System froze during kernel update, now not booting
During my last system update, which included updating the kernels, everything froze in Plasma. I couldn’t move the mouse or Alt+F2 my way out. I waited for a while in case the update was still going on in the background somehow. Then I killed the system by pressing the power button.
Now, when trying to boot, it says that no kernel is found.
How can I install a kernel again and boot into the system?
And for future reference… :point_down:
Gentle shut down a suddenly hanged PC to minimize a chance of getting a broken filesystem and data loss:
Thank you! I followed the instructions and during the update pacman complained about existing files for the kernel and nvidia packages, so I used “–overwrite “*””, which seemed to fix it.
However, after rebooting two things happened:
  1. Grub doesn’t show any UI - it’s all black until suddenly the system starts to boot.
  2. I have verbose boot mode on, and suddenly I see a lot of red errors. I managed to read something about D-bus (it went by too quickly to read in detail). Afterwards, I’m greeted with a black screen and can do nothing (except Ctrl-Alt Del my way out).
I tried booting back into the live USB doing manjaro-chroot and calling “journalctl -b”, but it says there are no entries. Trying to do the update again states there are no new packages.
What should I do?
So you need to enable grub menu
:mag: “grub menu”
And where am I supposed to type this “grub menu”?
But even if I get the menu to show up it won’t solve the failed boot. How do I find the messages if “journalctl” in manjaro-chroot won’t show them?
EDIT: I managed to get the menu to show again. It seems that it was set to hidden in /etc/default/grub, I changed it back to “menu”.
As for the error I expect is behind the system not booting correctly:
May 13 08:10:41  dbus-broker-launch[869]: Invalid XML in /etc/dbus-1/system.d/org.manjaro.pamac.daemon.conf +1: no element found
May 13 08:10:41  dbus-broker-launch[869]: ERROR run @ ../dbus-broker-36/src/launch/main.c +152: Return code 1
May 13 08:10:41  dbus-broker-launch[869]:       main @ ../dbus-broker-36/src/launch/main.c +178
May 13 08:10:41  dbus-broker-launch[869]: Exiting due to fatal error: -131
May 13 08:10:41  systemd[1]: dbus-broker.service: Main process exited, code=exited, status=1/FAILURE
May 13 08:10:41  systemd[1]: dbus-broker.service: Failed with result 'exit-code'.
May 13 08:10:41  systemd[1]: Failed to start D-Bus System Message Bus.
May 13 08:10:41  systemd[1]: Dependency failed for Network Manager.
May 13 08:10:41  systemd[1]: NetworkManager.service: Job NetworkManager.service/start failed with result 'dependency'.
May 13 08:10:41  systemd[1]: Reached target Network.
May 13 08:10:41  systemd[1]: Starting D-Bus System Message Bus...
May 13 08:10:41  dbus-broker-launch[874]: Invalid XML in /etc/dbus-1/system.d/org.manjaro.pamac.daemon.conf +1: no element found
May 13 08:10:41  dbus-broker-launch[874]: ERROR run @ ../dbus-broker-36/src/launch/main.c +152: Return code 1
May 13 08:10:41  dbus-broker-launch[874]:       main @ ../dbus-broker-36/src/launch/main.c +178
May 13 08:10:41  dbus-broker-launch[874]: Exiting due to fatal error: -131
May 13 08:10:41  dbus-broker-launch[879]: Invalid XML in /etc/dbus-1/system.d/org.manjaro.pamac.daemon.conf +1: no element found
May 13 08:10:41  dbus-broker-launch[879]: ERROR run @ ../dbus-broker-36/src/launch/main.c +152: Return code 1
May 13 08:10:41  dbus-broker-launch[879]:       main @ ../dbus-broker-36/src/launch/main.c +178
May 13 08:10:41  dbus-broker-launch[879]: Exiting due to fatal error: -131
May 13 08:10:41  dbus-broker-launch[884]: Invalid XML in /etc/dbus-1/system.d/org.manjaro.pamac.daemon.conf +1: no element found
May 13 08:10:41  dbus-broker-launch[884]: ERROR run @ ../dbus-broker-36/src/launch/main.c +152: Return code 1
May 13 08:10:41  dbus-broker-launch[884]:       main @ ../dbus-broker-36/src/launch/main.c +178
May 13 08:10:41  dbus-broker-launch[884]: Exiting due to fatal error: -131
May 13 08:10:42  systemd[1]: Failed to start D-Bus System Message Bus.
May 13 08:10:42  systemd[1]: Starting D-Bus System Message Bus...
