Apologies if I’m not pasting correctly… I changed priority to ‘4’, as removing it created pages of data…
Oct 09 07:37:12 HP-Elitebook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Oct 09 07:37:12 HP-Elitebook kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 09 07:37:12 HP-Elitebook kernel: #2 #3 #4 #5 #6 #7
Oct 09 07:37:12 HP-Elitebook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 09 07:37:12 HP-Elitebook kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 09 07:37:12 HP-Elitebook systemd-journald[286]: File /var/log/journal/036122c36a5d424c96ff4d634222f7d9/system.journal corrupted or uncleanly shut down, renaming and replacing.
Oct 09 07:37:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20211217/utaddress-204)
Oct 09 07:37:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20211217/utaddress-204)
Oct 09 07:37:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20211217/utaddress-204)
Oct 09 07:37:12 HP-Elitebook kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20211217/utaddress-204)
Oct 09 07:37:12 HP-Elitebook kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 09 07:37:13 HP-Elitebook kernel: iwlwifi 0000:25:00.0: can't disable ASPM; OS doesn't have ASPM control
Oct 09 07:37:13 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Oct 09 07:37:13 HP-Elitebook kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Oct 09 07:37:13 HP-Elitebook systemd[442]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 09 07:37:16 HP-Elitebook systemd-xdg-autostart-generator[500]: /home/dklabunde/.config/autostart/net.cozic.joplin_desktop.desktop:9: Unknown key name 'SingleMainWindow' in section 'Desktop Entry', ignoring.
Oct 09 07:37:16 HP-Elitebook systemd-journald[286]: File /var/log/journal/036122c36a5d424c96ff4d634222f7d9/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Oct 09 07:37:16 HP-Elitebook systemd-xdg-autostart-generator[500]: /home/dklabunde/.config/autostart/firefox.desktop:1: Unknown section 'Desktop Action new-private-window'. Ignoring.
Oct 09 07:37:16 HP-Elitebook systemd-xdg-autostart-generator[500]: /home/dklabunde/.config/autostart/firefox.desktop:6: Unknown section 'Desktop Action new-window'. Ignoring.
Oct 09 07:37:16 HP-Elitebook systemd-xdg-autostart-generator[500]: /home/dklabunde/.config/autostart/firefox.desktop:12: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Oct 09 07:37:16 HP-Elitebook systemd-xdg-autostart-generator[500]: /home/dklabunde/.config/autostart/firefox.desktop: not generating unit, error parsing Exec= line: No such file or directory
Oct 09 07:37:17 HP-Elitebook kernel: kauditd_printk_skb: 41 callbacks suppressed
Oct 09 07:37:17 HP-Elitebook systemd-xdg-autostart-generator[552]: /home/dklabunde/.config/autostart/net.cozic.joplin_desktop.desktop:9: Unknown key name 'SingleMainWindow' in section 'Desktop Entry', ignoring.
Oct 09 07:37:17 HP-Elitebook systemd-xdg-autostart-generator[552]: /home/dklabunde/.config/autostart/firefox.desktop:1: Unknown section 'Desktop Action new-private-window'. Ignoring.
Oct 09 07:37:17 HP-Elitebook systemd-xdg-autostart-generator[552]: /home/dklabunde/.config/autostart/firefox.desktop:6: Unknown section 'Desktop Action new-window'. Ignoring.
Oct 09 07:37:17 HP-Elitebook systemd-xdg-autostart-generator[552]: /home/dklabunde/.config/autostart/firefox.desktop:12: Unknown key name 'Actions' in section 'Desktop Entry', ignoring.
