just test some more on the test account, and if it still doesnt happen there, log in to your main user, open dolphin/show hidden files, and delete everything in the .cache
folder and reboot, then test … if it still happens, dolphin/show hidden files, and rename the .config
folder to .config.bak
, reboot - new .config
folder will be recreated - and test. If it helped and you dont have any freezes, you can copy from the config.bak
folder to the new recreated .config
folder your program folders, so that you dont have to set them up again, just dont copy there anything plasma related
Well - it just froze using that test config…
SLightly different behavior - the screen goes dark (as always)… then back to the display it was on - no keyboard activity though - then dark… then back… still had to do a hard shut-down to restart.
NOTE: cutting off some of the dump since it is too big…
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: Both point size and pixel size set. Using pixel size.
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:257:9: QML SwipeView: Binding loop detected for property "implicitWidth"
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:271:9: QML Image: Cannot open: file:///home/test/.face
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:0: ReferenceError: modelData is not defined
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
Oct 09 11:18:48 HP-Elitebook systemsettings[1600]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:603:17: QML ColumnLayout: Binding loop detected for property "width"
Oct 09 11:18:50 HP-Elitebook kwin_x11[607]: kwin_core: XCB error: 152 (BadDamage), sequence: 34392, resource id: 18877275, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 11:18:50 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34449, resource id: 62914696, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:18:53 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34853, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38248, resource id: 35651590, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38252, resource id: 46137349, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38308, resource id: 52428805, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38312, resource id: 50331653, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38320, resource id: 33554437, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38327, resource id: 58720315, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: QMetaProperty::read: Unable to handle unregistered datatype 'KWin::SessionState' for property 'KWin::EffectsHandlerImplX11::sessionState'
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38441, resource id: 29360197, major code: 15 (QueryTree), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38446, resource id: 29360219, major code: 25 (SendEvent), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38481, resource id: 29360145, major code: 15 (QueryTree), minor code: 0
Oct 09 11:19:15 HP-Elitebook kwin_x11[607]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38515, resource id: 29360219, major code: 15 (QueryTree), minor code: 0
Oct 09 11:19:16 HP-Elitebook startplasma-x11[535]: org.kde.startup: "kdeinit5_shutdown" () exited with code 255
Oct 09 11:19:16 HP-Elitebook kded5[605]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Oct 09 11:19:16 HP-Elitebook kwalletd5[534]: The X11 connection broke (error 1). Did the X11 server die?
Oct 09 11:19:16 HP-Elitebook kded5[605]: The X11 connection broke: I/O error (code 1)
Oct 09 11:19:16 HP-Elitebook systemd[522]: plasma-kded.service: Failed with result 'exit-code'.
Oct 09 11:19:16 HP-Elitebook kwin_x11[607]: The X11 connection broke: I/O error (code 1)
Oct 09 11:19:16 HP-Elitebook systemd[522]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Oct 09 11:19:16 HP-Elitebook pulseaudio[891]: Error opening PCM device front:0: No such file or directory
Oct 09 11:19:18 HP-Elitebook systemd[1715]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Oct 09 11:19:18 HP-Elitebook systemd[1715]: Failed to start Update XDG user dir configuration.
Oct 09 11:19:18 HP-Elitebook sddm-greeter[1724]: QFont::fromString: Invalid description '(empty)'
Oct 09 11:19:18 HP-Elitebook xdg-desktop-portal-kde[1747]: qt.qpa.xcb: could not connect to display
Oct 09 11:19:18 HP-Elitebook xdg-desktop-portal-kde[1747]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Oct 09 11:19:18 HP-Elitebook sddm-greeter[1724]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffc09178b80), parent's thread is QThread(0x55f261f4e4f0), current thread is QThread(0x55f262091550)
Oct 09 11:19:18 HP-Elitebook sddm-greeter[1724]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Oct 09 11:19:18 HP-Elitebook systemd-coredump[1755]: [🡕] Process 1747 (xdg-desktop-por) of user 964 dumped core.
Module linux-vdso.so.1 with build-id 67833441db018a149e7d23dfead684f2edcb2d3d
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libQt5XcbQpa.so.5 with build-id 22a26a78db099a7a86274c88f67252ec78b8cc41
Module libqxcb.so with build-id 1fdbc58e0182862fe58a8b652b794def082a3ca0
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libudev.so.1 with build-id 8c459883f08a1890f2f1daa9f6eeaae357e9e790
Module libKF5GlobalAccel.so.5 with build-id dfc766d1818cc24b9e82d7dc6977bff57162e616
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id ef3e323faf54271c824851913c119a7767c6bff1
Module libdbus-1.so.3 with build-id 6dece245a58f1549ed98431e1242f487e8ebf9a2
Module libKF5DBusAddons.so.5 with build-id 5eb888d8927faddb8d56c8ff6a693e2cce655e5c
Module ld-linux-x86-64.so.2 with build-id 075a6ad9f1c3f9cbb5f3301186bbe68c6a477808
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libKF5AuthCore.so.5 with build-id da9ff08c6e52c1ef73cfb30a8c37201731c688fc
Module libKF5Crash.so.5 with build-id 5ab2ca0fc5fa2dea833bb39525117bf40b85d137
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libKF5Archive.so.5 with build-id 819ae3371588dfb743e88c23a417bcbcc2a94694
Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
Module libKF5Codecs.so.5 with build-id bf96c60657188e783178682f28ba9db0ea507aa2
Module libKF5WidgetsAddons.so.5 with build-id f0abc3bee1fad21ec45b3188ce079b852e2fee80
Module libKF5GuiAddons.so.5 with build-id d02d92f5bdc155cea56f6c8a709ad60fa56b9317
Module libKF5ConfigWidgets.so.5 with build-id 60a779885da8389a2d94e258c09a9877b10c4b23
Module libQt5Network.so.5 with build-id 4ef4fd4a75511783248e62c378fe446cfa4ccc91
Module libKF5Completion.so.5 with build-id 0b50881b27f40a463706296b458b6f68c99f672d
Module libKF5JobWidgets.so.5 with build-id 58ac1e987656afcbecf92a8400a13f4dbd458a92
Module libKF5KIOGui.so.5 with build-id 15fb3141a045d1d4c63535c25cebe7332ee72efe
Module libKF5Solid.so.5 with build-id e74245c3a71b508d6d27dd5c30fef851c784d4ae
Module libKF5XmlGui.so.5 with build-id 12dbceba1d2c8b4024175f04c32c7ce59921c767
Module libKF5Bookmarks.so.5 with build-id 6008e6c2825cba8cea47c90aa66622d0c7006a57
Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libc.so.6 with build-id 90b9e4f641f8752292698389f241cbf0ff49d687
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libQt5Core.so.5 with build-id 10f403c84cef570e5302c7b1f0d8db34f8293f71
Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
Module libKF5CoreAddons.so.5 with build-id 0c1e61a987dcc5a413145ce6f4b3e9130d478885
Module libKF5I18n.so.5 with build-id 8b01b131521ee05f8dd1cdc649e8989a403f89e2
Module libKF5ConfigCore.so.5 with build-id 3a7aadabb9f7166cacb72f765b328e10c66fbfa8
Module libKF5Service.so.5 with build-id 9aa3259c2748aaa0c6bb8ad3a2d2a5c2a12264d5
Module libKF5KIOCore.so.5 with build-id 259587c6684343e9bd0ea1b998e84d57033cad09
Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
Module libQt5Gui.so.5 with build-id c3306c1f059a4d83b3ece5ca28ce2a147fc154e3
Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
Module libQt5Widgets.so.5 with build-id 7948b4cf67a2e204665689ba69adedcb6ec9f7e7
Module libKF5ConfigGui.so.5 with build-id 7ceed534598952ecd8bf33ad51b7d0b6db177d07
Module libKF5ItemViews.so.5 with build-id 056d51112983ee6da4ebeab5da319f58b3543f3f
Module libQt5PrintSupport.so.5 with build-id c2adb3cc1c1891fbd2099b4285dc59e045edfe1c
Module libKF5IconThemes.so.5 with build-id 4df7a5f6480a88fd05d6643cdf07638b2c76d4cc
Module libKF5WindowSystem.so.5 with build-id afc9a1c136b0d640c853e1f451c15bcda90d0575
Module libKF5KIOWidgets.so.5 with build-id 7c732f0ef6ac9a794468dd6562bcb4fe50bc60fe
Module libKF5KIOFileWidgets.so.5 with build-id 65786d4c4e326b7284b114c610ddbaf28610c974
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libKF5WaylandClient.so.5 with build-id 3bc9e53fdd7340d5d77aa731c529189626b61533
Module libKF5Notifications.so.5 with build-id b80091b385d6d74d1492928b2c465a0bc6822772
Module xdg-desktop-portal-kde with build-id 27e57ac12655c1d88c4f219fb1d0fa5d2f87403c
Stack trace of thread 1747:
#0 0x00007ff97ce1749c n/a (libc.so.6 + 0x8849c)
#1 0x00007ff97cdc7958 raise (libc.so.6 + 0x38958)
#2 0x00007ff97cdb153d abort (libc.so.6 + 0x2253d)
#3 0x00007ff97d24bede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
#4 0x00007ff97dfdeaa5 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13caa5)
#5 0x00007ff97dfdf109 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13d109)
#6 0x00007ff97d43e1ab _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2921ab)
#7 0x00007ff97dfdf1b9 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13d1b9)
#8 0x00007ff97ebbbe0e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175e0e)
#9 0x00005642448580c6 n/a (xdg-desktop-portal-kde + 0x1e0c6)
#10 0x00007ff97cdb2290 n/a (libc.so.6 + 0x23290)
#11 0x00007ff97cdb234a __libc_start_main (libc.so.6 + 0x2334a)
#12 0x0000564244859535 n/a (xdg-desktop-portal-kde + 0x1f535)
Stack trace of thread 1751:
#0 0x00007ff97ce89e5f __poll (libc.so.6 + 0xfae5f)
#1 0x00007ff97b752e2f n/a (libglib-2.0.so.0 + 0xabe2f)
#2 0x00007ff97b6fb0d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
#3 0x00007ff97d48350c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#4 0x00007ff97d43132c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#5 0x00007ff97d29349f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#6 0x00007ff97d6f0cba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007ff97d2902ba n/a (libQt5Core.so.5 + 0xe42ba)
#8 0x00007ff97ce1574d n/a (libc.so.6 + 0x8674d)
#9 0x00007ff97ce97700 n/a (libc.so.6 + 0x108700)
Oct 09 11:19:18 HP-Elitebook systemd[1715]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=6/ABRT
Oct 09 11:19:18 HP-Elitebook systemd[1715]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Oct 09 11:19:18 HP-Elitebook systemd[1715]: Failed to start Xdg Desktop Portal For KDE.
