System freezing - intermittent
This thing has always run hot. I can’t say whether it is running hotter now or not.
Should I give that addl parameter a try? If so, add it or in place of
well if it works now with radeon.dpm=0 and the pc was running always hot, i dont see a reason for radeon.bapm=0
but if you want to try it out if the temps are lower with the bapm parameter you can, so in that case you replace the dpm one with the bapm one, save grub, update grub, reboot and test
Changed grub with this setting: `radeon.bapm=0’
Fyi… Froze within minutes
so its the radeon.dpm=0 for you …
and check again logs, it you still have them:
journalctl -b0 -p4 --no-pager
No logs from the bapm freeze, I’d be very happy to change parameters to get a freeze and subsequent logs if you’d find them beneficial
no, i worded it wrong. I meant to check logs again with the radeon.dpm=0 parameter, to see if you still have some radeon errors…
also porvide additional dmesg logs:
sudo dmesg -l err,warn,emerg,alert,crit
Logs (but not sure if still useful as I was powered off over the weekend):
Oct 17 09:36:56 HP-Elitebook kernel: tsc: Unable to calibrate against PIT
Oct 17 09:36:56 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 17 09:36:56 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 17 09:36:56 HP-Elitebook kernel:  #2 #3 #4 #5 #6 #7
Oct 17 09:36:56 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 17 09:36:56 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 17 09:36:56 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Oct 17 09:36:56 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 17 09:36:56 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 17 09:36:56 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 17 09:36:56 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 17 09:36:57 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 17 09:36:57 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 17 09:36:57 HP-Elitebook systemd[431]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 17 09:37:01 HP-Elitebook pipewire[588]: mod.rt: Can't find xdg-portal: (null)
Oct 17 09:37:01 HP-Elitebook pipewire[588]: mod.rt: found session bus but no portal
Oct 17 09:37:01 HP-Elitebook pipewire-media-session[589]: mod.rt: Can't find xdg-portal: (null)
Oct 17 09:37:01 HP-Elitebook pipewire-media-session[589]: mod.rt: found session bus but no portal
Oct 17 09:37:01 HP-Elitebook kernel: kauditd_printk_skb: 50 callbacks suppressed
Oct 17 09:37:03 HP-Elitebook kernel: ------------[ cut here ]------------
Oct 17 09:37:03 HP-Elitebook kernel: WARNING: CPU: 1 PID: 506 at drivers/gpu/drm/ttm/ttm_bo.c:409 ttm_bo_release+0x2e9/0x310 [ttm]
Oct 17 09:37:03 HP-Elitebook kernel: Modules linked in: rfcomm ccm intel_rapl_msr qrtr intel_rapl_common ns iwldvm snd_ctl_led snd_hda_codec_idt x86_pkg_temp_thermal bnep mac80211 snd_hda_codec_generic intel_powerclamp crct10dif_pclmul ledtrig_audio crc32_pclmul coretemp snd_hda_codec_hdmi libarc4 uvcvideo ghash_clmulni_intel snd_hda_intel videobuf2_vmalloc btusb snd_intel_dspcfg aesni_intel iwlwifi ppdev hp_wmi snd_intel_sdw_acpi iTCO_wdt videobuf2_memops btrtl crypto_simd videobuf2_v4l2 intel_pmc_bxt sparse_keymap cryptd tpm_infineon mei_wdt wmi_bmof btbcm platform_profile iTCO_vendor_support snd_hda_codec rapl btintel videobuf2_common intel_cstate snd_hda_core bluetooth psmouse cfg80211 intel_uncore snd_hwdep pcspkr snd_pcm joydev videodev tpm_tis mousedev radeon mc ecdh_generic parport_pc tpm_tis_core snd_timer rfkill mei_me wmi parport snd tpm hp_accel drm_ttm_helper e1000e rng_core video lis3lv02d mac_hid mei soundcore lpc_ich ttm fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2
Oct 17 09:37:03 HP-Elitebook kernel:  hid_logitech_hidpp hid_logitech_dj serio_raw atkbd libps2 firewire_ohci sdhci_pci cqhci crc32c_intel sr_mod sdhci firewire_core i8042 cdrom usbhid mmc_core xhci_pci crc_itu_t serio
Oct 17 09:37:03 HP-Elitebook kernel: CPU: 1 PID: 506 Comm: Xorg Not tainted 5.15.74-3-MANJARO #1 6719dea2e0f43080bcbb84589c5fe78ca0af8a1c
Oct 17 09:37:03 HP-Elitebook kernel: Hardware name: Hewlett-Packard HP EliteBook 8560w (B2A76UT)/1631, BIOS 68SVD Ver. F.22 01/05/2012
Oct 17 09:37:03 HP-Elitebook kernel: RIP: 0010:ttm_bo_release+0x2e9/0x310 [ttm]
