[Testing Update] 2024-11-16 - Kernels, Mesa, Systemd, LxQt 2.1, Libreoffice
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
  • Kernels
  • Mesa 24.2.7
    • mesa-vdpau is now part of mesa again
  • Systemd 256.8
  • LibreOffice 24.8.3
  • LxQt 2.1.0
  • Thunderbird 128.4.3
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.323
  • linux54 5.4.285
  • linux510 5.10.229
  • linux515 5.15.172
  • linux61 6.1.117
  • linux66 6.6.61
  • linux610 6.10.14 [EOL]
  • linux611 6.11.8
  • linux612 6.12.0-rc7
  • linux61-rt 6.1.112_rt43
  • linux66-rt 6.6.53_rt44
  • linux610-rt 6.10.2_rt14
Package Changes (Sat Nov 16 09:01:56 CET 2024)
  • testing core x86_64: 2 new and 2 removed package(s)
  • testing extra x86_64: 563 new and 553 removed package(s)
  • testing multilib x86_64: 10 new and 12 removed package(s
Overlay Changes
  • testing core x86_64: 15 new and 15 removed package(s)
  • testing extra x86_64: 66 new and 130 removed package(s)
  • testing multilib x86_64: 1 new and 1 removed package(s)
A list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2024-11-16
2024-11-13
v86d has been dropped from Manjaro repositories and is no longer required for mhwd
Re: Unstable Update MHWD disussion
If pamac GUI options Enable AUR support and Check for updates are enabled, users should check the package list before agreeing to update and un-check AUR packages
2024-11-01
KVM default behavior change on module loading in kernel 6.12
In kernel 6.12, KVM initializes virtualization on module loading by default. This prevents VirtualBox VMs from starting. In order to avoid this, either add kvm.enable_virt_at_load=0 parameter into kernel command line or unload the corresponding kvm_XXX module. Initial support for 6.12 kernel series was added with Virtualbox 7.1.4.
More info about that in the Linux mailing list
2024-10-20
Kernel 6.10 has been marked [EOL] on kernel.org
sddm login problems with multiple monitors
  • bug report
  • login only works on secondary monitor
  • switching sddm theme to maldives works around the issue
2024-09-13
:warning: Linux 6.9 is EOL
Linux 6.9 is EOL and has been removed from the repos.
Suggestion is to install latest LTS; i.e.,
sudo mhwd-kernel -i linux66
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
– Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
KDE Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
Previous testing threads:
Hi,
Nice to see LXQt 2.1
Not possible to build a LXQt 2.1 image with Manjaro build iso…
[nls@lap ~]$ date -u
sam. 16 nov. 2024 10:57:13 UTC
[nls@lap ~]$ pamac install manjaro-tools-iso git
Preparing...
Refreshing AUR...
Failed to synchronize AUR database
Warning: git-2.46.1-1 is up to date -- skipping
Warning: manjaro-tools-iso-git-r3038.3ecba91-1 is up to date -- skipping
Nothing to do.
[nls@lap ~]$ sudo git clone https://gitlab.manjaro.org/profiles-and-settings/iso-profiles.git ~/iso-profiles
Cloning into '/home/nls/iso-profiles'...
remote: Enumerating objects: 22929, done.
remote: Counting objects: 100% (1242/1242), done.
remote: Compressing objects: 100% (445/445), done.
remote: Total 22929 (delta 877), reused 1064 (delta 750), pack-reused 21687
Receiving objects: 100% (22929/22929), 20.73 MiB | 50.18 MiB/s, done.
Resolving deltas: 100% (14563/14563), done.
[nls@lap ~]$ sudo buildiso -f -p lxqt -b testing -k linux66 2024.11.16
==> ERROR: lxqt is not a valid profile or build list!
==> ERROR: Profile [/home/nls/iso-profiles//lxqt] sanity check failed!
[nls@lap ~]$
The AUR package sooperlooper had to be removed:
Resolving dependencies...
:: installing rubberband (4.0.0-1) breaks dependency 'librubberband.so=2-64' required by sooperlooper-git
Sooperlooper rebuild fails because of another error / dependency. With the help of a more knowledgable user this was solved:
https://aur.archlinux.org/packages/sooperlooper-git
Not if you are using the official iso-profiles repo.
Many moons ago the iso-profiles repo was cleaned up and unsupported profiles removed.
Thanks for your reply,
I use the official iso-profiles repo
I’m not a dev to build my own profile, but, how to build a unsupported profile ?
Why does the gtk font look so bad under KDE wayland? Is this a misconfiguration? Can I change something about it?
Example:
Wayl_gtk
It is similar to the iso from current system section in → [root tip] [How To] Mini guide to build Manjaro ISO