Oct 09 11:19:18 HP-Elitebook sddm-greeter[1724]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Oct 09 11:19:18 HP-Elitebook sddm-greeter[1724]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Oct 09 11:19:18 HP-Elitebook sddm-greeter[1724]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Oct 09 11:19:19 HP-Elitebook sddm-greeter[1724]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Oct 09 11:19:24 HP-Elitebook kernel: kauditd_printk_skb: 19 callbacks suppressed
Oct 09 11:19:24 HP-Elitebook startplasma-x11[1784]: QIODevice::read (QFile, "/home/test/.config/kdedefaults/package"): device not open
Oct 09 11:19:25 HP-Elitebook startplasma-x11[1784]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Oct 09 11:19:25 HP-Elitebook startplasma-x11[1784]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Oct 09 11:19:25 HP-Elitebook startplasma-x11[1784]: QDBusConnection: error: could not send signal to service "" path "//home/test/.config/kdedefaults/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/test/.config/kdedefaults/kdeglobals
Oct 09 11:19:25 HP-Elitebook startplasma-x11[1784]: QDBusConnection: error: could not send signal to service "" path "//home/test/.config/kdedefaults/kcminputrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/test/.config/kdedefaults/kcminputrc
Oct 09 11:19:25 HP-Elitebook startplasma-x11[1784]: QDBusConnection: error: could not send signal to service "" path "//home/test/.config/kdedefaults/kwinrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/test/.config/kdedefaults/kwinrc
Oct 09 11:19:25 HP-Elitebook startplasma-x11[1784]: QPixmap: QGuiApplication must be created before calling defaultDepth().
Oct 09 11:19:25 HP-Elitebook pipewire-media-session[1848]: mod.rt: Can't find xdg-portal: (null)
Oct 09 11:19:25 HP-Elitebook pipewire-media-session[1848]: mod.rt: found session bus but no portal
Oct 09 11:19:25 HP-Elitebook pipewire[1847]: mod.rt: Can't find xdg-portal: (null)
Oct 09 11:19:25 HP-Elitebook pipewire[1847]: mod.rt: found session bus but no portal
Oct 09 11:19:25 HP-Elitebook ksplashqml[1821]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Oct 09 11:19:25 HP-Elitebook ksplashqml[1821]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Oct 09 11:19:26 HP-Elitebook ksmserver[1860]: Qt: Session management error: networkIdsList argument is NULL
Oct 09 11:19:26 HP-Elitebook ksmserver[1860]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.21'
Oct 09 11:19:26 HP-Elitebook systemd[522]: flatpak-session-helper.service: Failed with result 'exit-code'.
Oct 09 11:19:26 HP-Elitebook kwin_x11[1863]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 09 11:19:26 HP-Elitebook kwin_x11[1863]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 09 11:19:26 HP-Elitebook plasmashell[1890]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 09 11:19:26 HP-Elitebook plasmashell[1890]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 09 11:19:26 HP-Elitebook kwin_x11[1863]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Oct 09 11:19:26 HP-Elitebook org_kde_powerdevil[1911]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 09 11:19:26 HP-Elitebook org_kde_powerdevil[1911]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 09 11:19:26 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 11:19:26 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 11:19:26 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Oct 09 11:19:26 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x555c80a1a7c0)
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x555c80a1b1a0)
Oct 09 11:19:27 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x555c80a1b420)
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: QDBusConnection: error: could not send signal to service "" path "/plasma-org.kde.plasma.desktop-appletsrc" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: /plasma-org.kde.plasma.desktop-appletsrc
Oct 09 11:19:28 HP-Elitebook gst-plugin-scan[2117]: type name '-a-png-encoder-pred' contains invalid characters
Oct 09 11:19:28 HP-Elitebook gst-plugin-scan[2117]: g_type_set_qdata: assertion 'node != NULL' failed
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: kde.plasmashell: Activity added twice "9b96362c-cf3c-4e74-8364-3701660123e4"
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: org.kde.klipper: Failed to load history resource. Clipboard history cannot be read. : History file does not exist
Oct 09 11:19:28 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Oct 09 11:19:29 HP-Elitebook breath2tobreath[1970]: QApplication::qAppName: Please instantiate the QApplication object first
Oct 09 11:19:29 HP-Elitebook breath2tobreath[1970]: QSocketNotifier: Can only be used with threads started with QThread
Oct 09 11:19:29 HP-Elitebook breath2tobreath[1970]: QCoreApplication::arguments: Please instantiate the QApplication object first
Oct 09 11:19:29 HP-Elitebook pulseaudio[2111]: Failed to open cookie file '/home/test/.config/pulse/cookie': No such file or directory
Oct 09 11:19:29 HP-Elitebook pulseaudio[2111]: Failed to load authentication key '/home/test/.config/pulse/cookie': No such file or directory
Oct 09 11:19:29 HP-Elitebook pulseaudio[2111]: Failed to open cookie file '/home/test/.pulse-cookie': No such file or directory
Oct 09 11:19:29 HP-Elitebook pulseaudio[2111]: Failed to load authentication key '/home/test/.pulse-cookie': No such file or directory
Oct 09 11:19:29 HP-Elitebook pulseaudio[2111]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x555c80f11ce0)
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x555c80f015a0)
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x555c7fc224f0)
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x555c80eaa310)
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x555c7fc224f0)
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x555c80eaa310)
Oct 09 11:19:29 HP-Elitebook plasmashell[1890]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 09 11:19:29 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 3 (BadWindow), sequence: 3005, resource id: 4194331, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 09 11:19:29 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3006, resource id: 4194331, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 09 11:19:30 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3010, resource id: 4194351, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:30 HP-Elitebook kded5[1862]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.21'
Oct 09 11:19:30 HP-Elitebook kded5[1862]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Oct 09 11:19:30 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/main.qml:30: TypeError: Cannot read property 'longName' of undefined
Oct 09 11:19:30 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/main.qml:75: TypeError: Cannot read property 'displayName' of undefined
Oct 09 11:19:30 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.keyboardlayout/contents/ui/main.qml:68: TypeError: Cannot read property 'shortName' of undefined
Oct 09 11:19:31 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:19:32 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:19:33 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:19:33 HP-Elitebook plasmashell[1890]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 11:19:34 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:23:32: QML Action: Accessible must be attached to an Item
Oct 09 11:19:34 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: Failed to create settings proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: No skeleton to export
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: Error while sending AddMatch() message: The connection is closed
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: Failed to create file chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: Failed to create app chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: Failed to create print proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 09 11:19:34 HP-Elitebook xdg-desktop-por[1728]: Failed to create notification proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 09 11:19:34 HP-Elitebook systemd[1715]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 09 11:19:34 HP-Elitebook systemd[1715]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 09 11:19:34 HP-Elitebook kernel: kauditd_printk_skb: 18 callbacks suppressed
Oct 09 11:19:45 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3871, resource id: 56623114, major code: 15 (QueryTree), minor code: 0
Oct 09 11:19:47 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 11:19:47 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4298, resource id: 29360245, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:19:52 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Oct 09 11:19:53 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Oct 09 11:19:53 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
Oct 09 11:19:53 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
Oct 09 11:19:59 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Oct 09 11:19:59 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
Oct 09 11:19:59 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
Oct 09 11:20:05 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:628:17: QML Loader: Binding loop detected for property "sourceComponent"
Oct 09 11:20:06 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
Oct 09 11:20:06 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
Oct 09 11:20:07 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Oct 09 11:20:08 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Oct 09 11:20:08 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
Oct 09 11:20:08 HP-Elitebook plasmashell[1890]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
Oct 09 11:20:17 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:20:27 HP-Elitebook plasmashell[1890]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555c80c47ac0) QQmlContext(0x555c8120bdd0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 11:20:27 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 11:20:27 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 11:20:27 HP-Elitebook plasmashell[1890]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555c83f94c40) QQmlContext(0x555c8120bdd0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 11:20:28 HP-Elitebook plasmashell[1890]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555c82986db0) QQmlContext(0x555c8120bdd0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 11:20:28 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 11:20:28 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 11:20:31 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 152 (BadDamage), sequence: 21836, resource id: 18876203, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 11:20:34 HP-Elitebook plasmashell[1890]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555c82ff5170) QQmlContext(0x555c8120bdd0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 11:20:34 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 11:20:34 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 11:20:37 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 152 (BadDamage), sequence: 27222, resource id: 18876964, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 11:20:43 HP-Elitebook plasmashell[1890]: trying to show an empty dialog
Oct 09 11:20:45 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 11:21:00 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32443, resource id: 56623230, major code: 15 (QueryTree), minor code: 0
Oct 09 11:26:02 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 11:26:02 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16053, resource id: 29360373, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:26:03 HP-Elitebook dolphin[2975]: org.kde.dolphin: Unknown class "" in session saved data!
