[Testing Update] 2022-10-27 - Kernel, Plasma 5.26.2, Deepin, VirtualBox 7.0.2, Systemd
Hello community,
Another testing branch update with some usual package updates for you.
  • Most of our Kernels got updated
  • Plasma is now at 5.26.2
  • Deepin got renewed
  • VirtualBox 7.0.2 got added
  • Systemd is at 251.7
  • Some KDE-git, Haskell and Python updates as usual
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
:information_source: You may need to rebuild any AUR packages that install files to site-packages …
Our current supported kernels
  • linux419 4.19.262
  • linux54 5.4.220
  • linux510 5.10.150
  • linux515 5.15.75
  • linux519 5.19.17 [EOL]
  • linux60 6.0.5
  • linux61 6.1.0rc2
  • linux515-rt 5.15.73_rt52
  • linux519-rt 5.19.0_rt10
Package changes (Thu Oct 27 02:13:20 CEST 2022)
  • testing community x86_64: 1481 new and 1435 removed package(s)
  • testing core x86_64: 28 new and 28 removed package(s)
  • testing extra x86_64: 385 new and 488 removed package(s)
  • testing kde-unstable x86_64: 350 new and 350 removed package(s)
  • testing multilib x86_64: 17 new and 18 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2022-10-28
signature from "Manjaro Build Server <build_at_manjaro_dot_org>" is unknown trust
Seems our signing key for our Build Server had the 2022-10-28 as expire date set when generated. This is now fixed for chroot builds and fresh as also current existing installs via manjaro-keyring 20221028-4 Simply update your system to get that package, which got pushed to all our branches.
2022-10-27
Kernel 6.1-rc# might break backlight control on old/weird laptops, please test
https://hansdegoede.livejournal.com/26427.html
2022-10-18
Firefox 106.0 may have issues with screen sharing on GNOME with Wayland
2022-09-23
Nvidia 3060RTX cards may have issues with the 515.76 driver (fixed with 520.56.06)
Removing python2 from the repositories
2022-09-23 - Jelle van der Waa
Python 2 went end of life January 2020. Since then we have been actively cutting down the number of projects depending on python2 in our repositories, and we have finally been able to drop it from our distribution. If you still have python2 installed on your system consider removing it and any python2 package.
If you still require the python2 package you can keep it around, but please be aware that there will be no security updates. If you need a patched package please consult the AUR, or use an unofficial user repository.*
Arch Linux - News: Removing python2 from the repositories
* Note: Unofficial user repositories are not supported
2022-08-27
Changes with Back In Time packages
  • backintime has been renamed to backintime-qt
  • backintime-cli has been renamed to backintime
After replacing backintime-cli with backintime, you will need to install backintime-qt manually if you want the Qt frontend installed again.
2022-08-23
electron12, electron13, electron14 & electron16 have been dropped to the AUR
Unsupported Electron packages have been dropped from the official repos to the AUR. They no longer receive security updates and nothing in the repos depend on them.
If you have AUR packages depending on those versions, install the binary version from the AUR to replace them; i.e., electron16-bin.
See FS#75490 - electron12, electron13, electron14, electron16 are unsupported and vulnerable packages
End of Support for 15.x.y and 16.x.y
Electron 15.x.y and 16.x.y has reached end-of-support. As per Electron’s new 8-week cadence, we were supporting the latest four versions of Electron until May 2022. With this Electron 19 release, we’ll return to supporting the latest three major versions, as well as the alpha, beta, and nightly releases.
Release electron v19.0.0 · electron/electron · GitHub
2022-08-12
element-desktop dependency error (fixed with 1.11.4)
:: installing electron (20.0.0-1) breaks dependency 'electron19' required by element-desktop
The upstream package was already flagged out of date (it needs to be rebuilt against latest electron).
