try this:
mv /etc/grub.d{,.bak}
pacman -S grub
update-grub
and check if there is the same error
Grub Update worked … but there is no grub menue
but running 5.17 reboot persits.
Trying the 5.10 reboot persits.
Trying the userthem theory now.
also os-prober didn’t recognize my windows installation.
and reboot persits even before user login.
so if there were no errors after update-grub, you need to run also:
mkinitcpio -P
even if i did before ?
all your instructions run grub-update
last
after you reinstalled grub you should run also the mkinitcpio -P
command …and the update-grub command didnt detected windows?
nope no windows esc during boot brings up the menu.
but that is probably because i dont have the windows installation/its efi part. mounted. (im stupid)
also mkinitcpio -P
only builds for 5.10 and 5.17 not 5.15.
but i ran the commands in order now and will try again.
Okay unfortunatly no luck. Both kernels as well as the newly created user @linux-aarhus won’t fix the instability.
And since live boot is stable i don’t think its a Hardware problem as well. I think i might have to face a reinstall here.
so before that, post output from logs again:
journalctl --boot=-1 --priority=5 --no-pager
as you wish:
Jun 07 00:16:07 manjaro kernel: Linux version 5.17.9-1-MANJARO (builduser@fv-az451-156) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Wed May 18 09:20:53 UTC 2022
Jun 07 00:16:07 manjaro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64 root=UUID=bb7ffb9c-67ce-4002-b16b-05b7607979c4 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Jun 07 00:16:07 manjaro kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64", will be passed to user space.
Jun 07 00:16:07 manjaro kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x530 with crng_init=0
Jun 07 00:16:07 manjaro kernel: tsc: Unable to calibrate against PIT
Jun 07 00:16:07 manjaro kernel: audit: type=2000 audit(1654553763.166:1): state=initialized audit_enabled=0 res=1
Jun 07 00:16:07 manjaro kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jun 07 00:16:07 manjaro kernel: SCSI subsystem initialized
Jun 07 00:16:07 manjaro kernel: VFS: Disk quotas dquot_6.6.0
Jun 07 00:16:07 manjaro kernel: Initialise system trusted keyrings
Jun 07 00:16:07 manjaro kernel: Key type blacklist registered
Jun 07 00:16:07 manjaro kernel: Key type asymmetric registered
Jun 07 00:16:07 manjaro kernel: Asymmetric key parser 'x509' registered
Jun 07 00:16:07 manjaro kernel: SPI driver ili9163 has no spi_device_id for newhaven,1.8-128160EF
Jun 07 00:16:07 manjaro kernel: Loading compiled-in X.509 certificates
Jun 07 00:16:07 manjaro kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 8632eaf53803dc214d78374023fb0435c2e75297'
Jun 07 00:16:07 manjaro kernel: Key type ._fscrypt registered
Jun 07 00:16:07 manjaro kernel: Key type .fscrypt registered
Jun 07 00:16:07 manjaro kernel: Key type fscrypt-provisioning registered
Jun 07 00:16:07 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
Jun 07 00:16:07 manjaro kernel: scsi 0:0:0:0: Direct-Access ATA Samsung SSD 860 3B6Q PQ: 0 ANSI: 5
Jun 07 00:16:07 manjaro kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Jun 07 00:16:07 manjaro kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 07 00:16:07 manjaro kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 07 00:16:07 manjaro kernel: sd 0:0:0:0: [sda] supports TCG Opal
Jun 07 00:16:07 manjaro kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 07 00:16:07 manjaro kernel: ata2.00: supports DRM functions and may not be fully accessible
Jun 07 00:16:07 manjaro kernel: scsi 1:0:0:0: Direct-Access ATA ST1000DM003-1ER1 CC43 PQ: 0 ANSI: 5
Jun 07 00:16:07 manjaro kernel: sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Jun 07 00:16:07 manjaro kernel: sd 1:0:0:0: [sdb] 4096-byte physical blocks
Jun 07 00:16:07 manjaro kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jun 07 00:16:07 manjaro kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 07 00:16:07 manjaro kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jun 07 00:16:07 manjaro kernel: scsi 4:0:0:0: Direct-Access ATA TOSHIBA-TR150 12.3 PQ: 0 ANSI: 5
Jun 07 00:16:07 manjaro kernel: sd 4:0:0:0: [sdc] 468862128 512-byte logical blocks: (240 GB/224 GiB)
