so try with the modules above, and see if it helped …
if not we try adding some kernel parameters
Rebooted, again needed to logout in. No chnage in behaviours. Sorry.
I do not understand your question if the card works otherwise. I can move in the opened software, also, it gives me the preview windows when hovering. The rest is unusable…
this card
so lets add the parameters, open this file:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT
- inside the quotes add these 3 parameters:
intel_idle.max_cstate=1 i915.enable_dc=0 ahci.mobile_lpm_policy=1
dont remove anything from there, add them to the existing parameters, save the grub, update grub:
sudo update-grub
reboot and test
Yeah, the card is opened in Dolphin, just not writeable.
Why is there no group storage…? I hope it makes no problems to again mix topics…
Look, now, I wanted to open the shell and add the given commands to kate, but I cannot. I can only write in the firefox browser, use the tabs, means even open new ones and close, but cannot close or operate the whole firefox and am jailed in it.
Until log out or reboot, whereas logout is my choice.
ADDED it to what was written there like this GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=57372df7-9bb2-4987-8f8b-5bf50fffe676 udev.log_priority=3 intel_idle.max_cstate=1 i915.enable_dc=0 ahci.mobile_lpm_policy=1"
Okay, did and the early warning of the sympton is already, that I cannot use the mouse in the login screen to switch between users.
But after login I was able to see the hover effect (this highlighted white shadow, when you hover over the icons in the taskbar) but still I had to logout and in to be able to start anything (also the startmenu has no function all the time)
good, so remove the parameters:
save grub, update grub… and provide logs:
journalctl -b0 -p4 --no-pager
install gnome disks, and check if the card is detected there, if yes try to delete it, or format it
Am using the MicroSD Card in an old smartphone I just bought yesterday for 8 USD. Huawei. Swallows it. But on this laptop I guess this problem is because of the user group storage where my user is not into.
Because the window manager, wouldn’t it be a better idea to just get rid of this installation of KDE? I love KDE, but hey, I need to work and earn money instead of hanging out with the little errors caused by proprietary software for a really cool Graphics card I want to use or a display or something and if KDE is so sensitive then it is finally not mine.
Maybe we never find what’s the issue, despite your great expertise. You are doing it remote, you know, over a forum…
In the following the output of journalctl, but it was toolong to “save as” in complete…
Module libQt5DBus.so.5 with build-id 5e5cad799e1e2f4f8d071ebd72bc13b66ff07ebc
Module libQt5Sql.so.5 with build-id 1501373a5c1b22e01ca068d2781e1e6d8a341f12
Module libQt5Gui.so.5 with build-id 270e0bc1757145935f4cb78851dd79f80bdda3b2
Module libQt5Widgets.so.5 with build-id 4f09d90fe61df7287fefe47efbed85975e92f602
Module libQt5Network.so.5 with build-id 864c44f39dd2a7849b65ef2b8ffd54039dcf6d98
Module libQt5Qml.so.5 with build-id fd8dec14fee5f3c57f38544d3fa15b007e7f1d86
Module libQt5Quick.so.5 with build-id 639e87d618c066b275776542c12b2e0af6ac370f
Module libQt5QuickControls2.so.5 with build-id 3b4493374df76d3c624ceece912d9cbc5849a777