Oct 17 09:37:03 HP-Elitebook kernel: Code: e8 cc b3 7c de e9 b2 fd ff ff 49 8b 7e 98 b9 28 23 00 00 31 d2 be 01 00 00 00 e8 e2 d6 7c de 49 8b 46 e8 eb 9e 48 89 e8 eb 99 <0f> 0b e9 38 fd ff ff e8 5b b1 7c de e9 ef fe ff ff be 03 00 00 00
Oct 17 09:37:03 HP-Elitebook kernel: RSP: 0018:ffffb3aa80a73df8 EFLAGS: 00010202
Oct 17 09:37:03 HP-Elitebook kernel: RAX: 0000000000000001 RBX: ffffb3aa80a73e40 RCX: 0000000000000001
Oct 17 09:37:03 HP-Elitebook kernel: RDX: ffff8d67c7dc71d8 RSI: 0000000000000000 RDI: ffff8d67c7dc71d8
Oct 17 09:37:03 HP-Elitebook kernel: RBP: ffff8d67d41146f0 R08: 0000000000000000 R09: 0000000000000000
Oct 17 09:37:03 HP-Elitebook kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff8d67e668df58
Oct 17 09:37:03 HP-Elitebook kernel: R13: ffff8d67c7dc7078 R14: ffff8d67c7dc71d8 R15: 0000000000000000
Oct 17 09:37:03 HP-Elitebook kernel: FS:  00007f4ceb2960c0(0000) GS:ffff8d6ce5c40000(0000) knlGS:0000000000000000
Oct 17 09:37:03 HP-Elitebook kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Oct 17 09:37:03 HP-Elitebook kernel: CR2: 00007f4ceb194000 CR3: 000000010b062002 CR4: 00000000000606e0
Oct 17 09:37:03 HP-Elitebook kernel: Call Trace:
Oct 17 09:37:03 HP-Elitebook kernel:  <TASK>
Oct 17 09:37:03 HP-Elitebook kernel:  radeon_bo_unref+0x1a/0x30 [radeon 3f215497a44c006693127ef1f6afc6b4bc21a17a]
Oct 17 09:37:03 HP-Elitebook kernel:  radeon_gem_object_free+0x30/0x60 [radeon 3f215497a44c006693127ef1f6afc6b4bc21a17a]
Oct 17 09:37:03 HP-Elitebook kernel:  drm_gem_dmabuf_release+0x36/0x50
Oct 17 09:37:03 HP-Elitebook kernel:  dma_buf_release+0x42/0xa0
Oct 17 09:37:03 HP-Elitebook kernel:  __dentry_kill+0xfe/0x170
Oct 17 09:37:03 HP-Elitebook kernel:  __fput+0xd8/0x240
Oct 17 09:37:03 HP-Elitebook kernel:  task_work_run+0x5c/0xa0
Oct 17 09:37:03 HP-Elitebook kernel:  exit_to_user_mode_prepare+0x183/0x190
Oct 17 09:37:03 HP-Elitebook kernel:  syscall_exit_to_user_mode+0x23/0x50
Oct 17 09:37:03 HP-Elitebook kernel:  do_syscall_64+0x67/0x90
Oct 17 09:37:03 HP-Elitebook kernel:  ? do_syscall_64+0x67/0x90
Oct 17 09:37:03 HP-Elitebook kernel:  ? syscall_exit_to_user_mode+0x23/0x50
Oct 17 09:37:03 HP-Elitebook kernel:  entry_SYSCALL_64_after_hwframe+0x61/0xcb
Oct 17 09:37:03 HP-Elitebook kernel: RIP: 0033:0x7f4cebc0bc0f
Oct 17 09:37:03 HP-Elitebook kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
Oct 17 09:37:03 HP-Elitebook kernel: RSP: 002b:00007ffe062bdb80 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Oct 17 09:37:03 HP-Elitebook kernel: RAX: 0000000000000000 RBX: 0000557b1e7e25f0 RCX: 00007f4cebc0bc0f
Oct 17 09:37:03 HP-Elitebook kernel: RDX: 00007ffe062bdc28 RSI: 0000000040086409 RDI: 0000000000000014
Oct 17 09:37:03 HP-Elitebook kernel: RBP: 00007ffe062bdc28 R08: 0000000000000011 R09: 0000000000000000
Oct 17 09:37:03 HP-Elitebook kernel: R10: 0000557b1d919010 R11: 0000000000000246 R12: 0000000040086409
Oct 17 09:37:03 HP-Elitebook kernel: R13: 0000000000000014 R14: 0000557b1e80e980 R15: 0000557b1e80edd0
Oct 17 09:37:03 HP-Elitebook kernel:  </TASK>
Oct 17 09:37:03 HP-Elitebook kernel: ---[ end trace fd62f38a38a7e29a ]---
Oct 17 09:37:05 HP-Elitebook pulseaudio[897]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 17 09:37:07 HP-Elitebook kernel: kauditd_printk_skb: 7 callbacks suppressed
 0.026666] tsc: Unable to calibrate against PIT
[    0.000682] x86/cpu: VMX (outside TXT) disabled by BIOS
[    0.025993] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.025993]  #2 #3 #4 #5 #6 #7
[    0.053448] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.053456] mtrr: your CPUs had inconsistent variable MTRR settings
[    6.377679] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
[    6.377690] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[    6.377695] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[    6.377699] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[    6.377703] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    7.078807] iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
[    7.079034] iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
[   11.742235] kauditd_printk_skb: 50 callbacks suppressed
[   13.344290] ------------[ cut here ]------------