Jun 07 00:16:07 manjaro kernel: sd 4:0:0:0: [sdc] Write Protect is off
Jun 07 00:16:07 manjaro kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 07 00:16:07 manjaro kernel: sd 4:0:0:0: [sdc] Attached SCSI disk
Jun 07 00:16:07 manjaro kernel: scsi 5:0:0:0: Direct-Access ATA WDC WD20EZAZ-00G 0A80 PQ: 0 ANSI: 5
Jun 07 00:16:07 manjaro kernel: sd 5:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Jun 07 00:16:07 manjaro kernel: sd 5:0:0:0: [sdd] 4096-byte physical blocks
Jun 07 00:16:07 manjaro kernel: sd 5:0:0:0: [sdd] Write Protect is off
Jun 07 00:16:07 manjaro kernel: sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 07 00:16:07 manjaro kernel: sd 5:0:0:0: [sdd] Attached SCSI disk
Jun 07 00:16:07 manjaro kernel: random: fast init done
Jun 07 00:16:07 manjaro kernel: usb: port power management may be unreliable
Jun 07 00:16:07 manjaro systemd[1]: Configuration file /etc/systemd/system/kill_kwin.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Jun 07 00:16:07 manjaro kernel: random: lvm: uninitialized urandom read (4 bytes read)
Jun 07 00:16:07 manjaro kernel: audit: type=1130 audit(1654553767.767:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:07 manjaro kernel: audit: type=1131 audit(1654553767.767:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:07 manjaro kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 07 00:16:07 manjaro kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jun 07 00:16:07 manjaro kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0
Jun 07 00:16:07 manjaro kernel: sd 5:0:0:0: Attached scsi generic sg3 type 0
Jun 07 00:16:07 manjaro kernel: audit: type=1130 audit(1654553767.797:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:07 manjaro kernel: audit: type=1400 audit(1654553767.801:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=367 comm="apparmor_parser"
Jun 07 00:16:07 manjaro kernel: audit: type=1300 audit(1654553767.801:5): arch=c000003e syscall=1 success=yes exit=7609 a0=6 a1=559268d2bca0 a2=1db9 a3=0 items=0 ppid=355 pid=367 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
Jun 07 00:16:07 manjaro kernel: audit: type=1327 audit(1654553767.801:5): proctitle=2F7362696E2F61707061726D6F725F706172736572002D2D7265706C616365002D2D002F6574632F61707061726D6F722E64
Jun 07 00:16:07 manjaro kernel: v4l2loopback_dc: loading out-of-tree module taints kernel.
Jun 07 00:16:07 manjaro kernel: v4l2loopback_dc: module verification failed: signature and/or required key missing - tainting kernel
Jun 07 00:16:07 manjaro kernel: audit: type=1130 audit(1654553767.814:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:07 manjaro systemd-random-seed[356]: Kernel entropy pool is not initialized yet, waiting until it is.
Jun 07 00:16:07 manjaro kernel: audit: type=1130 audit(1654553767.827:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:07 manjaro kernel: audit: type=1334 audit(1654553767.827:8): prog-id=6 op=LOAD
Jun 07 00:16:07 manjaro systemd-modules-load[348]: Failed to find module 'vboxdrv'
Jun 07 00:16:07 manjaro systemd-modules-load[348]: Failed to find module 'vboxnetadp'
Jun 07 00:16:07 manjaro systemd-modules-load[348]: Failed to find module 'vboxnetflt'
Jun 07 00:16:08 manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jun 07 00:16:08 manjaro kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Jun 07 00:16:08 manjaro kernel: random: crng init done
Jun 07 00:16:08 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20211217/utaddress-204)
Jun 07 00:16:08 manjaro kernel: ccp 0000:08:00.2: ccp enabled
Jun 07 00:16:08 manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Jun 07 00:16:08 manjaro kernel: Disabling lock debugging due to kernel taint
Jun 07 00:16:09 manjaro kernel: scsi 10:0:0:0: Direct-Access TOSHIBA External USB 3.0 5438 PQ: 0 ANSI: 6
Jun 07 00:16:09 manjaro kernel: sd 10:0:0:0: Attached scsi generic sg4 type 0
Jun 07 00:16:09 manjaro kernel: sd 10:0:0:0: [sde] 976773164 512-byte logical blocks: (500 GB/466 GiB)
Jun 07 00:16:09 manjaro kernel: sd 10:0:0:0: [sde] Write Protect is off
Jun 07 00:16:09 manjaro kernel: sd 10:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 07 00:16:09 manjaro kernel: scsi 9:0:0:0: Direct-Access FCR-HS3 -0 1.00 PQ: 0 ANSI: 6
Jun 07 00:16:09 manjaro kernel: scsi 9:0:0:1: Direct-Access FCR-HS3 -1 1.00 PQ: 0 ANSI: 6