Oct 09 07:37:17 HP-Elitebook systemd-xdg-autostart-generator[552]: /home/dklabunde/.config/autostart/firefox.desktop: not generating unit, error parsing Exec= line: No such file or directory
Oct 09 07:37:17 HP-Elitebook pipewire[562]: mod.rt: Can't find xdg-portal: (null)
Oct 09 07:37:17 HP-Elitebook pipewire[562]: mod.rt: found session bus but no portal
Oct 09 07:37:17 HP-Elitebook pipewire-media-session[563]: mod.rt: Can't find xdg-portal: (null)
Oct 09 07:37:17 HP-Elitebook pipewire-media-session[563]: mod.rt: found session bus but no portal
Oct 09 07:37:18 HP-Elitebook ksplashqml[546]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Oct 09 07:37:18 HP-Elitebook ksplashqml[546]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Oct 09 07:37:18 HP-Elitebook ksmserver[597]: Qt: Session management error: networkIdsList argument is NULL
Oct 09 07:37:18 HP-Elitebook baloo_file[564]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.27'
Oct 09 07:37:18 HP-Elitebook ksmserver[597]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.20'
Oct 09 07:37:18 HP-Elitebook plasmashell[641]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 09 07:37:18 HP-Elitebook plasmashell[641]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 09 07:37:18 HP-Elitebook kwin_x11[600]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 09 07:37:18 HP-Elitebook kwin_x11[600]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 09 07:37:18 HP-Elitebook org_kde_powerdevil[658]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 09 07:37:18 HP-Elitebook kded5[599]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.20'
Oct 09 07:37:18 HP-Elitebook kwin_x11[600]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Oct 09 07:37:19 HP-Elitebook org_kde_powerdevil[658]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 09 07:37:19 HP-Elitebook org_kde_powerdevil[658]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 09 07:37:19 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 07:37:19 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 07:37:19 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Oct 09 07:37:19 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Oct 09 07:37:19 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.calculator/contents/ui/calculator.qml:243:5: QML Connections: Detected function "onPopupEvent" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 09 07:37:19 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.calculator/contents/ui/calculator.qml:40:5: Unable to assign [undefined] to QString
Oct 09 07:37:20 HP-Elitebook plasmashell[641]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 09 07:37:20 HP-Elitebook plasmashell[641]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 07:37:20 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Oct 09 07:37:20 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Oct 09 07:37:20 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 09 07:37:20 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 09 07:37:20 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1710, resource id: 58720263, major code: 12 (ConfigureWindow), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 453, resource id: 58720263, major code: 7 (ReparentWindow), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 455, resource id: 58720263, major code: 142 (Unknown), minor code: 1
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 456, resource id: 58720263, major code: 6 (ChangeSaveSet), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 457, resource id: 58720263, major code: 25 (SendEvent), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 458, resource id: 58720263, major code: 12 (ConfigureWindow), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 460, resource id: 58720263, major code: 12 (ConfigureWindow), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 461, resource id: 58720263, major code: 8 (MapWindow), minor code: 0
Oct 09 07:37:20 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 462, resource id: 58720263, major code: 61 (ClearArea), minor code: 0
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55bfbe760910)
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55bfbe7640c0)
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55bfbe513ed0)
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55bfbe667570)
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55bfbe763f70)
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55bfbe619600)
Oct 09 07:37:21 HP-Elitebook ktraderclient5[1096]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/bitwarden" not found
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 09 07:37:21 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Oct 09 07:37:22 HP-Elitebook pulseaudio[1068]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 09 07:37:22 HP-Elitebook plasmashell[641]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 09 07:37:22 HP-Elitebook plasmashell[641]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 09 07:37:22 HP-Elitebook ktraderclient5[1114]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Oct 09 07:37:22 HP-Elitebook ktraderclient5[1114]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Oct 09 07:37:22 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Oct 09 07:37:22 HP-Elitebook ktraderclient5[1114]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/bitwarden" not found
Oct 09 07:37:22 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2848, resource id: 62914568, major code: 12 (ConfigureWindow), minor code: 0
Oct 09 07:37:22 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 500, resource id: 62914568, major code: 7 (ReparentWindow), minor code: 0
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 501, resource id: 62914568, major code: 142 (Unknown), minor code: 1
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 502, resource id: 62914568, major code: 6 (ChangeSaveSet), minor code: 0
