime-qt              1.5.6-2              1.6.0-1
                  linux619-acpi_call           1.2.2-0.10              1.2.2-1
                   linux619-bbswitch             0.8-0.10                0.8-1
                linux619-broadcom-wl    6.30.223.271-0.10       6.30.223.271-1
                     linux619-nvidia       590.48.01-0.10          590.48.01-1
                linux619-nvidia-open        590.48.01-0.8          590.48.01-1
                      linux619-r8168        8.055.00-0.10           8.055.00-1
                  linux619-rtl8723bu        20250813-0.10           20250813-1
                   linux619-tp_smapi            0.45-0.10               0.45-1
                linux619-vhba-module        20250329-0.10           20250329-1
    linux619-virtualbox-host-modules            7.2.6-0.3              7.2.6-1
                        linux619-zfs           2.3.5-0.10              2.3.5-1
:: Different sync package(s) in repository extra x86_64
                               3cpio             0.13.1-1             0.14.0-1
                        alertmanager             0.30.1-1             0.31.0-1
                             aws-cli            1.44.29-1            1.44.34-1
                          aws-cli-v2            2.33.12-2            2.33.17-1
                         aws-sdk-cpp           1.11.739-1           1.11.744-1
                    aws-sdk-cpp-core           1.11.739-1           1.11.744-1
                     aws-sdk-cpp-ec2           1.11.739-1           1.11.744-1
                aws-sdk-cpp-firehose           1.11.739-1           1.11.744-1
                     aws-sdk-cpp-iam           1.11.739-1           1.11.744-1
                 aws-sdk-cpp-kinesis           1.11.739-1           1.11.744-1
                      aws-sdk-cpp-s3           1.11.739-1           1.11.744-1
                       bbswitch-dkms              0.8-798              0.8-799
                               beets              2.5.1-4              2.6.1-1
                                 bun              1.3.8-2              1.3.9-1
                              ccache             4.12.2-1             4.12.3-1
                              chrony              4.6.1-2                4.8-2
                cinnamon-screensaver              6.6.1-1              6.6.1-2
                              cmocka              1.1.8-1              2.0.2-1
                          diffoscope                312-1                312-2
                           distrobox            1.8.2.3-1            1.8.2.4-1
                              eksctl            0.214.0-2            0.222.0-1
                              elinks             0.19.0-1             0.19.1-1
                              ffmpeg            2:8.0.1-4            2:8.0.1-5
                            flashrom              1.6.0-1              1.6.0-2
                      forgejo-runner             12.6.3-1             12.6.4-1
                             freetds             1.5.10-1             1.5.11-1
                              fulcio              1.8.3-2              1.8.5-2
                          gemini-cli           1:0.26.0-1           1:0.27.3-1
                             gitsign             0.13.0-2             0.14.0-2
                             glances              4.4.1-5            4.5.0.1-1
                            glewlwyd              2.7.6-5                    -
                             glslang        1:1.4.335.0-1        1:1.4.341.0-1
                          goreleaser             2.13.0-2             2.13.3-2
                            goverlay              1.7.3-1              1.7.4-1
    gpu-screen-recorder-notification              1.1.0-2              1.1.1-1
                            hcxtools              7.0.1-1              7.1.0-1
                            helmfile              1.1.7-2              1.2.3-2
                                hugo            0.155.2-1            0.155.3-2
                             jenkins              2.548-1              2.549-1
                                knot              3.4.6-1              3.5.3-2
                       knot-resolver              5.7.6-1              6.2.0-3
                             kubeone             1.12.2-2             1.12.3-3
                            kubeseal             0.33.1-2             0.34.0-2
                          libfontenc              1.1.8-1              1.1.9-1
                          libplacebo            7.351.0-4            7.351.0-5
      libreoffice-extension-texmaths             0.52.4-1             0.52.5-1
                            libvdpau                1.5-3                1.5-4
                                luau            1:0.707-1            1:0.708-1
                                mesa           1:25.3.4-1           1:25.3.5-1
                           mesa-docs           1:25.3.4-1           1:25.3.5-1
                            minikube             1.37.0-2             1.38.0-2
                        mkdocstrings              1.0.2-1              1.0.3-1
                           mtd-utils              2.1.6-1              2.3.0-1
