[Testing Update] 2025-03-30 - Kernels, Qt 6.8.3, Umu-Launcher, Haskell, Python
Hello community, here we have another set of package updates. Since I’m still recovering from my move back to Europe from Asia, I might be less responsive on the forum. So lets test these packages thoroughly so we can do another stable branch snap.
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
Recent News
Previous News
Notable Package Updates
  • Kernels
  • Qt 6.8.3
  • UMU-Launcher 1.2.6
  • Haskell and Python updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.290
  • linux510 5.10.235
  • linux515 5.15.178
  • linux61 6.1.132
  • linux66 6.6.85
  • linux612 6.12.21
  • linux613 6.13.9
  • linux614 6.14.0
  • linux61-rt 6.1.128_rt49-1
  • linux66-rt 6.6.84_rt52
  • linux612-rt 6.12.16_rt9
  • linux613-rt 6.13_rt5
Package Changes (Sun Mar 30 06:17:52 CEST 2025)
  • testing core x86_64: 15 new and 15 removed package(s)
  • testing extra x86_64: 952 new and 946 removed package(s)
  • testing multilib x86_64: 3 new and 3 removed package(s)
A list of all changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2025-03-30
2025-03-20
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
2025-03-05
[community] repo removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
Previous testing threads:
For me Windows disappeared from the GRUB menu. I am using Manjaro Testing and Windows 10 in Bios Mode. Kernel 6.12.20-2-MANJARO
Any idea, how to fix this?
First, make sure you have the right grub installed by
sudo pacman-mirrors -f && sudo pacman -Syyuu
Restore the boot loader, make sure os-prober is enabled in your /etc/default/grub and then run
sudo update-grub
Finally, reboot.
Seems this was reported now multiple times. The current grub update larger than 2.13-3 might have some issues. What happens when the current stable version is used and any grub update ignored?
sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/grub-2:2.12-3-x86_64.pkg.tar.zst
Also, a smaller issue, on boot I get the grub menu even though I did not get it 2-4 Updates ago, since I do not dual boot.
TLRD: GRUB menu shoes up even though I dont need it.
4 posts were split to a new topic: Manjaro Settings Manager showing out-of-date kernel information
Thought all is OK till I disovered, that kwin window rules stopped working properly.
I noticed first that PIP are not on the front as they were set to be on Wayland. I went to window special settings and noticed this:
Where are the options and why are they invisible?
Rolling back the update :frowning: I’m using PiP too often.
This bug is also already present in Manjaro Stable. Presumably it was introduced with Plasma 6.3.3.
You are right. I rolled back the update, still having Plasma 6.3.3 and the bug is still there. Checked, vanilla test user and the same, so it’s not a matter of configs. How did I not see that earlier?
Will check on unstable then. Rolling even earlier backup is possible, but I am hesitant going so much back.
EDIT: On regular FF, PiP works, but on my installed web-app version is not and I can’t fix it, because settings are broken. Hard to choose from plethora of invisible options ;).
Looks like it’s this bug:
https://bugs.kde.org/show_bug.cgi?id=501357
Fixed in kwin 6.3.4, which currently is in unstable
Updated BIOS, looks like my Grub broke. Booting to error: symbol grub rescue> 'symbol grub_cli_set_auth_needed' not found
This probably doesn’t belong here, but if I could be forwarded to help on this. I’m having one of those moments right now.
No, downgrading the BIOS didn’t work.
Wollie, nerve wracking, but got me in! Thank you!!
Have you tried to restore the boot loader?
there is this patch for amd gpu & nvidia to apply
