[Testing Update] 2026-02-13 - Kernels, BinUtils, COSMIC 1.0.6
Current Promotions
Recent News
New in Manjaro GNOME!
When choosing an accent color in Settings, the folder colors will now change automatically to match when using the Papirus Dark or Papirus Light icon theme.
To try it out, install gnome-shell-extension-papirus-folders-colorizer from Add/Remove Software, logout / login and enable Papirus Folder Colorizer from Extensions.
Or, if you prefer the command line:
Install:
sudo pacman -Syu gnome-shell-extension-papirus-folders-colorizer
Enable the extension:
 gnome-extensions enable papirus-folders-colorizer@NiffirgkcaJ.github.com
Logout:
gnome-session-quit --logout
Also, when applying accent colors from Layout Switcher settings, it will also set the matching folder color. Requires accent-color-change r172.c761c84-2 or newer.
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
  • Most Kernels got updated
  • binutils 2.46
  • COSMIC 1.0.6
  • Python updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux510 5.10.250
  • linux515 5.15.200
  • linux61 6.1.163
  • linux66 6.6.124
  • linux612 6.12.71
  • linux618 6.18.10
  • linux619 6.19.0
  • linux61-rt 6.1.158_rt58
  • linux66-rt 6.6.116_rt66
  • linux612-rt 6.12.66_rt15
  • linux617-rt 6.17.5_rt7
Package Changes (2/13/26 10:45)
  • testing core x86_64: 55 new and 39 removed package(s)
  • testing extra x86_64: 653 new and 649 removed package(s)
  • testing multilib x86_64: 5 new and 5 removed package(s)
More details about the package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2026-02-13
2025-12-29
NVIDIA 590 driver drops Pascal and Maxwell support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) or Maxwell (GTX 9xx) GPUs
Impact: Updating the NVIDIA packages on systems with Pascal or Maxwell cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required: Switch to a legacy driver to maintain support:
Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages. You can use nvidia-driver-assistant to figure out which driver would support your hardware best.
2025-12-09
.NET packages may require manual intervention
2025-12-11 - George Rawlinson
The following packages may require manual intervention due to the upgrade from 9.0 to 10.0:
  • aspnet-runtime
  • aspnet-targeting-pack
  • dotnet-runtime
  • dotnet-sdk
  • dotnet-source-built-artifacts
  • dotnet-targeting-pack
pacman may display the following error failed to prepare transaction (could not satisfy dependencies) for the affected packages.
If you are affected by this and require the 9.0 packages, the following commands will update e.g. aspnet-runtime to aspnet-runtime-9.0:
pacman -Syu aspnet-runtime-9.0
pacman -Rs aspnet-runtime
– Arch Linux - News: .NET packages may require manual intervention
2025-11-10
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs - sudo mkinitcpio -P
  • Update boot loader - sudo update-grub
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
Previous testing threads:
Aha, I see that now there’s at least one option for older nvidia cards:
               linux619-nvidia-470xx                    -         470.256.02-2
So I count that as progress, altough I’ll probably just wait to update the kernel on my old laptop, since that currently is running with linux618-nvidia-575xx
So, I hope it’s just a matter of time until the equivalent version linux619-nvidia-575xx.
On that note, will there eventually be a linux619-nvidia-580xx? I heared there are some issues with that, but It’s what nvidia calls recommended for the dropped cards…
I personally didn’t experience any problems with that before the update to 590.
Any reason why you would want to use kernel 6.19? 6.18 is a long-term-support kernel — it’s supported until at least December 2027 — and if your laptop is really that old, then you might actually be better off sticking to 6.18.
Where’s the point in running testing if not to see if things work and to try to help fix or at least report what’s broken?
If I wasn’t willing to tinker and experiment a bit, I would be running stable.
I usually do keep the latest LTS kernel installed alsongside, just in case, since an update making my system unbootable bit me before in the worst possible moment - but that was before switching to manjaro.
Well, I don’t know. Some people run the Testing branch because they always want The Latest & Greatest™. :man_shrugging:
No issues. I simply found these filenames to be amusing:
extra/gst-plugins-bad         1.26.10-4                    1.26.10-5                       0.00 MiB       1.12 MiB
extra/gst-plugins-bad-libs    1.26.10-4                    1.26.10-5                      -0.02 MiB       2.86 MiB
extra/gst-plugins-base        1.26.10-4                    1.26.10-5                       0.00 MiB       0.21 MiB
extra/gst-plugins-base-libs   1.26.10-4                    1.26.10-5                       0.00 MiB       2.35 MiB
extra/gst-plugins-good        1.26.10-4                    1.26.10-5                       0.00 MiB       2.21 MiB
extra/gst-plugins-ugly        1.26.10-4                    1.26.10-5                       0.00 MiB       0.17 MiB
Well, that’s what they’re named after. :cowboy_hat_face:
In Manjaro Settings manager, kernel 6.18 isn’t labelled as LTS on my installation. Is it a local issue or the label is yet to be attached?
Labeling a kernel as LTS in the manjaro-settings-manager requires an update to the manjaro-settings-manager package itself.
It’s a result of the ad hoc way the software was written, and its developer chose to do it that way because new LTS kernels appear only once every year. :wink:
It is now with manjaro-settings-manager 0.5.8-8 coming along shortly.
That’s my POV, but not everyone does it for that reason.
So far, testing is as stable as stable for me, with both testing installs. One on the SSD of this computer, and on on the SSD out of the computer that died, running via USB. I’m posting from that install at the moment.
Just tried plasma-login-manager and got stuck at Graphical.target reached
I even can’t ctrl+alt+f* out of this state, but Ctrl+Alt+Del works.
But in another boot, when I press Ctrl+Alt+F3 right before the login manager usually kicks in, it was able to start.
Found in the logs of the problem boot
фев 18 00:13:48 gl-laptop systemd[2028]: Starting KDE Window Manager (Login Manager Version)...
фев 18 00:13:48 gl-laptop kwin_wayland[2098]: No backend specified, automatically choosing drm
фев 18 00:13:48 gl-laptop systemd[1]: Starting Authorization Manager...
фев 18 00:13:48 gl-laptop polkitd[2100]: Started polkitd version 127
фев 18 00:13:48 gl-laptop systemd[1]: Started Authorization Manager.
фев 18 00:13:48 gl-laptop kwin_wayland[2098]: Accepting client connections on sockets: QList("wayland-0")
фев 18 00:13:48 gl-laptop kwin_wayland[2098]: Failed to open /dev/dri/card1 device (Device or resource busy)
фев 18 00:13:49 gl-laptop kwin_wayland[2098]: Failed to open /dev/dri/card1 device (Device or resource busy)
PS:
Fixed by
systemctl unmask plymouth-quit.service
systemctl unmask plymouth-quit-wait.service
I don’t remember when and why it was masked before.
