updated KDE/5.4
plasmashell crashed on reboot with no input (keyboard or touchpad). after a little time taskbar panel also went missing, rebooted with same result. however within yakuake, both keyboard or touchpad were working with ability to execute commands. tried manually starting plasmashell with;
kstart5 plasmashell
with no avail, plasmashell crashing immediately on start. the immediate error did show “org.kde.plasma.eventcalendar” issues. quick look at the logs proved the crash with these stack-traces;
Summary
Sep 16 06:34:06 koshika-inspiron-5520 plasmashell[1143]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Sep 16 06:34:06 koshika-inspiron-5520 plasmashell[1143]: file:///home/koshika/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/MeteogramView.qml:35:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Sep 16 06:34:06 koshika-inspiron-5520 audit[1143]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=1143 comm=“plasmashell” exe="/usr/bin/plasmashell" sig=11 res=1
Sep 16 06:34:06 koshika-inspiron-5520 kernel: audit: type=1701 audit(1600218246.606:90): auid=1000 uid=1000 gid=1000 ses=2 pid=1143 comm=“plasmashell” exe="/usr/bin/plasmashell" sig=11 res=1
Sep 16 06:34:06 koshika-inspiron-5520 systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Sep 16 06:34:06 koshika-inspiron-5520 systemd[1]: Started Process Core Dump (PID 1406/UID 0).
Sep 16 06:34:06 koshika-inspiron-5520 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-1406-0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Sep 16 06:34:06 koshika-inspiron-5520 kernel: audit: type=1130 audit(1600218246.652:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-1406-0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Sep 16 06:34:07 koshika-inspiron-5520 kded5[1084]: Service “org.kde.StatusNotifierHost-1143” unregistered
Sep 16 06:34:07 koshika-inspiron-5520 kwin_x11[1088]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3731, resource id: 29360143, major code: 15 (QueryTree), minor code: 0
Sep 16 06:34:07 koshika-inspiron-5520 kwin_x11[1088]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3798, resource id: 29360164, major code: 15 (QueryTree), minor code: 0
Sep 16 06:34:07 koshika-inspiron-5520 kwin_x11[1088]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3866, resource id: 29360246, major code: 15 (QueryTree), minor code: 0
Sep 16 06:34:09 koshika-inspiron-5520 systemd-coredump[1407]: Process 1143 (plasmashell) of user 1000 dumped core.
Stack trace of thread 1143:
#0 0x00007f0f303a5758 n/a (libQt5Gui.so.5 + 0x49d758)
#1 0x00007f0f303a90ce _ZNK17QGridLayoutEngine22ensureColumnAndRowDataEP18QGridLayoutRowDataP14QGridLayoutBoxPKdS5_N2Qt11OrientationEPK24QAbstractLayoutStyleInfo (libQt5Gui.so.5 + 0x4a10ce)
#2 0x00007f0f303a94d6 _ZNK17QGridLayoutEngine8sizeHintEN2Qt8SizeHintERK6QSizeFPK24QAbstractLayoutStyleInfo (libQt5Gui.so.5 + 0x4a14d6)
#3 0x00007f0f128f6d5e n/a (libqquicklayoutsplugin.so + 0x10d5e)
#4 0x00007f0f128f46ba n/a (libqquicklayoutsplugin.so + 0xe6ba)
#5 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#6 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#7 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#8 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#9 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#10 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#11 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#12 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#13 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#14 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#15 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#16 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#17 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#18 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#19 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#20 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#21 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#22 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#23 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#24 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#25 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#26 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#27 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#28 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#29 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#30 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#31 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#32 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#33 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#34 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#35 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#36 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#37 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#38 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#39 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#40 