[Testing Update] 2024-10-16 - Virtualbox, Blender, Plasma 6.2.1, OpenSearch
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Our current supported kernels
  • linux419 4.19.322
  • linux54 5.4.284
  • linux510 5.10.226
  • linux515 5.15.167
  • linux61 6.1.114
  • linux66 6.6.56
  • linux610 6.10.14 [EOL]
  • linux611 6.11.3
  • linux612 6.12.0-rc3
  • linux61-rt 6.1.112_rt43
  • linux66-rt 6.6.53_rt44
  • linux610-rt 6.10.2_rt14
Package Changes (Wed Oct 16 14:40:09 CEST 2024)
  • testing core x86_64: 5 new and 5 removed package(s)
  • testing extra x86_64: 283 new and 272 removed package(s)
A list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2024-10-16
Kernel 6.10 has been marked [EOL] on kernel.org
2024-09-13
:warning: Linux 6.9 is EOL
Linux 6.9 is EOL and has been removed from the repos.
Suggestion is to install latest LTS; i.e.,
sudo mhwd-kernel -i linux66
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
KDE Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
2024-08-04
pulseaudio-ctl requires pulseaudio and is not compatible with pipewire
If one is using PipeWire, one will need to remove pulseaudio-ctl if prompted during the update as it’s only compatible with pulseaudio
Previous testing threads:
My update went ok but I have one annoyance. Suddenly my logon splash screen is up for 30 seconds rather than about 5. I was more than a little concerned that my logon may have frozen there. I did your basic stopwatch test first, but it’s also visible in journalctl.
I started with a custom splash screen but switched to Breeze, which did not help.
inxi -Fazy
  Kernel: 6.11.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=f0812a05-f95b-47a2-a7a3-d652d9b60591 rw
    resume=UUID=5052202f-aca8-4237-92d4-ae513ec48917 udev.log_priority=3
    sysrq_always_enabled=1 acpi_pstate=active
  Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A info: frameworks v: 6.7.0
  Type: Desktop Mobo: ASRock model: A320M-HDV R4.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: P7.00
    date: 11/15/2021
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2200 min/max: 2200/4208 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    bogomips: 86268
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Micro-Star MSI driver: amdgpu
    v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
    DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 07:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 54.0 C
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 res: 3840x1600 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 LLVM 18.1.8 DRM 3.59 6.11.3-1-MANJARO) device-ID: 1002:67df
    memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 24.2.4-arch1.1
    device-ID: 1002:67df surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.11.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp5s0 state: down mac: <filter>
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0aa7
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 2.95 TiB used: 1.27 TiB (43.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 36.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0400 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A02 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10JMVW-11AJGS1 size: 931.48 GiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1042 scheme: GPT
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 402.49 GiB (44.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 27.2 MiB (9.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 57.4 C mobo: N/A gpu: amdgpu temp: 54.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 199
  Memory: total: 32 GiB available: 31.28 GiB used: 6.2 GiB (19.8%)
  Processes: 334 Power: uptime: 58m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.5 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1912 pm: pacman pkgs: 1897 libs: 530 tools: pamac,yay pm: rpm
    pkgs: 1 pm: flatpak pkgs: 14 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh
    v: 5.9 running-in: konsole inxi: 3.3.36
From a few days ago:
journalctl -b -2 | grep 'Splash sc'         ✔
Oct 14 23:15:43 flashymanjaro systemd[1111]: Starting Splash screen shown during boot...
Oct 14 23:15:49 flashymanjaro systemd[1111]: Finished Splash screen shown during boot.
And today. I logged on and off several times to make sure it was repeatable:
journalctl -b | grep 'Splash sc'         INT ✘
Oct 16 09:32:55 flashymanjaro systemd[1026]: Starting Splash screen shown during boot...
Oct 16 09:33:26 flashymanjaro systemd[1026]: Finished Splash screen shown during boot.
Oct 16 09:34:38 flashymanjaro systemd[1026]: Starting Splash screen shown during boot...
Oct 16 09:35:09 flashymanjaro systemd[1026]: Finished Splash screen shown during boot.
Oct 16 09:40:12 flashymanjaro systemd[1026]: Starting Splash screen shown during boot...
Oct 16 09:40:43 flashymanjaro systemd[1026]: Finished Splash screen shown during boot.
Oct 16 09:41:42 flashymanjaro systemd[1026]: Starting Splash screen shown during boot...
Oct 16 09:42:13 flashymanjaro systemd[1026]: Finished Splash screen shown during boot.
Edit: I created a new user and logged on with that. No difference
I didn’t have time to test and troubleshoot, but this happened to me as well. I was just starting to hold the Power button when I saw the desktop pop up.