[   13.344295] WARNING: CPU: 1 PID: 506 at drivers/gpu/drm/ttm/ttm_bo.c:409 ttm_bo_release+0x2e9/0x310 [ttm]
[   13.344306] Modules linked in: rfcomm ccm intel_rapl_msr qrtr intel_rapl_common ns iwldvm snd_ctl_led snd_hda_codec_idt x86_pkg_temp_thermal bnep mac80211 snd_hda_codec_generic intel_powerclamp crct10dif_pclmul ledtrig_audio crc32_pclmul coretemp snd_hda_codec_hdmi libarc4 uvcvideo ghash_clmulni_intel snd_hda_intel videobuf2_vmalloc btusb snd_intel_dspcfg aesni_intel iwlwifi ppdev hp_wmi snd_intel_sdw_acpi iTCO_wdt videobuf2_memops btrtl crypto_simd videobuf2_v4l2 intel_pmc_bxt sparse_keymap cryptd tpm_infineon mei_wdt wmi_bmof btbcm platform_profile iTCO_vendor_support snd_hda_codec rapl btintel videobuf2_common intel_cstate snd_hda_core bluetooth psmouse cfg80211 intel_uncore snd_hwdep pcspkr snd_pcm joydev videodev tpm_tis mousedev radeon mc ecdh_generic parport_pc tpm_tis_core snd_timer rfkill mei_me wmi parport snd tpm hp_accel drm_ttm_helper e1000e rng_core video lis3lv02d mac_hid mei soundcore lpc_ich ttm fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2
[   13.344362]  hid_logitech_hidpp hid_logitech_dj serio_raw atkbd libps2 firewire_ohci sdhci_pci cqhci crc32c_intel sr_mod sdhci firewire_core i8042 cdrom usbhid mmc_core xhci_pci crc_itu_t serio
[   13.344392] CPU: 1 PID: 506 Comm: Xorg Not tainted 5.15.74-3-MANJARO #1 6719dea2e0f43080bcbb84589c5fe78ca0af8a1c
[   13.344399] Hardware name: Hewlett-Packard HP EliteBook 8560w (B2A76UT)/1631, BIOS 68SVD Ver. F.22 01/05/2012
[   13.344403] RIP: 0010:ttm_bo_release+0x2e9/0x310 [ttm]
[   13.344418] Code: e8 cc b3 7c de e9 b2 fd ff ff 49 8b 7e 98 b9 28 23 00 00 31 d2 be 01 00 00 00 e8 e2 d6 7c de 49 8b 46 e8 eb 9e 48 89 e8 eb 99 <0f> 0b e9 38 fd ff ff e8 5b b1 7c de e9 ef fe ff ff be 03 00 00 00
[   13.344422] RSP: 0018:ffffb3aa80a73df8 EFLAGS: 00010202
[   13.344428] RAX: 0000000000000001 RBX: ffffb3aa80a73e40 RCX: 0000000000000001
[   13.344431] RDX: ffff8d67c7dc71d8 RSI: 0000000000000000 RDI: ffff8d67c7dc71d8
[   13.344435] RBP: ffff8d67d41146f0 R08: 0000000000000000 R09: 0000000000000000
[   13.344438] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8d67e668df58
[   13.344441] R13: ffff8d67c7dc7078 R14: ffff8d67c7dc71d8 R15: 0000000000000000
[   13.344455] FS:  00007f4ceb2960c0(0000) GS:ffff8d6ce5c40000(0000) knlGS:0000000000000000
[   13.344462] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   13.344467] CR2: 00007f4ceb194000 CR3: 000000010b062002 CR4: 00000000000606e0
[   13.344474] Call Trace:
[   13.344481]  <TASK>
[   13.344489]  radeon_bo_unref+0x1a/0x30 [radeon 3f215497a44c006693127ef1f6afc6b4bc21a17a]
[   13.344664]  radeon_gem_object_free+0x30/0x60 [radeon 3f215497a44c006693127ef1f6afc6b4bc21a17a]
[   13.344709]  drm_gem_dmabuf_release+0x36/0x50
[   13.344714]  dma_buf_release+0x42/0xa0
[   13.344718]  __dentry_kill+0xfe/0x170
[   13.344722]  __fput+0xd8/0x240
[   13.344725]  task_work_run+0x5c/0xa0
[   13.344731]  exit_to_user_mode_prepare+0x183/0x190
[   13.344735]  syscall_exit_to_user_mode+0x23/0x50
[   13.344739]  do_syscall_64+0x67/0x90
[   13.344743]  ? do_syscall_64+0x67/0x90
[   13.344746]  ? syscall_exit_to_user_mode+0x23/0x50
[   13.344748]  ? do_syscall_64+0x67/0x90
[   13.344751]  entry_SYSCALL_64_after_hwframe+0x61/0xcb
[   13.344755] RIP: 0033:0x7f4cebc0bc0f
[   13.344758] Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
[   13.344759] RSP: 002b:00007ffe062bdb80 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[   13.344762] RAX: 0000000000000000 RBX: 0000557b1e7e25f0 RCX: 00007f4cebc0bc0f
[   13.344763] RDX: 00007ffe062bdc28 RSI: 0000000040086409 RDI: 0000000000000014
[   13.344764] RBP: 00007ffe062bdc28 R08: 0000000000000011 R09: 0000000000000000
[   13.344766] R10: 0000557b1d919010 R11: 0000000000000246 R12: 0000000040086409
[   13.344767] R13: 0000000000000014 R14: 0000557b1e80e980 R15: 0000557b1e80edd0
[   13.344770]  </TASK>
[   13.344770] ---[ end trace fd62f38a38a7e29a ]---
[   17.409255] kauditd_printk_skb: 7 callbacks suppressed
ok no radeon errors, but there is some kernel issue, its only one… so next time you will be using the pc post again logs, to see if the kernel logs are still there
Its been a bit - things appear to be running well (no freezes!)
