My 90 degree rotated monitor is completely broken (KDE)
I don’t have this problem myself, but it’s mentioned here that it’s fixed in 6.2.1.1
https://www.reddit.com/r/kde/comments/1g58bhl/90_degree_rotated_display_is_broken_on_621/
Then buy a new monitor. ![]()
Or if help is needed, perhaps you could explain what you mean by “completely broken”. Though it seems someone may have actually figured it out already.
A bit of system info will help, so we can see what you are using:
inxi -zv8
… and some more detail on the symptoms e.g.: no display at all, resolution or orientation wrong, pointer not moving correctly, etc. as suggested by @dmt ![]()
Cheers ![]()
Comments like this only equate to noise.
Perhaps you would elaborate in a new thread, with a clear and precise description of not only your issue, but also the system concerned. I’m sure others will be more than willing to help.
Cheers.
Post moved from:
[Testing Update] 2024-10-16 - Virtualbox, Blender, Plasma 6.2.1, OpenSearch - #14