Jun 07 00:16:09 manjaro kernel: scsi 9:0:0:2: Direct-Access FCR-HS3 -2 1.00 PQ: 0 ANSI: 6
Jun 07 00:16:09 manjaro kernel: scsi 9:0:0:3: Direct-Access FCR-HS3 -3 1.00 PQ: 0 ANSI: 6
Jun 07 00:16:09 manjaro kernel: sd 9:0:0:0: Attached scsi generic sg5 type 0
Jun 07 00:16:09 manjaro kernel: sd 9:0:0:1: Attached scsi generic sg6 type 0
Jun 07 00:16:09 manjaro kernel: sd 9:0:0:2: Attached scsi generic sg7 type 0
Jun 07 00:16:09 manjaro kernel: sd 9:0:0:3: Attached scsi generic sg8 type 0
Jun 07 00:16:09 manjaro kernel: sd 9:0:0:0: [sdf] Media removed, stopped polling
Jun 07 00:16:09 manjaro kernel: sd 9:0:0:1: [sdg] Media removed, stopped polling
Jun 07 00:16:09 manjaro kernel: sd 10:0:0:0: [sde] Attached SCSI disk
Jun 07 00:16:10 manjaro kernel: scsi 11:0:0:0: Direct-Access SMI USB DISK 1100 PQ: 0 ANSI: 6
Jun 07 00:16:10 manjaro kernel: sd 11:0:0:0: Attached scsi generic sg9 type 0
Jun 07 00:16:10 manjaro kernel: sd 11:0:0:0: [sdj] 61440000 512-byte logical blocks: (31.5 GB/29.3 GiB)
Jun 07 00:16:10 manjaro kernel: sd 11:0:0:0: [sdj] Write Protect is off
Jun 07 00:16:10 manjaro kernel: sd 11:0:0:0: [sdj] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 07 00:16:10 manjaro kernel: sd 11:0:0:0: [sdj] Attached SCSI removable disk
Jun 07 00:16:10 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.129.06 Thu May 12 22:52:02 UTC 2022
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:2: [sdh] 3938304 512-byte logical blocks: (2.02 GB/1.88 GiB)
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:2: [sdh] Write Protect is off
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:2: [sdh] No Caching mode page found
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:2: [sdh] Assuming drive cache: write through
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:1: [sdg] Attached SCSI removable disk
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:0: [sdf] Attached SCSI removable disk
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:3: [sdi] Media removed, stopped polling
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:3: [sdi] Attached SCSI removable disk
Jun 07 00:16:10 manjaro kernel: sd 9:0:0:2: [sdh] Attached SCSI removable disk
Jun 07 00:16:11 manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Jun 07 00:16:11 manjaro kernel: kauditd_printk_skb: 82 callbacks suppressed
Jun 07 00:16:11 manjaro kernel: audit: type=1130 audit(1654553771.531:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:11 manjaro kernel: audit: type=1130 audit(1654553771.567:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:11 manjaro kernel: audit: type=1130 audit(1654553771.577:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:11 manjaro kernel: audit: type=1130 audit(1654553771.584:52): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:11 manjaro kernel: audit: type=1130 audit(1654553771.587:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lxcfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:11 manjaro kernel: audit: type=1334 audit(1654553771.594:54): prog-id=10 op=LOAD
Jun 07 00:16:11 manjaro kernel: audit: type=1334 audit(1654553771.594:55): prog-id=11 op=LOAD
Jun 07 00:16:11 manjaro kernel: audit: type=1334 audit(1654553771.594:56): prog-id=12 op=LOAD
Jun 07 00:16:11 manjaro kernel: audit: type=1334 audit(1654553771.594:57): prog-id=13 op=LOAD
Jun 07 00:16:11 manjaro kernel: audit: type=1334 audit(1654553771.594:58): prog-id=14 op=LOAD
Jun 07 00:16:11 manjaro polkitd[1386]: Loading rules from directory /etc/polkit-1/rules.d
Jun 07 00:16:11 manjaro polkitd[1386]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 07 00:16:11 manjaro polkitd[1386]: Finished loading, compiling and executing 9 rules
Jun 07 00:16:11 manjaro polkitd[1386]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 07 00:16:12 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000a0000-0x000dffff window]
Jun 07 00:16:12 manjaro kernel: caller _nv000720rm+0x1ad/0x200 [nvidia] mapping multiple BARs
Jun 07 00:16:12 manjaro kernel: usb 3-4: current rate 2338115 is different from the runtime rate 16000
Jun 07 00:16:12 manjaro kernel: usb 3-4: 3:1: cannot get min/max values for control 2 (id 3)
Jun 07 00:16:14 manjaro kernel: watchdog: watchdog0: watchdog did not stop!