May 13 08:10:42  dbus-broker-launch[889]: Invalid XML in /etc/dbus-1/system.d/org.manjaro.pamac.daemon.conf +1: no element found
May 13 08:10:42  dbus-broker-launch[889]: ERROR run @ ../dbus-broker-36/src/launch/main.c +152: Return code 1
May 13 08:10:42  dbus-broker-launch[889]:       main @ ../dbus-broker-36/src/launch/main.c +178
May 13 08:10:42  dbus-broker-launch[889]: Exiting due to fatal error: -131
May 13 08:10:42  systemd[1]: dbus-broker.service: Main process exited, code=exited, status=1/FAILURE
May 13 08:10:42  systemd[1]: dbus-broker.service: Failed with result 'exit-code'.
May 13 08:10:42  systemd[1]: dbus-broker.service: Start request repeated too quickly.
May 13 08:10:42  systemd[1]: dbus.socket: Failed with result 'service-start-limit-hit'.
dbus-broker is not my field of expertise !
But maybe you find something related with :mag: “dbus-broker”
:footprints:
:mag: =
I solved the D-bus error by installing it from the other provider.
Now, however, I have no network interfaces when booting into Manjaro. Wifi doesn’t work and it doesn’t recognize any networks at all.
Here are some potentially relevant entries from “journalctl -b”
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: loading /lib/firmware/iwlwifi-9000-pu-b0-jf-b0-46.ucode.zst failed with error -22
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-46.ucode failed with error -22
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-45.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-44.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-43.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-42.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-41.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-40.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-39.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: loading /lib/firmware/iwlwifi-9000-pu-b0-jf-b0-38.ucode.zst failed with error -22
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-38.ucode failed with error -22
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-37.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-36.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-35.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: loading /lib/firmware/iwlwifi-9000-pu-b0-jf-b0-34.ucode.zst failed with error -22
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-34.ucode failed with error -22
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-33.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-32.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-31.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-30.ucode failed with error -2
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: no suitable firmware found!
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: minimum version required: iwlwifi-9000-pu-b0-jf-b0-30
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-9000-pu-b0-jf-b0-46
maj 14 07:48:44  kernel: iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
maj 14 07:48:47  systemd[1]: Started Network Manager Script Dispatcher Service.
maj 14 07:48:47  kernel: r8169 0000:07:00.0: loading /lib/firmware/rtl_nic/rtl8168h-2.fw.zst failed with error -22
maj 14 07:48:47  kernel: r8169 0000:07:00.0: Direct firmware load for rtl_nic/rtl8168h-2.fw failed with error -22
maj 14 07:48:47  kernel: r8169 0000:07:00.0: Unable to load firmware rtl_nic/rtl8168h-2.fw (-22)
maj 14 07:48:47  kernel: Generic FE-GE Realtek PHY r8169-0-700:00: attached PHY driver (mii_bus:phy_addr=r8169-0-700:00, irq=MAC)
maj 14 07:48:47  kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Output of “pacman -Qkk | grep warning”:
warning: accountsservice: /var/lib/AccountsService (Permissions mismatch)
warning: accountsservice: /var/lib/AccountsService/icons (Permissions mismatch)
warning: audit: /etc/libaudit.conf (failed to calculate SHA256 checksum)
warning: audit: /etc/audit/audisp-filter.conf (failed to calculate SHA256 checksum)
warning: audit: /etc/audit/audisp-remote.conf (failed to calculate SHA256 checksum)
warning: audit: /etc/audit/zos-remote.conf (failed to calculate SHA256 checksum)
warning: audit: /etc/audit/plugins.d/af_unix.conf (Lupa evätty)
warning: audit: /etc/audit/plugins.d/au-remote.conf (Lupa evätty)
warning: audit: /etc/audit/plugins.d/audispd-zos-remote.conf (Lupa evätty)
warning: audit: /etc/audit/plugins.d/filter.conf (Lupa evätty)
warning: audit: /etc/audit/plugins.d/syslog.conf (Lupa evätty)
warning: audit: /usr/share/factory/etc/libaudit.conf (failed to calculate SHA256 checksum)
warning: audit: /usr/share/factory/etc/audit/audisp-filter.conf (failed to calculate SHA256 checksum)
warning: audit: /usr/share/factory/etc/audit/audisp-remote.conf (failed to calculate SHA256 checksum)
warning: audit: /usr/share/factory/etc/audit/zos-remote.conf (failed to calculate SHA256 checksum)
warning: audit: /usr/share/factory/etc/audit/plugins.d/af_unix.conf (Lupa evätty)
warning: audit: /usr/share/factory/etc/audit/plugins.d/au-remote.conf (Lupa evätty)
warning: audit: /usr/share/factory/etc/audit/plugins.d/audispd-zos-remote.conf (Lupa evätty)
warning: audit: /usr/share/factory/etc/audit/plugins.d/filter.conf (Lupa evätty)
warning: audit: /usr/share/factory/etc/audit/plugins.d/syslog.conf (Lupa evätty)
warning: bluez: /etc/bluetooth (Permissions mismatch)
warning: cdrtools: /usr/bin/cdda2wav (failed to calculate SHA256 checksum)
warning: cdrtools: /usr/bin/cdrecord (failed to calculate SHA256 checksum)
warning: cdrtools: /usr/bin/readcd (failed to calculate SHA256 checksum)
warning: cdrtools: /usr/bin/rscsi (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/classes.conf (Permissions mismatch)
warning: cups: /etc/cups/classes.conf (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/cups-files.conf (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/cups-files.conf.default (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/cupsd.conf (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/cupsd.conf.default (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/printers.conf (Permissions mismatch)
warning: cups: /etc/cups/printers.conf (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/snmp.conf (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/snmp.conf.default (failed to calculate SHA256 checksum)