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 503, resource id: 62914568, major code: 25 (SendEvent), minor code: 0
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 504, resource id: 62914568, major code: 12 (ConfigureWindow), minor code: 0
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 506, resource id: 62914568, major code: 12 (ConfigureWindow), minor code: 0
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 507, resource id: 62914568, major code: 8 (MapWindow), minor code: 0
Oct 09 07:37:22 HP-Elitebook xembedsniproxy[660]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 508, resource id: 62914568, major code: 61 (ClearArea), minor code: 0
Oct 09 07:37:22 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3009, resource id: 4194351, major code: 18 (ChangeProperty), minor code: 0
Oct 09 07:37:23 HP-Elitebook plasmashell[641]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 09 07:37:23 HP-Elitebook kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 09 07:37:25 HP-Elitebook plasmashell[641]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 07:37:25 HP-Elitebook plasmashell[641]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 09 07:37:26 HP-Elitebook plasmashell[641]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 07:37:26 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:23:32: QML Action: Accessible must be attached to an Item
Oct 09 07:37:27 HP-Elitebook plasmashell[641]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 07:37:28 HP-Elitebook plasmashell[641]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 09 07:37:58 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8172, resource id: 92274691, major code: 15 (QueryTree), minor code: 0
Oct 09 07:38:00 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 07:38:32 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12213, resource id: 29360282, major code: 18 (ChangeProperty), minor code: 0
Oct 09 07:38:32 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Oct 09 07:40:14 HP-Elitebook kwin_x11[600]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 09 07:40:15 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 35830, resource id: 8393252, major code: 20 (GetProperty), minor code: 0
Oct 09 07:40:24 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 37696, resource id: 111149067, major code: 18 (ChangeProperty), minor code: 0
Oct 09 07:41:19 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 40292, resource id: 8393943, major code: 20 (GetProperty), minor code: 0
Oct 09 07:42:59 HP-Elitebook plasmashell[641]: trying to show an empty dialog
Oct 09 07:43:02 HP-Elitebook plasmashell[641]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 09 07:43:02 HP-Elitebook plasmashell[641]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 09 07:43:04 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45342, resource id: 29360306, major code: 18 (ChangeProperty), minor code: 0
Oct 09 07:43:05 HP-Elitebook pamac-manager[2323]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Oct 09 07:43:44 HP-Elitebook librewolf[1467]: Running in confined mode, using Portal notifications. Some features and hints won't be supported
Oct 09 07:43:45 HP-Elitebook plasmashell[641]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55bfbf684d90) QQmlContext(0x55bfbec02ce0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 07:43:45 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 09 07:43:45 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 09 07:43:45 HP-Elitebook plasmashell[641]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Oct 09 07:43:45 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Oct 09 07:43:45 HP-Elitebook plasmashell[641]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55bfc12ee190) QQmlContext(0x55bfbec02ce0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 09 07:43:56 HP-Elitebook kwin_x11[600]: kwin_core: XCB error: 152 (BadDamage), sequence: 352, resource id: 8397656, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 09 07:43:57 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 711, resource id: 8394024, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 07:43:57 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 712, resource id: 8394024, major code: 14 (GetGeometry), minor code: 0
Oct 09 07:43:57 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 715, resource id: 8394024, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 07:43:57 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 716, resource id: 8394024, major code: 14 (GetGeometry), minor code: 0
Oct 09 07:47:39 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27793, resource id: 92275284, major code: 18 (ChangeProperty), minor code: 0
Oct 09 07:47:39 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27807, resource id: 29360354, major code: 18 (ChangeProperty), minor code: 0
Oct 09 07:47:44 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29086, resource id: 8402347, major code: 3 (GetWindowAttributes), minor code: 0
Oct 09 07:47:44 HP-Elitebook kwin_x11[600]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29087, resource id: 8402347, major code: 14 (GetGeometry), minor code: 0
Oct 09 07:47:51 HP-Elitebook plasmashell[641]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 09 07:48:07 HP-Elitebook kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10444msec
Oct 09 07:48:07 HP-Elitebook kernel: radeon 0000:01:00.0: GPU lockup (current fence id 0x0000000000008142 last fence id 0x0000000000008168 on ring 0)
Oct 09 07:48:07 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 07:48:08 HP-Elitebook kernel: radeon 0000:01:00.0: Wait for MC idle timedout !
Oct 09 07:48:08 HP-Elitebook kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Oct 09 07:48:08 HP-Elitebook kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Oct 09 07:48:08 HP-Elitebook kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x8504)=0xCAFEDEAD)
Oct 09 07:48:08 HP-Elitebook kernel: [drm:evergreen_resume [radeon]] *ERROR* evergreen startup failed on resume