Oct 09 11:26:03 HP-Elitebook dolphin[2975]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:26:04 HP-Elitebook dolphin[2975]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:26:05 HP-Elitebook dolphin[2975]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:26:56 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:26:57 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:26:58 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:26:59 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:00 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:01 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:02 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:03 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:04 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:05 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:06 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:07 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:08 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:09 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:10 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:12 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:13 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:13 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 152 (BadDamage), sequence: 29238, resource id: 18887809, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 11:27:14 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:15 HP-Elitebook xdg-desktop-portal-kde[1834]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:19 HP-Elitebook kwin_x11[1863]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 09 11:27:19 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30713, resource id: 18888006, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 11:27:19 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30714, resource id: 18888006, major code: 14 (GetGeometry), minor code: 0
Oct 09 11:27:19 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30717, resource id: 18888006, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 11:27:21 HP-Elitebook dolphin[2975]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 11:27:24 HP-Elitebook plasmashell[1890]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 09 11:27:24 HP-Elitebook plasmashell[1890]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 09 11:27:29 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34078, resource id: 69206021, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:27:31 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34809, resource id: 67108865, major code: 15 (QueryTree), minor code: 0
Oct 09 11:27:31 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35145, resource id: 18888530, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 11:27:31 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 35146, resource id: 18888530, major code: 14 (GetGeometry), minor code: 0
Oct 09 11:29:42 HP-Elitebook plasmashell[1890]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x555c8402b550) QQmlContext(0x555c8120bdd0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 11:29:42 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 11:29:42 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 11:31:27 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39966, resource id: 65011723, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:32:37 HP-Elitebook kscreenlocker_greet[3397]: Qt: Session management error: networkIdsList argument is NULL
Oct 09 11:32:38 HP-Elitebook kscreenlocker_greet[3397]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
Oct 09 11:32:38 HP-Elitebook kscreenlocker_greet[3397]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Oct 09 11:56:24 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42804, resource id: 65011764, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:56:28 HP-Elitebook kwin_x11[1863]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 09 11:56:28 HP-Elitebook kwin_x11[1863]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:56:28 HP-Elitebook kwin_x11[1863]: file:///usr/lib/qt/qml/org/kde/kwin/private/effects/WindowHeap.qml:56:9: Unable to assign null to QUuid
Oct 09 11:56:33 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44035, resource id: 18889276, major code: 20 (GetProperty), minor code: 0
Oct 09 11:56:33 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 152 (BadDamage), sequence: 44130, resource id: 18889832, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 11:56:36 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44863, resource id: 60817429, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:56:36 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44872, resource id: 29360410, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:56:40 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45320, resource id: 18889930, major code: 20 (GetProperty), minor code: 0
Oct 09 11:57:12 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:57:17 HP-Elitebook plasmashell[1890]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 09 11:57:17 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:289:9: QML QQuickItem* (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredWidth"
Oct 09 11:57:17 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:38:5: QML Loader: Binding loop detected for property "height"
Oct 09 11:57:20 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 11:57:20 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:38:5: QML Loader: Binding loop detected for property "height"
Oct 09 11:57:20 HP-Elitebook plasmashell[1890]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/BreadcrumbControl.qml:17:5: Unable to assign [undefined] to QQuickItem*
Oct 09 11:57:33 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56027, resource id: 29360450, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:57:34 HP-Elitebook systemsettings[4223]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Oct 09 11:57:46 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58538, resource id: 60817559, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:57:46 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58546, resource id: 29360451, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:59:17 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10890, resource id: 56623116, major code: 15 (QueryTree), minor code: 0
Oct 09 11:59:17 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11045, resource id: 29360455, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:59:19 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11675, resource id: 18890572, major code: 20 (GetProperty), minor code: 0
Oct 09 11:59:30 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12291, resource id: 4194360, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:59:30 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12301, resource id: 29360456, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:59:35 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12958, resource id: 29360458, major code: 18 (ChangeProperty), minor code: 0
Oct 09 11:59:35 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 12:03:58 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10142, resource id: 29360472, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:04:03 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13197, resource id: 18896554, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 12:04:03 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13198, resource id: 18896554, major code: 14 (GetGeometry), minor code: 0
Oct 09 12:04:03 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13201, resource id: 18896554, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 12:04:03 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13202, resource id: 18896554, major code: 14 (GetGeometry), minor code: 0
Oct 09 12:04:04 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13866, resource id: 18903308, major code: 20 (GetProperty), minor code: 0
Oct 09 12:04:19 HP-Elitebook plasmashell[1890]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 09 12:04:30 HP-Elitebook systemsettings[4942]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Oct 09 12:04:30 HP-Elitebook systemsettings[4942]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 09 12:04:31 HP-Elitebook systemsettings[4942]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 12:04:31 HP-Elitebook systemsettings[4942]: file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:289:9: QML QQuickItem* (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredWidth"
Oct 09 12:04:31 HP-Elitebook systemsettings[4942]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 12:04:41 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19006, resource id: 60817560, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:04:43 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19225, resource id: 69206050, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:04:43 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19253, resource id: 29360496, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:05:48 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27508, resource id: 18904460, major code: 20 (GetProperty), minor code: 0
Oct 09 12:09:23 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57722, resource id: 56623116, major code: 15 (QueryTree), minor code: 0
Oct 09 12:09:24 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57811, resource id: 29360497, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:09:28 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58284, resource id: 4194321, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:09:28 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58296, resource id: 29360498, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:09:30 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58930, resource id: 29360506, major code: 18 (ChangeProperty), minor code: 0
Oct 09 12:09:30 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 12:15:49 HP-Elitebook kscreenlocker_greet[5867]: Qt: Session management error: networkIdsList argument is NULL
Oct 09 12:15:50 HP-Elitebook kscreenlocker_greet[5867]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
Oct 09 12:15:50 HP-Elitebook kscreenlocker_greet[5867]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Oct 09 13:04:38 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18831, resource id: 4194352, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:04:53 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20854, resource id: 18904905, major code: 20 (GetProperty), minor code: 0
Oct 09 13:10:23 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12218, resource id: 29360507, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:10:26 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:10:26 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13340, resource id: 18921849, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 13:10:26 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13341, resource id: 18921849, major code: 14 (GetGeometry), minor code: 0
Oct 09 13:11:53 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28784, resource id: 29360510, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:11:54 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29178, resource id: 18924170, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 13:11:54 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29179, resource id: 18924170, major code: 14 (GetGeometry), minor code: 0
Oct 09 13:12:13 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32801, resource id: 56623115, major code: 15 (QueryTree), minor code: 0
Oct 09 13:12:58 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:12:58 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40020, resource id: 29360515, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:02 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41474, resource id: 18914573, major code: 20 (GetProperty), minor code: 0
Oct 09 13:13:03 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:352: TypeError: Cannot call method 'indexOf' of undefined
Oct 09 13:13:03 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:328: TypeError: Cannot call method 'indexOf' of undefined
Oct 09 13:13:08 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42367, resource id: 29360538, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:08 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42435, resource id: 29360539, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:10 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42994, resource id: 18925556, major code: 20 (GetProperty), minor code: 0
Oct 09 13:13:11 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43308, resource id: 18925709, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 13:13:11 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 43309, resource id: 18925709, major code: 14 (GetGeometry), minor code: 0
Oct 09 13:13:11 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43312, resource id: 18925709, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 13:13:11 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 43313, resource id: 18925709, major code: 14 (GetGeometry), minor code: 0
Oct 09 13:13:12 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:352: TypeError: Cannot read property 'indexOf' of undefined
Oct 09 13:13:12 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:352: TypeError: Cannot call method 'indexOf' of undefined
Oct 09 13:13:12 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:328: TypeError: Cannot call method 'indexOf' of undefined
Oct 09 13:13:13 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 3 (BadWindow), sequence: 43908, resource id: 29360540, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 09 13:13:13 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43909, resource id: 29360540, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 09 13:13:14 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44035, resource id: 29360554, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:14 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44097, resource id: 29360555, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:15 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44341, resource id: 29360557, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:15 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:13:15 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44404, resource id: 29360558, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:21 HP-Elitebook plasmashell[1890]: QMetaObject::invokeMethod: No such method FolderViewDropArea_QMLTYPE_15_QML_54::actionTriggered(QVariant)
Oct 09 13:13:31 HP-Elitebook systemsettings5[7683]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Oct 09 13:13:31 HP-Elitebook systemsettings5[7683]: kf.coreaddons: "Could not load plugin from kcm_kscreen: The shared library was not found."
Oct 09 13:13:31 HP-Elitebook systemsettings5[7683]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 09 13:13:31 HP-Elitebook systemsettings5[7683]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
Oct 09 13:13:37 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49176, resource id: 29360589, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:37 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49244, resource id: 29360590, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:37 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:13:38 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49486, resource id: 29360592, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:38 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:13:38 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49559, resource id: 29360593, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:13:49 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:352: TypeError: Cannot read property 'indexOf' of undefined
Oct 09 13:13:49 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ContextMenu.qml:328: TypeError: Cannot call method 'indexOf' of undefined
Oct 09 13:13:49 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 3 (BadWindow), sequence: 51542, resource id: 29360605, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 09 13:13:49 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51543, resource id: 29360605, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 09 13:13:55 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53865, resource id: 65011715, major code: 15 (QueryTree), minor code: 0
Oct 09 13:14:01 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55317, resource id: 18926748, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 13:14:01 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 55318, resource id: 18926748, major code: 14 (GetGeometry), minor code: 0
Oct 09 13:14:11 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57854, resource id: 18926939, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 13:14:11 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 57855, resource id: 18926939, major code: 14 (GetGeometry), minor code: 0
Oct 09 13:14:49 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63360, resource id: 60817419, major code: 15 (QueryTree), minor code: 0
Oct 09 13:17:16 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21668, resource id: 4194457, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:17:16 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21673, resource id: 29360644, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:17:17 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21835, resource id: 65011723, major code: 15 (QueryTree), minor code: 0
Oct 09 13:29:31 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36385, resource id: 29360645, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:29:31 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:29:33 HP-Elitebook pamac-manager[10227]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 09 13:30:34 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 13:30:34 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46821, resource id: 29360655, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:30:35 HP-Elitebook dolphin[10287]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 13:30:40 HP-Elitebook dolphin[10287]: kf.kio.widgets: Cannot read information about filesystem under path "/home/test/.cache/thumbnails/"
Oct 09 13:30:52 HP-Elitebook kwin_x11[1863]: kwin_core: XCB error: 3 (BadWindow), sequence: 50544, resource id: 60817430, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 09 13:30:52 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50545, resource id: 60817430, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 09 13:31:52 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59926, resource id: 60817489, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:31:52 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59933, resource id: 60817490, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:31:53 HP-Elitebook dolphin[10426]: inotify_add_watch(/home/dklabunde) failed: (Permission denied)
Oct 09 13:31:53 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 09 13:31:53 HP-Elitebook dolphin[10426]: kf.kio.core: "Could not enter folder /home/dklabunde."
