The installation of the update went very well. I liked the way it was updated inux59-nvidia, linux59-headers and linux - utils.
I am using a MacBook Pro 13" mid 2010
The updated worked for me.
BUT if I switch to nouveau driver, the power management does not work anymore.
Additionally I have since long time the issue that wifi does not work after cold-boot. Only after I send my macbook to sleep and wake it up again, the wifi works. But that does not work with nouveau driver, as it does not wake up from sleep anymore, or better said it does not really go to sleep mode. Display turns off but sleep LED does not light up. Have to hold power button for several seconds to turn off. The legacy NVIDIA driver works fine.
Manjaro-hello
does not work in combination with Pamac 10 Beta. It requires version 9.0.
~ >>> manjaro-hello
File "/usr/bin/manjaro-hello", line 409, in <module>
hello = Hello()
File "/usr/bin/manjaro-hello", line 172, in __init__
manager.get_modules(self)
File "/usr/bin/manjaro-hello", line 30, in get_modules
app.load(window)
File "/usr/bin/manjaro-hello", line 80, in load
from application_utility.browser.application_browser import ApplicationBrowser
File "/usr/lib/python3.9/site-packages/application_utility/browser/application_browser.py", line 26, in <module>
from application_utility.config.hello_config import HelloConfig
File "/usr/lib/python3.9/site-packages/application_utility/config/hello_config.py", line 25, in <module>
from application_utility.browser.config import Config
File "/usr/lib/python3.9/site-packages/application_utility/browser/config.py", line 27, in <module>
from .data import Data
File "/usr/lib/python3.9/site-packages/application_utility/browser/data.py", line 31, in <module>
gi.require_version("Pamac", "9.0")
File "/usr/lib/python3.9/site-packages/gi/__init__.py", line 129, in require_version
raise ValueError('Namespace %s not available for version %s' %
ValueError: Namespace Pamac not available for version 9.0'
I created an issue on gitlab: Manjaro-Hello does not run together with Pamac 10 Beta
i will add
correct video-nvidia by chroot
( remove nvidia-utils-455xx with option -Rdd , then mhwd -a pci free 0300 , mhwd -a cpi nonfree 0300)
nb : if you have Grub error on boot ( csm + secureboot activated --> no csm , no secureboot )
with lightdm - xfce - lock screen and systemd
i will check if trouble still occurs on screen lock:
- i can log in
- lost of video screen ( goes black )
- i log in TTY
- i apply âsudo systemctl restart lightdmâ to get back xorg & video
and then itâs ok
with boot kernel : systemd.unified_cgroup_hierarchy=1 ( need to apply 4)
next try : without systemd.unified_cgroup_hierarchy ( need to apply 4 )
next try : downgrade systemd ==> version 247 systemd is not ready
( lib32-systemd , systemd , systemd-libs , systemd-syscompat) ( need to apply 4 )
@philm
what i have see :
pam secret on lock xfce session do not know login ,
with check ( sudo systemctl status )
session 2 with login ( user ok on boot )
lock screen , type password
failed return session 2 ( no more login appears , pam secret with warn )
pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknow>]
==> NO USER HERE
then Ctrl+Alt+F2
tty create session 5 with login ( user ok )
check , there is 2 session2 and 5 , only session5 has login --user
if i do sudo systemctl restart ligthdm.service
session 2 & session 5 are fusioned , video is back ( login user is ok )
==> we lost login --user HERE on lock screen
Had to downgrade linux-firmware
due to wifi problems
affected device
Network controller: Qualcomm Atheros AR9462 Wireless Network Adapter (rev 01)
Subsystem: Lite-On Communications Inc Device 6621
Kernel driver in use: ath9k
Kernel modules: ath9k
This switch to the new nvidia packages is kind of a mess. lib32-nvidia-utils
correctly conflicts and replaces, while nvidia-utils
does not for example (it only conflicts). I also ended up with linux59 without the nvidia kernel module thanks to linux-latest. Fixed all those issues on my end, but unless thatâs addressed, we may end up with a lot of broken systems.
P.s.: Why not make kernel linux59 replace all previous kernels instead of using a proxy meta package? That would also solve various dependency issues. When for example the kernel gui tries to remove linux59.
Not sure why this happened. But I am running the testing branch on my laptop. I am using KDE Plasma. Itâs an Asus Laptop. No dedicated GPU. Itâs only GPU is the internal one by my CPU (Intel).