Module libQt5WebSockets.so.5 with build-id 15445167cacbc82eb6ab1d56230ecd2b1bb5845a
Module libcrypto.so.1.1 with build-id 4bd35662a4ecae1ab5bf139931bb6067a000a174
Module genymotion with build-id a52f4f5d1788eb436678a415fa645e732c8ae336
Stack trace of thread 12325:
#0 0x00007f6885eac21b _ZNK18QThreadStorageData3getEv (libQt5Core.so.5 + 0xac21b)
#1 0x00007f6885e88c88 _ZN13QUnifiedTimer8instanceEb (libQt5Core.so.5 + 0x88c88)
#2 0x00007f6885e8ab5e _ZN16QAnimationDriver16advanceAnimationEx (libQt5Core.so.5 + 0x8ab5e)
#3 0x00007f6888f94422 n/a (libQt5Quick.so.5 + 0x194422)
#4 0x00007f6888fba6ef n/a (libQt5Quick.so.5 + 0x1ba6ef)
#5 0x00007f6888fbd88c n/a (libQt5Quick.so.5 + 0x1bd88c)
#6 0x00007f6885ea60a3 n/a (libQt5Core.so.5 + 0xa60a3)
#7 0x00007f68858a074d n/a (libc.so.6 + 0x8674d)
#8 0x00007f6885922700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 12287:
#0 0x00007f688589d306 n/a (libc.so.6 + 0x83306)
#1 0x00007f68858a2253 n/a (libc.so.6 + 0x88253)
#2 0x00007f6869ab3238 n/a (iris_dri.so + 0xb3238)
#3 0x00007f6869ab3354 n/a (iris_dri.so + 0xb3354)
#4 0x00007f6885854df5 n/a (libc.so.6 + 0x3adf5)
#5 0x00007f6885854f70 exit (libc.so.6 + 0x3af70)
#6 0x00007f6881c445b2 _ZN14QXcbConnection16processXcbEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5XcbQpa.so.5 + 0x445b2)
#7 0x00007f6881c6bce3 n/a (libQt5XcbQpa.so.5 + 0x6bce3)
#8 0x00007f6889c9281b g_main_context_dispatch (libglib-2.0.so.0 + 0x5581b)
#9 0x00007f6889ce8ec9 n/a (libglib-2.0.so.0 + 0xabec9)
#10 0x00007f6889c910d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
#11 0x00007f68860cc75f _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2cc75f)
#12 0x00007f6886073c0a _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x273c0a)
#13 0x00007f688607c650 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x27c650)
#14 0x0000563f8163a23e n/a (genymotion + 0x3a23e)
#15 0x00007f688583d290 n/a (libc.so.6 + 0x23290)
#16 0x00007f688583d34a __libc_start_main (libc.so.6 + 0x2334a)
#17 0x0000563f8163a87a n/a (genymotion + 0x3a87a)
Stack trace of thread 12290:
#0 0x00007f6885914e5f __poll (libc.so.6 + 0xfae5f)
#1 0x00007f6889ce8e2f n/a (libglib-2.0.so.0 + 0xabe2f)
#2 0x00007f6889c910d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
#3 0x00007f68860cc75f _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2cc75f)
#4 0x00007f6886073c0a _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x273c0a)
#5 0x00007f6885ea4b6c _ZN7QThread4execEv (libQt5Core.so.5 + 0xa4b6c)
#6 0x00007f6888908345 n/a (libQt5Qml.so.5 + 0x308345)
#7 0x00007f6885ea60a3 n/a (libQt5Core.so.5 + 0xa60a3)
#8 0x00007f68858a074d n/a (libc.so.6 + 0x8674d)
#9 0x00007f6885922700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 12299:
Stack trace of thread 12298:
#6 0x00007f6886615b45 n/a (libQt5DBus.so.5 + 0x15b45)
Stack trace of thread 12300:
Stack trace of thread 12311:
Stack trace of thread 12301:
#0 0x00007f688591a88b __madvise (libc.so.6 + 0x10088b)
#1 0x00007f68858a085e n/a (libc.so.6 + 0x8685e)
#2 0x00007f6885922700 n/a (libc.so.6 + 0x108700)
Oct 12 12:05:59 shaka2u1u-hpzbook17g4 systemd[14334]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Oct 12 12:05:59 shaka2u1u-hpzbook17g4 systemd[14334]: Failed to start Update XDG user dir configuration.
Oct 12 12:05:59 shaka2u1u-hpzbook17g4 systemd-coredump[14377]: [🡕] Process 14373 (xdg-desktop-por) of user 962 dumped core.