Jun 07 00:16:14 manjaro libvirtd[1459]: ignoring missing fifo '/dev/log'
Jun 07 00:16:14 manjaro libvirtd[1459]: ignoring missing fifo '/dev/stderr'
Jun 07 00:16:14 manjaro libvirtd[1459]: ignoring missing fifo '/dev/stdout'
Jun 07 00:16:14 manjaro libvirtd[1459]: ignoring missing fifo '/dev/tty'
Jun 07 00:16:14 manjaro libvirtd[1459]: cannot open directory '/run/media/bastian/Phobos - 250/Iso & utility/Linux/ISO/Arch - Manjaro': Datei oder Verzeichnis nicht gefunden
Jun 07 00:16:14 manjaro libvirtd[1459]: Interner Fehler: Autostart von Speicherpool »Arch_-_Manjaro« fehlgeschlagen: cannot open directory '/run/media/bastian/Phobos - 250/Iso & utility/Linux/ISO/Arch - Manjaro': Datei oder Verzeichnis nicht gefunden
Jun 07 00:16:14 manjaro systemd[1641]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 07 00:16:15 manjaro sddm-greeter[1679]: QFont::fromString: Invalid description '(empty)'
Jun 07 00:16:15 manjaro sddm-greeter[1679]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffc54972b50), parent's thread is QThread(0x55b07bb3ad80), current thread is QThread(0x55b07bc17620)
Jun 07 00:16:15 manjaro sddm-greeter[1679]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jun 07 00:16:15 manjaro kernel: Bridge firewalling registered
Jun 07 00:16:15 manjaro udisksd[1859]: udisks daemon version 2.9.4 starting
Jun 07 00:16:15 manjaro udisksd[1859]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 07 00:16:15 manjaro sddm-greeter[1679]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Dieser Typ von Bilddaten wird nicht unterstützt
Jun 07 00:16:15 manjaro sddm-greeter[1679]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jun 07 00:16:15 manjaro sddm-greeter[1679]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jun 07 00:16:15 manjaro sddm-greeter[1679]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jun 07 00:16:16 manjaro sddm-greeter[1679]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.23'
Jun 07 00:16:16 manjaro kernel: kauditd_printk_skb: 459 callbacks suppressed
Jun 07 00:16:16 manjaro kernel: audit: type=1130 audit(1654553776.864:240): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lxd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:17 manjaro kernel: audit: type=1130 audit(1654553777.231:241): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:17 manjaro kernel: audit: type=1131 audit(1654553777.851:242): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:19 manjaro kernel: audit: type=1100 audit(1654553779.854:243): pid=2207 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="bastian" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:19 manjaro kernel: audit: type=1101 audit(1654553779.857:244): pid=2207 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="bastian" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:19 manjaro kernel: audit: type=1103 audit(1654553779.857:245): pid=2207 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="bastian" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:19 manjaro kernel: audit: type=1006 audit(1654553779.857:246): pid=2207 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jun 07 00:16:19 manjaro kernel: audit: type=1300 audit(1654553779.857:246): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffc99f4dec0 a2=4 a3=7ffc99f4dbd4 items=0 ppid=1463 pid=2207 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
Jun 07 00:16:19 manjaro kernel: audit: type=1327 audit(1654553779.857:246): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746838393766326530352D333264302D346632382D393531372D323232633633613535383030002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Jun 07 00:16:19 manjaro kernel: audit: type=1130 audit(1654553779.901:247): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:19 manjaro systemd[2209]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[bastian] ruser=[<unknown>] rhost=[<unknown>]
Jun 07 00:16:19 manjaro systemd-xdg-autostart-generator[2215]: Configuration file /home/bastian/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jun 07 00:16:20 manjaro systemd-xdg-autostart-generator[2245]: Configuration file /home/bastian/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jun 07 00:16:20 manjaro klauncher[2254]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 07 00:16:21 manjaro kcminit_startup[2258]: QDBusConnection: error: could not send signal to service "" path "//home/bastian/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/bastian/.kde4/share/config/kdeglobals
Jun 07 00:16:21 manjaro kwin_x11[2269]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jun 07 00:16:21 manjaro kwin_x11[2269]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Jun 07 00:16:21 manjaro kded5[2266]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.11'
Jun 07 00:16:21 manjaro ksmserver[2309]: Qt: Session management error: networkIdsList argument is NULL
Jun 07 00:16:21 manjaro kded5[2266]: kscreen.kded: PowerDevil SuspendSession action not available!