Workaround for now:
sudo pacman -Syy electron electron19 --asdeps
sudo pacman -Su
2022-08-04
Glibc 2.36 update will break EasyAntiCheat within Proton (should be fixed with glibc 2.36-2)
Temporary workaround for now is to use the flatpak version of steam:
sudo pacman -S flatpak --needed --noconfirm
sudo flatpak install com.valvesoftware.Steam -y
You can use flatseal (another flatpak app) to grant it access to your existing game library so you don’t have to re-download your games (add the game library install path under “Other files” under “Filesystem”).
sudo flatpak install com.github.tchx84.Flatseal -y
For advanced users (not recommended by us): patched glibc and lib32-glibc are available here. They remove the commit that broke EAC.
2022-07-27
Fixed: Pamac shows archlinux-keyring (20220713-2) and manjaro-keyring (20220514-2) as orphans
sudo pacman -D --asexplicit archlinux-keyring manjaro-keyring
Resolved: w/ base 3-2 Revert changes:
sudo pacman -D --asdeps archlinux-keyring manjaro-keyring
2022-07-16
wxWidgets 3.2 update may need manual intervention
Packages have been renamed from wxgtk- to wxwidgets-. The GTK2 frontend is no longer provided. If you have wxgtk2 installed, the upgrade will fail with:
In such case, uninstall wxgtk2 first and then proceed with the upgrade.
2022-07-13
Linux518: could not insert 'amd_pstate': No such device
With Kernel 5.18.11 there was added a regression to AMD P-State driver preventing it from loading.
2022-07-08
Wireplumber 0.4.11 may crash for GDM users
Currently there is an issue with 0.4.11 and GDM crashing on boot-up. More in the upstream bugtracker issue: Making sure you're not a bot!
2022-06-07
Locale file changes
C.UTF8 locale is now included in glibc:
Credits @diabonas for this change. Systemd wants us to include C.UTF8 by default and it seems the locale may be in included by glibc upstream in the future. To fix building and avoid nasty fixing in devtools, we include the locale in the package. See systemd/systemd#23252 (comment) FS#74864 : [systemd] >= 251 breaks devtools' locale
There is a pacsave for /etc/locale.conf as it has been removed from the filesystem package.
UPDATE: With filesystem 2022.06.08-2, it will automatically restore /etc/locale.conf if it did not already exist.
There is a pacnew for /etc/locale.gen. Please review it and regenerate your locale if necessary.
2 posts were split to a new topic: Virtualbox-guest-utils 7.02 slows down the guest
I added some more packages to this one.
:: Package Changes (Fri Oct 28 08:27:10 CEST 2022)
 - testing community x86_64:  153 new and 144 removed package(s)
 - testing core x86_64:  1 new and 1 removed package(s)
 - testing extra x86_64:  15 new and 79 removed package(s)
:: Different overlay package(s) in repository community x86_64
                             PACKAGE           2022-10-27           2022-10-28
                      discord-canary            0.0.142-1                    -
:: Different sync package(s) in repository community x86_64
                        ansible-lint              6.8.3-1              6.8.4-1
                       budgie-extras              1.4.0-1              1.4.0-2
                              ccache              4.6.3-1              4.7.1-1
                          containerd              1.6.8-1              1.6.9-1
                         dark-reader             4.9.59-1             4.9.60-1
                        deepin-album             5.10.6-1             5.10.7-1
                   deepin-calculator             5.7.21-3             5.7.22-1
                       deepin-editor            5.10.38-1            5.10.39-1
                 deepin-font-manager             5.9.13-1             5.9.14-1
                 deepin-image-viewer              5.9.3-2              5.9.4-1
                     deepin-launcher             5.5.33-1             5.5.34-1
                       deepin-reader            5.10.25-1            5.10.26-1
                deepin-session-shell             5.5.74-1             5.5.75-1
                            diffstat               1.64-2               1.65-1
                      discord-canary            0.0.140-1            0.0.142-1
                              docker         1:20.10.20-1         1:20.10.21-1
                           duplicity              1.0.1-1              1.0.1-2
                           filezilla             3.61.0-2             3.62.0-1
                 firefox-dark-reader             4.9.59-1             4.9.60-1
                         flatbuffers           22.10.25-1           22.10.26-1
               freepats-general-midi           20210329-3           20221026-1
                               gajim              1.4.7-2              1.5.2-3