I was installing new kernels from previous update in pamac-cli and noticed warning about EOL kernel
NOTE, 6.10.14 is the last maintenance release of the 6.10 kernel series.
This kernel is now marked ‘End Of Life’ (EOL).
It is recommend to switch to the newer linux611 series:
‘sudo mhwd-kernel -i linux611’
Do you want Testing Branch users to help test the new metapackages when kernel 6.10 is dropped?
No, cos we know that the meta-packages will work. They get updated when we really drop 6.10. Now we plan to update mhwd-kernel to allow uninstalls of 6.10 with meta packages present.
Kernel 6.6, 6.10, 6.11 w Plasma, Wayland, nVidia. Slow splash screen, after that desktop shows, but unresponsive for another half a minute. After that no mouse cursor is visible for the rest of the session. It is moving and you are able to click on GUI elements, but you have to do it blindly.
EDIT: reverting/updating kwin (6.2.1-1 → 6.2.1.1-0) and plasma-workspaces (6.2.1-1.2 → 6.2.1.1-0) (now on test branch repo) fixed all issues.
In the meantime, I nuked plasma .config, plasmoids and nothing helped.
On both 6.6 and 6.11 KDE Plasma, after logging in via SDDM kwin_wayland coredumps followed by other applications. After this I return to the login screen. Trying to login leads to the same issues. Switched back to updates as of Oct 15 and no issues.
Oct 16 18:14:05 tufwrapper kernel: kwin_wayland[1643]: segfault at 10 ip 00007375ed81323b sp 00007ffdac6ba680 error 4 in libkwin.so.6.2.1[41323b,7375ed54b000+4a7000] likely on CPU 6 (core 12, socket 0)
Oct 16 18:14:05 tufwrapper kernel: Code: 89 e7 ff 15 8f bd 36 00 49 39 df 0f 85 6a ff ff ff 48 8b 9d e8 fe ff ff 48 8b 85 d0 fe ff ff 4c 8d ad 20 ff ff ff 48 8b 40 10 <48> 8b 78 10 ff 15 33 52 36 00 48 8b b5 f8 fe ff ff 31 d2 f3 0f 7e
Oct 16 18:14:05 tufwrapper systemd-coredump[1779]: Process 1643 (kwin_wayland) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Oct 16 18:14:05 tufwrapper systemd[1]: Created slice Slice /system/systemd-coredump.
Oct 16 18:14:05 tufwrapper systemd[1]: Started Process Core Dump (PID 1779/UID 0).
Oct 16 18:14:05 tufwrapper wireplumber[1750]: e[0;1;33me[0;1;39me[0;1;33mdefault: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwnere[0m
Oct 16 18:14:05 tufwrapper kernel: Bluetooth: RFCOMM TTY layer initialized
Oct 16 18:14:05 tufwrapper kernel: Bluetooth: RFCOMM socket layer initialized
Oct 16 18:14:05 tufwrapper kernel: Bluetooth: RFCOMM ver 1.11
Oct 16 18:14:05 tufwrapper systemd-coredump[1780]: e]8;;man:core(5)a[🡕]e]8;;a e[0;1;31me[0;1;39me[0;1;31mProcess 1643 (kwin_wayland) of user 1000 dumped core.e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1643:e[0m
                                                   e[0;1;31m#0  0x00007375ed81323b n/a (libkwin.so.6 + 0x41323b)e[0m
                                                   e[0;1;31m#1  0x00007375ed815ff0 n/a (libkwin.so.6 + 0x415ff0)e[0m
                                                   e[0;1;31m#2  0x00007375ed816828 n/a (libkwin.so.6 + 0x416828)e[0m
                                                   e[0;1;31m#3  0x00007375ed816ac6 n/a (libkwin.so.6 + 0x416ac6)e[0m
                                                   e[0;1;31m#4  0x00007375ed8171f9 n/a (libkwin.so.6 + 0x4171f9)e[0m
                                                   e[0;1;31m#5  0x00007375ed80a538 n/a (libkwin.so.6 + 0x40a538)e[0m
                                                   e[0;1;31m#6  0x00007375ed828421 n/a (libkwin.so.6 + 0x428421)e[0m
                                                   e[0;1;31m#7  0x00007375ed82913b n/a (libkwin.so.6 + 0x42913b)e[0m
                                                   e[0;1;31m#8  0x00007375ed82941a n/a (libkwin.so.6 + 0x42941a)e[0m
                                                   e[0;1;31m#9  0x00007375ed82a589 n/a (libkwin.so.6 + 0x42a589)e[0m
                                                   e[0;1;31m#10 0x00007375ed81cf14 n/a (libkwin.so.6 + 0x41cf14)e[0m
                                                   e[0;1;31m#11 0x00007375ed81ccf1 n/a (libkwin.so.6 + 0x41ccf1)e[0m
                                                   e[0;1;31m#12 0x00007375ed81cdc0 n/a (libkwin.so.6 + 0x41cdc0)e[0m
                                                   e[0;1;31m#13 0x00007375ed81cdc0 n/a (libkwin.so.6 + 0x41cdc0)e[0m
                                                   e[0;1;31m#14 0x00007375ed8200fa n/a (libkwin.so.6 + 0x4200fa)e[0m
                                                   e[0;1;31m#15 0x00007375ed7fc68e _ZN4KWin10DrmBackend18applyOutputChangesERKNS_19OutputConfigurationE (libkwin.so.6 + 0x3fc68e)e[0m
