Hey,
HP Elitebook x360 1030 g2 Convertible.
Currently on Linux 6.11.11-1-MANJARO, Gnome.
I’m having trouble with my tablet-mode. When folding my convertible laptop, it switches to tablet-mode and back to laptop-mode, as it should be.
But this does not work always. It occurs to me that the longer the laptop stays in tablet mode, the more likely it is to being unable to recognize the lid-switch back to laptop-mode. Tablet-mode disables keyboard and touchpad and the only way to get out of this is by killing the laptop, simply rebooting does not work.
I’m a student with daily classes, so i have to kill my laptop at least once everyday.
I had it fixed about a month ago by simply disabling tablet mode:
sudo rmmod intel_hid
sudo rmmod intel_ish_ipc
and blacklisting them:
sudo touch /etc/modprobe.d/blacklist.intel.hid
blacklist intel_hid
sudo touch /etc/modprobe.d/blacklsit_intel_ish_ipc.conf
blacklist intel_ish_ipc
After an update about a week ago, this no longer works.
I looked on ArchWiki “Tablet-PC” and tried to get “tablet-mode” by schard running.
This is the error message that i got:
File "/usr/bin/setsysmode", line 33, in <module>
sys.exit(load_entry_point('tabletmode==2.2.0', 'console_scripts', 'setsysmode')())
File "/usr/lib/python3.12/site-packages/tabletmode/cli.py", line 117, in main
config = load_config()
File "/usr/lib/python3.12/site-packages/tabletmode/config.py", line 20, in load_config
return load(cfg)
File "/usr/lib/python3.12/json/__init__.py", line 293, in load
return loads(fp.read(),
File "/usr/lib/python3.12/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.12/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.12/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 3 (char 2)
I tried messing around, but nothing worked.
This is my current tablet-mode.jason file:
"tablet": [
"/dev/input/by-path/platform-i8042-serio-0-event-kbd",
"/dev/input/by-path/platform-i8042-serio-3-event-mouse"
"notify": false,
"sudo": "/usr/bin/doas"
Just to be clear, that my laptop does theoretically recognize the sensor, as long as i don’t stay for too long in tablet mode:
sudo libinput debug-events
-event3 DEVICE_ADDED Power Button seat0 default group1 cap:k
-event5 DEVICE_ADDED Video Bus seat0 default group2 cap:k
-event2 DEVICE_ADDED Power Button seat0 default group3 cap:k
-event1 DEVICE_ADDED Lid Switch seat0 default group4 cap:S
-event0 DEVICE_ADDED Sleep Button seat0 default group5 cap:k
-event18 DEVICE_ADDED Wacom HID 481C Pen seat0 default group6 cap:T size 294x165mm left calib
-event19 DEVICE_ADDED Wacom HID 481C Finger seat0 default group6 cap:t size 294x165mm ntouches 10 calib
-event17 DEVICE_ADDED ALP0016:00 044E:1215 seat0 default group7 cap:pg size 107x58mm tap(dl off) left scroll-nat scroll-2fg-edge click-buttonareas-clickfinger dwt-on dwtp-on
-event8 DEVICE_ADDED Intel Virtual Buttons seat0 default group8 cap:k
-event9 DEVICE_ADDED Intel Virtual Switches seat0 default group9 cap:S
-event7 DEVICE_ADDED Intel HID events seat0 default group10 cap:k
-event4 DEVICE_ADDED AT Translated Set 2 keyboard seat0 default group11 cap:k
-event20 DEVICE_ADDED AlpsPS/2 ALPS GlidePoint seat0 default group12 cap:pg size 104x60mm tap(dl off) left scroll-nat scroll-2fg-edge click-buttonareas-clickfinger dwt-on dwtp-on
-event6 DEVICE_ADDED Wireless hotkeys seat0 default group13 cap:k
-event11 DEVICE_ADDED HP WMI hotkeys seat0 default group14 cap:kS
-event9 SWITCH_TOGGLE +0.420s switch tablet-mode state 1
event9 SWITCH_TOGGLE +1.987s switch tablet-mode state 0
The problem occurs after spending up to 1h30 (i don’t know the specific time window, but happens mostly after every class) in tablet-mode. Then, the switch-toggle just doesn’t appear anymore and my keyboard / touchpad keep being disabled.
I don’t find any solution to this, and i really don’t want to keep on killing my laptop day by day. Can anyone help me?