                       gitlab-gitaly             15.4.0-2             15.5.1-1
                            goaurrpc             1.1.10-1             1.1.11-1
                     gtk-layer-shell              0.7.0-3              0.8.0-1
                   haskell-esqueleto            3.5.4.1-4            3.5.4.2-1
                haskell-generic-data           1.0.0.0-15           1.0.0.0-16
                      haskell-ghcide            1.5.0.1-7            1.5.0.1-8
                      haskell-gi-atk             2.0.25-4             2.0.25-5
          haskell-gi-cairo-connector             0.1.1-17             0.1.1-18
             haskell-gi-cairo-render              0.1.1-8              0.1.2-1
                 haskell-gi-dbusmenu            0.4.10-16            0.4.10-17
             haskell-gi-dbusmenugtk3            0.4.11-17            0.4.11-18
                      haskell-gi-gdk             4.0.4-17             4.0.4-18
                     haskell-gi-gdk3            3.0.25-16            3.0.25-17
                  haskell-gi-gdk3x11            3.0.12-16            3.0.12-17
                haskell-gi-gdkpixbuf            2.0.28-16            2.0.28-17
                   haskell-gi-gdkx11             4.0.4-16             4.0.4-17
                      haskell-gi-gio            2.0.29-16            2.0.29-17
                     haskell-gi-glib            2.0.26-16             2.0.27-1
                  haskell-gi-gmodule             2.0.2-16             2.0.2-17
                  haskell-gi-gobject            2.0.27-16            2.0.27-17
                 haskell-gi-graphene             1.0.4-16             1.0.4-17
                      haskell-gi-gsk              4.0.5-2              4.0.5-3
                      haskell-gi-gtk             4.0.5-19             4.0.5-20
                   haskell-gi-gtk-hs            0.3.12-17            0.3.12-18
                     haskell-gi-gtk3            3.0.38-17            3.0.38-18
                 haskell-gi-harfbuzz             0.0.6-16             0.0.6-17
                    haskell-gi-pango            1.0.26-16            1.0.26-17
                haskell-gtk-sni-tray           0.1.8.1-17           0.1.8.1-19
                   haskell-gtk-strut           0.1.3.2-16           0.1.3.2-17
   haskell-hls-call-hierarchy-plugin           1.0.1.1-18           1.0.1.1-19
             haskell-hls-eval-plugin            1.2.0.2-8            1.2.0.2-9
 haskell-hls-explicit-imports-plugin           1.0.1.1-18            1.0.1.2-2
         haskell-hls-floskell-plugin           1.0.0.2-57           1.0.0.2-58
         haskell-hls-fourmolu-plugin           1.0.1.2-16           1.0.1.2-17
                   haskell-hls-graph            1.5.1.0-9            1.5.1.1-1
 haskell-hls-haddock-comments-plugin           1.0.0.4-43           1.0.0.4-44
            haskell-hls-hlint-plugin           1.0.2.0-18           1.0.2.0-19
      haskell-hls-module-name-plugin           1.0.0.3-42           1.0.0.3-43
           haskell-hls-ormolu-plugin           1.0.1.1-18            1.0.1.2-1
              haskell-hls-plugin-api           1.2.0.2-14           1.2.0.2-15
          haskell-hls-pragmas-plugin           1.0.1.1-71           1.0.1.1-72
           haskell-hls-retrie-plugin           1.0.1.3-17           1.0.1.3-18
  haskell-hls-stylish-haskell-plugin           1.0.0.3-18           1.0.0.3-19
              haskell-hls-test-utils           1.1.0.2-15           1.1.0.2-16
                    haskell-hopenpgp             2.9.8-50             2.9.8-51
                 haskell-ixset-typed           0.5.1.0-57           0.5.1.0-58
             haskell-language-server           1.5.0.0-21            1.5.1.0-2
                 haskell-linear-base             0.2.0-17              0.3.0-1
                   haskell-one-liner               2.1-38               2.1-39
                    haskell-safecopy         0.10.4.2-176         0.10.4.2-177
                    haskell-summoner          2.0.1.1-373          2.0.1.1-374
                haskell-summoner-tui          2.0.1.1-424          2.0.1.1-425
                      hopenpgp-tools            0.23.7-52            0.23.7-53
                             jenkins              2.375-1              2.375-2
                                jmol           14.32.78-1           14.32.79-1
                               jsmol           14.32.78-1           14.32.79-1
                   jupyter-nbconvert              7.2.2-1              7.2.3-1
                                just              1.6.0-1              1.7.0-2
                                 jwm              2.4.2-2              2.4.3-1