                                                   e[0;1;31m#16 0x00007375ed77c839 _ZN4KWin9Workspace24applyOutputConfigurationERKNS_19OutputConfigurationERKSt8optionalI5QListIPNS_6OutputEEE (libkwin.so.6 + 0x37c839)e[0m
                                                   e[0;1;31m#17 0x00007375ed7817f2 _ZN4KWin9Workspace25updateOutputConfigurationEv (libkwin.so.6 + 0x3817f2)e[0m
                                                   e[0;1;31m#18 0x00007375ed7886e3 _ZN4KWin9Workspace31slotOutputBackendOutputsQueriedEv (libkwin.so.6 + 0x3886e3)e[0m
                                                   e[0;1;31m#19 0x00007375eadb2229 n/a (libQt6Core.so.6 + 0x1b2229)e[0m
                                                   e[0;1;31m#20 0x00007375ed7fa44c _ZN4KWin10DrmBackend13updateOutputsEv (libkwin.so.6 + 0x3fa44c)e[0m
                                                   e[0;1;31m#21 0x00007375eadb2229 n/a (libQt6Core.so.6 + 0x1b2229)e[0m
                                                   e[0;1;31m#22 0x00007375ed572e29 _ZN4KWin17WaylandCompositor5startEv (libkwin.so.6 + 0x172e29)e[0m
                                                   e[0;1;31m#23 0x00007375eada348a _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1a348a)e[0m
                                                   e[0;1;31m#24 0x00007375ebefe31a _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0xfe31a)e[0m
                                                   e[0;1;31m#25 0x00007375ead585a8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x1585a8)e[0m
                                                   e[0;1;31m#26 0x00007375ead59035 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x159035)e[0m
                                                   e[0;1;31m#27 0x00007375eaedd773 _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x2dd773)e[0m
                                                   e[0;1;31m#28 0x00007375eb84da33 _ZN23QUnixEventDispatcherQPA13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Gui.so.6 + 0x64da33)e[0m
                                                   e[0;1;31m#29 0x00007375ead64566 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x164566)e[0m
                                                   e[0;1;31m#30 0x00007375ead59a2f _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x159a2f)e[0m
                                                   e[0;1;31m#31 0x00005ec8f7565127 n/a (kwin_wayland + 0x3f127)e[0m
                                                   e[0;1;31m#32 0x00007375ea634e08 n/a (libc.so.6 + 0x25e08)e[0m
                                                   e[0;1;31m#33 0x00007375ea634ecc __libc_start_main (libc.so.6 + 0x25ecc)e[0m
                                                   e[0;1;31m#34 0x00005ec8f756b6a5 n/a (kwin_wayland + 0x456a5)e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1762:e[0m
                                                   e[0;1;31m#0  0x00007375ea69fa19 n/a (libc.so.6 + 0x90a19)e[0m
                                                   e[0;1;31m#1  0x00007375ea6a2479 pthread_cond_wait (libc.so.6 + 0x93479)e[0m
                                                   e[0;1;31m#2  0x00007375e64cecae n/a (libgallium-24.2.4-arch1.1.so + 0xcecae)e[0m
                                                   e[0;1;31m#3  0x00007375e64ab6bc n/a (libgallium-24.2.4-arch1.1.so + 0xab6bc)e[0m
                                                   e[0;1;31m#4  0x00007375e64cebdd n/a (libgallium-24.2.4-arch1.1.so + 0xcebdd)e[0m
                                                   e[0;1;31m#5  0x00007375ea6a339d n/a (libc.so.6 + 0x9439d)e[0m
                                                   e[0;1;31m#6  0x00007375ea72849c n/a (libc.so.6 + 0x11949c)e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1777:e[0m
                                                   e[0;1;31m#2  0x00007375ea8d6c31 __gthread_cond_wait (libstdc++.so.6 + 0xd6c31)e[0m
                                                   e[0;1;31m#3  0x00007375ed8050fe n/a (libkwin.so.6 + 0x4050fe)e[0m
                                                   e[0;1;31m#4  0x00007375ed8005e6 n/a (libkwin.so.6 + 0x4005e6)e[0m
                                                   e[0;1;31m#5  0x00007375ea6a88fb n/a (libc.so.6 + 0x998fb)e[0m
                                                   e[0;1;31m#6  0x00007375ea6a8979 pthread_once (libc.so.6 + 0x99979)e[0m
                                                   e[0;1;31m#7  0x00007375ed801250 n/a (libkwin.so.6 + 0x401250)e[0m
                                                   e[0;1;31m#8  0x00007375eae50b95 n/a (libQt6Core.so.6 + 0x250b95)e[0m
                                                   e[0;1;31m#9  0x00007375eaed840f n/a (libQt6Core.so.6 + 0x2d840f)e[0m
                                                   e[0;1;31m#10 0x00007375ea6a339d n/a (libc.so.6 + 0x9439d)e[0m