When checking for updates using yay, yay -Syu
, I get âMissing aur packages: mwhd-nvidia-340xx, 418xx, 430xx, 440xx, 450xx, and 455xxâ. I did not have this issue until this latest testing update.
Note: In the âmissing aur packagesâ output I put, I didnât include the âmwhd-nvidiaâ part for the rest of the packages just to save myself from typing it all out.
Another note and possible issue. When I go to âAdd or Remove Softwareâ and I check for updates via that, it getâs to about 90% and seems to finish but crashes. I think it may be crashing when itâs going to display the updates I have.
That means theyâre orphans an you can remove them.
I was able to upgrade my intel/nvidia stack by removing conflicting packages and then reinstall the prime package for linux59. Everything went seamlessly from there on in respect to the gpu drivers and kernel upgrade.
But I have two other problems:
Iâm on a thinkpad T480 and with linux59 brightness controls are not working, no problems with linux54, linux58 and linux510. So I switched to linux510 for now and can live with this workaround
I had to do a partial upgrade due to problems with the pipewire package and itâs pulse plugins:
:: Synchronizing package databases... core 168,3 KiB 7,15 MiB/s 00:00 [------------------------------------------------------------------------------] 100% extra 1961,6 KiB 31,9 MiB/s 00:00 [------------------------------------------------------------------------------] 100% community 6,3 MiB 31,7 MiB/s 00:00 [------------------------------------------------------------------------------] 100% multilib 182,2 KiB 44,5 MiB/s 00:00 [------------------------------------------------------------------------------] 100% :: Starting full system upgrade... resolving dependencies... looking for conflicting packages... :: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] y :: pipewire-pulse and pulseaudio-modules-bt are in conflict (pulseaudio-bluetooth). Remove pulseaudio-modules-bt? [y/N] y error: failed to prepare transaction (could not satisfy dependencies) :: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-equalizer :: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-jack :: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-lirc :: removing pulseaudio breaks dependency 'pulseaudio=14.0-1' required by pulseaudio-zeroconf error installing repo packages```
Iâm not sure if this is an individual problem.
UPDATE:
For now, I ended up with removing the pipewire-pulse
package and the upgrade went fine. Will try the pulse replacement by pipewire later again.
To remove pulseaudio and use pipewireis difficult, but not impossible;
first remove all apps using pulsaudio and write down, which.
in this case:
pulseaudio-jack
pulseaudio-lirc
pulseaudio-zeroconf
With pamac its easier - if you get a warning, "remove (long list , containing e.g gdm, dont do that.
Do this as long, as no warning because oif de-install occurs.
Dependencies warning may be ignored - deinstall not
Than try upgrade - if pamac doesnot want to de-install anything, than its o.k.
For pipewire I have installed:
pipewire
pipewire-alsa
pipewire-jack
pipewire-pulse
gst-plugin-pipewire
libpipewire02
and:
systemctl --user enable pipewire.socket
systemctl --user enable pipewire.service
May the force be with youâŠ
Will this break any desktops? I know cinnamon needs the pulseaudio libs and removing pulseaudio used to remove the cinnamon desktop as well. Hopefully this isnât an issue anymore
Everything that removes something else than âpulseaudio*â
WILL break your System!
I am on Gnome. Did remove any pulseaudio-apps before upgrading - IF there was no warning about
removing the System like gdm (or cinnamon-desktop).
The upgrade-script using pamac managed to do this without breakage, whereas on TTY it could not be doneâŠ
hmm looks like those systemd-resolved
issues werenât that innocent, after this update on my testing machine that has DNS over TLS (cloudflare) I was getting a lot of core dumps in Chromium for example
Snip of those
09/12/2020 04:52 systemd-coredump Process 5504 (chromium) of user 1000 dumped core.