                                mame              0.248-1              0.249-1
                          mame-tools              0.248-1              0.249-1
                               mkosi                 13-1                 14-1
                                mosh             1.3.2-18              1.4.0-1
                     multipath-tools              0.9.2-2              0.9.3-1
                               nomad              1.4.1-1              1.4.2-1
                            obsidian              1.0.0-1              1.0.3-1
                          ocamlbuild             0.14.1-2             0.14.2-1
                               opera       92.0.4561.21-1       92.0.4561.30-1
                           osinfo-db           20220830-1           20221018-1
           perl-acme-alien-dontpanic             2.6500-1             2.7200-1
                         php-mongodb             1.14.1-2             1.14.2-1
                        php7-mongodb             1.14.1-2             1.14.2-1
                        python-build              0.8.0-2              0.9.0-1
                  python-flatbuffers           22.10.25-1           22.10.26-1
                  python-google-auth              2.6.1-1              2.6.2-1
                       python-nbxmpp              3.2.1-1              3.2.4-1
                   python-pyhamcrest              2.0.3-1              2.0.4-1
                        python-pyicu               2.10-1             2.10.1-1
                  python-pytest-mock              3.9.0-1             3.10.0-1
                python-pytest-pylint             0.18.0-4             0.19.0-1
                 python-pytest-xdist              2.5.0-2              3.0.0-1
                                qcad           3.27.8.0-1           3.27.8.1-1
                             reapack            1.2.4.1-1            1.2.4.2-1
                            ruby-ast              2.4.2-1              2.4.2-2
                           rust-rage              0.8.1-1              0.9.0-1
                                salt               3005-1             3005.1-1
                             scummvm              2.6.0-2              2.6.1-1
                            startdde             5.9.56-1             5.9.59-1
                            taffybar              4.0.0-1              4.0.0-3
                           tailscale             1.32.1-1             1.32.2-1
                            tectonic             0.11.0-2             0.12.0-1
                          terminator              2.1.1-3              2.1.2-1
             thunderbird-dark-reader             4.9.59-1             4.9.60-1
                         ttc-iosevka             16.2.0-1             16.3.4-1
                    ttc-iosevka-aile             16.2.0-1             16.3.4-1
                   ttc-iosevka-curly             16.2.0-1             16.3.4-1
              ttc-iosevka-curly-slab             16.2.0-1             16.3.4-1
                  ttc-iosevka-etoile             16.2.0-1             16.3.4-1
                    ttc-iosevka-slab             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss01             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss02             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss03             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss04             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss05             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss06             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss07             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss08             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss09             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss10             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss11             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss12             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss13             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss14             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss15             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss16             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss17             16.2.0-1             16.3.4-1
                    ttc-iosevka-ss18             16.2.0-1             16.3.4-1
                                uasm               2.55-2             2.56.2-1
         v2ray-domain-list-community     20221026064907-1     20221027101443-1
                         v2ray-geoip       202210200105-1       202210270100-1