Oct 09 13:32:01 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61743, resource id: 69206061, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:32:33 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62967, resource id: 75497478, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:33:57 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65067, resource id: 75497478, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:33:58 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65098, resource id: 75497478, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:34:56 HP-Elitebook baloo_file_extractor[10572]: libpng warning: iCCP: known incorrect sRGB profile
Oct 09 13:34:56 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1310, resource id: 75497478, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:35:05 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1667, resource id: 67108875, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:35:34 HP-Elitebook baloo_file_extractor[10586]: Invalid document structure (docProps is missing)
Oct 09 13:35:36 HP-Elitebook baloo_file_extractor[10586]: Invalid document structure (docProps is missing)
Oct 09 13:35:37 HP-Elitebook baloo_file_extractor[10586]: Invalid document structure (docProps is missing)
Oct 09 13:35:38 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2408, resource id: 67108870, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:36:27 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3688, resource id: 75497478, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:36:29 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3728, resource id: 71303179, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:36:50 HP-Elitebook baloo_file_extractor[10646]: Invalid document structure (docProps is missing)
Oct 09 13:36:50 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4609, resource id: 71303174, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:39:47 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9948, resource id: 73400526, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:39:47 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9961, resource id: 69206062, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:40:13 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15058, resource id: 69206094, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:40:40 HP-Elitebook kwin_x11[1863]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17078, resource id: 67108875, major code: 18 (ChangeProperty), minor code: 0
Oct 09 13:40:58 HP-Elitebook plasmashell[1890]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 09 13:42:46 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10070msec
Oct 09 13:42:46 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:42:46 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:42:47 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:42:47 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:42:47 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:42:47 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:42:47 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:42:58 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10400msec
Oct 09 13:42:58 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:42:58 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:42:59 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:42:59 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:42:59 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:42:59 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:42:59 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:43:09 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10400msec
Oct 09 13:43:09 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:43:10 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:10 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:43:10 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:43:11 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:43:11 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:43:21 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10380msec
Oct 09 13:43:21 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:43:21 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:22 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:22 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:43:22 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:43:22 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:43:22 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:43:32 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10387msec
Oct 09 13:43:32 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:43:33 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:34 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:34 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:43:34 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:43:34 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:43:34 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:43:44 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10390msec
Oct 09 13:43:44 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:43:45 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:45 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:43:45 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:43:46 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:43:46 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:43:56 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10380msec
Oct 09 13:43:56 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:43:56 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:57 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:43:57 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:43:57 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:43:57 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:43:57 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:44:07 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10394msec
Oct 09 13:44:07 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:44:08 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:44:09 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:44:09 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:44:09 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:44:09 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:44:09 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
Oct 09 13:44:19 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10377msec
Oct 09 13:44:19 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000004656f last fence id 0x0000000000046576 on ring 0)
Oct 09 13:44:20 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 13:44:20 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 13:44:20 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 13:44:21 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 13:44:21 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
you have again these:
and from the above logs you have also this:
can't disable ASPM; OS doesn't have ASPM control
so open this file:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT=
inside the quotes add this parameter:
pcie_aspm=off
dont remove anything from there, add it to existing parameters, save the file, update grub:
sudo update-grub
reboot and test in the main user - you dont need to use the test user, since it happens also there, so you can delete it
OK - just to verify this is what grub looks like:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 pcie_aspm=off"
GRUB_CMDLINE_LINUX=""
yes, looks good, save it, update grub: sudo update-grub, reboot and test
WOW - 22 hours and no freeze after that Grub update… BUT… just froze… (thought we were free and clear).
FIRST - I really need to thank you for your efforts. I’m overwhelmed with this support and very grateful. Of course if you are tired of dealing with this - I completely understand. No issues.
Anyway - here is the dump after the latest freezing up. Note - the behavior was a little different… usually the screen goes black without notice - and I’m done. THis time - things froze up - and it was 10 seconds or so before the screen went black.
Oct 09 14:34:40 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 09 14:34:40 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 09 14:34:40 HP-Elitebook kernel: #2 #3 #4 #5 #6 #7
Oct 09 14:34:40 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 09 14:34:40 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 09 14:34:41 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Oct 09 14:34:41 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 09 14:34:41 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 09 14:34:41 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 09 14:34:41 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 09 14:34:41 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 09 14:34:41 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 09 14:34:41 HP-Elitebook systemd[456]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 09 14:34:46 HP-Elitebook kernel: kauditd_printk_skb: 45 callbacks suppressed
Oct 09 14:34:46 HP-Elitebook pipewire[563]: mod.rt: Can't find xdg-portal: (null)
Oct 09 14:34:46 HP-Elitebook pipewire[563]: mod.rt: found session bus but no portal
Oct 09 14:34:46 HP-Elitebook pipewire-media-session[564]: mod.rt: Can't find xdg-portal: (null)
Oct 09 14:34:46 HP-Elitebook pipewire-media-session[564]: mod.rt: found session bus but no portal
Oct 09 14:34:46 HP-Elitebook ksplashqml[546]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Oct 09 14:34:46 HP-Elitebook ksplashqml[546]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Oct 09 14:34:46 HP-Elitebook ksmserver[593]: Qt: Session management error: networkIdsList argument is NULL
Oct 09 14:34:46 HP-Elitebook ksmserver[593]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.19'
Oct 09 14:34:46 HP-Elitebook kwin_x11[596]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 09 14:34:46 HP-Elitebook kwin_x11[596]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 09 14:34:47 HP-Elitebook plasmashell[623]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 09 14:34:47 HP-Elitebook plasmashell[623]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 09 14:34:47 HP-Elitebook kwin_x11[596]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Oct 09 14:34:47 HP-Elitebook org_kde_powerdevil[639]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 09 14:34:47 HP-Elitebook kded5[595]: kscreen.kded: PowerDevil SuspendSession action not available!
Oct 09 14:34:47 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 14:34:47 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 14:34:47 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Oct 09 14:34:47 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Oct 09 14:34:47 HP-Elitebook org_kde_powerdevil[639]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.calculator/contents/ui/calculator.qml:243:5: QML Connections: Detected function "onPopupEvent" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.calculator/contents/ui/calculator.qml:40:5: Unable to assign [undefined] to QString
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 09 14:34:48 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55f64f84ccf0)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55f64f80aa00)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55f64f600e20)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55f64f84cde0)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55f64f600e20)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55f64f706590)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Oct 09 14:34:49 HP-Elitebook pulseaudio[864]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Oct 09 14:34:49 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 2217, resource id: 4194331, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 09 14:34:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2218, resource id: 4194331, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 09 14:34:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2222, resource id: 4194351, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:34:49 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 2228, resource id: 18874406, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 14:34:49 HP-Elitebook plasmashell[623]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 09 14:34:51 HP-Elitebook kernel: kauditd_printk_skb: 5 callbacks suppressed
Oct 09 14:34:51 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:34:51 HP-Elitebook plasmashell[623]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 14:34:52 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:34:53 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:34:54 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:34:54 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:23:32: QML Action: Accessible must be attached to an Item
Oct 09 14:34:55 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:35:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3827, resource id: 29360273, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:35:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3842, resource id: 29360274, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:35:24 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 14:35:31 HP-Elitebook plasmashell[623]: trying to show an empty dialog
Oct 09 14:35:31 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 14:35:31 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6485, resource id: 29360288, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:35:32 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6939, resource id: 18875081, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:35:32 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 6940, resource id: 18875081, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:35:51 HP-Elitebook kwin_x11[596]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 09 14:35:51 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12152, resource id: 18875787, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:35:51 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 12153, resource id: 18875787, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:35:51 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12156, resource id: 18875787, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:35:51 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 12157, resource id: 18875787, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:36:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26623, resource id: 18876387, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:36:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 26624, resource id: 18876387, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:36:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26627, resource id: 18876387, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:36:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 26628, resource id: 18876387, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:36:53 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27544, resource id: 60818325, major code: 15 (QueryTree), minor code: 0
Oct 09 14:38:02 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34609, resource id: 62914571, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:39:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45542, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:41:45 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 164, resource id: 18877844, major code: 20 (GetProperty), minor code: 0
Oct 09 14:41:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1832, resource id: 18882381, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:41:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1833, resource id: 18882381, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:41:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1836, resource id: 18882381, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:41:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1837, resource id: 18882381, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:42:15 HP-Elitebook librewolf[924]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 09 14:43:55 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12179, resource id: 18882493, major code: 20 (GetProperty), minor code: 0
Oct 09 14:46:23 HP-Elitebook librewolf[924]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 09 14:46:24 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f6506cc780) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 14:46:24 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 14:46:24 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 14:46:24 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Oct 09 14:46:24 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Oct 09 14:46:24 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f651f88f00) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 14:48:13 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35036, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:48:16 HP-Elitebook plasmashell[623]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 09 14:48:16 HP-Elitebook plasmashell[623]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 09 14:48:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37570, resource id: 18885889, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:48:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 37571, resource id: 18885889, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:49:47 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47182, resource id: 18883325, major code: 20 (GetProperty), minor code: 0
Oct 09 14:50:25 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51012, resource id: 60821057, major code: 15 (QueryTree), minor code: 0
Oct 09 14:50:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51359, resource id: 4194352, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:50:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51387, resource id: 4194352, major code: 15 (QueryTree), minor code: 0
Oct 09 14:50:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51475, resource id: 4194374, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:54:58 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59586, resource id: 18886930, major code: 20 (GetProperty), minor code: 0
Oct 09 14:55:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60292, resource id: 58720285, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:55:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60316, resource id: 29360385, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:55:06 HP-Elitebook plasmashell[623]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 09 14:55:07 HP-Elitebook plasmashell[623]: kf.kio.gui: Failed to register new cgroup: "app-org.kde.kuserfeedback\\x2dconsole-42e4e6c5ecdd4b5595192c86fd27a88d.scope" "org.freedesktop.DBus.Error.UnixProcessIdUnknown" "Process with ID 2820 does not exist."
Oct 09 14:55:07 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62599, resource id: 29360398, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:55:15 HP-Elitebook plasmashell[623]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: QFSFileEngine::open: No file name specified
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: kf.coreaddons.desktopparser: Error: Failed to open ""
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: QFileDevice::seek: IODevice is not open
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:271:9: QML Image: Cannot open: file:///home/dklabunde/.face?0
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/main.qml:50:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:246:38: QML FocusScope: Binding loop detected for property "contentItemMaximumWidth"
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: Both point size and pixel size set. Using pixel size.