Here are two log dumps I generated (wasn’t sure which you wanted):
sudo dmesg -l err,warn,emerg,alert,crit         ✔
[sudo] password for dklabunde:
[   12.629636]  do_syscall_64+0x67/0x90
[   12.629642]  ? syscall_exit_to_user_mode+0x23/0x50
[   12.629646]  ? do_syscall_64+0x67/0x90
[   12.629650]  ? do_syscall_64+0x67/0x90
[   12.629654]  ? do_syscall_64+0x67/0x90
[   12.629658]  ? syscall_exit_to_user_mode+0x23/0x50
[   12.629662]  ? do_syscall_64+0x67/0x90
[   12.629666]  ? syscall_exit_to_user_mode+0x23/0x50
[   12.629669]  ? do_syscall_64+0x67/0x90
[   12.629673]  ? exc_page_fault+0x71/0x180
[   12.629677]  entry_SYSCALL_64_after_hwframe+0x61/0xcb
[   12.629683] RIP: 0033:0x7f5d52ea9c0f
[   12.629687] Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
[   12.629690] RSP: 002b:00007fff15e641c0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[   12.629695] RAX: 0000000000000000 RBX: 000055b7fc07f040 RCX: 00007f5d52ea9c0f
[   12.629697] RDX: 00007fff15e64268 RSI: 0000000040086409 RDI: 0000000000000014
[   12.629700] RBP: 00007fff15e64268 R08: 0000000000000010 R09: 0000000000000000
[   12.629702] R10: 0000000000000013 R11: 0000000000000246 R12: 0000000040086409
[   12.629705] R13: 0000000000000014 R14: 000055b7fc0d04c0 R15: 000055b7fc0d0910
[   12.629710]  </TASK>
[   12.629712] ---[ end trace e55ea2b56944d4c4 ]---
[   17.002134] kauditd_printk_skb: 9 callbacks suppressed
[ 5155.891528] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
[ 5155.891696] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[ 5158.074519] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[ 5158.074523] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[ 5158.090739] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[ 5159.996060] acpi PNP0501:00: Still not present
[ 5159.997242] done.
[ 7361.732575] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
[ 7361.732793] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[ 7363.547073] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[ 7363.547076] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[ 7363.563294] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[ 7365.455464] acpi PNP0501:00: Still not present
[ 7365.457313] done.
[14038.150422] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
[14038.150649] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[14039.904286] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[14039.904290] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[14039.920500] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[14041.829199] acpi PNP0501:00: Still not present
[14041.831037] done.
[16245.250664] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[16245.250667] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[16245.266892] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[16247.158900] acpi PNP0501:00: Still not present
[16247.160623] done.
[18107.757326] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
[18107.757563] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[18109.474270] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[18109.474273] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[18109.490489] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[18111.412621] acpi PNP0501:00: Still not present
[18111.414260] done.
[20938.611439] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
[20938.611645] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[20940.315595] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[20940.315598] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[20940.331815] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[20942.250330] acpi PNP0501:00: Still not present
[20942.254838] done.
[27984.846629] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
[27984.846845] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[27986.553314] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[27986.553317] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[27986.569534] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[27988.491765] acpi PNP0501:00: Still not present
[27988.494217] done.
[30812.530242] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
[30812.530456] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[30814.247159] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[30814.247163] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[30814.263383] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[30816.208091] acpi PNP0501:00: Still not present
[30816.211541] done.
[38545.626217] xhci_hcd 0000:26:00.0: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[38545.626395] xhci_hcd 0000:26:00.0: WARN Event TRB for slot 1 ep 4 with no TDs queued?
