[Testing Update] 2023-09-15 - Kernels, KDE Gear, LibreOffice 7.6.1, Firefox
Hello community,
Another testing branch update with some usual package updates for you.
Get the lastest SoftMaker Office with ChatGPT buillt-in. You will find our Special Offer here!
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Notable Package Updates:
  • Some Kernels got updated
  • KDE Gear got updated to 23.08.1
  • Firefox got renewed to 117.0.1
  • LibreOffice is at 7.6.1
  • Usual KDE-git, Haskell and Python updates
Additional Info
Python 3.11 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.10.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.10/ :
pacman -Qoq /usr/lib/python3.10/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.10)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Our current supported kernels
  • linux419 4.19.294
  • linux54 5.4.256
  • linux510 5.10.194
  • linux515 5.15.131
  • linux61 6.1.53
  • linux64 6.4.16 [EOL]
  • linux65 6.5.3
  • linux66 6.6.0rc1
  • linux61-rt 6.1.46_rt13
  • linux64-rt 6.4.6_rt8
  • linux65-rt 6.5.2_rt8
Package Changes (Fri Sep 15 11:38:22 CEST 2023)
  • testing core x86_64: 4 new and 4 removed package(s)
  • testing extra x86_64: 752 new and 753 removed package(s)
  • testing multilib x86_64: 7 new and 7 removed package(s)
Overlay Changes
  • testing core x86_64: 6 new and 6 removed package(s)
  • testing extra x86_64: 38 new and 137 removed package(s)
  • testing kde-unstable x86_64: 102 new and 101 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-09-06
filesystem and bashrc-manjaro pacnews
With the filesystem 2023.09.03-1 and bashrc-manjaro 5.1.016-3 updates there may be pacnews for the following files if you have local modifications:
  • /etc/shells
  • /etc/bash.bashrc
This would be a good time to test @Ste74’s new manjaro-pacnew-checker program. See Check and manage pacnew files for more info.
2023-08-25
ansible-core >= 2.15.3-1 update may require manual intervention
2023-08-19 - Robin Candau
As of ansible-core 2.15.3, upstream moved documentation and examples to a separate dedicated repository (see the related changelogs).
This means that, starting from version 2.15.3 the ansible-core package will stop shipping documentation and a default configuration example under /etc/ansible/ansible.cfg.
Regarding the documentation, it is available online: https://docs.ansible.com/
As for the configuration file, as explained in the wiki, a base config can be generated with the following command:
ansible-config init --disabled > ansible.cfg
After updating from ansible-core <= 2.15.2-1 to >= 2.15.3-1, everyone using a custom global Ansible configuration file stored under /etc/ansible/ansible.cfg will have their configuration saved as a pacsave file.
To restore it, run the following command:
mv /etc/ansible/ansible.cfg.pacsave /etc/ansible/ansible.cfg
Arch Linux - News: ansible-core >= 2.15.3-1 update may require manual intervention
2023-08-04
Possible glibc 2.38 posix_memalign regression
There seems a performance regression of posix_memalign in Glibc-2.38. More info here: Making sure you're not a bot!
Workarounds:
You can try another malloc like mimalloc or jemalloc as workaround. Install mimalloc and start mpv with:
LD_PRELOAD=/usr/lib/libmimalloc.so mpv
or
LD_PRELOAD=/usr/lib/libjemalloc.so mpv
For folks that dont want to change things too much .. an apparent workaround is to set a lowish cache size:
mkdir -p ~/.config/mpv && printf '\ndemuxer-max-bytes=50MiB\ndemuxer-max-back-bytes=25MiB\n' | tee -a ~/.config/mpv/mpv.conf
budgie-desktop >= 10.7.2-6 update requires manual intervention
When upgrading from budgie-desktop 10.7.2-5 to 10.7.2-6, the package mutter43 must be replaced with magpie-wm, which currently depends on mutter. As mutter43 conflicts with mutter, manual intervention is required to complete the upgrade.