Module linux-vdso.so.1 with build-id 7467d56e4461a4a575da09415c40bdbe2878c975
Module libcomposeplatforminputcontextplugin.so with build-id b7d75f89aa42cbf4504bce73360cd2bb3fe2535c
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libxcb-damage.so.0 with build-id d18fa3897f9041bfe25380abd9834332896cda81
Module libxcb-composite.so.0 with build-id e8b69e2806d928f66445390cc50ab33a0b98bef0
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libQt5XcbQpa.so.5 with build-id 22a26a78db099a7a86274c88f67252ec78b8cc41
Module libdxcb.so with build-id d85d4c4f68ac61c09a67e86597146501e5c09f3b
Module libdl.so.2 with build-id 48e99bed239dc0c9005d0126a3dbb4018c435fab
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libresolv.so.2 with build-id e90e926c000e236818dd625b0addac91609ae4d3
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
Module libpthread.so.0 with build-id fa736186bac7d97413cc42b6760b3432ee7e11c7
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module liblzma.so.5 with build-id 8a7334fec02fef6a82ff641a68b3e3200a44a702
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libudev.so.1 with build-id 8c459883f08a1890f2f1daa9f6eeaae357e9e790
Module libKF5GlobalAccel.so.5 with build-id dfc766d1818cc24b9e82d7dc6977bff57162e616
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id ef3e323faf54271c824851913c119a7767c6bff1
Module libdbus-1.so.3 with build-id 6dece245a58f1549ed98431e1242f487e8ebf9a2
Module libKF5DBusAddons.so.5 with build-id 5eb888d8927faddb8d56c8ff6a693e2cce655e5c
Module ld-linux-x86-64.so.2 with build-id 44db3ccb9e01b83c9cff0216f36e26d90c1ba85d
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libKF5AuthCore.so.5 with build-id da9ff08c6e52c1ef73cfb30a8c37201731c688fc
Module libKF5Crash.so.5 with build-id 5ab2ca0fc5fa2dea833bb39525117bf40b85d137
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libKF5Archive.so.5 with build-id 819ae3371588dfb743e88c23a417bcbcc2a94694
Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libm.so.6 with build-id 8a4929d22ebcbb96a075a378918a2804f49ca28f
Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
Module libKF5Codecs.so.5 with build-id bf96c60657188e783178682f28ba9db0ea507aa2
Module libKF5WidgetsAddons.so.5 with build-id f0abc3bee1fad21ec45b3188ce079b852e2fee80
Module libKF5GuiAddons.so.5 with build-id d02d92f5bdc155cea56f6c8a709ad60fa56b9317
Module libKF5ConfigWidgets.so.5 with build-id 60a779885da8389a2d94e258c09a9877b10c4b23
Module libQt5Network.so.5 with build-id 4ef4fd4a75511783248e62c378fe446cfa4ccc91
Module libKF5Completion.so.5 with build-id 0b50881b27f40a463706296b458b6f68c99f672d
Module libKF5JobWidgets.so.5 with build-id 58ac1e987656afcbecf92a8400a13f4dbd458a92
Module libKF5KIOGui.so.5 with build-id 15fb3141a045d1d4c63535c25cebe7332ee72efe
Module libKF5Solid.so.5 with build-id e74245c3a71b508d6d27dd5c30fef851c784d4ae
Module libKF5XmlGui.so.5 with build-id 12dbceba1d2c8b4024175f04c32c7ce59921c767
Module libKF5Bookmarks.so.5 with build-id 6008e6c2825cba8cea47c90aa66622d0c7006a57
Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libc.so.6 with build-id 21a9a7f001414ad7fce50b6aeb125889f39499d0
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libQt5Core.so.5 with build-id 10f403c84cef570e5302c7b1f0d8db34f8293f71
Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
Module libKF5CoreAddons.so.5 with build-id 0c1e61a987dcc5a413145ce6f4b3e9130d478885
Module libKF5I18n.so.5 with build-id 8b01b131521ee05f8dd1cdc649e8989a403f89e2
Module libKF5ConfigCore.so.5 with build-id 3a7aadabb9f7166cacb72f765b328e10c66fbfa8
Module libKF5Service.so.5 with build-id 9aa3259c2748aaa0c6bb8ad3a2d2a5c2a12264d5
Module libKF5KIOCore.so.5 with build-id 259587c6684343e9bd0ea1b998e84d57033cad09
Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
Module libQt5Gui.so.5 with build-id c3306c1f059a4d83b3ece5ca28ce2a147fc154e3
Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
Module libQt5Widgets.so.5 with build-id 7948b4cf67a2e204665689ba69adedcb6ec9f7e7
Module libKF5ConfigGui.so.5 with build-id 7ceed534598952ecd8bf33ad51b7d0b6db177d07
Module libKF5ItemViews.so.5 with build-id 056d51112983ee6da4ebeab5da319f58b3543f3f