[44710.712680] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
[44710.712773] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[44713.002000] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[44713.002004] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[44713.018220] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[44714.923621] acpi PNP0501:00: Still not present
[44714.927666] done.
[48939.957916] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[48939.957920] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[48939.974139] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[48941.878364] acpi PNP0501:00: Still not present
[48941.881752] done.
[54059.672753] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
[54059.672995] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[54061.266152] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[54061.266155] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[54061.282366] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[54063.197571] acpi PNP0501:00: Still not present
[54063.200918] done.
[56787.205722] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
[56787.205813] [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
[56788.801521] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[56788.801525] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[56788.817741] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[56790.740738] acpi PNP0501:00: Still not present
[56790.749078] done.
   ~  journalctl --boot=-1 --priority=4 --no-pager         ✔
Oct 19 08:31:11 HP-Elitebook kernel: tsc: Unable to calibrate against PIT
Oct 19 08:31:11 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 19 08:31:11 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 19 08:31:11 HP-Elitebook kernel:  #2 #3 #4 #5 #6 #7
Oct 19 08:31:11 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 19 08:31:11 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 19 08:31:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Oct 19 08:31:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 19 08:31:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 19 08:31:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 19 08:31:12 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 19 08:31:12 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 19 08:31:12 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 19 08:31:13 HP-Elitebook systemd[471]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 19 08:31:17 HP-Elitebook kernel: kauditd_printk_skb: 51 callbacks suppressed
Oct 19 08:31:17 HP-Elitebook pipewire[583]: mod.rt: Can't find xdg-portal: (null)
Oct 19 08:31:17 HP-Elitebook pipewire[583]: mod.rt: found session bus but no portal
Oct 19 08:31:17 HP-Elitebook pipewire-media-session[584]: mod.rt: Can't find xdg-portal: (null)
Oct 19 08:31:17 HP-Elitebook pipewire-media-session[584]: mod.rt: found session bus but no portal
Oct 19 08:31:21 HP-Elitebook pulseaudio[900]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 19 08:31:23 HP-Elitebook kernel: kauditd_printk_skb: 7 callbacks suppressed
Oct 19 08:31:31 HP-Elitebook kernel: ------------[ cut here ]------------
Oct 19 08:31:31 HP-Elitebook kernel: WARNING: CPU: 0 PID: 633 at drivers/gpu/drm/ttm/ttm_bo.c:409 ttm_bo_release+0x2e9/0x310 [ttm]
Oct 19 08:31:31 HP-Elitebook kernel: Modules linked in: rfcomm ccm intel_rapl_msr intel_rapl_common bnep x86_pkg_temp_thermal hp_wmi intel_powerclamp crct10dif_pclmul iTCO_wdt sparse_keymap intel_pmc_bxt wmi_bmof platform_profile mei_wdt ppdev crc32_pclmul snd_ctl_led uvcvideo videobuf2_vmalloc iTCO_vendor_support snd_hda_codec_idt ghash_clmulni_intel snd_hda_codec_generic videobuf2_memops qrtr videobuf2_v4l2 snd_hda_codec_hdmi aesni_intel ns btusb ledtrig_audio btrtl snd_hda_intel crypto_simd videobuf2_common tpm_infineon iwldvm cryptd snd_intel_dspcfg btbcm rapl snd_intel_sdw_acpi btintel intel_cstate videodev joydev snd_hda_codec radeon mac80211 bluetooth mousedev intel_uncore snd_hda_core pcspkr mc coretemp snd_hwdep libarc4 ecdh_generic tpm_tis psmouse drm_ttm_helper iwlwifi snd_pcm ttm tpm_tis_core parport_pc wmi snd_timer tpm hp_accel parport cfg80211 rng_core snd e1000e mei_me soundcore mei lis3lv02d video rfkill mac_hid lpc_ich fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2
Oct 19 08:31:31 HP-Elitebook kernel:  hid_logitech_hidpp hid_logitech_dj serio_raw atkbd libps2 sdhci_pci firewire_ohci cqhci firewire_core crc32c_intel sdhci sr_mod i8042 cdrom mmc_core usbhid xhci_pci crc_itu_t serio
Oct 19 08:31:31 HP-Elitebook kernel: CPU: 0 PID: 633 Comm: kwin_x11:rcs0 Not tainted 5.15.74-3-MANJARO #1 6719dea2e0f43080bcbb84589c5fe78ca0af8a1c
Oct 19 08:31:31 HP-Elitebook kernel: Hardware name: Hewlett-Packard HP EliteBook 8560w (B2A76UT)/1631, BIOS 68SVD Ver. F.22 01/05/2012