First remove mutter43, then immediately perform the upgrade. Do not relog or reboot between these steps.
pacman -Rdd mutter43
pacman -Syu
2023-07-28
Grub conflicting files
Error: Failed to commit transaction:
conflicting files:
grub: /usr/bin/update-grub already exists in filesystem (owned by grub-update)
sudo pacman -Rdd grub-update
sudo pacman -Suu grub
[1] [2] [3]
2023-07-24
One core of CPU has high IO-wait operation at 100%
[Unstable Update] 2023-05-21 - Repository changes - #199 by Zesko
Kernel 6.4.4, 6.4.5 and 6.1.39 LTS are affected:
The known issue and report:
2023-07-15
Steam crashes on startup with lib32-libgudev installed
The latest lib32-libgudev update does not cooperate with the version of the same package provided by steam, and steam seems to attempt making calls to both leading to the crash.
Details: bug report, arch task, arch forum thread.
  • Workaround #1 (causes steam to avoid making any calls to lib32-libgudev by using a different library altogether)
    • sudo pacman -S lib32-libnm
  • Workaround #2 (forces steam and any other application to always use the new lib32-libgudev)
    • sudo pacman -S lib32-libudev0-shim
  • Workaround #3 (use steam-native-runtime, which doesn’t have the issue)
    • sudo pacman -S steam-native-runtime
2023-06-27
possible kernel bug for amdgpu users
[Testing Update] 2023-06-27 - Kernels, Linux-Firmware, Mesa, Wine, Nvidia, KDE-git - #4 by xvin
2023-06-24
Pamac GUI theme does not match theme for Xfce
pamac-gtk 11.0.1 uses Gtk 4 that is not supported by Xfce
user can replace pamac-gtk with pamac-gtk3
pamac install pamac-gtk3
TeX Live package reorganization
2023-06-18 - Antonio Rojas
Starting from version 2023.66594-9, TeX Live packages have been reorganized to mirror upstream collections. Even though the new texlive-basic replaces the old texlive-core, many of the texlive-core contents (including language specific files) are now split between different packages. To find out which Arch package contains a specific CTAN package, you can use the tlmgr utility, eg.
$ tlmgr info euler | grep collection
collection:  collection-latexrecommended
which means the euler CTAN package is contained in texlive-latexrecommended. You may also use pacman -F to query for specific files.
A new metapackage texlive-meta is available to install all subpackages (except for language specific ones), and the new texlive-doc package provides the full documentation for offline use.
Arch Linux - News: TeX Live package reorganization
2023-06-15
[details=“The “community” repository has been merged into “extra” and is now empty”]
The [community] repository has been merged into [extra] and is now empty. It may take a bit of time for mirrors to catch up.
:point_right: Update your system and merge the pacman pacnew /etc/pacman.conf.pacnew file.
sudo pacman -Syu "pacman>=6.0.2-11"
[/details]
OpenBLAS >= 0.3.23-2 update requires manual intervention
2023-06-14 - Felix Yan
The openblas package prior to version 0.3.23-2 doesn’t ship optimized LAPACK routine and CBLAS/LAPACKE interfaces for compatibility. This decision has been reverted now, and the ability to choose a different default system BLAS/LAPACK implementation while keeping openblas installed is now provided to allow future co-installation of BLIS, ATLAS, etc.
The default BLAS implementation will be used for most packages like NumPy or R. Please install blas-openblas and blas64-openblas to make OpenBLAS the default BLAS implementation, just like the old behavior.
Unfortunately you will get errors on updating if you currently have OpenBLAS installed as the default BLAS implementation:
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by cblas
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by lapack
Please append your preferred default BLAS implementation to the regular -Syu command line to get around it. For example:
sudo pacman -Syu blas-openblas
or
Arch Linux - News: OpenBLAS >= 0.3.23-2 update requires manual intervention
Previous testing threads:
[As per previous post]
I have an odd (wireless) keyboard problem with kernel 6.6rc1-1 which is resolved by dropping back to 6.5.3-1 or by plugging the keyboard in.
evtest is returning the wrong keys when a key is pressed. From what I can tell almost none of the keys are mapped correctly. No F keys return an event, alphanumerical keys seem to return a combination a, e, m, 3 and volume up.
For reference I have a Logitech G915 using the lightspeed receiver and have never seen anything like this before!
I tried the suggest of removing the layout_memory.xml kindly suggested by Aragorn, but this did nothing. For now will revet back to 6.5.3
Maybe report the issue to Kernel developers instead of Manjaro forum?
