[Testing Update] 2026-02-08 - Kernels, KDE Gear, COSMIC, Systemd, Qt6, LibreOffice
Current Promotions
Recent News
KDE Plasma users with SDDM can now migrate to Plasma Login Manager
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
NVIDIA 590 driver drops Pascal support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) GPUs or older.
Impact: Updating the NVIDIA packages on systems with Pascal, Maxwell, or older cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required for Pascal/older users: Users with GTX 10xx series and older cards must switch to a legacy driver to maintain support:
  • Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages.
  • Manjaro 26.0 Anh-Linh released
  • Manjaro Summit public Alpha now available
  • As of Linux 5.4.302, the 5.4 series is now EOL (End Of Life). Please install 5.10 LTS (Long Term Support) or 5.15 LTS.
  • As of Linux 6.16.12, the 6.16 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
  • As of Linux 6.17.13, the 6.17 series is now EOL (End Of Life). Please install 6.18 LTS (Long Term Support) and/or 6.12 LTS.
Previous News
Notable Package Updates
Additional Info
Python 3.14 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux510 5.10.249
  • linux515 5.15.199
  • linux61 6.1.162
  • linux66 6.6.123
  • linux612 6.12.69
  • linux618 6.18.9
  • linux619 6.19.0-rc8
  • linux61-rt 6.1.158_rt58
  • linux66-rt 6.6.116_rt66
  • linux612-rt 6.12.66_rt15
  • linux617-rt 6.17.5_rt7
Package Changes (2/8/26 05:47 CET)
  • testing core x86_64: 34 new and 35 removed package(s)
  • testing extra x86_64: 1870 new and 2016 removed package(s)
  • testing multilib x86_64: 8 new and 6 removed package(s)
List of changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2026-02-08
2025-12-29
NVIDIA 590 driver drops Pascal and Maxwell support
With the update to driver version 590, the NVIDIA driver no longer supports Pascal (GTX 10xx) or Maxwell (GTX 9xx) GPUs
Impact: Updating the NVIDIA packages on systems with Pascal or Maxwell cards will fail to load the driver, which may result in a broken graphical environment.
Intervention required: Switch to a legacy driver to maintain support:
Install the official linuxXXX-nvidia-575xx, linuxXXX-nvidia-570xx, or related DKMS packages. You can use nvidia-driver-assistant to figure out which driver would support your hardware best.
2025-12-09
.NET packages may require manual intervention
2025-12-11 - George Rawlinson
The following packages may require manual intervention due to the upgrade from 9.0 to 10.0:
  • aspnet-runtime
  • aspnet-targeting-pack
  • dotnet-runtime
  • dotnet-sdk
  • dotnet-source-built-artifacts
  • dotnet-targeting-pack
pacman may display the following error failed to prepare transaction (could not satisfy dependencies) for the affected packages.
If you are affected by this and require the 9.0 packages, the following commands will update e.g. aspnet-runtime to aspnet-runtime-9.0:
pacman -Syu aspnet-runtime-9.0
pacman -Rs aspnet-runtime
– Arch Linux - News: .NET packages may require manual intervention
2025-11-10
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs - sudo mkinitcpio -P
  • Update boot loader - sudo update-grub
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
Previous testing threads:
I’ve followed one issue all the way from Arch Testing that may deserve mention when this goes to Stable Branch.
It affects only Proton Mail Bridge and ProtonVPN. (Strangely, the Proton Mail Desktop Client seems unaffected.) Keychain updates mean autologins need to be refreshed–you need to login again. Autostarts, of course, fail until the autologins are refreshed.
It’s fine and easy with VPN. Bridge, however requires a total reconfiguration as if installed from scratch. Which means in Thunderbird, removing the old certificate exception, adding a new one, and new passwords for IMAP and SMTP.
Then it resyncs local copies of all messages from the server. Tedious. And I, for one, have trouble remembering where Thunderbird hides everything I need to change when this happens.
It’s purely a ProtonAG issue. Nothing at all to do with Arch or Manjaro. But a mention in the release notes for Stable Branch could help reduce support questions. And perhaps a reminder that the outfits that make Proton Mail/VPN/etc. and the Proton whatever that gamers use, are two completely unrelated companies and product lines.
EDIT: I can blame the eye surgery I had last week. I clicked the wrong choice in the vote above. Clicked the “I have an issue” button instead of the “I fixed my issue” button.