warning: cups: /etc/cups/subscriptions.conf (Permissions mismatch)
warning: cups: /etc/cups/subscriptions.conf (failed to calculate SHA256 checksum)
warning: cups: /usr/bin/cupsd (failed to calculate SHA256 checksum)
warning: cups: /usr/share/applications/cups.desktop (Modification time mismatch)
warning: cups: /usr/share/applications/cups.desktop (Size mismatch)
warning: cups: /usr/share/applications/cups.desktop (SHA256 checksum mismatch)
warning: cups: /var/cache/cups/rss (Lupa evätty)
warning: cups: /var/spool/cups/tmp (Lupa evätty)
warning: cups-pdf: /usr/lib/cups/backend/cups-pdf (failed to calculate SHA256 checksum)
warning: dbus: /usr/lib/dbus-1.0/dbus-daemon-launch-helper (failed to calculate SHA256 checksum)
warning: filesystem: /etc/crypttab (failed to calculate SHA256 checksum)
warning: filesystem: /etc/gshadow (failed to calculate SHA256 checksum)
warning: filesystem: /etc/shadow (failed to calculate SHA256 checksum)
warning: filesystem: /usr/share/factory/etc/crypttab (failed to calculate SHA256 checksum)
warning: filesystem: /usr/share/factory/etc/gshadow (failed to calculate SHA256 checksum)
warning: filesystem: /usr/share/factory/etc/shadow (failed to calculate SHA256 checksum)
warning: firefox: /usr/lib/firefox/distribution/distribution.ini (Modification time mismatch)
warning: firefox: /usr/lib/firefox/distribution/distribution.ini (Size mismatch)
warning: firefox: /usr/lib/firefox/distribution/distribution.ini (SHA256 checksum mismatch)
warning: fwupd: /etc/fwupd/fwupd.conf (failed to calculate SHA256 checksum)
error: error while reading file /var/lib/pacman/local/game-devices-udev-0.23-1/mtree: Unrecognized archive format
warning: grub: /etc/grub.d/30_os-prober (Modification time mismatch)
warning: grub: /etc/grub.d/30_os-prober (Size mismatch)
warning: grub: /etc/grub.d/30_os-prober (SHA256 checksum mismatch)
warning: gutenprint: /usr/lib/cups/backend/gutenprint53+usb (failed to calculate SHA256 checksum)
warning: hplip: /usr/lib/cups/backend/hp (failed to calculate SHA256 checksum)
warning: hplip: /usr/lib/cups/backend/hpfax (failed to calculate SHA256 checksum)
error: error while reading file /var/lib/pacman/local/libpamac-11.6.4+1+g3fe0f42-1/mtree: Unrecognized archive format
warning: libutempter: /usr/lib/utempter/utempter (GID mismatch)
warning: libutempter: /usr/lib/utempter/utempter (Permissions mismatch)
error: error while reading file /var/lib/pacman/local/linux-firmware-20240409.1addd7dc-1.0/mtree: Unrecognized archive format
error: error while reading file /var/lib/pacman/local/linux-firmware-whence-20240409.1addd7dc-1.0/mtree: Unrecognized archive format
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.alias (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.alias (Size mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.alias (SHA256 checksum mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.alias.bin (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.alias.bin (Size mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.alias.bin (SHA256 checksum mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.builtin.alias.bin (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.builtin.bin (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.dep (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.dep (Size mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.dep (SHA256 checksum mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.dep.bin (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.dep.bin (Size mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.dep.bin (SHA256 checksum mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.devname (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.softdep (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.symbols (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.symbols (Size mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.symbols (SHA256 checksum mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.symbols.bin (Modification time mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.symbols.bin (Size mismatch)
warning: linux66: /usr/lib/modules/6.6.30-2-MANJARO/modules.symbols.bin (SHA256 checksum mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.alias (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.alias (Size mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.alias (SHA256 checksum mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.alias.bin (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.alias.bin (Size mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.alias.bin (SHA256 checksum mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.builtin.alias.bin (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.builtin.bin (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.dep (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.dep (Size mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.dep (SHA256 checksum mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.dep.bin (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.dep.bin (Size mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.dep.bin (SHA256 checksum mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.devname (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.softdep (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.symbols (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.symbols (Size mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.symbols (SHA256 checksum mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.symbols.bin (Modification time mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.symbols.bin (Size mismatch)