Stack trace of thread 5521:
#0 0x00007fa7f1007615 raise (libc.so.6 + 0x3d615)
#1 0x00007fa7f0ff0862 abort (libc.so.6 + 0x26862)
#2 0x00007fa7e72041e4 n/a (libnss_resolve.so.2 + 0x101e4)
#3 0x00007fa7e71f6fe7 n/a (libnss_resolve.so.2 + 0x2fe7)
#4 0x00007fa7e72015c5 _nss_resolve_gethostbyname4_r (libnss_resolve.so.2 + 0xd5c5)
#5 0x00007fa7f10b3146 gaih_inet.constprop.0 (libc.so.6 + 0xe9146)
#6 0x00007fa7f10b3fc9 getaddrinfo (libc.so.6 + 0xe9fc9)
#7 0x0000563b7ce94411 n/a (chromium + 0x1fa7411)
#8 0x0000563b7cebe4fe n/a (chromium + 0x1fd14fe)
#9 0x0000563b7ceb4b9b n/a (chromium + 0x1fc7b9b)
#10 0x0000563b7ceb4dd8 n/a (chromium + 0x1fc7dd8)
#11 0x0000563b7f71b5ee n/a (chromium + 0x482e5ee)
#12 0x0000563b7f734078 n/a (chromium + 0x4847078)
#13 0x0000563b7f733b18 n/a (chromium + 0x4846b18)
#14 0x0000563b7f76a96d n/a (chromium + 0x487d96d)
#15 0x0000563b7f733592 n/a (chromium + 0x4846592)
#16 0x0000563b7f7403cb n/a (chromium + 0x48533cb)
#17 0x0000563b7f73ff8a n/a (chromium + 0x4852f8a)
#18 0x0000563b7f76b1d5 n/a (chromium + 0x487e1d5)
#19 0x00007fa7f50133e9 start_thread (libpthread.so.0 + 0x93e9)
#20 0x00007fa7f10ca293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 5520:
#0 0x00007fa7f10bf56e ppoll (libc.so.6 + 0xf556e)
#1 0x00007fa7e71f90d5 n/a (libnss_resolve.so.2 + 0x50d5)
#2 0x00007fa7e72011d5 n/a (libnss_resolve.so.2 + 0xd1d5)
#3 0x00007fa7e7201543 _nss_resolve_gethostbyname4_r (libnss_resolve.so.2 + 0xd543)
#4 0x00007fa7f10b3146 gaih_inet.constprop.0 (libc.so.6 + 0xe9146)
#5 0x00007fa7f10b3fc9 getaddrinfo (libc.so.6 + 0xe9fc9)
#6 0x0000563b7ce94411 n/a (chromium + 0x1fa7411)
#7 0x0000563b7cebe4fe n/a (chromium + 0x1fd14fe)
#8 0x0000563b7ceb4b9b n/a (chromium + 0x1fc7b9b)
#9 0x0000563b7ceb4dd8 n/a (chromium + 0x1fc7dd8)
#10 0x0000563b7f71b5ee n/a (chromium + 0x482e5ee)
#11 0x0000563b7f734078 n/a (chromium + 0x4847078)
#12 0x0000563b7f733b18 n/a (chromium + 0x4846b18)
#13 0x0000563b7f76a96d n/a (chromium + 0x487d96d)
#14 0x0000563b7f733592 n/a (chromium + 0x4846592)
#15 0x0000563b7f7403cb n/a (chromium + 0x48533cb)
#16 0x0000563b7f73ff8a n/a (chromium + 0x4852f8a)
#17 0x0000563b7f76b1d5 n/a (chromium + 0x487e1d5)
#18 0x00007fa7f50133e9 start_thread (libpthread.so.0 + 0x93e9)
#19 0x00007fa7f10ca293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 5522:
#0 0x00007fa7f10c1b7b __select (libc.so.6 + 0xf7b7b)
#1 0x0000563b7f76d7de n/a (chromium + 0x48807de)
#2 0x0000563b7f76b1d5 n/a (chromium + 0x487e1d5)
#3 0x00007fa7f50133e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007fa7f10ca293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 5504:
#0 0x00007fa7f50196a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x0000563b7f767901 n/a (chromium + 0x487a901)
#2 0x0000563b7f7681b5 n/a (chromium + 0x487b1b5)
#3 0x0000563b7f767eab n/a (chromium + 0x487aeab)
#4 0x0000563b7f6ddd8b n/a (chromium + 0x47f0d8b)
#5 0x0000563b7f72d64e n/a (chromium + 0x484064e)
#6 0x0000563b7f704362 n/a (chromium + 0x4817362)
#7 0x0000563b7f431cdb n/a (chromium + 0x4544cdb)
#8 0x0000563b7f69fc84 n/a (chromium + 0x47b2c84)
#9 0x0000563b7f69df16 n/a (chromium + 0x47b0f16)
#10 0x0000563b7cd860a3 ChromeMain (chromium + 0x1e990a3)
#11 0x00007fa7f0ff2152 __libc_start_main (libc.so.6 + 0x28152)
#12 0x0000563b7ca8b56e _start (chromium + 0x1b9e56e)
...list continues
DNS o. TLS settings were these:
resolvectl status
Global
LLMNR setting: yes
MulticastDNS setting: yes
DNSOverTLS setting: yes
DNSSEC setting: no
DNSSEC supported: no
DNS Servers: 1.1.1.1
1.0.0.1
2606:4700:4700::1111
2606:4700:4700::1001
Fallback DNS Servers: 8.8.8.8
8.8.4.4
2001:4860:4860::8888
2001:4860:4860::8884
DNS Domain: ~.