                           navidrome             0.60.0-1             0.60.2-1
                                ncnn           20260113-1           20260113-2
                              ncspot              1.3.2-1              1.3.3-1
                              nebula             1.10.2-1             1.10.3-1
               netfilter-fullconenat      r73.0cf3b48-495      r73.0cf3b48-496
                         netsniff-ng              0.6.8-6              0.6.9-1
                               ocicl             2.16.0-1             2.16.4-1
                         opencl-mesa           1:25.3.4-1           1:25.3.5-1
                            opencode             1.1.51-1             1.1.53-3
                              packer             1.14.3-1             1.15.0-2
             perl-business-isbn-data       20260123.001-1       20260203.001-1
                 perl-image-exiftool              13.44-1              13.50-1
                               picom               12.5-3                 13-1
                               ponyc             0.60.5-1             0.60.6-1
                      postfix-tlspol             1.8.24-1             1.8.25-1
                  python-aiobotocore              3.1.1-1              3.1.2-1
                        python-black            25.12.0-4             26.1.0-1
                        python-boto3            1.42.39-1            1.42.44-1
                     python-botocore            1.42.39-1            1.42.44-1
                     python-cfn-lint             1.43.4-1             1.44.0-1
                         python-docs             3.14.2-2             3.14.3-1
                     python-engineio             4.13.0-1             4.13.1-1
                      python-fastapi            0.128.0-2            0.128.3-1
                       python-fsspec           2026.1.0-1           2026.2.0-2
          python-gcp-devrel-py-tools             0.0.16-9            0.0.16-10
                        python-gmpy2              2.2.2-2              2.3.0-1
                        python-parse             1.20.2-3             1.21.0-1
                     python-pathspec             0.12.1-4              1.0.4-1
                         python-perf              2.9.0-2             2.10.0-1
                       python-polars             1.37.1-1             1.38.1-1
            python-polars-runtime-32             1.37.1-1             1.38.1-1
            python-polars-runtime-64             1.37.1-1             1.38.1-1
        python-polars-runtime-compat             1.37.1-1             1.38.1-1
                python-pyperformance             1.13.0-2             1.14.0-1
            python-requests-oauthlib              1.3.1-6              2.0.0-1
                   python-sentry_sdk             2.51.0-1             2.52.0-1
                   python-setuptools           1:80.9.0-4           1:81.0.0-1
                     python-socketio             5.16.0-1             5.16.1-1
                 python-sqlite-anyio              0.2.3-3              0.2.4-1
           python-strawberry-graphql            0.291.0-1            0.291.3-1
                         python-tqdm             4.67.2-1             4.67.3-1
                               rekor              1.4.3-2              1.5.0-2
                       roundcubemail             1.6.12-1             1.6.13-1
                  ruby-cucumber-core             16.1.1-1             16.2.0-1
                               satty             0.20.0-1             0.20.1-1
                          scx-scheds             1.0.19-1             1.0.20-1
                           scx-tools             1.0.19-1             1.0.20-1
                                sdl3              3.4.0-2              3.4.0-3
                             shaderc             2025.5-1             2026.1-1
                         spire-agent             1.13.3-2             1.14.1-2
                        spire-server             1.13.3-2             1.14.1-2
                       spirv-headers        1:1.4.335.0-1        1:1.4.341.0-1
                         spirv-tools        1:1.4.335.0-1        1:1.4.341.0-1
                            talosctl             1.12.2-1             1.12.3-1
                               tanka             0.36.2-2             0.36.3-2
                                toot             0.51.0-3             0.51.1-1
                                vale             3.13.0-1             3.13.1-1
                                vals             0.42.6-2             0.43.1-2
                     vaultwarden-web        2025.12.2.0-1         2026.1.0p0-1
                             vcspull             1.51.1-1             1.52.1-1
                    vhba-module-dkms          20250329-62          20250329-63
                                volk          1.4.335.0-1          1.4.341.0-1
                        vulkan-asahi           1:25.3.4-1           1:25.3.5-1
                     vulkan-broadcom           1:25.3.4-1           1:25.3.5-1
                          vulkan-dzn           1:25.3.4-1           1:25.3.5-1
                 vulkan-extra-layers          1.4.335.0-2          1.4.341.1-1