Oct 19 08:31:31 HP-Elitebook kernel: RIP: 0010:ttm_bo_release+0x2e9/0x310 [ttm]
Oct 19 08:31:31 HP-Elitebook kernel: Code: e8 cc 93 0e f3 e9 b2 fd ff ff 49 8b 7e 98 b9 28 23 00 00 31 d2 be 01 00 00 00 e8 e2 b6 0e f3 49 8b 46 e8 eb 9e 48 89 e8 eb 99 <0f> 0b e9 38 fd ff ff e8 5b 91 0e f3 e9 ef fe ff ff be 03 00 00 00
Oct 19 08:31:31 HP-Elitebook kernel: RSP: 0018:ffffb8bf41ffbd80 EFLAGS: 00010202
Oct 19 08:31:31 HP-Elitebook kernel: RAX: 0000000000000001 RBX: ffffb8bf41ffbdc8 RCX: 0000000000000001
Oct 19 08:31:31 HP-Elitebook kernel: RDX: ffff9bec24158dd8 RSI: 0000000000000000 RDI: ffff9bec24158dd8
Oct 19 08:31:31 HP-Elitebook kernel: RBP: ffff9bec05f986f0 R08: 0000000000000000 R09: 0000000000000000
Oct 19 08:31:31 HP-Elitebook kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9bec1d970658
Oct 19 08:31:31 HP-Elitebook kernel: R13: ffff9bec24158c78 R14: ffff9bec24158dd8 R15: 0000000000000000
Oct 19 08:31:31 HP-Elitebook kernel: FS:  00007f44a4f2a6c0(0000) GS:ffff9bf125c00000(0000) knlGS:0000000000000000
Oct 19 08:31:31 HP-Elitebook kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Oct 19 08:31:31 HP-Elitebook kernel: CR2: 00007f7cf400f010 CR3: 0000000102ec2001 CR4: 00000000000606f0
Oct 19 08:31:31 HP-Elitebook kernel: Call Trace:
Oct 19 08:31:31 HP-Elitebook kernel:  <TASK>
Oct 19 08:31:31 HP-Elitebook kernel:  radeon_bo_unref+0x1a/0x30 [radeon 3f215497a44c006693127ef1f6afc6b4bc21a17a]
Oct 19 08:31:31 HP-Elitebook kernel:  radeon_gem_object_free+0x30/0x60 [radeon 3f215497a44c006693127ef1f6afc6b4bc21a17a]
Oct 19 08:31:31 HP-Elitebook kernel:  drm_gem_dmabuf_release+0x36/0x50
Oct 19 08:31:31 HP-Elitebook kernel:  dma_buf_release+0x42/0xa0
Oct 19 08:31:31 HP-Elitebook kernel:  __dentry_kill+0xfe/0x170
Oct 19 08:31:31 HP-Elitebook kernel:  __fput+0xd8/0x240
Oct 19 08:31:31 HP-Elitebook kernel:  task_work_run+0x5c/0xa0
Oct 19 08:31:31 HP-Elitebook kernel:  exit_to_user_mode_prepare+0x183/0x190
Oct 19 08:31:31 HP-Elitebook kernel:  syscall_exit_to_user_mode+0x23/0x50
Oct 19 08:31:31 HP-Elitebook kernel:  do_syscall_64+0x67/0x90
Oct 19 08:31:31 HP-Elitebook kernel:  ? syscall_exit_to_user_mode+0x23/0x50
Oct 19 08:31:31 HP-Elitebook kernel:  ? do_syscall_64+0x67/0x90
Oct 19 08:31:31 HP-Elitebook kernel:  entry_SYSCALL_64_after_hwframe+0x61/0xcb
Oct 19 08:31:31 HP-Elitebook kernel: RIP: 0033:0x7f44ad72cc0f
Oct 19 08:31:31 HP-Elitebook kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
Oct 19 08:31:31 HP-Elitebook kernel: RSP: 002b:00007f44a4f298e0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Oct 19 08:31:31 HP-Elitebook kernel: RAX: 0000000000000000 RBX: 0000556e755f0c30 RCX: 00007f44ad72cc0f
Oct 19 08:31:31 HP-Elitebook kernel: RDX: 00007f44a4f29988 RSI: 0000000040086409 RDI: 000000000000000a
Oct 19 08:31:31 HP-Elitebook kernel: RBP: 00007f44a4f29988 R08: 000000000000000a R09: 0000000000000000
Oct 19 08:31:31 HP-Elitebook kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 0000000040086409
Oct 19 08:31:31 HP-Elitebook kernel: R13: 000000000000000a R14: 00007f44a40dc190 R15: 0000556e74b12da8
Oct 19 08:31:31 HP-Elitebook kernel:  </TASK>
Oct 19 08:31:31 HP-Elitebook kernel: ---[ end trace 528d4d98fdd6b2d3 ]---
Oct 19 09:03:08 HP-Elitebook librewolf[1001]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 19 09:30:21 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
Oct 19 09:30:21 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 19 12:26:31 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
Oct 19 12:26:31 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 19 12:26:52 HP-Elitebook pamac-manager[15809]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 19 12:27:57 HP-Elitebook kernel: kauditd_printk_skb: 26 callbacks suppressed
Oct 19 13:22:14 HP-Elitebook librewolf[16791]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 19 13:41:54 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 19 13:41:54 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 19 14:09:47 HP-Elitebook librewolf[16791]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 19 15:22:18 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 19 15:22:18 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 19 16:19:18 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
Oct 19 16:19:18 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 19 17:20:22 HP-Elitebook librewolf[16791]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 19 17:20:26 HP-Elitebook librewolf[16791]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 20 07:48:31 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 20 07:48:31 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 20 08:43:33 HP-Elitebook org.kde.kmtpd5[82761]: ERROR: Could not close session!
