[Testing Update] 2025-11-27 - Firmware, Xorg, Firefox, Qt6, ROCm
Hello community, here we have another set of package updates. Welcome to our new development cycle of Manjaro 25.1.0, code-named ‘Anh-Linh’.We will focus on Plasma 6.5 series and will introduce GNOME 49, maybe Cosmic 1.0 (Beta).
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Arch Linux - News: Valkey to replace Redis in the [extra] Repository
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.301
  • linux510 5.10.246
  • linux515 5.15.196
  • linux61 6.1.158
  • linux66 6.6.117
  • linux612 6.12.59
  • linux617 6.17.9
  • linux618 6.18.0-rc7
  • linux61-rt 6.1.158_rt58
  • linux66-rt 6.6.116_rt66
  • linux612-rt 6.12.57_rt14
  • linux617-rt 6.17.5_rt7
Package Changes (11/27/25 11:24 CET)
  • testing core x86_64: 20 new and 20 removed package(s)
  • testing extra x86_64: 709 new and 707 removed package(s)
  • testing multilib x86_64: 8 new and 8 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-11-10
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs - sudo mkinitcpio -P
  • Update boot loader - sudo update-grub
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
2025-09-28
2025-9-27
Heads up: Gnome 49 is here and wayland is the default.
Previous testing threads:
I moved to Testing today, in the hopre that I can contribute more, in the form of bug reporting. Concurrent, it appears, with this update.
Other than the unexpected changes to mkinitcpio.conf via a pacnew, I have experienced no issues.