                            wasmtime              2.0.0-1              2.0.1-1
                     yubikey-manager              4.0.9-1              5.0.0-1
                                 dsq                    -             0.23.0-2
                       haskell-focus                    -              1.0.3-1
            haskell-primitive-extras                    -           0.10.1.5-1
          haskell-primitive-unlifted                    -            0.1.3.1-1
              haskell-stm-containers                    -                1.2-1
                    haskell-stm-hamt                    -            1.2.0.8-1
                     ruby-lumberjack                    -              1.2.8-1
                    ruby-minitest-rg                    -              5.2.0-1
                        ruby-timecop                    -              0.9.5-1
                                ttyd                    -              1.7.2-2
:: Different sync package(s) in repository core x86_64
                            iana-etc           20220915-1           20221025-1
:: Different overlay package(s) in repository extra x86_64
                         thunderbird            102.4.1-1                    -
                 thunderbird-i18n-af            102.4.1-1                    -
                 thunderbird-i18n-ar            102.4.1-1                    -
                thunderbird-i18n-ast            102.4.1-1                    -
                 thunderbird-i18n-be            102.4.1-1                    -
                 thunderbird-i18n-bg            102.4.1-1                    -
                 thunderbird-i18n-br            102.4.1-1                    -
                 thunderbird-i18n-ca            102.4.1-1                    -
                thunderbird-i18n-cak            102.4.1-1                    -
                 thunderbird-i18n-cs            102.4.1-1                    -
                 thunderbird-i18n-cy            102.4.1-1                    -
                 thunderbird-i18n-da            102.4.1-1                    -
                 thunderbird-i18n-de            102.4.1-1                    -
                thunderbird-i18n-dsb            102.4.1-1                    -
                 thunderbird-i18n-el            102.4.1-1                    -
              thunderbird-i18n-en-gb            102.4.1-1                    -
              thunderbird-i18n-en-us            102.4.1-1                    -
              thunderbird-i18n-es-ar            102.4.1-1                    -
              thunderbird-i18n-es-es            102.4.1-1                    -
                 thunderbird-i18n-et            102.4.1-1                    -
                 thunderbird-i18n-eu            102.4.1-1                    -
                 thunderbird-i18n-fi            102.4.1-1                    -
                 thunderbird-i18n-fr            102.4.1-1                    -
              thunderbird-i18n-fy-nl            102.4.1-1                    -
              thunderbird-i18n-ga-ie            102.4.1-1                    -
                 thunderbird-i18n-gd            102.4.1-1                    -
                 thunderbird-i18n-gl            102.4.1-1                    -
                 thunderbird-i18n-he            102.4.1-1                    -
                 thunderbird-i18n-hr            102.4.1-1                    -
                thunderbird-i18n-hsb            102.4.1-1                    -
                 thunderbird-i18n-hu            102.4.1-1                    -
              thunderbird-i18n-hy-am            102.4.1-1                    -
                 thunderbird-i18n-id            102.4.1-1                    -
                 thunderbird-i18n-is            102.4.1-1                    -
                 thunderbird-i18n-it            102.4.1-1                    -
                 thunderbird-i18n-ja            102.4.1-1                    -
                 thunderbird-i18n-ka            102.4.1-1                    -
                thunderbird-i18n-kab            102.4.1-1                    -
                 thunderbird-i18n-kk            102.4.1-1                    -
                 thunderbird-i18n-ko            102.4.1-1                    -
                 thunderbird-i18n-lt            102.4.1-1                    -
                 thunderbird-i18n-ms            102.4.1-1                    -
              thunderbird-i18n-nb-no            102.4.1-1                    -
                 thunderbird-i18n-nl            102.4.1-1                    -
              thunderbird-i18n-nn-no            102.4.1-1                    -