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 14:55:20 HP-Elitebook systemsettings[2824]: libpng warning: iCCP: known incorrect sRGB profile
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: libpng warning: iCCP: known incorrect sRGB profile
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:257:9: QML SwipeView: Binding loop detected for property "implicitWidth"
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:271:9: QML Image: Cannot open: file:///home/dklabunde/.face
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:345: ReferenceError: modelData is not defined
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:603:17: QML ColumnLayout: Binding loop detected for property "width"
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:263:9: QML ActionToolBar: Binding loop detected for property "atBottom"
Oct 09 14:55:21 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:271:9: QML Image: Cannot open: file:///home/test/.face?0
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:246:38: QML FocusScope: Binding loop detected for property "contentItemMaximumWidth"
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: Both point size and pixel size set. Using pixel size.
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:257:9: QML SwipeView: Binding loop detected for property "implicitWidth"
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:271:9: QML Image: Cannot open: file:///home/test/.face
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:345: ReferenceError: modelData is not defined
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
Oct 09 14:55:22 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:603:17: QML ColumnLayout: Binding loop detected for property "width"
Oct 09 14:55:24 HP-Elitebook systemsettings[2824]: QFSFileEngine::open: No file name specified
Oct 09 14:55:24 HP-Elitebook systemsettings[2824]: kf.coreaddons.desktopparser: Error: Failed to open ""
Oct 09 14:55:24 HP-Elitebook systemsettings[2824]: QFileDevice::seek: IODevice is not open
Oct 09 14:55:29 HP-Elitebook polkit-kde-authentication-agent-1[638]: QObject::connect: No such slot AuthDialog::on_userCB_currentIndexChanged(int)
Oct 09 14:55:29 HP-Elitebook polkit-kde-authentication-agent-1[638]: QObject::connect: (sender name: 'userCB')
Oct 09 14:55:29 HP-Elitebook polkit-kde-authentication-agent-1[638]: QObject::connect: (receiver name: 'AuthDialog')
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:246:38: QML FocusScope: Binding loop detected for property "contentItemMaximumWidth"
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: Both point size and pixel size set. Using pixel size.
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:257:9: QML SwipeView: Binding loop detected for property "implicitWidth"
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:271:9: QML Image: Cannot open: file:///home/dklabunde/.face
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/share/kpackage/kcms/kcm_users/contents/ui/UserDetailsPage.qml:345: ReferenceError: modelData is not defined
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
Oct 09 14:55:35 HP-Elitebook systemsettings[2824]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:603:17: QML ColumnLayout: Binding loop detected for property "width"
Oct 09 14:55:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5617, resource id: 4194444, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:55:40 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 14:55:40 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6073, resource id: 29360406, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:55:41 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6569, resource id: 18889727, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:55:41 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 6570, resource id: 18889727, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:55:46 HP-Elitebook dolphin[2875]: inotify_add_watch(/root) failed: (Permission denied)
Oct 09 14:55:46 HP-Elitebook dolphin[2875]: inotify_add_watch(/lost+found) failed: (Permission denied)
Oct 09 14:56:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9210, resource id: 18890025, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 14:56:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 9211, resource id: 18890025, major code: 14 (GetGeometry), minor code: 0
Oct 09 14:56:04 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9687, resource id: 62914589, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:56:04 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9696, resource id: 4194349, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:56:07 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9934, resource id: 58720267, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:56:07 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9938, resource id: 4194350, major code: 18 (ChangeProperty), minor code: 0
Oct 09 14:56:07 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9948, resource id: 29360407, major code: 18 (ChangeProperty), minor code: 0
Oct 09 16:29:32 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52862, resource id: 18888564, major code: 20 (GetProperty), minor code: 0
Oct 09 16:30:09 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56379, resource id: 18905495, major code: 20 (GetProperty), minor code: 0
Oct 09 16:30:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56720, resource id: 18905725, major code: 20 (GetProperty), minor code: 0
Oct 09 16:55:06 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35270, resource id: 29360416, major code: 18 (ChangeProperty), minor code: 0
Oct 09 16:55:11 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 16:55:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39406, resource id: 29360424, major code: 18 (ChangeProperty), minor code: 0
Oct 09 16:55:17 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 16:55:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40328, resource id: 60817413, major code: 18 (ChangeProperty), minor code: 0
Oct 09 16:55:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40877, resource id: 4194305, major code: 15 (QueryTree), minor code: 0
Oct 09 16:55:19 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 40951, resource id: 18926553, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 17:00:41 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13951, resource id: 18905772, major code: 20 (GetProperty), minor code: 0
Oct 09 17:00:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15012, resource id: 18930535, major code: 20 (GetProperty), minor code: 0
Oct 09 17:00:46 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15790, resource id: 18930574, major code: 20 (GetProperty), minor code: 0
Oct 09 17:01:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21700, resource id: 58720672, major code: 15 (QueryTree), minor code: 0
Oct 09 17:01:19 HP-Elitebook xdg-desktop-portal-kde[547]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 17:01:19 HP-Elitebook xdg-desktop-portal-kde[547]: qrc:/AppChooserDialog.qml:106:25: QML Icon: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Kirigami.Icon {
Kirigami.Icon {
Kirigami.Icon {
Kirigami.Icon {
Oct 09 17:01:30 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23609, resource id: 58720771, major code: 15 (QueryTree), minor code: 0
Oct 09 17:01:43 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 17:01:43 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27627, resource id: 29360430, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:01:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28097, resource id: 18931864, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 17:01:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28098, resource id: 18931864, major code: 14 (GetGeometry), minor code: 0
Oct 09 17:01:52 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30679, resource id: 62914581, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:01:52 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30684, resource id: 62914582, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:01:52 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31260, resource id: 62914583, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:02:18 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 09 17:02:33 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38168, resource id: 29360474, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:02:33 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38690, resource id: 29360475, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:02:37 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39301, resource id: 65011723, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:02:37 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39305, resource id: 62914584, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:02:37 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39310, resource id: 29360476, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:02:42 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40715, resource id: 18930664, major code: 20 (GetProperty), minor code: 0
Oct 09 17:03:17 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 48085, resource id: 29360592, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 09 17:03:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48086, resource id: 29360592, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 09 17:03:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48521, resource id: 18933221, major code: 20 (GetProperty), minor code: 0
Oct 09 17:03:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49511, resource id: 18934101, major code: 20 (GetProperty), minor code: 0
Oct 09 17:04:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56198, resource id: 18934147, major code: 20 (GetProperty), minor code: 0
Oct 09 17:04:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56829, resource id: 18934574, major code: 20 (GetProperty), minor code: 0
Oct 09 17:04:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57714, resource id: 18934606, major code: 20 (GetProperty), minor code: 0
Oct 09 17:05:36 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60254, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 09 17:05:55 HP-Elitebook librewolf[10440]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 09 17:05:56 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f652536fd0) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 17:05:56 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 17:05:56 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 17:05:56 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Oct 09 17:05:56 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Oct 09 17:06:01 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 62385, resource id: 18934905, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 18:19:28 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f652a10b20) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 18:19:28 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 18:19:28 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 21:29:00 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f652d6b7e0) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 21:29:00 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 21:29:00 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 00:33:14 HP-Elitebook kernel: kauditd_printk_skb: 1 callbacks suppressed
Oct 10 05:35:04 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f65138ac30) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 05:35:04 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 05:35:04 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 05:35:04 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Oct 10 07:47:05 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18842, resource id: 18934707, major code: 20 (GetProperty), minor code: 0
Oct 10 07:47:06 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19433, resource id: 18992586, major code: 20 (GetProperty), minor code: 0
Oct 10 07:47:09 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20011, resource id: 18992622, major code: 20 (GetProperty), minor code: 0
Oct 10 07:57:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51114, resource id: 18993325, major code: 20 (GetProperty), minor code: 0
Oct 10 08:01:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6485, resource id: 18996847, major code: 20 (GetProperty), minor code: 0
Oct 10 08:02:39 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f6508cd440) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 08:02:39 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 08:02:39 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 08:05:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22483, resource id: 58720986, major code: 15 (QueryTree), minor code: 0
Oct 10 08:05:50 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 10 08:57:02 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30541, resource id: 18999487, major code: 20 (GetProperty), minor code: 0
Oct 10 09:02:07 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35826, resource id: 19012264, major code: 20 (GetProperty), minor code: 0
Oct 10 09:05:24 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f651827860) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 09:05:24 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 09:05:24 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 09:05:29 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 3367, resource id: 19016569, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 09:06:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4066, resource id: 19012995, major code: 20 (GetProperty), minor code: 0
Oct 10 09:11:03 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f650fa6630) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 09:11:03 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 09:11:03 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 09:12:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21980, resource id: 19019520, major code: 20 (GetProperty), minor code: 0
Oct 10 09:12:13 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22716, resource id: 19019558, major code: 20 (GetProperty), minor code: 0
Oct 10 09:17:01 HP-Elitebook librewolf[10440]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:17:08 HP-Elitebook librewolf[10440]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:17:22 HP-Elitebook librewolf[10440]: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown
Oct 10 09:17:53 HP-Elitebook librewolf[10440]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:18:00 HP-Elitebook librewolf[10440]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:18:07 HP-Elitebook librewolf[10440]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:18:11 HP-Elitebook librewolf[10440]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:18:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6870, resource id: 58724992, major code: 15 (QueryTree), minor code: 0
Oct 10 09:18:37 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 10 09:18:37 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9722, resource id: 29360733, major code: 18 (ChangeProperty), minor code: 0
Oct 10 09:18:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10192, resource id: 19025375, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:18:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 10193, resource id: 19025375, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:19:06 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 10 09:19:11 HP-Elitebook librewolf[10440]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:19:14 HP-Elitebook librewolf[10440]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 10 09:19:57 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23885, resource id: 19019971, major code: 20 (GetProperty), minor code: 0
Oct 10 09:19:59 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24489, resource id: 73400331, major code: 18 (ChangeProperty), minor code: 0
Oct 10 09:19:59 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24498, resource id: 71303193, major code: 18 (ChangeProperty), minor code: 0
Oct 10 09:19:59 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24507, resource id: 29360750, major code: 18 (ChangeProperty), minor code: 0
Oct 10 09:23:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31091, resource id: 75497483, major code: 18 (ChangeProperty), minor code: 0
Oct 10 09:25:09 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42359, resource id: 19027386, major code: 20 (GetProperty), minor code: 0
