I’ll test it with systemd 247.1-3 as well when the time comes, soon I presume. May be useful for some that would want to use DNS over TLS, instead of dnscrypt or DoH.
my CUPS service failed to start after the update.
Ran systemctl start cups.service
to fix.
And I thought it was my fault, when cups.service disappeared the same day on my thinkpad…
Always read pacman / pamac output during the update process and you’ll be fine.
systemctl enable cups.service
Maybe you missed previous updates notes about cupsd service being renamed to cups?
It does.
OK
Fine. Was merely reporting packages flagged by checkrebuild
as needing to be rebuilt, as per @philm request. Granted, libpurple
and pidgin
have been mentioned by others.
No worries. Thanks for reporting them, otherwise old, broken packages would have still been in the repos needlessly.
Hello, is there any chance to support video-hybrid-intel-nvidia-390xx-bumblebee in future 20.2 releases with 5.4 LTS kernel?
If the packages are switched correctly (which they are not, check my post), then it will work just fine
Those have not actually been dropped, check the relevant post.
Poedit is broken since this update:
poedit
poedit: symbol lookup error: /usr/lib/liblucene++.so.0: undefined symbol: _ZN5boost16re_detail_10720019raise_runtime_errorERKSt13runtime_error
Had problems with Libreoffice too, but fixed those
With this “testing” update had problems with “Catfish” and “zeitgeist” as being in conflict …
Bluntly solved by removing " Catfish" for the time being …
maybe one of them needs rebuild against new python, that’s why they are in conflict
Hi, I understood that, but hardware detection selects video-linux instead of 390xx-bumblebee.
I had other things to do. Here is the missing part of switching the Nvidia drivers correctly:
@TotallyNotElite maybe review it.
@philm Tested, this does not work:
- manjaro-system script fails to copy the files, because they have not been installed yet. (Maybe this should be done in mhwd-db’s post update scripts?)
- Linux-latest still screws around with the nvidia packages
- After forcing the completion of this update by fixing the conflict, you end up with a franken-nvidia system:
This happens because nvidia-utils does not replace the previous nvidia-utils packages, unlike lib32-nvidia-utils.
For some reason, lib32-nvidia-utils is now no longer marked as explicitly installed. - It also seems like there are quite a few more packages that need to be dropped from the repo.
So in short, this is a complete mess right now.
on lock Xfce screen ,
lost info user connecting with password
no solution