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#41 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#42 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#43 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#44 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#45 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#46 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#47 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#48 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#49 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#50 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#51 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#52 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#53 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#54 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#55 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#56 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#57 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#58 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#59 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
#60 0x00007f0f128f472f n/a (libqquicklayoutsplugin.so + 0xe72f)
#61 0x00007f0f128f92b6 n/a (libqquicklayoutsplugin.so + 0x132b6)
#62 0x00007f0f128f6a22 n/a (libqquicklayoutsplugin.so + 0x10a22)
#63 0x00007f0f317564f1 _ZN10QQuickItem15setImplicitSizeEdd (libQt5Quick.so.5 + 0x23e4f1)
Stack trace of thread 1383:
#0 0x00007f0f2ef456a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x00007f0f2fa8a0d4 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd40d4)
#2 0x00007f0f3170d2fb n/a (libQt5Quick.so.5 + 0x1f52fb)
#3 0x00007f0f3170f89b n/a (libQt5Quick.so.5 + 0x1f789b)
#4 0x00007f0f2fa83e8f n/a (libQt5Core.so.5 + 0xcde8f)
#5 0x00007f0f2ef3f3e9 start_thread (libpthread.so.0 + 0x93e9)
#6 0x00007f0f2f70e293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1381:
#0 0x00007f0f2ef459c8 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf9c8)
#1 0x00007f0f2fa8a058 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd4058)
#2 0x00007f0f2fa87fc4 n/a (libQt5Core.so.5 + 0xd1fc4)
#3 0x00007f0f2fa83e8f n/a (libQt5Core.so.5 + 0xcde8f)
#4 0x00007f0f2ef3f3e9 start_thread (libpthread.so.0 + 0x93e9)
#5 0x00007f0f2f70e293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1402:
Stack trace of thread 1169:
#0 0x00007f0f2f70346f __poll (libc.so.6 + 0xf546f)
#1 0x00007f0f2e136188 n/a (libglib-2.0.so.0 + 0xa4188)
#2 0x00007f0f2e0e3421 g_main_context_iteration (libglib-2.0.so.0 + 0x51421)
#3 0x00007f0f2fcc2941 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30c941)
#4 0x00007f0f2fc6865c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b265c)
#5 0x00007f0f2fa82ca2 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccca2)
#6 0x00007f0f30d6e098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007f0f2fa83e8f n/a (libQt5Core.so.5 + 0xcde8f)
#8 0x00007f0f2ef3f3e9 start_thread (libpthread.so.0 + 0x93e9)
#9 0x00007f0f2f70e293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1374:
#6 0x00007f0f3165e1db n/a (libQt5Quick.so.5 + 0x1461db)
Stack trace of thread 1376:
Stack trace of thread 1366:
#6 0x00007f0f313c24b9 n/a (libQt5Qml.so.5 + 0x30c4b9)
Stack trace of thread 1382:
Stack trace of thread 1367:
#1 0x00007f0f1b704a6c n/a (i965_dri.so + 0x51fa6c)
#2 0x00007f0f1b703d88 n/a (i965_dri.so + 0x51ed88)
#3 0x00007f0f2ef3f3e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007f0f2f70e293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1163:
#1 0x00007f0f31b3663b n/a (libxcb.so.1 + 0xc63b)
#2 0x00007f0f31b3837b xcb_wait_for_event (libxcb.so.1 + 0xe37b)
#3 0x00007f0f2b595f61 n/a (libQt5XcbQpa.so.5 + 0x5df61)
Stack trace of thread 1377:
Stack trace of thread 1368:
Stack trace of thread 1378:
Stack trace of thread 1380:
Stack trace of thread 1370:
Stack trace of thread 1379:
Stack trace of thread 1369:
Stack trace of thread 1375:
Stack trace of thread 1403:
Sep 16 06:34:09 koshika-inspiron-5520 systemd[1]: systemd-coredump@0-1406-0.service: Succeeded.
Sep 16 06:34:10 koshika-inspiron-5520 kernel: audit: type=1131 audit(1600218249.596:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-1406-0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Sep 16 06:34:09 koshika-inspiron-5520 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-coredump@0-1406-0 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
didnt know how to properly remove plasmoids, but proceeded to manually remove org.kde.plasma.eventcalendar from ~/.local/share/plasma/plasmoids/ and rebooted with no issues like previously. obvious culprit being org.kde.plasma.eventcalendar
i’m using a dual monitor setup on a laptop, everything seems to be in order with nothing to report as a new issue other than the usual quirks on KDE with dual monitors. but i do feel the options i get in display output selection panel are somehow different than before, although i cant tell which.
other than the org.kde.plasma.eventcalendar drama, update seems pretty solid.