warning: linux68: /usr/lib/modules/6.8.9-3-MANJARO/modules.symbols.bin (SHA256 checksum mismatch)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g0bsinitvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g0bsinitvals9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g0initvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g0initvals9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g1bsinitvals13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g1bsinitvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g1bsinitvals9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g1initvals13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g1initvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/a0g1initvals9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/b0g0bsinitvals13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/b0g0bsinitvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/b0g0bsinitvals9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/b0g0initvals13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/b0g0initvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/b0g0initvals9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ht0bsinitvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ht0bsinitvals29.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ht0initvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ht0initvals29.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn0bsinitvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn0bsinitvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn0bsinitvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn0initvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn0initvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn0initvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn1bsinitvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn1bsinitvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn1bsinitvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn1initvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn1initvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn1initvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn2bsinitvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn2bsinitvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn2bsinitvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn2initvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn2initvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn2initvals26.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn400bsinitvals33.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lcn400initvals33.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0bsinitvals13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0bsinitvals14.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0bsinitvals15.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0bsinitvals16.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0initvals13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0initvals14.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0initvals15.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp0initvals16.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp1bsinitvals20.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp1bsinitvals22.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp1initvals20.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp1initvals22.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp2bsinitvals19.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/lp2initvals19.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0absinitvals11.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0bsinitvals11.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0bsinitvals16.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0bsinitvals17.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0bsinitvals22.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0bsinitvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0bsinitvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0initvals11.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0initvals16.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0initvals17.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0initvals22.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0initvals24.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n0initvals25.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n16bsinitvals30.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n16initvals30.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n18bsinitvals32.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n18initvals32.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n1bsinitvals20.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n1initvals20.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n2bsinitvals19.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/n2initvals19.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/pcm5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn0bsinitvals16.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn0initvals16.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn1bsinitvals20.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn1bsinitvals27.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn1initvals20.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn1initvals27.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn2bsinitvals19.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn2initvals19.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn3bsinitvals21.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn3initvals21.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn4bsinitvals22.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/sslpn4initvals22.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode11.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode13.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode14.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode15.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode16_lp.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode16_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode16_sslpn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode16_sslpn_nobt.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode17_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode19_sslpn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode19_sslpn_nobt.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode20_sslpn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode20_sslpn_nobt.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode21_sslpn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode21_sslpn_nobt.