Oct 10 09:25:09 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 42466, resource id: 19028997, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 09:25:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44712, resource id: 19029180, major code: 20 (GetProperty), minor code: 0
Oct 10 09:25:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45218, resource id: 19029213, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:25:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 45219, resource id: 19029213, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:25:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45222, resource id: 19029213, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:25:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 45223, resource id: 19029213, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:25:25 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46289, resource id: 19029259, major code: 20 (GetProperty), minor code: 0
Oct 10 09:26:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52591, resource id: 19029412, major code: 20 (GetProperty), minor code: 0
Oct 10 09:26:17 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 52680, resource id: 19029702, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 09:26:52 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57007, resource id: 19030017, major code: 20 (GetProperty), minor code: 0
Oct 10 09:27:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62430, resource id: 19030029, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:27:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 62431, resource id: 19030029, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:27:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 62434, resource id: 19030029, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:27:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 62435, resource id: 19030029, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:29:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5975, resource id: 19030587, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:29:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5976, resource id: 19030587, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:29:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5979, resource id: 19030587, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:30:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8082, resource id: 19031241, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:30:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 8083, resource id: 19031241, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:30:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8086, resource id: 19031241, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:30:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 8087, resource id: 19031241, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:31:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17849, resource id: 19032034, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:31:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 17850, resource id: 19032034, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:31:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17853, resource id: 19032034, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:31:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 17854, resource id: 19032034, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:32:30 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31948, resource id: 19033312, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:32:30 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 31949, resource id: 19033312, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:32:30 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31952, resource id: 19033312, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:32:30 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 31953, resource id: 19033312, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:32:47 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33991, resource id: 19033450, major code: 20 (GetProperty), minor code: 0
Oct 10 09:33:05 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36335, resource id: 19033644, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:33:05 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 36336, resource id: 19033644, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:33:05 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36339, resource id: 19033644, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:33:05 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 36340, resource id: 19033644, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:33:16 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37628, resource id: 19033732, major code: 20 (GetProperty), minor code: 0
Oct 10 09:33:22 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 10 09:33:26 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 39178, resource id: 60817656, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 09:33:26 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39179, resource id: 60817656, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 09:35:03 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 43116, resource id: 60817681, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 09:35:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43117, resource id: 60817681, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 09:35:06 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 43363, resource id: 60817686, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 09:35:06 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43364, resource id: 60817686, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 09:35:26 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44815, resource id: 19033904, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:35:26 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 44816, resource id: 19033904, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:35:26 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44819, resource id: 19033904, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:35:26 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 44820, resource id: 19033904, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:36:08 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47824, resource id: 19034641, major code: 20 (GetProperty), minor code: 0
Oct 10 09:36:26 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49637, resource id: 19034712, major code: 20 (GetProperty), minor code: 0
Oct 10 09:36:35 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50364, resource id: 19034773, major code: 20 (GetProperty), minor code: 0
Oct 10 09:37:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52976, resource id: 19034980, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 52977, resource id: 19034980, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52980, resource id: 19034980, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 52981, resource id: 19034980, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53675, resource id: 19035020, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53676, resource id: 19035020, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53679, resource id: 19035020, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53680, resource id: 19035020, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:33 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55674, resource id: 19035120, major code: 20 (GetProperty), minor code: 0
Oct 10 09:37:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56509, resource id: 19035182, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 56510, resource id: 19035182, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56513, resource id: 19035182, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 56514, resource id: 19035182, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57465, resource id: 19035226, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 57466, resource id: 19035226, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:37:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57469, resource id: 19035226, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:37:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 57470, resource id: 19035226, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58377, resource id: 19035294, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58378, resource id: 19035294, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58381, resource id: 19035294, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58382, resource id: 19035294, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59949, resource id: 19035385, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 59950, resource id: 19035385, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59953, resource id: 19035385, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 59954, resource id: 19035385, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60816, resource id: 19035442, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 60817, resource id: 19035442, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60820, resource id: 19035442, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:20 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 60821, resource id: 19035442, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61245, resource id: 19035471, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 61246, resource id: 19035471, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:38:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61249, resource id: 19035471, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:38:24 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 61250, resource id: 19035471, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:39:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2487, resource id: 19035965, major code: 20 (GetProperty), minor code: 0
Oct 10 09:40:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4776, resource id: 19035977, major code: 20 (GetProperty), minor code: 0
Oct 10 09:41:14 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7074, resource id: 19036310, major code: 20 (GetProperty), minor code: 0
Oct 10 09:41:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7663, resource id: 19036344, major code: 20 (GetProperty), minor code: 0
Oct 10 09:41:42 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10737, resource id: 19036709, major code: 20 (GetProperty), minor code: 0
Oct 10 09:43:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18061, resource id: 19037695, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:43:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 18062, resource id: 19037695, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:43:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18065, resource id: 19037695, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 09:43:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 18066, resource id: 19037695, major code: 14 (GetGeometry), minor code: 0
Oct 10 09:43:53 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19101, resource id: 19037738, major code: 20 (GetProperty), minor code: 0
Oct 10 09:43:55 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19764, resource id: 19037793, major code: 20 (GetProperty), minor code: 0
Oct 10 09:44:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21673, resource id: 19037933, major code: 20 (GetProperty), minor code: 0
Oct 10 09:44:41 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23787, resource id: 19037977, major code: 20 (GetProperty), minor code: 0
Oct 10 09:45:49 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 27869, resource id: 60817723, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 09:45:49 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27870, resource id: 60817723, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 09:46:16 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 29625, resource id: 60817763, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 09:46:16 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29626, resource id: 60817763, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 09:46:25 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30786, resource id: 19038427, major code: 20 (GetProperty), minor code: 0
Oct 10 09:46:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31541, resource id: 19038721, major code: 20 (GetProperty), minor code: 0
Oct 10 09:46:28 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32213, resource id: 19038763, major code: 20 (GetProperty), minor code: 0
Oct 10 09:46:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33948, resource id: 19038847, major code: 20 (GetProperty), minor code: 0
Oct 10 09:48:09 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38601, resource id: 19039423, major code: 20 (GetProperty), minor code: 0
Oct 10 09:48:13 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 39419, resource id: 19039463, major code: 20 (GetProperty), minor code: 0
Oct 10 10:00:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47472, resource id: 19039508, major code: 20 (GetProperty), minor code: 0
Oct 10 10:55:43 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10390, resource id: 19046099, major code: 20 (GetProperty), minor code: 0
Oct 10 10:56:00 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12747, resource id: 19046421, major code: 20 (GetProperty), minor code: 0
Oct 10 10:56:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15539, resource id: 19046522, major code: 20 (GetProperty), minor code: 0
Oct 10 10:57:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20564, resource id: 19046716, major code: 20 (GetProperty), minor code: 0
Oct 10 10:59:48 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 40252, resource id: 19048892, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 11:01:02 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49553, resource id: 19047214, major code: 20 (GetProperty), minor code: 0
Oct 10 11:01:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50064, resource id: 19049673, major code: 20 (GetProperty), minor code: 0
Oct 10 11:01:41 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52847, resource id: 19050015, major code: 20 (GetProperty), minor code: 0
Oct 10 11:01:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53671, resource id: 19050069, major code: 20 (GetProperty), minor code: 0
Oct 10 11:01:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54375, resource id: 19050126, major code: 20 (GetProperty), minor code: 0
Oct 10 11:01:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55132, resource id: 19050196, major code: 20 (GetProperty), minor code: 0
Oct 10 11:01:57 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55767, resource id: 19050258, major code: 20 (GetProperty), minor code: 0
Oct 10 11:02:02 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56411, resource id: 19050315, major code: 20 (GetProperty), minor code: 0
Oct 10 11:06:51 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 5385, resource id: 60817994, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:06:51 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5386, resource id: 60817994, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:06:58 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 6343, resource id: 60818024, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:06:58 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6344, resource id: 60818024, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:06:59 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 6650, resource id: 60818039, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:06:59 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6651, resource id: 60818039, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:06:59 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 6769, resource id: 60818044, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:06:59 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6770, resource id: 60818044, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:07:23 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 7869, resource id: 60818049, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:07:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7870, resource id: 60818049, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:07:43 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 9126, resource id: 60818064, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:07:43 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9127, resource id: 60818064, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:08:42 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 3 (BadWindow), sequence: 11738, resource id: 60818074, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 11:08:42 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11739, resource id: 60818074, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 11:10:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21353, resource id: 19054057, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 11:10:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 21354, resource id: 19054057, major code: 14 (GetGeometry), minor code: 0