Jun 07 00:16:22 manjaro kwin_x11[2269]: kf.plasma.core: Could not locate plasma theme "Aritim-Dark" in plasma/desktoptheme/ using search path ("/home/bastian/.local/share", "/home/bastian/.local/share/flatpak/exports/share", "/var/lib/flatpak/exports/share", "/usr/local/share", "/usr/share", "/var/lib/snapd/desktop")
Jun 07 00:16:22 manjaro kwalletd5[2222]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
Jun 07 00:16:22 manjaro kernel: kauditd_printk_skb: 11 callbacks suppressed
Jun 07 00:16:22 manjaro kernel: audit: type=1130 audit(1654553782.144:257): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:22 manjaro polkitd[1386]: Registered Authentication Agent for unix-session:2 (system bus name :1.38 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8)
Jun 07 00:16:22 manjaro backlighthelper[2382]: org.kde.powerdevil: no kernel backlight interface found
Jun 07 00:16:22 manjaro kwin_x11[2269]: kwin_core: XCB error: 10 (BadAccess), sequence: 848, resource id: 665, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Jun 07 00:16:22 manjaro org_kde_powerdevil[2330]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 07 00:16:22 manjaro org_kde_powerdevil[2330]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 952, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 984, resource id: 31457287, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 988, resource id: 31457288, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: kf.config.core: "\"fsrestore1\" - conversion of \"481,481,0,0\" to QRect failed"
Jun 07 00:16:22 manjaro kwin_x11[2269]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 07 00:16:22 manjaro kwin_x11[2269]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 07 00:16:22 manjaro plasmashell[2325]: kf.plasma.core: Could not locate plasma theme "Aritim-Dark" in plasma/desktoptheme/ using search path ("/home/bastian/.local/share", "/home/bastian/.local/share/flatpak/exports/share", "/var/lib/flatpak/exports/share", "/usr/local/share", "/usr/share", "/var/lib/snapd/desktop")
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1050, resource id: 31457289, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1054, resource id: 31457290, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1081, resource id: 31457291, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1085, resource id: 31457292, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro org_kde_powerdevil[2330]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 07 00:16:22 manjaro org_kde_powerdevil[2330]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1164, resource id: 31457293, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1168, resource id: 31457294, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:22 manjaro kernel: audit: type=1130 audit(1654553782.754:258): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pcscd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:22 manjaro zeitgeist-datah[2484]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
Jun 07 00:16:23 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1273, resource id: 71303173, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:23 manjaro kernel: usb 3-4: current rate 81140 is different from the runtime rate 16000
Jun 07 00:16:23 manjaro kernel: audit: type=1111 audit(1654553783.054:259): pid=1433 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="eno1" ifindex=2 args=500 pid=2443 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:23 manjaro kernel: audit: type=1111 audit(1654553783.081:260): pid=1433 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="64:A2:F9:EA:7F:2B" args=500 pid=2443 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:23 manjaro kernel: usb 3-4: current rate 513 is different from the runtime rate 16000
Jun 07 00:16:23 manjaro kernel: audit: type=1111 audit(1654553783.087:261): pid=1433 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="64:A2:F9:EA:7F:2B" args=500 pid=2443 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:23 manjaro kwin_x11[2269]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jun 07 00:16:23 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:43:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Jun 07 00:16:23 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:41: TypeError: Cannot read property 'length' of undefined
Jun 07 00:16:23 manjaro goa-daemon[2573]: goa-daemon version 3.44.0 starting
Jun 07 00:16:23 manjaro dolphin[2435]: kf.kio.core: "Die Datei oder der Ordner /run/media/bastian/cd098425-5b98-4c61-b970-6d83ad782095 existiert nicht."