                                                   e[0;1;31m#11 0x00007375ea72849c n/a (libc.so.6 + 0x11949c)e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1737:e[0m
                                                   e[0;1;31m#0  0x00007375ea71abb0 ppoll (libc.so.6 + 0x10bbb0)e[0m
                                                   e[0;1;31m#1  0x00007375e97bf227 n/a (libglib-2.0.so.0 + 0xc0227)e[0m
                                                   e[0;1;31m#2  0x00007375e975ba55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)e[0m
                                                   e[0;1;31m#3  0x00007375eafbf71d _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3bf71d)e[0m
                                                   e[0;1;31m#4  0x00007375ead64566 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x164566)e[0m
                                                   e[0;1;31m#5  0x00007375eae571d2 _ZN7QThread3runEv (libQt6Core.so.6 + 0x2571d2)e[0m
                                                   e[0;1;31m#6  0x00007375eaed840f n/a (libQt6Core.so.6 + 0x2d840f)e[0m
                                                   e[0;1;31m#7  0x00007375ea6a339d n/a (libc.so.6 + 0x9439d)e[0m
                                                   e[0;1;31m#8  0x00007375ea72849c n/a (libc.so.6 + 0x11949c)e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1712:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1764:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1754:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1763:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1767:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1748:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1711:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1695:e[0m
                                                   e[0;1;31m#5  0x00007375eae57072 _ZN7QThread4execEv (libQt6Core.so.6 + 0x257072)e[0m
                                                   e[0;1;31m#6  0x00007375ebc1d79e n/a (libQt6DBus.so.6 + 0x2e79e)e[0m
                                                   e[0;1;31m#7  0x00007375eaed840f n/a (libQt6Core.so.6 + 0x2d840f)e[0m
                                                   e[0;1;31m#8  0x00007375ea6a339d n/a (libc.so.6 + 0x9439d)e[0m
                                                   e[0;1;31m#9  0x00007375ea72849c n/a (libc.so.6 + 0x11949c)e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1761:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1753:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1766:e[0m
                                                   e[0;1;31me[0m
                                                   e[0;1;31mStack trace of thread 1765:e[0m
                                                   e[0;1;31mELF object binary architecture: AMD x86-64e[0m
Oct 16 18:14:05 tufwrapper systemd[1]: systemd-coredump@0-1779-0.service: Deactivated successfully.
Oct 16 18:14:05 tufwrapper systemd[1]: systemd-coredump@0-1779-0.service: Consumed 308ms CPU time, 204.6M memory peak.
If I set Splash Screen to None in System Settings the desktop appears as fast as before when logging in.
To me, it seems, that the splash screen isn’t properly notified anymore that it should terminate itself because the desktop has finished loading.
Splash screen delay was reported:
https://bugs.kde.org/show_bug.cgi?id=494840
And proposed fix:
I guess it’s coming with Plasma 6.2.2
Based on the issue it should be Version Fixed In: 6.2.1.1
2 posts were split to a new topic: My 90 degree rotated monitor is completely broken
It is.
Wow, that was fast :+1:
I hope that Plasma 6.2.2 will fix more issues people may still see in 6.2 series. That is one reason why we normally don’t rush Plasma releases these days. Other than that it is kinda good release.
with this latest plasma-desktop 6.2 update, the desktop icons lose position every time the screen locks then unlocks or play a game then return to the desktop (i am assuming every time it refreshes the desktop)
Same issue as @kqr
Recently switched to the edgelord branch and multi-monitor support went from iffy to buggy real fast and I don’t know if it is my vertical (portrait) monitor + horizontal one. When switching off the monitor or making adjustments in the relative position (which in itself is buggy) makes so that the usable region gets mangled or outright goes black but plasma UI still visible. Everything gets corrected with a good old reboot but I don’t know. If you want logs just tell me the command for I have terminal commands Alzheimer.
it’s fixed now
A post was split to a new topic: Annoying behaviour of recurring notifications