Oct 10 11:10:22 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22225, resource id: 19050357, major code: 20 (GetProperty), minor code: 0
Oct 10 11:10:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22793, resource id: 19054122, major code: 20 (GetProperty), minor code: 0
Oct 10 11:10:25 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23413, resource id: 19054159, major code: 20 (GetProperty), minor code: 0
Oct 10 11:10:40 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25237, resource id: 19054240, major code: 20 (GetProperty), minor code: 0
Oct 10 11:10:43 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25866, resource id: 19054365, major code: 20 (GetProperty), minor code: 0
Oct 10 11:10:47 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///home/dklabunde/Documents/34803.xlsx")
Oct 10 11:11:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30871, resource id: 19054407, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:11 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 30968, resource id: 19054866, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 11:11:12 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31449, resource id: 19054891, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:15 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32061, resource id: 19054924, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:16 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32577, resource id: 19054960, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:17 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33127, resource id: 19054996, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:18 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33698, resource id: 19055033, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34302, resource id: 19055069, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:21 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34850, resource id: 19055108, major code: 20 (GetProperty), minor code: 0
Oct 10 11:11:21 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 34854, resource id: 19055116, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 11:11:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35023, resource id: 4194307, major code: 15 (QueryTree), minor code: 0
Oct 10 11:11:23 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35101, resource id: 29360751, major code: 18 (ChangeProperty), minor code: 0
Oct 10 11:11:29 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35763, resource id: 19055157, major code: 20 (GetProperty), minor code: 0
Oct 10 11:14:12 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46613, resource id: 71303179, major code: 18 (ChangeProperty), minor code: 0
Oct 10 11:16:33 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51070, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 10 11:17:05 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f651fafab0) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 11:17:05 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 11:17:05 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 11:17:07 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f650549e50) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 11:17:07 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 11:17:07 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 11:44:55 HP-Elitebook xdg-desktop-portal-kde[547]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 11:44:55 HP-Elitebook xdg-desktop-portal-kde[547]: qrc:/AppChooserDialog.qml:106:25: QML Icon: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Kirigami.Icon {
Kirigami.Icon {
Kirigami.Icon {
Oct 10 11:45:05 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18898, resource id: 6291515, major code: 15 (QueryTree), minor code: 0
Oct 10 11:49:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60017, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 10 11:51:28 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6615, resource id: 19059777, major code: 20 (GetProperty), minor code: 0
Oct 10 11:56:39 HP-Elitebook librewolf[10440]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 10 12:18:11 HP-Elitebook soffice.bin[10798]: kf.jobwidgets: Cannot register a job with KUiServerV2JobTracker without QGuiApplication::desktopFileName
Oct 10 12:18:16 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: protocol mismatch: "https" vs "file"
Oct 10 12:18:17 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: protocol mismatch: "https" vs "file"
Oct 10 12:18:18 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: protocol mismatch: "https" vs "file"
Oct 10 12:18:19 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: protocol mismatch: "https" vs "file"
Oct 10 12:18:20 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: protocol mismatch: "https" vs "file"
Oct 10 12:18:21 HP-Elitebook soffice.bin[10798]: kf.kio.widgets.kdirmodel: protocol mismatch: "https" vs "file"
Oct 10 12:18:32 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f6533c76c0) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 12:18:32 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 12:18:32 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 12:18:32 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Oct 10 12:18:32 HP-Elitebook plasmashell[623]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Oct 10 12:18:52 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 48868, resource id: 19068582, major code: 20 (GetProperty), minor code: 0
Oct 10 12:18:55 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50246, resource id: 19083097, major code: 20 (GetProperty), minor code: 0
Oct 10 12:19:02 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51019, resource id: 19083173, major code: 20 (GetProperty), minor code: 0
Oct 10 12:19:09 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51877, resource id: 19083217, major code: 20 (GetProperty), minor code: 0
Oct 10 12:19:11 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52532, resource id: 19083256, major code: 20 (GetProperty), minor code: 0
Oct 10 12:19:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54821, resource id: 19083422, major code: 20 (GetProperty), minor code: 0
Oct 10 12:19:30 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55824, resource id: 19083605, major code: 20 (GetProperty), minor code: 0
Oct 10 12:22:42 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1308, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 10 12:23:51 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5911, resource id: 19083671, major code: 20 (GetProperty), minor code: 0
Oct 10 12:23:53 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6543, resource id: 19085848, major code: 20 (GetProperty), minor code: 0
Oct 10 12:23:57 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7220, resource id: 19085887, major code: 20 (GetProperty), minor code: 0
Oct 10 12:24:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14549, resource id: 19086086, major code: 20 (GetProperty), minor code: 0
Oct 10 12:25:36 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20074, resource id: 60818260, major code: 18 (ChangeProperty), minor code: 0
Oct 10 12:25:36 HP-Elitebook soffice.bin[10798]: A KUiServerV2JobTracker instance contains 1 stalled jobs
Oct 10 12:25:36 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20144, resource id: 29360807, major code: 18 (ChangeProperty), minor code: 0
Oct 10 12:28:48 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25798, resource id: 4194305, major code: 15 (QueryTree), minor code: 0
Oct 10 12:28:54 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f6531a73c0) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 12:28:54 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 12:28:54 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 12:28:57 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28780, resource id: 19087824, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:28:57 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 28781, resource id: 19087824, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:29:29 HP-Elitebook plasmashell[623]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55f652267740) QQmlContext(0x55f64fca1c20) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 12:29:29 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 12:29:29 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 12:29:34 HP-Elitebook kwin_x11[596]: kwin_core: XCB error: 152 (BadDamage), sequence: 35281, resource id: 19088345, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 12:30:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38887, resource id: 19086524, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:30:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 38888, resource id: 19086524, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:30:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38891, resource id: 19086524, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:30:27 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 38892, resource id: 19086524, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:31:11 HP-Elitebook plasmashell[623]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 10 12:31:35 HP-Elitebook librewolf[10440]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 10 12:32:06 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54920, resource id: 19089027, major code: 20 (GetProperty), minor code: 0
Oct 10 12:32:08 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55719, resource id: 19090353, major code: 20 (GetProperty), minor code: 0
Oct 10 12:32:45 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59187, resource id: 19090817, major code: 20 (GetProperty), minor code: 0
Oct 10 12:32:47 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60110, resource id: 19090878, major code: 20 (GetProperty), minor code: 0
Oct 10 12:33:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63692, resource id: 19091315, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:33:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 63693, resource id: 19091315, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:33:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63696, resource id: 19091315, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:33:38 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 63697, resource id: 19091315, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:33:54 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 864, resource id: 19091490, major code: 20 (GetProperty), minor code: 0
Oct 10 12:33:58 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1689, resource id: 19091557, major code: 20 (GetProperty), minor code: 0
Oct 10 12:34:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4877, resource id: 19091813, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:34:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4878, resource id: 19091813, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:34:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4881, resource id: 19091813, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 12:34:19 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4882, resource id: 19091813, major code: 14 (GetGeometry), minor code: 0
Oct 10 12:35:42 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16332, resource id: 19091940, major code: 20 (GetProperty), minor code: 0
Oct 10 12:35:43 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17086, resource id: 19092559, major code: 20 (GetProperty), minor code: 0
Oct 10 12:35:44 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17627, resource id: 19092592, major code: 20 (GetProperty), minor code: 0
Oct 10 12:36:03 HP-Elitebook kwin_x11[596]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21460, resource id: 19092944, major code: 20 (GetProperty), minor code: 0
Oct 10 12:36:14 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10364msec
Oct 10 12:36:14 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x0000000000098791 last fence id 0x0000000000098796 on ring 0)
Oct 10 12:36:14 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 10 12:36:15 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 10 12:36:15 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 10 12:36:15 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 10 12:36:15 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 10 12:36:15 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
you have the same errors again, so add another kernel parameter just like you added the aspm=off, add this:
radeon.runpm=0
save grub, update grub, reboot and test
this parameter disables power management on your gpu, so monitor for temperatures/overheating …
if it overheats to much remove the parameter and we try something else
OK - TCO - will watch it again!
THANKS!
Had some system updates - and after - it prompted me to upgrade to a newer kernel… I ignored it.
Currently I’m on the LTS of 5.15.72-1…
Not sure the recommended upgrade… unless you say differently I’ll leave the current kernel in place!
(should I always stick to the LTS kernels? Due to the age/type of video card in my machine?)
Just froze again - new dump below.
Also - here are the grub lines (just to eliminate in case I did it wrong):
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 pcie_aspm=off radeon.runpm=0"
GRUB_CMDLINE_LINUX=""
Oct 10 14:19:51 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 10 14:19:51 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 10 14:19:51 HP-Elitebook kernel: #2 #3 #4 #5 #6 #7
Oct 10 14:19:51 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 10 14:19:51 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 10 14:19:52 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Oct 10 14:19:52 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 10 14:19:52 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 10 14:19:52 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 10 14:19:52 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 10 14:19:52 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 10 14:19:52 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 10 14:19:52 HP-Elitebook systemd[417]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 10 14:19:57 HP-Elitebook kernel: kauditd_printk_skb: 47 callbacks suppressed
Oct 10 14:19:57 HP-Elitebook pipewire[585]: mod.rt: Can't find xdg-portal: (null)
Oct 10 14:19:57 HP-Elitebook pipewire[585]: mod.rt: found session bus but no portal
Oct 10 14:19:57 HP-Elitebook pipewire-media-session[586]: mod.rt: Can't find xdg-portal: (null)
Oct 10 14:19:57 HP-Elitebook pipewire-media-session[586]: mod.rt: found session bus but no portal
Oct 10 14:19:57 HP-Elitebook ksplashqml[568]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Oct 10 14:19:57 HP-Elitebook ksmserver[601]: Qt: Session management error: networkIdsList argument is NULL
Oct 10 14:19:57 HP-Elitebook ksplashqml[568]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Oct 10 14:19:57 HP-Elitebook ksmserver[601]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.19'
Oct 10 14:19:58 HP-Elitebook kwin_x11[604]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 10 14:19:58 HP-Elitebook kwin_x11[604]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 10 14:19:58 HP-Elitebook plasmashell[627]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 10 14:19:58 HP-Elitebook plasmashell[627]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 10 14:19:58 HP-Elitebook kwin_x11[604]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Oct 10 14:19:58 HP-Elitebook org_kde_powerdevil[647]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 10 14:19:58 HP-Elitebook kded5[603]: kscreen.kded: PowerDevil SuspendSession action not available!