Jun 07 00:16:23 manjaro gnome-keyring-daemon[2656]: couldn't access control socket: /run/user/1000/keyring/control: Datei oder Verzeichnis nicht gefunden
Jun 07 00:16:23 manjaro gnome-keyring-d[2656]: couldn't access control socket: /run/user/1000/keyring/control: Datei oder Verzeichnis nicht gefunden
Jun 07 00:16:23 manjaro pulseaudio[2343]: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
Jun 07 00:16:23 manjaro plasmashell[2325]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jun 07 00:16:24 manjaro plasmashell[2325]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:57:9: Unable to assign [undefined] to int
Jun 07 00:16:24 manjaro plasmashell[2325]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/FullRepresentation.qml:28:9: Unable to assign [undefined] to double
Jun 07 00:16:24 manjaro plasmashell[2325]: kf.quickcharts.deprecated: LegendDelegate::colorVisible is deprecated (since 5.82): Use an empty indicator instead
Jun 07 00:16:24 manjaro plasmashell[2325]: kf.quickcharts.deprecated: LegendDelegate::layoutWidth is deprecated (since 5.82): Unused
Jun 07 00:16:24 manjaro plasmashell[2325]: kf.quickcharts.deprecated: LegendDelegate::valueWidth is deprecated (since 5.82): Use maximumValueWidth instead
Jun 07 00:16:24 manjaro plasmashell[2325]: Error: cannot change the containment to AppletsLayout
Jun 07 00:16:24 manjaro plasmashell[2325]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 07 00:16:25 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2732, resource id: 4194328, major code: 18 (ChangeProperty), minor code: 0
Jun 07 00:16:25 manjaro plasmashell[2325]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizontalbars/contents/ui/FullRepresentation.qml:28:9: Unable to assign [undefined] to double
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 07 00:16:25 manjaro plasmashell[2325]: Error: cannot change the containment to AppletsLayout
Jun 07 00:16:25 manjaro plasmashell[2325]: Both point size and pixel size set. Using pixel size.
Jun 07 00:16:25 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:54:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 07 00:16:25 manjaro plasmashell[2325]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 07 00:16:26 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Jun 07 00:16:27 manjaro plasmashell[2325]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55fc6fab2280) QQmlContext(0x55fc6f1d14b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jun 07 00:16:27 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jun 07 00:16:27 manjaro plasmashell[2325]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jun 07 00:16:27 manjaro plasmashell[2325]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55fc6f9f4730) QQmlContext(0x55fc6f1d14b0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jun 07 00:16:28 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4217, resource id: 46137426, major code: 15 (QueryTree), minor code: 0
Jun 07 00:16:28 manjaro plasmashell[2325]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jun 07 00:16:28 manjaro plasmashell[2325]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jun 07 00:16:30 manjaro systemd[1642]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 07 00:16:30 manjaro kernel: audit: type=1131 audit(1654553790.244:262): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:30 manjaro kernel: audit: type=1131 audit(1654553790.287:263): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:31 manjaro kwin_x11[2269]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6019, resource id: 46137444, major code: 15 (QueryTree), minor code: 0
Jun 07 00:16:31 manjaro sudo[2799]: bastian : TTY=pts/1 ; PWD=/home/bastian ; USER=root ; COMMAND=/usr/bin/uname -r
Jun 07 00:16:31 manjaro kernel: audit: type=1100 audit(1654553791.551:264): pid=2799 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="bastian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jun 07 00:16:31 manjaro kernel: audit: type=1101 audit(1654553791.551:265): pid=2799 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="bastian" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jun 07 00:16:31 manjaro kernel: audit: type=1110 audit(1654553791.551:266): pid=2799 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jun 07 00:16:31 manjaro kernel: audit: type=1105 audit(1654553791.551:267): pid=2799 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jun 07 00:16:31 manjaro kernel: audit: type=1106 audit(1654553791.554:268): pid=2799 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jun 07 00:16:31 manjaro kernel: audit: type=1104 audit(1654553791.554:269): pid=2799 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jun 07 00:16:46 manjaro kded5[2266]: kf.service.services: The desktop entry file "/usr/share/applications/qemu.desktop" has Type= "Application" but no Exec line
Jun 07 00:16:46 manjaro kded5[2266]: kf.service.sycoca: Invalid Service : "/usr/share/applications/qemu.desktop"
Jun 07 00:16:47 manjaro kernel: audit: type=1131 audit(1654553807.520:270): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:47 manjaro kernel: audit: type=1334 audit(1654553807.570:271): prog-id=0 op=UNLOAD
Jun 07 00:16:47 manjaro kernel: audit: type=1334 audit(1654553807.570:272): prog-id=0 op=UNLOAD