Oct 20 08:43:33 HP-Elitebook org.kde.kmtpd5[82761]: inep: usb_get_endpoint_status(): No such device
Oct 20 08:43:33 HP-Elitebook org.kde.kmtpd5[82761]: outep: usb_get_endpoint_status(): No such device
Oct 20 08:56:55 HP-Elitebook librewolf[16791]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 20 09:17:53 HP-Elitebook librewolf[16791]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 20 10:37:58 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 20 10:37:58 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 20 12:16:10 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 20 12:16:10 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 20 12:16:10 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 20 12:16:10 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 20 12:16:10 HP-Elitebook kernel: done.
Oct 20 14:47:54 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 20 14:47:54 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 20 14:47:54 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 20 14:47:54 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 20 14:47:54 HP-Elitebook kernel: done.
Oct 20 16:19:11 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 20 16:19:11 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 20 16:19:11 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 20 16:19:11 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 20 16:19:11 HP-Elitebook kernel: done.
Oct 20 16:53:13 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 20 16:53:13 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 21 15:46:04 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 21 15:46:04 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 21 15:46:04 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 21 15:46:04 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 21 15:46:04 HP-Elitebook kernel: done.
Oct 21 15:46:05 HP-Elitebook org.kde.kmtpd5[82761]: ERROR: Could not close session!
Oct 21 15:46:05 HP-Elitebook org.kde.kmtpd5[82761]: inep: usb_get_endpoint_status(): No such device
Oct 21 15:46:05 HP-Elitebook org.kde.kmtpd5[82761]: outep: usb_get_endpoint_status(): No such device
Oct 22 06:14:19 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 22 06:14:19 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 22 06:14:19 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 22 06:14:19 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 22 06:14:19 HP-Elitebook kernel: done.
Oct 22 07:15:46 HP-Elitebook org.kde.kmtpd5[82761]: ERROR: Could not close session!
Oct 22 07:15:46 HP-Elitebook org.kde.kmtpd5[82761]: inep: usb_get_endpoint_status(): No such device
Oct 22 07:15:46 HP-Elitebook org.kde.kmtpd5[82761]: outep: usb_get_endpoint_status(): No such device
Oct 22 07:15:47 HP-Elitebook org.kde.kmtpd5[82761]: ERROR: Could not close session!
Oct 22 07:15:47 HP-Elitebook org.kde.kmtpd5[82761]: inep: usb_get_endpoint_status(): No such device
Oct 22 07:15:47 HP-Elitebook org.kde.kmtpd5[82761]: outep: usb_get_endpoint_status(): No such device
Oct 22 07:45:29 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
Oct 22 07:45:29 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 22 07:51:50 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 22 07:51:50 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 22 07:51:50 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 22 07:51:50 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 22 07:51:50 HP-Elitebook kernel: done.
Oct 22 09:12:06 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 22 09:12:06 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 22 10:28:26 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 22 10:28:26 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 22 10:28:26 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 22 10:28:26 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 22 10:28:26 HP-Elitebook kernel: done.
Oct 22 11:02:19 HP-Elitebook librewolf[120731]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 11:02:23 HP-Elitebook librewolf[120731]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 11:02:25 HP-Elitebook librewolf[120731]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 11:09:10 HP-Elitebook librewolf[120731]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 11:09:40 HP-Elitebook librewolf[120731]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 11:15:41 HP-Elitebook librewolf[120731]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 12:15:51 HP-Elitebook librewolf[120731]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 22 13:01:10 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 22 13:01:10 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 22 13:25:38 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 22 13:25:38 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 22 13:25:38 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 22 13:25:38 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 22 13:25:38 HP-Elitebook kernel: done.
Oct 22 13:25:55 HP-Elitebook pamac-manager[138165]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 22 13:33:58 HP-Elitebook kernel: kauditd_printk_skb: 30 callbacks suppressed
Oct 22 15:03:25 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 22 15:03:25 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 22 16:03:50 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 22 16:03:50 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 22 16:03:50 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 22 16:03:50 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 22 16:03:50 HP-Elitebook kernel: done.