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Oct 10 14:19:59 HP-Elitebook org_kde_powerdevil[647]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 10 14:19:59 HP-Elitebook org_kde_powerdevil[647]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.calculator/contents/ui/calculator.qml:243:5: QML Connections: Detected function "onPopupEvent" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.calculator/contents/ui/calculator.qml:40:5: Unable to assign [undefined] to QString
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 10 14:19:59 HP-Elitebook plasmashell[627]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x56217ebe2d80)
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56217eb9fea0)
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x56217e9951e0)
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x56217ebe31b0)
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56217e9951e0)
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x56217ebe31b0)
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 10 14:20:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Oct 10 14:20:00 HP-Elitebook pulseaudio[872]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 10 14:20:01 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Oct 10 14:20:01 HP-Elitebook kwin_x11[604]: kwin_core: XCB error: 3 (BadWindow), sequence: 2368, resource id: 4194331, major code: 129 (SHAPE), minor code: 6 (Input)
Oct 10 14:20:01 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2369, resource id: 4194331, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 10 14:20:01 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2373, resource id: 4194351, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:20:01 HP-Elitebook plasmashell[627]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 10 14:20:03 HP-Elitebook kernel: kauditd_printk_skb: 5 callbacks suppressed
Oct 10 14:20:04 HP-Elitebook plasmashell[627]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 14:20:04 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:23:32: QML Action: Accessible must be attached to an Item
Oct 10 14:20:05 HP-Elitebook plasmashell[627]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 14:20:05 HP-Elitebook plasmashell[627]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 10 14:20:06 HP-Elitebook plasmashell[627]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 14:20:34 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4111, resource id: 29360260, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:20:34 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4136, resource id: 29360284, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:20:35 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4628, resource id: 18874853, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 14:20:35 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4629, resource id: 18874853, major code: 14 (GetGeometry), minor code: 0
Oct 10 14:21:00 HP-Elitebook plasmashell[627]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56217f8c6990) QQmlContext(0x56217f038010) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 14:21:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 14:21:00 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 14:21:00 HP-Elitebook plasmashell[627]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5621813002a0) QQmlContext(0x56217f038010) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 14:21:01 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8922, resource id: 62914571, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:21:01 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8933, resource id: 60817507, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:21:16 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13468, resource id: 58720286, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:21:16 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13479, resource id: 29360324, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:21:20 HP-Elitebook plasmashell[627]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 10 14:21:20 HP-Elitebook plasmashell[627]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 10 14:21:50 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 10 14:21:56 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 10 14:21:58 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23422, resource id: 29360372, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:21:58 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 10 14:22:20 HP-Elitebook kwin_x11[604]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 10 14:22:21 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32216, resource id: 18878447, major code: 20 (GetProperty), minor code: 0
Oct 10 14:22:59 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 10 14:24:05 HP-Elitebook librewolf[1110]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 10 14:24:06 HP-Elitebook plasmashell[627]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56217fcab350) QQmlContext(0x56217f038010) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 14:24:06 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 14:24:06 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 14:24:06 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53696, resource id: 18878764, major code: 20 (GetProperty), minor code: 0
Oct 10 14:24:09 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54934, resource id: 18881462, major code: 20 (GetProperty), minor code: 0
Oct 10 14:24:11 HP-Elitebook kwin_x11[604]: kwin_core: XCB error: 152 (BadDamage), sequence: 56018, resource id: 18881279, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 14:24:14 HP-Elitebook kwin_x11[604]: kwin_core: XCB error: 152 (BadDamage), sequence: 56943, resource id: 18879254, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 14:24:24 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58421, resource id: 18881854, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 14:24:24 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58422, resource id: 18881854, major code: 14 (GetGeometry), minor code: 0
Oct 10 14:24:24 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58425, resource id: 18881854, major code: 3 (GetWindowAttributes), minor code: 0
Oct 10 14:24:24 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 58426, resource id: 18881854, major code: 14 (GetGeometry), minor code: 0
Oct 10 14:24:31 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58757, resource id: 4194315, major code: 18 (ChangeProperty), minor code: 0
Oct 10 14:34:28 HP-Elitebook librewolf[1110]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 10 14:35:53 HP-Elitebook plasmashell[627]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x562181a5e480) QQmlContext(0x56217f038010) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 14:35:53 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 14:35:53 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 14:44:11 HP-Elitebook plasmashell[627]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5621813d1bd0) QQmlContext(0x56217f038010) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 14:44:11 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 14:44:11 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 14:47:22 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19712, resource id: 18882053, major code: 20 (GetProperty), minor code: 0
Oct 10 14:49:51 HP-Elitebook librewolf[1110]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 10 14:57:26 HP-Elitebook plasmashell[627]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5621810d6760) QQmlContext(0x56217f038010) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 10 14:57:26 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 10 14:57:26 HP-Elitebook plasmashell[627]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 10 14:57:31 HP-Elitebook kwin_x11[604]: kwin_core: XCB error: 152 (BadDamage), sequence: 3159, resource id: 18900528, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 10 15:04:24 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28967, resource id: 18894723, major code: 20 (GetProperty), minor code: 0
Oct 10 15:39:11 HP-Elitebook kwin_x11[604]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51846, resource id: 62914957, major code: 15 (QueryTree), minor code: 0
Oct 10 15:39:51 HP-Elitebook xdg-desktop-portal-kde[569]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:239:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 10 15:40:46 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10104msec
Oct 10 15:40:46 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x0000000000013a7d last fence id 0x0000000000013a8f on ring 0)
Oct 10 15:40:47 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 10 15:40:47 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 10 15:40:47 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 10 15:40:48 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 10 15:40:48 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
ok, again the same errors …
open this file:
kate /etc/environment
and inside it put this line:
QT_LOGGING_RULES='*=false'
save the file. this will disable the useless qt/kwin logs, so that those log output are more readable
the grub looks ok, so add again another parameters:
radeon.modeset=1 radeon.drm=1
then edit this line in grub to look like this:
GRUB_TIMEOUT_STYLE=menu
save the grub, update grub, reboot and test;
this will make your grub being shown during boot, so if for whatever reason you cant boot with these parameter, press ‘E’ in the grub menu, locate the parameters and remove them…
also install the 5.10 lts kernel from system settings/kernel, and if you have freezes with 5.15, switch to the 5.10 in grub/advanced options (dont select the fallback one), and test if you have freezes also with the 5.10;
OK - have done these - as always here is my grub (again, just to remove the possibility of my making an error):
GRUB_DEFAULT=saved GRUB_TIMEOUT=5 GRUB_TIMEOUT_STYLE=menu GRUB_DISTRIBUTOR="Manjaro" GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 pcie_aspm=off radeon.runpm=0 radeon.modeset=1 radeon.drm=1" GRUB_CMDLINE_LINUX=""
I have noticed/wondered if some of this is related to how hot this system gets… fans are cycling on/off pretty regularly. I installed a temp monitor and will watch that and see if I see if freezes happen when the system reaches a certain temp. I’m also going to do a physical check for my fans - make sure they are physically working… and not clogged or broken.
I found this thread - any value into looking into it: FanControl
There was another thread that seemed similar to my issue - where there is a swap issue that causes a similar freeze? Is that worth pursuing? Freezing
the grub looks ok, so test with the parameters, and yes monitor the temps and clean the fans…
the fans start to spin at around 50C, and as you mentioned they do spin, so that means they working … so at this time fancontrol si not needed, since we didnt established that the reason is overheating…
and you have 24 gb of ram, so swap is needed when you run out of ram, so that your system doesnt crash… however you have the radeon logs when the freeze happens, so its definitely not related to you running out of ram…
Ok - thanks for that…
So here is the latest dump after a freeze. I don’t think it is temp or fan related… fan is clean and runs fine - temp was fine also when it last froze.
Is this related to Manjaro - or hardware or ?? … would a different OS distro be worth trying? (mainly as a test as I really want to stay on Manjaro)
Oct 11 14:37:31 HP-Elitebook kernel: tsc: Unable to calibrate against PIT
Oct 11 14:37:31 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 11 14:37:31 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 11 14:37:31 HP-Elitebook kernel: #2 #3 #4 #5 #6 #7
Oct 11 14:37:31 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 11 14:37:31 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 11 14:37:31 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
Oct 11 14:37:31 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Oct 11 14:37:31 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Oct 11 14:37:31 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
Oct 11 14:37:31 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 11 14:37:32 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 11 14:37:32 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 11 14:37:32 HP-Elitebook systemd[421]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 11 14:37:32 HP-Elitebook kernel: radeon: unknown parameter 'drm' ignored
Oct 11 14:37:36 HP-Elitebook kernel: kauditd_printk_skb: 39 callbacks suppressed
Oct 11 14:37:37 HP-Elitebook pipewire[577]: mod.rt: Can't find xdg-portal: (null)
Oct 11 14:37:37 HP-Elitebook pipewire[577]: mod.rt: found session bus but no portal
Oct 11 14:37:37 HP-Elitebook pipewire-media-session[578]: mod.rt: Can't find xdg-portal: (null)
Oct 11 14:37:37 HP-Elitebook pipewire-media-session[578]: mod.rt: found session bus but no portal
Oct 11 14:37:40 HP-Elitebook pulseaudio[866]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 11 14:37:42 HP-Elitebook kernel: kauditd_printk_skb: 7 callbacks suppressed
Oct 11 14:52:30 HP-Elitebook librewolf[948]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 11 18:06:30 HP-Elitebook pamac-manager[3385]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 11 18:07:24 HP-Elitebook kernel: kauditd_printk_skb: 25 callbacks suppressed
Oct 11 18:36:10 HP-Elitebook librewolf[948]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 11 18:40:34 HP-Elitebook librewolf[948]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 11 18:45:36 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10407msec
Oct 11 18:45:36 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000002b953 last fence id 0x000000000002b961 on ring 0)
Oct 11 18:45:37 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
did it also happened with the 5.10 kernel as mentioned above?
if it did, switch back to 5.15 and lets try different parameters, but first remove these:
and replace them with this one:
radeon.dpm=0
save the grub, update grub, reboot and test…
if it again freezes, add another paramer:
radeon.hard_reset=1
again, save and update grub, reboot and test
could be a software + hardware issues, since you mention it happen only using browsers, so its possible that it would be present on other distros… lets try to fix it here, and if it doesnt work, you can then try for example manjaro xfce edition, or other non arch distro…
Changes made - and yes - it froze on 5.10 also.
As always here is my grub:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 pcie_aspm=off radeon.dpm=0"
Since the last change (didn’t need to add this parameter yet: radeon.hard_reset=1
) - I’ve not frozen up…
Hard to say for certain whether this has been browser based… as I spend at least 98% of my time in a browser on this device…
This machine does tend to run hot - the fan is a bit noisy and is on most of the time… as I monitor the temp it runs from 70-95c regularly…
But - it is a pretty decent workstation and with Manjaro - it will keep me from needing to buy something else!
Great stuff - we’ll keep our fingers crossed…
wow, thats a lot for only using browsers… of course if you are watching 4k videos the temps could be justified
No freezes ,
Looking good. Thank you very very much for the support.
Would you mind sharing what the fix is resolving?
it disables dynamic power management (dpm)…
there is another parameter that disables bidirectional application power management: radeon.bapm=0
and what were the temps before applying the parameter?