                  vulkan-extra-tools          1.4.335.0-2          1.4.341.1-1
                    vulkan-freedreno           1:25.3.4-1           1:25.3.5-1
                    vulkan-gfxstream           1:25.3.4-1           1:25.3.5-1
                      vulkan-headers        1:1.4.335.0-2        1:1.4.341.0-1
                    vulkan-html-docs          1:1.4.335-1          1:1.4.341-1
                   vulkan-icd-loader          1.4.335.0-1          1.4.341.0-1
                        vulkan-intel           1:25.3.4-1           1:25.3.5-1
         vulkan-mesa-implicit-layers           1:25.3.4-1           1:25.3.5-1
                  vulkan-mesa-layers           1:25.3.4-1           1:25.3.5-1
                      vulkan-nouveau           1:25.3.4-1           1:25.3.5-1
                     vulkan-panfrost           1:25.3.4-1           1:25.3.5-1
                      vulkan-powervr           1:25.3.4-1           1:25.3.5-1
                       vulkan-radeon           1:25.3.4-1           1:25.3.5-1
                       vulkan-swrast           1:25.3.4-1           1:25.3.5-1
                        vulkan-tools          1.4.335.0-1          1.4.341.0-1
            vulkan-utility-libraries          1.4.335.0-1          1.4.341.0-1
            vulkan-validation-layers          1.4.335.0-1          1.4.341.0-1
                       vulkan-virtio           1:25.3.4-1           1:25.3.5-1
                              waybar             0.14.0-6             0.15.0-1
                                wine               11.1-2               11.2-1
                        wine-staging               11.1-1               11.2-1
                             xdotool       3.20211022.1-2       4.20251130.1-1
             xorg-fonts-alias-100dpi              1.0.5-1              1.0.6-1
              xorg-fonts-alias-75dpi              1.0.5-1              1.0.6-1
           xorg-fonts-alias-cyrillic              1.0.5-1              1.0.6-1
               xorg-fonts-alias-misc              1.0.5-1              1.0.6-1
                          xorg-xcalc              1.1.2-2              1.1.3-2
                                anki                    -            25.09.2-5
         python-requests-ratelimiter                    -              0.8.0-1
                        rate-mirrors                    -             0.25.0-3
                              vortix                    -              0.1.2-1
:: Different sync package(s) in repository multilib x86_64
                          lib32-mesa           1:25.3.4-1           1:25.3.5-1
                   lib32-opencl-mesa           1:25.3.4-1           1:25.3.5-1
                       lib32-p11-kit             0.26.1-1             0.26.2-1
                   lib32-spirv-tools        1:1.4.335.0-1        1:1.4.341.0-1
                  lib32-vulkan-asahi           1:25.3.4-1           1:25.3.5-1
               lib32-vulkan-broadcom           1:25.3.4-1           1:25.3.5-1
                    lib32-vulkan-dzn           1:25.3.4-1           1:25.3.5-1
              lib32-vulkan-freedreno           1:25.3.4-1           1:25.3.5-1
              lib32-vulkan-gfxstream           1:25.3.4-1           1:25.3.5-1
             lib32-vulkan-icd-loader          1.4.335.0-1          1.4.341.0-1
                  lib32-vulkan-intel           1:25.3.4-1           1:25.3.5-1
   lib32-vulkan-mesa-implicit-layers           1:25.3.4-1           1:25.3.5-1
            lib32-vulkan-mesa-layers           1:25.3.4-1           1:25.3.5-1
                lib32-vulkan-nouveau           1:25.3.4-1           1:25.3.5-1
               lib32-vulkan-panfrost           1:25.3.4-1           1:25.3.5-1
                lib32-vulkan-powervr           1:25.3.4-1           1:25.3.5-1
                 lib32-vulkan-radeon           1:25.3.4-1           1:25.3.5-1
                 lib32-vulkan-swrast           1:25.3.4-1           1:25.3.5-1
      lib32-vulkan-utility-libraries          1.4.335.0-1          1.4.341.0-1
      lib32-vulkan-validation-layers          1.4.335.0-1          1.4.341.0-1
                 lib32-vulkan-virtio           1:25.3.4-1           1:25.3.5-1
0 voters
Known issues and solutions
:arrow_right: 2026-02-09
2025-12-29
NVIDIA 590 driver drops Pascal and Maxwell support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) or Maxwell (GTX 9xx) GPUs
Impact: Updating the NVIDIA packages on systems with Pascal or Maxwell cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required: Switch to a legacy driver to maintain support:
Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages. You can use nvidia-driver-assistant to figure out which driver would support your hardware best.
2025-12-09
.NET packages may require manual intervention
2025-12-11 - George Rawlinson
The following packages may require manual intervention due to the upgrade from 9.0 to 10.0:
  • aspnet-runtime
  • aspnet-targeting-pack
  • dotnet-runtime
  • dotnet-sdk
  • dotnet-source-built-artifacts
  • dotnet-targeting-pack
pacman may display the following error failed to prepare transaction (could not satisfy dependencies) for the affected packages.