Jun 07 00:16:47 manjaro kernel: audit: type=1334 audit(1654553807.570:273): prog-id=0 op=UNLOAD
Jun 07 00:16:50 manjaro kernel: audit: type=1701 audit(1654553810.161:274): auid=1000 uid=1000 gid=1001 ses=3 subj==unconfined pid=2217 comm="appimagelaunche" exe="/usr/bin/appimagelauncherd" sig=11 res=1
Jun 07 00:16:50 manjaro kernel: audit: type=1334 audit(1654553810.188:275): prog-id=23 op=LOAD
Jun 07 00:16:50 manjaro kernel: audit: type=1334 audit(1654553810.188:276): prog-id=24 op=LOAD
Jun 07 00:16:50 manjaro kernel: audit: type=1334 audit(1654553810.188:277): prog-id=25 op=LOAD
Jun 07 00:16:50 manjaro kernel: audit: type=1130 audit(1654553810.188:278): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-2847-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:50 manjaro systemd-coredump[2848]: Process 2217 (appimagelaunche) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 370089c88b3a7d60d221324a1342c5e8411e9ae2
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libpangoft2-1.0.so.0 with build-id c2c09f789578900f61b7fca4a4311d8b94d9a750
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libresolv.so.2 with build-id 89a368a6ad1b392d126a2a5beb9c2f61ade00279
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 36db7c21bc57a9b934ad2d3463782db9fef4af07
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id f1c113fea46023cdf62c7e51cb643c45831abdd5
Module libkrb5.so.3 with build-id 9350783c946d77aec8ee8fd9c6bc12f4f7b72be9
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libpangocairo-1.0.so.0 with build-id b65f507d9e33adfbd19369acef5e5a0a2422c6d1
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libboost_atomic.so.1.78.0 with build-id 194f88dfc556fa19a886a23cd9ff3051d7725c08
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libgssapi_krb5.so.2 with build-id 1813217c8baf82a1078772eed0d868310cd59f8b
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libssl.so.1.1 with build-id 25a55106cb13dec5d495c34ca1caf2c2f3114f11
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libnghttp2.so.14 with build-id f2738fead8e6593084b4fb8756f460aa8cf5535a
Module ld-linux-x86-64.so.2 with build-id fc93487393eea02b5bc6e76e48976fc325294c24
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libsystemd.so.0 with build-id cdfc45d8f96e3af51b3d041c32f7899a93b86706
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module librsvg-2.so.2 with build-id 8c033bf594f51f48c7b2ee078fa4586ddb70513a
Module libsquashfuse.so.0 with build-id 450212c2ecbebc35d1bd40b0c3d26c540c482218
Module libarchive.so.13 with build-id 79dc2cbd51eb8ff72ee83974b3244027bd970ea4
Module libboost_filesystem.so.1.78.0 with build-id 1d5e5d4cc25f6c44a946e4b5652265018108443b
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libm.so.6 with build-id 210ec9905e41825671210f8f7d0b24d6c371196a
Module libcurl.so.4 with build-id 8ab1352b26fc2bb50933b8caa480e032b0b7d6b3
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libc.so.6 with build-id 388993b6ef62f964bc7bf473c069fbfe957b9e44
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libstdc++.so.6 with build-id b3eaebcb5369487562e52dd8d016c9cd77f80c54
Module libQt5Core.so.5 with build-id c38b617c7f758f3327a3cf4d1b4168ec8e4db842
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libappimage.so.1.0 with build-id d67ce2a7aa8dd4b46166cf517820f31cfbca1930
Module libQt5Gui.so.5 with build-id f2aced11623934e05c00514f8e891a65700fca20
Module libQt5Widgets.so.5 with build-id 4718220524507280b1711f967e97d6017eaa0d6c
Module libappimageupdate.so with build-id e102343adacf6676d8481a521db2482e6c6b8b3e
Module libQt5DBus.so.5 with build-id 9095840053834c1683ba54020b63d7e545cd0f47
Module appimagelauncherd with build-id 2fafbe9e86541032ce92120998276a7dda1b22c3
Stack trace of thread 2217:
#0 0x00007f95236473d4 local_Rb_tree_increment (libstdc++.so.6 + 0xbf3d4)
#1 0x000055e8ebc675b9 n/a (appimagelauncherd + 0x215b9)
#2 0x000055e8ebc54a4f n/a (appimagelauncherd + 0xea4f)
#3 0x00007f9523a7d791 n/a (libQt5Core.so.5 + 0x2be791)
#4 0x00007f9523a7fb4f _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2c0b4f)
#5 0x00007f9523a708b6 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b18b6)
#6 0x00007f9523a4cfdc _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28dfdc)
#7 0x00007f9523a97003 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d8003)
#8 0x00007f9523a97642 n/a (libQt5Core.so.5 + 0x2d8642)
#9 0x00007f9523d35163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#10 0x00007f9523d8b9e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#11 0x00007f9523d326c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#12 0x00007f9523a977bc _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d87bc)
#13 0x00007f9523a4579c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28679c)
#14 0x00007f9523a502a9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2912a9)
#15 0x000055e8ebc53189 n/a (appimagelauncherd + 0xd189)
#16 0x00007f9523384290 n/a (libc.so.6 + 0x29290)
#17 0x00007f952338434a __libc_start_main (libc.so.6 + 0x2934a)
#18 0x000055e8ebc5369e n/a (appimagelauncherd + 0xd69e)
Jun 07 00:16:50 manjaro systemd[2209]: appimagelauncherd.service: Main process exited, code=dumped, status=11/SEGV
Jun 07 00:16:50 manjaro systemd[2209]: appimagelauncherd.service: Failed with result 'core-dump'.