Oct 22 16:07:55 HP-Elitebook librewolf[144714]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 22 16:16:36 HP-Elitebook ark[145928]: kf.jobwidgets: A KUiServerV2JobTracker instance contains 1 stalled jobs
Oct 22 16:21:43 HP-Elitebook librewolf[144714]: gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
Oct 22 16:42:21 HP-Elitebook librewolf[144714]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:42:27 HP-Elitebook librewolf[144714]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:43:06 HP-Elitebook librewolf[144714]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:43:10 HP-Elitebook librewolf[144714]: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown
Oct 22 16:43:19 HP-Elitebook librewolf[144714]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:43:20 HP-Elitebook librewolf[144714]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:43:26 HP-Elitebook librewolf[144714]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:44:30 HP-Elitebook librewolf[144714]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:44:33 HP-Elitebook librewolf[144714]: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 16:44:42 HP-Elitebook librewolf[144714]: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: org.freedesktop.DBus.Error.ServiceUnknown
Oct 22 16:44:50 HP-Elitebook librewolf[144714]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 22 17:48:39 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery tried 5 times
Oct 22 17:48:39 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 22 21:19:23 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 22 21:19:23 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 22 21:19:23 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 22 21:19:23 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 22 21:19:23 HP-Elitebook kernel: done.
Oct 22 21:19:38 HP-Elitebook librewolf[163823]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 22 21:53:24 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery reached max voltage
Oct 22 21:53:24 HP-Elitebook kernel: [drm:radeon_dp_link_train [radeon]] *ERROR* clock recovery failed
Oct 23 07:39:06 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 23 07:39:06 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 23 07:39:06 HP-Elitebook kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Oct 23 07:39:06 HP-Elitebook kernel: acpi PNP0501:00: Still not present
Oct 23 07:39:06 HP-Elitebook kernel: done.
Oct 23 08:12:45 HP-Elitebook sddm[447]: Authentication error: "Process crashed"
Oct 23 08:12:45 HP-Elitebook sddm[447]: Auth: sddm-helper crashed (exit code 15)
Oct 23 08:12:45 HP-Elitebook sddm[447]: Auth: sddm-helper exited with 15
Oct 23 08:12:46 HP-Elitebook systemd[513]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 23 08:12:46 HP-Elitebook systemd[513]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Oct 23 08:12:46 HP-Elitebook systemd[513]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 23 08:12:46 HP-Elitebook systemd[513]: flatpak-session-helper.service: Failed with result 'exit-code'.
Oct 23 08:12:46 HP-Elitebook systemd-coredump[174139]: Failed to connect to coredump service: Connection refused
Oct 23 08:12:46 HP-Elitebook pulseaudio[900]: Error opening PCM device front:0: No such file or directory
Oct 23 08:12:46 HP-Elitebook systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Oct 23 08:12:46 HP-Elitebook systemd[1]: udisks2.service: Failed with result 'core-dump'.
Oct 23 08:12:47 HP-Elitebook sddm[447]: Signal received: SIGTERM
Oct 23 08:12:48 HP-Elitebook sddm[447]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
you have these…
install the 6.0.2 kernel from system settings, reboot and boot with it and see if you have any freezes … and again provide logs …
also when in 6.0 kernel provide output from:
inxi -G
if you for whatever reason cant boot with the 6 kernel, just switch back to the 5.15 in grub menu… i want to check if you can use the amdgpu driver instead of the radeon one…
Booted fine - here are the logs:
Oct 26 10:39:46 HP-Elitebook kernel: tsc: Unable to calibrate against PIT
Oct 26 10:39:46 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 26 10:39:46 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 26 10:39:46 HP-Elitebook kernel:  #2 #3 #4 #5 #6 #7
Oct 26 10:39:46 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 26 10:39:46 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 26 10:39:47 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Oct 26 10:39:47 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 26 10:39:47 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 26 10:39:47 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 26 10:39:47 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 26 10:39:47 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 26 10:39:47 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 26 10:39:48 HP-Elitebook systemd[474]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 26 10:39:52 HP-Elitebook sddm[397]: Signal received: SIGTERM
Oct 26 10:39:52 HP-Elitebook sddm[397]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Oct 26 10:39:52 HP-Elitebook kernel: kauditd_printk_skb: 43 callbacks suppressed
inxi -G         ✔
  Device-1: AMD Whistler [Radeon HD 6730M/6770M/7690M XT] driver: radeon
    v: kernel
  Device-2: Sunplus Innovation HP Universal Camera type: USB
    driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: radeon
    unloaded: modesetting dri: r600 gpu: radeon resolution: 1: 1920x1080~60Hz
    2: N/A
  OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 6.0.2-2-MANJARO LLVM 14.0.6)
    v: 3.3 Mesa 22.1.7
ok so no kernel logs in the 6.0…
but the amdgpu as a alternate is not detected in the 6.0 kernel:
like it was detected when you were running the 5.18 kernel:
so lets keep using radeon and see if you have any issues with the 6.0 kernel
Hi - things are running well.
My question is - I am running kernel: 6.0.19-4 MANJARO (64-bit). Do I need to stay on that kernel - or should I at some point - upgrade to a newer kernel? Or perhaps the better question is - do I need to stay on this kernel so I don’t start seeing those intermittent freezes again?
Linux 6.0 is EOL already. Upgrade as soon as possible. 6.1 is new LTS version.
TCO - Thanks!