If you are affected by this and require the 9.0 packages, the following commands will update e.g. aspnet-runtime to aspnet-runtime-9.0:
pacman -Syu aspnet-runtime-9.0
pacman -Rs aspnet-runtime
Arch Linux - News: .NET packages may require manual intervention
2025-11-10
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs - sudo mkinitcpio -P
  • Update boot loader - sudo update-grub
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
Previous testing threads:
Is there an option to see which ones do? Also do you have any insight on why? Do they “just” need to be rebuilt or is there more to do (just curious about the technical background)?
6.19 is not an officially released kernel yet — it’s a release candidate. If you want stability and/or full functionality, use 6.18, which is an LTS kernel and will be supported until (at least) the end of 2027.
You mean not officially released by manjaro? Because the official release of the kernel was two days ago (Linux 6.19 [LWN.net])
I’m just kurios about the technical hows and whys - no criticism intended :slight_smile:
Only 580xx and 590xx are official supported by Nvidia for 6.19 series. Older like 390xx, 570xx and 575xx need patches to build. 470xx got updated by the user community.
Yes.
That is too soon for Manjaro to have all of the proprietary driver modules for the kernel ready.
Manjaro uses custom kernels with several additional patches. Proprietary drivers — in this case being Nvidia, which is also the most difficult one because of the different driver versions depending on the different generations of Nvidia graphics adapters — must interface with the kernel by way of a kind of shim, which must be explicitly compiled against each specific kernel version, and for each of the different Nvidia drivers.
There are generally two ways of going about it. The first way is to do exactly what I’ve described here-above, and then the Nvidia driver is hard-linked against the chosen kernel before you even install it. The second way is by way of the DKMS framework, which automatically compiles the shim against the running kernel at boot time.
This is of course only a one-time operation, taking place upon the first boot after installing a new kernel or a new DKMS Nvidia driver module — it’s no longer required for subsequent boots into the same kernel and Nvidia driver combination. Once the DKMS Nvidia shim has been created, your driver is as good as hard-coded against your running kernel.
However, DKMS-enabled driver modules are yet another and separate type of packages, and they too need to be created separately for each of the different Nvidia driver versions. So this is a lot of work, and it cannot possibly run in lockstep with the release of new kernels by kernel.org.
Furthermore, we’ve only got one team member building the kernels and sorting out the proprietary drivers, i.e. @philm himself.
I understand. Honest questions are always welcomed. :wink:
@philm I assume these builds are automated together with the packaging. Are you doing those in gitlab CI or do you use jenkins or something similar?
It is super simple. If you want to support legacy drivers Nvidia is not updating anyone you have to patch them downstream. Also there is the risk of security issues with old drivers. This would mean we have to drop all drivers and only maintain 580xx as legacy and 590xx or whatever newer driver will come out. Users of old hardware then have to switch to nouveau driver or buy newer hardware. Each kernel release has a build log of all modules: Release 6.19.0-1 · manjaro-kernels/linux619 · GitHub
Intel i915 GUC error on Alder Lake UP3 GT2 GPU
An old, familiar error on older Intel platforms has returned. The GPU crashes after a short time when using windy.com. Tested with the latest versions of Firefox and Brave browsers. The newer Arrow Lake GPUs do not appear to be affected. Switching to the Intel XE driver did not resolve the issue.
inxi -G
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] driver: i915 v: kernel
    compositor: kwin_wayland driver: gpu: i915 resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.5-arch1.1
    renderer: Mesa Intel Iris Xe Graphics (ADL GT2)
  API: Vulkan v: 1.4.341 drivers: intel surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
dmesg output:
[  453.190308] i915 0000:00:02.0: [drm] *ERROR* GT0: GUC: Engine reset failed on 0:0 (rcs0) because 0x00000000
[  453.368828] i915 0000:00:02.0: [drm] GPU HANG: ecode 12:1:84dffffb, in CanvasRenderer [3041]
[  453.368841] i915 0000:00:02.0: [drm] GPU error state saved to /sys/class/drm/card1/error
[  453.370580] i915 0000:00:02.0: [drm] GT0: Resetting chip for GuC failed to reset engine mask=0x1
[  453.474009] i915 0000:00:02.0: [drm] *ERROR* GT0: rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
[  453.474871] i915 0000:00:02.0: [drm] *ERROR* GT0: rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
[  453.475055] i915 0000:00:02.0: [drm] CanvasRenderer[3041] context reset due to GPU hang
[  453.475217] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.49.4
[  453.475225] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[  453.510921] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[  453.511988] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[  453.512000] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
Probably this old bug which is indeed still not fixed.
An interesting development: from 2024 onwards, it will probably not be fixed; Alder Lake will likely have to retire soon. :cowboy_hat_face:
