There are a few ACPI related errors in dmesg
[ 3.159344] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
[ 3.159352] ACPI: This conflict may cause random problems and system instability
[ 3.159353] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.159360] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
[ 3.159365] ACPI: This conflict may cause random problems and system instability
[ 3.159366] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.159368] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
[ 3.159372] ACPI: This conflict may cause random problems and system instability
[ 3.159373] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 3.159374] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
[ 3.159378] ACPI: This conflict may cause random problems and system instability
[ 3.159379] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
According to Linux: ACPI: Fix problems with Suspend, Resume, and Missing devices using acpi_osi= , I currently have the following ACPI kernel option set:
acpi_enforce_resources=lax acpi_osi=! "acpi_osi=Windows 2012"
Is there any change necessary? (BTW, more info and an explanation is here: backlight - how to set acpi_osi parameter in the grub - Unix & Linux Stack Exchange )
Hardware information from inxi -Fxxxza --no-host
System: Kernel: 5.10.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=345b76c0-f339-4ca7-8582-440f229512a1 ro quiet
acpi_enforce_resources=lax "acpi_osi=Windows 2009" loglevel=3
root=UUID=345b76c0-f339-4ca7-8582-440f229512a1 ro resume=UUID=a9353f2a-2cf9-4d4e-ada9-f72d8602045e vga=off
nvidia-drm.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Foxconn model: H67M-S/H67M-V/H67M serial: <filter> BIOS: American Megatrends
v: C29F1P03 date: 03/15/2013
CPU: Info: Dual Core model: Intel Core i3-2105 bits: 64 type: MT MCP arch: Sandy Bridge family: 6
model-id: 2A (42) stepping: 7 microcode: 2F L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 24754
Speed: 1596 MHz min/max: 1600/3100 MHz Core speeds (MHz): 1: 1596 2: 1677 3: 1945 4: 2154
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: Gigabyte driver: nvidia v: 390.141
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1244
Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 953x286mm (37.5x11.3") s-diag: 995mm (39.2")
Monitor-1: DVI-I-2 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DVI-I-3 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: GeForce GTX 550 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.141 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Foxconn driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Device-2: NVIDIA GF116 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0bee
Device-3: Creative Live! Cam Chat HD [VF0700] type: USB driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
bus ID: 1-1.3:5 chip ID: 041e:4097 serial: <filter>
Sound Server: ALSA v: k5.10.7-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Foxconn driver: r8169 v: kernel
port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
Device-2: AVM Fritz!Card PCI v2.0 ISDN driver: N/A modules: avmfritz port: c000 bus ID: 05:01.0
chip ID: 1244:0e00
Drives: Local Storage: total: 1.35 TiB used: 362.09 GiB (26.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intenso model: SSD SATAIII size: 447.13 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 4A0
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000333AS size: 931.51 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: CC3H
Partition: ID-1: / raw size: 438.54 GiB size: 430.65 GiB (98.20%) used: 107.36 GiB (24.9%) fs: ext4 dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw size: 915 GiB size: 899.64 GiB (98.32%) used: 254.73 GiB (28.3%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.51 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb2 maj-min: 8:18
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 56 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 60%
Info: Processes: 213 Uptime: 20m wakeups: 0 Memory: 7.74 GiB used: 2.45 GiB (31.7%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1317 lib: 395 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.2.02