              thunderbird-i18n-pa-in            102.4.1-1                    -
                 thunderbird-i18n-pl            102.4.1-1                    -
              thunderbird-i18n-pt-br            102.4.1-1                    -
              thunderbird-i18n-pt-pt            102.4.1-1                    -
                 thunderbird-i18n-rm            102.4.1-1                    -
                 thunderbird-i18n-ro            102.4.1-1                    -
                 thunderbird-i18n-ru            102.4.1-1                    -
                 thunderbird-i18n-sk            102.4.1-1                    -
                 thunderbird-i18n-sl            102.4.1-1                    -
                 thunderbird-i18n-sq            102.4.1-1                    -
                 thunderbird-i18n-sr            102.4.1-1                    -
              thunderbird-i18n-sv-se            102.4.1-1                    -
                 thunderbird-i18n-th            102.4.1-1                    -
                 thunderbird-i18n-tr            102.4.1-1                    -
                 thunderbird-i18n-uk            102.4.1-1                    -
                 thunderbird-i18n-uz            102.4.1-1                    -
                 thunderbird-i18n-vi            102.4.1-1                    -
              thunderbird-i18n-zh-cn            102.4.1-1                    -
              thunderbird-i18n-zh-tw            102.4.1-1                    -
:: Different sync package(s) in repository extra x86_64
                            chromium      107.0.5304.68-1      107.0.5304.87-1
                         jdk-openjdk         19.0.1.u10-2         19.0.1.u10-3
                         jre-openjdk         19.0.1.u10-2         19.0.1.u10-3
                jre-openjdk-headless         19.0.1.u10-2         19.0.1.u10-3
                         openjdk-doc         19.0.1.u10-2         19.0.1.u10-3
                         openjdk-src         19.0.1.u10-2         19.0.1.u10-3
                             pyside6              6.4.0-1            6.4.0.1-1
            python-lazy-object-proxy              1.7.1-1              1.8.0-1
                    python-pytest-qt              4.1.0-1              4.2.0-1
                   python-virtualenv            20.16.5-1            20.16.6-1
                          qt5-script            5.15.10-3            5.15.11-1
                       qt5-webengine            5.15.10-4            5.15.11-1
                           shiboken6              6.4.0-1            6.4.0.1-1
                              taglib               1.12-2               1.13-1
                         thunderbird            102.4.0-2            102.4.1-1
                 thunderbird-i18n-af            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ar            102.4.0-2            102.4.1-1
                thunderbird-i18n-ast            102.4.0-2            102.4.1-1
                 thunderbird-i18n-be            102.4.0-2            102.4.1-1
                 thunderbird-i18n-bg            102.4.0-2            102.4.1-1
                 thunderbird-i18n-br            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ca            102.4.0-2            102.4.1-1
                thunderbird-i18n-cak            102.4.0-2            102.4.1-1
                 thunderbird-i18n-cs            102.4.0-2            102.4.1-1
                 thunderbird-i18n-cy            102.4.0-2            102.4.1-1
                 thunderbird-i18n-da            102.4.0-2            102.4.1-1
                 thunderbird-i18n-de            102.4.0-2            102.4.1-1
                thunderbird-i18n-dsb            102.4.0-2            102.4.1-1
                 thunderbird-i18n-el            102.4.0-2            102.4.1-1
              thunderbird-i18n-en-gb            102.4.0-2            102.4.1-1
              thunderbird-i18n-en-us            102.4.0-2            102.4.1-1
              thunderbird-i18n-es-ar            102.4.0-2            102.4.1-1
              thunderbird-i18n-es-es            102.4.0-2            102.4.1-1
                 thunderbird-i18n-et            102.4.0-2            102.4.1-1
                 thunderbird-i18n-eu            102.4.0-2            102.4.1-1
                 thunderbird-i18n-fi            102.4.0-2            102.4.1-1
                 thunderbird-i18n-fr            102.4.0-2            102.4.1-1
              thunderbird-i18n-fy-nl            102.4.0-2            102.4.1-1
              thunderbird-i18n-ga-ie            102.4.0-2            102.4.1-1
                 thunderbird-i18n-gd            102.4.0-2            102.4.1-1
                 thunderbird-i18n-gl            102.4.0-2            102.4.1-1
                 thunderbird-i18n-he            102.4.0-2            102.4.1-1
                 thunderbird-i18n-hr            102.4.0-2            102.4.1-1
                thunderbird-i18n-hsb            102.4.0-2            102.4.1-1
                 thunderbird-i18n-hu            102.4.0-2            102.4.1-1
              thunderbird-i18n-hy-am            102.4.0-2            102.4.1-1
                 thunderbird-i18n-id            102.4.0-2            102.4.1-1
                 thunderbird-i18n-is            102.4.0-2            102.4.1-1
                 thunderbird-i18n-it            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ja            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ka            102.4.0-2            102.4.1-1
                thunderbird-i18n-kab            102.4.0-2            102.4.1-1
                 thunderbird-i18n-kk            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ko            102.4.0-2            102.4.1-1
                 thunderbird-i18n-lt            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ms            102.4.0-2            102.4.1-1
              thunderbird-i18n-nb-no            102.4.0-2            102.4.1-1
                 thunderbird-i18n-nl            102.4.0-2            102.4.1-1
              thunderbird-i18n-nn-no            102.4.0-2            102.4.1-1
              thunderbird-i18n-pa-in            102.4.0-2            102.4.1-1
                 thunderbird-i18n-pl            102.4.0-2            102.4.1-1
              thunderbird-i18n-pt-br            102.4.0-2            102.4.1-1
              thunderbird-i18n-pt-pt            102.4.0-2            102.4.1-1
                 thunderbird-i18n-rm            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ro            102.4.0-2            102.4.1-1
                 thunderbird-i18n-ru            102.4.0-2            102.4.1-1
                 thunderbird-i18n-sk            102.4.0-2            102.4.1-1
                 thunderbird-i18n-sl            102.4.0-2            102.4.1-1
                 thunderbird-i18n-sq            102.4.0-2            102.4.1-1
                 thunderbird-i18n-sr            102.4.0-2            102.4.1-1
              thunderbird-i18n-sv-se            102.4.0-2            102.4.1-1
                 thunderbird-i18n-th            102.4.0-2            102.4.1-1
                 thunderbird-i18n-tr            102.4.0-2            102.4.1-1
                 thunderbird-i18n-uk            102.4.0-2            102.4.1-1
                 thunderbird-i18n-uz            102.4.0-2            102.4.1-1
                 thunderbird-i18n-vi            102.4.0-2            102.4.1-1
              thunderbird-i18n-zh-cn            102.4.0-2            102.4.1-1
              thunderbird-i18n-zh-tw            102.4.0-2            102.4.1-1
                               xterm                374-1                375-1
I’m on unstable and have key problem on this package.
error: linux515: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux515-5.15.75-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Same, signature are missing for linux kernels
Error: linux515: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
Error: linux515-headers: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
Error: linux519: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
Error: linux519-headers: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
Error: linux60: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
Error: linux60-headers: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
Same error here on unstable.
The PGP signature for the kernel packages seem to be broken.
Pamac error
Pacman error
Do you want to delete it? [Y/n]
ManjaroBuildServer vom 2022-10-28 16-05-44
Key expired - thats it.
2 posts were split to a new topic: Icu (72.1-1) breaks dependency ‘libicudata.so=71’ required by postgresql13
A post was merged into an existing topic: Icu (72.1-1) breaks dependency ‘libicudata.so=71’ required by postgresql13
The same
Thanks. Now I managed to update.
With Firefox 106.0.2 pushed and updated just now, the only major blocker that I had was fixed.
Yes! Especially since they seem to have merged wayland screen sharing fixes - it no longer crashes while sharing a window for me… huge win :+1:
What was the issue?
As detailed in the second post:
manjaro-keyring 20221028-4 should fix that signature issue. However those me too comments on the same issue might not help here.
For me it was sharing a single window under wayland and while using nvidia card with external monitor / mixed DPI.