Link 2 (enp61s0)
Current Scopes: none
DefaultRoute setting: no
LLMNR setting: yes
MulticastDNS setting: no
DNSSEC setting: no
Link 3 (wlp62s0)
Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6
DefaultRoute setting: yes
LLMNR setting: yes
DNSSEC setting: no
DNS Servers: 192.168.1.1
fe80::1%21913
DNS Domain: ~.
home
So apart from DNSSEC managed by systemd utterly broken for a long time already (does not respond at all from a point on and new updated default resolved.conf
has set #DNSSEC=no replacing the previous default #DNSSEC=allow-downgrade), seems like systemd 247.1-1
is buggy with DNSoTLS as well
Problem solved downgrading to previous 246.6-1, (no systemd-resolved CPU struggle, no Chromium core dumps), Arch adopted 247 too early?
systemd 246.6-1 247.1-1
systemd-libs 246.6-1 247.1-1
systemd-resolvconf 246.6-1 247.1-1
systemd-sysvcompat 246.6-1 247.1-1
systemd 247.1-1 âwasâ very buggy excepted some bugs on an Arch VPS > is ok with systemd 247.1-3 so in my opinion we should use this version in unstable and testing . In stable stay at 246.6.
Flatpak creates some issues in pamac. Will this be fixed in next stable update?
All good here. From the repos, libpurple, pidgin and python-tesserwarp need to be rebuilded.
So I updated and rebooted. Now nvidia isnt working.
The GUI says that nvidia driver is not installed, so I tried to instal it. but then this message shows up:
" Waiting for user input...
Starting
Error: config 'video-hybrid-intel-nvidia-prime' conflicts with config(s): video-hybrid-intel-nvidia-455xx-prime
Hecho."
so I try this to remove the old driver
sudo mhwd -r pci video-hybrid-intel-nvidia-455xx-prime
but it complains that removing nvidia-455xx-utils breaks dependency with «nvidia-utils», needed for the package lib32-nvidia-utils
So what now? because it seems Im in a dead end here
Edit:
I was able to yay -R mhwd-nvidia-455xx
but the error is still here when installing from the driver GUI
Starting
Warning: config '/var/lib/mhwd/local/pci/video-hybrid-intel-nvidia-455xx-prime/MHWDCONFIG' is invalid!
Installing video-hybrid-intel-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
warning: nvidia-prime-1.0-4 is up to date -- skipping
warning: lib32-nvidia-utils-455.45.01-3 is up to date -- skipping
warning: linux510-nvidia-455.45.01-0.7 is up to date -- skipping
warning: linux59-nvidia-455.45.01-2 is up to date -- skipping
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: nvidia-utils and nvidia-455xx-utils are in conflict (nvidia-libgl). Remove nvidia-455xx-utils? [y/N] error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Error: pacman failed!
Error: script failed!
Hecho.
Edit 2: uninstalling optimus manager fixed the nvidia card not working at all, but the problem above still remains, I cant install the driver that shows up in the driver GUI utility. Would be nice to have instructions about how to fix it since you already knew that were going to break.
Replace issues were solved with nvidia-utils already. I only have to fix mhwd-profiles similar like this. However Iâm more occupied in ARM part of Manjaro, so Iâve less time to do x86_64 stuff.
The Nvidia drivers switch will mess up a lot of systems, so we have to figure out on how to switch the drivers best. Especially those systems with Hybrid drivers âŠ
The first two are imported directly from Arch and are not related to migrating to Python 3.9. Does Pidgin still work? If not, create a new thread in Software & Applications.
As far as python-tesserwrap
, it hasnât been updated since 2014. The only thing that requires it is ocrdesktop
. The project webpage is dead, canât find anything about it.
Iâm removing them from our repos, youâre on youâre own. Looks like theyâre in the AUR.
âYou are the weakest link. Goodbyeâ
Seems the small icons in KDE audio widget, mentioned by omano, is still present.
I tried different Plasma Styles, and narrowed it to the colour-scheme-respecting Breath2.
