As I was on holidays the last two weeks, I don’t know which of the recent 4 Testing Updates introduced the annoying behaviour of recurring notifications for available updates in Gnome. It doesn’t matter if I click on the “Details” button or the “X” Button. It keeps recurring every few seconds. In the journal I see that the Pamac Daemon starts every ~6 seconds.
Okt 19 11:04:38 liebig gnome-shell[1071]: updates_checker.vala:59: check updates
Okt 19 11:04:38 liebig systemd[1]: Starting Pamac Daemon...
Okt 19 11:04:38 liebig systemd[1]: Started Pamac Daemon.
Okt 19 11:04:39 liebig systemd[1]: pamac-daemon.service: Deactivated successfully.
Okt 19 11:04:40 liebig gnome-shell[1071]: Object St.Icon (0x6069309f24c0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
== Stack trace for context 0x60692848e450 ==
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:181 (2ab29815c420 @ 49)
#1 6069285a1238 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:232 (2ab29815c5b0 @ 108)
#2 6069285a11a8 i resource:///org/gnome/shell/ui/init.js:21 (132aa9670c90 @ 48)
Okt 19 11:04:40 liebig gnome-shell[1071]: Object St.BoxLayout (0x606930c86430), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7ffe8c855cb0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:197 (2ab29815c470 @ 34)
#1 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:182 (2ab29815c420 @ 119)
#2 6069285a1238 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:232 (2ab29815c5b0 @ 108)
#3 6069285a11a8 i resource:///org/gnome/shell/ui/init.js:21 (132aa9670c90 @ 48)
Okt 19 11:04:40 liebig gnome-shell[1071]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x606930c7d340), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7ffe8c855cb0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:203 (2ab29815c470 @ 97)
Okt 19 11:04:40 liebig gnome-shell[1071]: Object St.Icon (0x606930c83e50), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7ffe8c855cb0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:204 (2ab29815c470 @ 121)
Okt 19 11:04:40 liebig gnome-shell[1071]: Object St.Label (0x606930c80170), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7ffe8c855cb0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:205 (2ab29815c470 @ 152)
Okt 19 11:04:40 liebig gnome-shell[1071]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
Okt 19 11:04:40 liebig gnome-shell[1071]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
Okt 19 11:04:40 liebig gnome-shell[1071]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
#0 7ffe8c855cb0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:206 (2ab29815c470 @ 167)
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (2ab29815c4c0 @ 45)
#1 7ffe8c855c00 b self-hosted:160 (132aa9697f60 @ 245)
#2 7ffe8c855cb0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:208 (2ab29815c470 @ 241)
#3 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:182 (2ab29815c420 @ 119)
#4 6069285a1238 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:232 (2ab29815c5b0 @ 108)
#5 6069285a11a8 i resource:///org/gnome/shell/ui/init.js:21 (132aa9670c90 @ 48)
Okt 19 11:04:40 liebig gnome-shell[1071]: Object .Gjs_pamac-updates_manjaro_org_extension_PamacUpdateIndicator (0x606930c6f9c0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7ffe8c855cc0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:168 (2ab29815c380 @ 80)
#1 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (2ab29815c420 @ 251)
Okt 19 11:04:44 liebig gnome-shell[1071]: updates_checker.vala:59: check updates
Okt 19 11:04:44 liebig systemd[1]: Starting Pamac Daemon...
Okt 19 11:04:44 liebig systemd[1]: Started Pamac Daemon.
Okt 19 11:04:46 liebig systemd[1]: pamac-daemon.service: Deactivated successfully.
Okt 19 11:04:46 liebig gnome-shell[1071]: Object St.Icon (0x606929b4ac30), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
Okt 19 11:04:46 liebig gnome-shell[1071]: Object St.BoxLayout (0x60692ffe5300), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:197 (2ab29815c470 @ 34)
Okt 19 11:04:46 liebig gnome-shell[1071]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x60693027c530), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:203 (2ab29815c470 @ 97)
Okt 19 11:04:46 liebig gnome-shell[1071]: Object St.Icon (0x60693039fcd0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:204 (2ab29815c470 @ 121)
Okt 19 11:04:46 liebig gnome-shell[1071]: Object St.Label (0x60692df51960), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:205 (2ab29815c470 @ 152)
Okt 19 11:04:46 liebig gnome-shell[1071]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
Okt 19 11:04:46 liebig gnome-shell[1071]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
Okt 19 11:04:46 liebig gnome-shell[1071]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:206 (2ab29815c470 @ 167)
#0 6069285a1408 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (2ab29815c4c0 @ 45)
#1 7ffe8c855cc0 b self-hosted:160 (132aa9697f60 @ 245)
#2 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:208 (2ab29815c470 @ 241)
Okt 19 11:04:46 liebig gnome-shell[1071]: Object .Gjs_pamac-updates_manjaro_org_extension_PamacUpdateIndicator (0x606933dd0fc0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a1380 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:168 (2ab29815c380 @ 80)
Okt 19 11:04:51 liebig gnome-shell[1071]: updates_checker.vala:59: check updates
Okt 19 11:04:51 liebig systemd[1]: Starting Pamac Daemon...
Okt 19 11:04:51 liebig systemd[1]: Started Pamac Daemon.
Okt 19 11:04:53 liebig systemd[1]: pamac-daemon.service: Deactivated successfully.
Okt 19 11:04:53 liebig gnome-shell[1071]: Object St.Icon (0x6069309f24c0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 7ffe8c855cc0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:181 (2ab29815c420 @ 49)
Okt 19 11:04:53 liebig gnome-shell[1071]: Object St.BoxLayout (0x606930c86430), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:197 (2ab29815c470 @ 34)
#1 7ffe8c855cc0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:182 (2ab29815c420 @ 119)
Okt 19 11:04:53 liebig gnome-shell[1071]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x606930c7d340), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:203 (2ab29815c470 @ 97)
Okt 19 11:04:53 liebig gnome-shell[1071]: Object St.Icon (0x606930c83e50), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:204 (2ab29815c470 @ 121)
Okt 19 11:04:53 liebig gnome-shell[1071]: Object St.Label (0x606930c80170), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:205 (2ab29815c470 @ 152)
Okt 19 11:04:53 liebig gnome-shell[1071]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
Okt 19 11:04:53 liebig gnome-shell[1071]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
Okt 19 11:04:53 liebig gnome-shell[1071]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:206 (2ab29815c470 @ 167)
#0 7ffe8c854a80 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (2ab29815c4c0 @ 45)
#1 7ffe8c8551b0 b self-hosted:160 (132aa9697f60 @ 245)
#2 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:208 (2ab29815c470 @ 241)
#3 7ffe8c855cc0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:182 (2ab29815c420 @ 119)
Okt 19 11:04:53 liebig gnome-shell[1071]: Object .Gjs_pamac-updates_manjaro_org_extension_PamacUpdateIndicator (0x606930c6f9c0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
#0 6069285a12c8 i file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:168 (2ab29815c380 @ 80)
#1 7ffe8c855cc0 b file:///usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (2ab29815c420 @ 251)
Okt 19 11:04:58 liebig gnome-shell[1071]: updates_checker.vala:59: check updates
Okt 19 11:04:58 liebig systemd[1]: Starting Pamac Daemon...
Okt 19 11:04:58 liebig systemd[1]: Started Pamac Daemon.
A second issue I have is that the internal display gets set to maximum brightness after resuming from suspend. This only happens with kernel series 6.11. With 6.10 there is no issue. Others are also having the issue and opened tickets for it. See 3691 and 3474