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode22_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode22_sslpn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode24_lcn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode24_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode25_lcn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode25_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode26_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode27_sslpn.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode29_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode30_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode32_mimo.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode33_lcn40.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43/ucode9.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/a0g0bsinitvals2.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/a0g0bsinitvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/a0g0initvals2.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/a0g0initvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/a0g1bsinitvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/a0g1initvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/b0g0bsinitvals2.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/b0g0bsinitvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/b0g0initvals2.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/b0g0initvals5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/pcm4.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/pcm5.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/ucode11.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/ucode2.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/ucode4.fw (Lupa evätty)
warning: manjaro-firmware: /usr/lib/firmware/b43legacy/ucode5.fw (Lupa evätty)
error: error while reading file /var/lib/pacman/local/manjaro-icons-20240502-1/mtree: Unrecognized archive format
error: error while reading file /var/lib/pacman/local/mhwd-0.6.5-36/mtree: Unrecognized archive format
error: error while reading file /var/lib/pacman/local/mhwd-db-0.6.5-36/mtree: Unrecognized archive format
warning: modemmanager: /usr/share/ModemManager/connection.available.d/99-log-event (failed to calculate SHA256 checksum)
warning: modemmanager: /usr/share/ModemManager/fcc-unlock.available.d/105b (failed to calculate SHA256 checksum)
warning: modemmanager: /usr/share/ModemManager/fcc-unlock.available.d/1199 (failed to calculate SHA256 checksum)
warning: modemmanager: /usr/share/ModemManager/fcc-unlock.available.d/1eac (failed to calculate SHA256 checksum)
warning: modemmanager: /usr/share/ModemManager/fcc-unlock.available.d/2c7c (failed to calculate SHA256 checksum)
warning: networkmanager: /usr/lib/NetworkManager/conf.d/20-connectivity.conf (Modification time mismatch)
warning: networkmanager: /usr/lib/NetworkManager/conf.d/20-connectivity.conf (Size mismatch)
warning: networkmanager: /usr/lib/NetworkManager/conf.d/20-connectivity.conf (SHA256 checksum mismatch)
warning: nfs-utils: /usr/bin/mount.nfs (failed to calculate SHA256 checksum)
warning: nfs-utils: /var/lib/nfs/statd/state (Lupa evätty)
warning: nfs-utils: /var/lib/nfs/statd/sm (Lupa evätty)
warning: nfs-utils: /var/lib/nfs/statd/sm.bak (Lupa evätty)
warning: openssh: /usr/lib/ssh/ssh-keysign (failed to calculate SHA256 checksum)
warning: pacman-mirrors: /usr/share/pacman-mirrors/mirrors.json (Modification time mismatch)
warning: pacman-mirrors: /usr/share/pacman-mirrors/mirrors.json (Size mismatch)
warning: pacman-mirrors: /usr/share/pacman-mirrors/mirrors.json (SHA256 checksum mismatch)
warning: ppp: /etc/ppp/chap-secrets (failed to calculate SHA256 checksum)
warning: ppp: /etc/ppp/eaptls-client (failed to calculate SHA256 checksum)
warning: ppp: /etc/ppp/eaptls-server (failed to calculate SHA256 checksum)
warning: ppp: /etc/ppp/pap-secrets (failed to calculate SHA256 checksum)
warning: shadow: /etc/default/useradd (failed to calculate SHA256 checksum)
warning: shadow: /usr/bin/groupmems (GID mismatch)
warning: shadow: /usr/bin/groupmems (Permissions mismatch)
warning: shadow: /usr/bin/groupmems (failed to calculate SHA256 checksum)
warning: sudo: /etc/sudoers (failed to calculate SHA256 checksum)
warning: system-config-printer: /usr/share/applications/system-config-printer.desktop (Modification time mismatch)
warning: system-config-printer: /usr/share/applications/system-config-printer.desktop (Size mismatch)
warning: system-config-printer: /usr/share/applications/system-config-printer.desktop (SHA256 checksum mismatch)
warning: systemd: /var/log/journal (GID mismatch)
warning: thunderbird: /usr/lib/thunderbird/distribution/distribution.ini (Modification time mismatch)
warning: thunderbird: /usr/lib/thunderbird/distribution/distribution.ini (Size mismatch)
warning: thunderbird: /usr/lib/thunderbird/distribution/distribution.ini (SHA256 checksum mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (Modification time mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (Size mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (SHA256 checksum mismatch)
warning: vpnc: /etc/vpnc/default.conf (failed to calculate SHA256 checksum)
Can those warnings be solved by reinstalling all the mentioned packages?
What does that mean?
It may be similar to other like this:
In which case an update is incoming, as mentioned there.
But if you really really need it now you can temporarily follow the downgrade instructions there.
Or if you have no way to download packages then you can use pacman with the cache directly via something like
sudo pacman -U /var/cache/pacman/pkg/linux-firmware-20240409.1addd7dc-any.pkg.tar.zst
It means I followed the instructions here: Failed to start D-Bus after system update
Basically, I re-installed D-bus using the “dbus-daemon-units” package instead of the default dbus-broker one.
I solved the issue with Wifi (writing this in my Manjaro installation now) by reinstalling all packages mentioned by the output in the “pacman -Qkk” command with the “–overwrite ‘*’” flag. Re-running “pacman -Qkk” chrooted in the live USB didn’t then give those errors. However, running the same command booted into Manjaro does return the same errors (even though Wifi works). Is that anything to be worried about?