Jun 07 00:16:53 manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Jun 07 00:16:53 manjaro kernel: audit: type=1131 audit(1654553813.053:283): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 07 00:16:53 manjaro kernel: audit: type=1334 audit(1654553813.192:284): prog-id=0 op=UNLOAD
Jun 07 00:16:53 manjaro kernel: audit: type=1334 audit(1654553813.192:285): prog-id=0 op=UNLOAD
Jun 07 00:16:53 manjaro kernel: audit: type=1334 audit(1654553813.192:286): prog-id=0 op=UNLOAD
so the last log is the dumped core of appimagelauncher, dont think its because of it, but uninstall it and see:
pacman -R appimagelauncher
reboot persits.
and it will even happen before im logged in.
as im facing some graphical glitches could this be a compositor issue ?
is there no way to trace if a process is initiating the shutdown ?
you can check logs with
journalctl --boot=-1 --no-pager
this show you all logs, and you can scrool thru the last one, and check if theres something…
So there is no Solution.
Oh Well I Thank you for your time and effort I at least learned some stuff.
Have a great Evening.
Manjaro in itself is not unstable.
My systems has been using Manjaro for years without major incidents
From my long time using Manjaro - and being present on the forum - I have learned that many issues stem from applying customizations taught by outdated Youtube or using AUR without knowledge of the implications and then -when issues occur - trying to fix those from random sources - again without knowing what really went wrong.
Then the problem goes deeper.
From you log - just above this comment - I see a lot of system inconstencies in the log provided. Various Qt components failing due to invalid functions and configuration.
I wouldn’t be surprised if this is a kind of XY problem - trying to fix the fix which should have fixed an earlier issue
E.g. this looks off to me
A quick search - it belongs to a custom package from AUR.
What other custom packages have you built? Clean your system
sudo pacman -R $(pacman -Qqem)
This also appears off to me - why would the kernel fail to load vbox modules - unless they have been manually removed
Did you ensure your system is fully updated?
Did you use a TTY to run a full sync?
sudo pacman-mirrors -c Global && sudo pacman -Syyu
While you may need to reinstall - I highly recommend 2 things
- Log your changes
- In case of a sudden issue - you can backtrack and hopefully pinpoint the cause
@linux-aarhus Thanks for your time.
Up-to-Date ? manjaro-chroot -a && pacman -Syyu
should do that right ?
While I’m still new to Linux (it’s been 2 1/2 years now) I know a few things and I did not install AUR recently so this is something that is weird. This really is a sudden change that did not occurred after an update. I had been using this system sate for a week without problems.
but AUR definitely can cause instability so I will expect that manjaro-chroot -a
& pacman -R $(pacman -Qqem)
will remove all AUR packages ? and that should auto-magically solve the problem right ?
just to Confirm. And also shouldn’t be there a journal log if a Programm crashes that is critical to the system i mean i don’t expect a full reboot if my terminal or VS Code crashes.
I now remember that i added /dev to a storage pool in Virt-manager. could that have changed permissions of system relevant files ? that now cause a reboot ?
the first reboot happend right when i Installed that VM with /dev/sdj as boot media.
If you are new after 2.5 years then you’ll be new after 20 years.
Doesn’t matter when something was installed.
That is… a lot?
Nice of you that you post something (perhaps) relevant after 50+ posts. Would you maybe try reverting that and test?
I was more concerned with using it, than getting to know the system
Well 53/57 are focused on the same Solution. But well I didn’t think it was relevant as adding it as a pool didn’t have immediate impact, only after a few minutes as I clicked install. But well.
I reverted boot looped 3 times still. But is now stable.
I’m kinda Puzzled, even if that was the cause if something under /dev
wasn’t available to anything shouldn’t there be a message in journal / dmesg ? That seems rather critical to me.
But that seems to be the Solution. Sorry to have “wasted” your time, feel kinda stupid now.
Has to be some kind of sport around here to mark own posts as solutions.
Well I would not mark anything as solution.
