I think there is something not proper yet with NVIDIA drivers. I tried to install nfancurve from the AUR, and it tries to replace the video drivers because it needs nvidia-settings wich is, I think, actually provided within nvidia-utils maybe their is an oversight and nvidia-settings needs to be added to the packages provided by nvidia-utils or maybe there is something wrong on my side and/or I’m confused about the nvidia packages names. From my understanding nvidia-settings provides the Nvidia control panel, that I currently can open from terminal with command nvidia-settings so I assume it is provided with package nvidia-utils already on my machine.
[omano@omano-nvme ~]$ pamac install nfancurve
Warning: nfancurve is only available from AUR
Build nfancurve from AUR ? [y/N] y
Preparing...
Cloning nfancurve build files...
Checking nfancurve dependencies...
Cloning nvidia-utils-beta build files...
Checking nvidia-settings-beta dependencies...
Cloning nvidia-full-vulkan-all build files...
Checking nvidia-settings-full-vulkan-all dependencies...
Cloning nvidia-settings-gtk2 build files...
Checking nvidia-settings-gtk2 dependencies...
Choose a provider for nvidia-settings:
1: nvidia-settings-beta 455.45.01-1 AUR
2: nvidia-settings-full-vulkan-all 455.46.02-1 AUR
3: nvidia-settings-gtk2 455.28-1 AUR
Enter a number (default=1):
It should install and work properly in theory because I should have nvidia-settings installed already and it shouldn’t try to find an alternative for the missing dependency nvidia-settings.
[omano@omano-nvme ~]$ pacman -Qo /usr/bin/nvidia-settings
/usr/bin/nvidia-settings is owned by nvidia-utils 455.45.01-2
Yes I have done that and I could install the AUR package. But is it a mistake in the AUR package or should nvidia-settings be referenced as provided by nvidia-utils? That is my initial question related to the Testing branch thread because of the new changes with NVIDIA, this is why I didn’t open a new thread initially.
//EDIT: what I meant is that package nvidia-utils provides nvidia-settings but it doesn’t say so in the nvidia-utils package details. In theory nvidia-settings is a standalone package (on Arch for instance, an optional dependency of nvidia-utils), hence why it conflicts with some AUR package on Manjaro, I’m assuming.
Maybe it is intended like that or it is an oversight, but I was wondering why nvidia-settings wasn’t marked as provided by nvidia-utils. Not a big deal but maybe it could create other issues later on.
Ah OK… there was not enough words. Not to argue but my second post is basically the exact same thing, with more words. I didn’t feel the need to write an essay to ask the same thing. Whatever.
While I agree with you, we don’t officially support the AUR. There aren’t any packages in our repos that require or conflict with nvidia-settings since it’s part of nvidia-utils. When you come across a package that requires or conflicts with nvidia-settings, edit the PKGBUILD and either replace it with nvidia-utils or remove it.