Module libQt5PrintSupport.so.5 with build-id c2adb3cc1c1891fbd2099b4285dc59e045edfe1c
Module libKF5IconThemes.so.5 with build-id 4df7a5f6480a88fd05d6643cdf07638b2c76d4cc
Module libKF5WindowSystem.so.5 with build-id afc9a1c136b0d640c853e1f451c15bcda90d0575
Module libKF5KIOWidgets.so.5 with build-id 7c732f0ef6ac9a794468dd6562bcb4fe50bc60fe
Module libKF5KIOFileWidgets.so.5 with build-id 65786d4c4e326b7284b114c610ddbaf28610c974
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libKF5WaylandClient.so.5 with build-id 3bc9e53fdd7340d5d77aa731c529189626b61533
Module libKF5Notifications.so.5 with build-id b80091b385d6d74d1492928b2c465a0bc6822772
Module xdg-desktop-portal-kde with build-id 27e57ac12655c1d88c4f219fb1d0fa5d2f87403c
Stack trace of thread 14373:
#0 0x00007f1545e64817 _ZN15QXcbIntegration10initializeEv (libQt5XcbQpa.so.5 + 0x42817)
#1 0x00007f154b93d162 _ZN22QGuiApplicationPrivate20eventDispatcherReadyEv (libQt5Gui.so.5 + 0x13d162)
#2 0x00007f154ae920f7 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2920f7)
#3 0x00007f154b93d1b9 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13d1b9)
#4 0x00007f154c775e0e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175e0e)
#5 0x000055f4765410c6 n/a (xdg-desktop-portal-kde + 0x1e0c6)
#6 0x00007f154a63d290 n/a (libc.so.6 + 0x23290)
#7 0x00007f154a63d34a __libc_start_main (libc.so.6 + 0x2334a)
#8 0x000055f476542535 n/a (xdg-desktop-portal-kde + 0x1f535)
Stack trace of thread 14374:
#0 0x00007f154a714e5f __poll (libc.so.6 + 0xfae5f)
#1 0x00007f154936fe2f n/a (libglib-2.0.so.0 + 0xabe2f)
#2 0x00007f15493180d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
#3 0x00007f154aed750c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#4 0x00007f154ae8532c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#5 0x00007f154ace749f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#6 0x00007f154b6f2cba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007f154ace42ba n/a (libQt5Core.so.5 + 0xe42ba)
#8 0x00007f154a6a074d n/a (libc.so.6 + 0x8674d)
#9 0x00007f154a722700 n/a (libc.so.6 + 0x108700)
Oct 12 12:05:59 shaka2u1u-hpzbook17g4 systemd[14334]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=11/SEGV
Oct 12 12:05:59 shaka2u1u-hpzbook17g4 systemd[14334]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Oct 12 12:05:59 shaka2u1u-hpzbook17g4 systemd[14334]: Failed to start Xdg Desktop Portal For KDE.
Oct 12 12:06:07 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 25 callbacks suppressed
Oct 12 12:06:07 shaka2u1u-hpzbook17g4 systemd[11809]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 12 12:06:07 shaka2u1u-hpzbook17g4 systemd[11809]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 12 12:06:07 shaka2u1u-hpzbook17g4 kernel: vboxnetflt: 163941 out of 164063 packets were not sent (directed to host)
Oct 12 12:06:07 shaka2u1u-hpzbook17g4 systemd-coredump[14398]: [🡕] Process 12346 (VBoxSVC) of user 1000 dumped core.
Module VDPluginCrypt.so without build-id.
Module libopus.so.0 with build-id 35fafc4024675e9cfe57c7d50c3965eac6bac358
Module libFLAC.so.12 with build-id 33c73690d24bc47897a89c69fa78e39e0953d835
Module libvorbisenc.so.2 with build-id 2b1ce7fcdcc925bc663ebe2c1c008c0dd96e5bd0
Module libasyncns.so.0 with build-id 3ed7e52f247b08f1dff19aef6a253ee4c5c785c0
Module libsndfile.so.1 with build-id 923361ca7a51d29651ef1e282559cbff70e31cde
Module libpulsecommon-16.1.so with build-id 17e5c781f557e60fbc789cb631816a4a29230f4a
Module libpulse.so.0 with build-id 0c1618cb1e11cc14128914e45965433374cbd10e
Module VBoxPuelMain.so without build-id.
Module VBoxXPCOM.so with build-id 44d2d128389ae90cd0e72fe3438b383e6cfc7c76
Module VBoxVMM.so with build-id 6b263e9d925a5019afbb6041b3ce26391172061b
Module VBoxDDU.so with build-id 80da7665f6718de70f1e82bc9455bc5ca339e3d2
Module VBoxRT.so with build-id 0ef6fefca8429149c5cda5cb1faad9f19406d992
Module VBoxXPCOMIPCC.so with build-id 61fd72b6dab285a8e11b9e3496c00febd106a158
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libnghttp2.so.14 with build-id 2b3da1b8c8fef25bf3aa4dbfea446a7ac94e41f9
Module libcurl.so.4 with build-id 93344344927f7c4bc68cba8e664b3744a7d69df7
Module libxml2.so.2 with build-id 49868de417eee9052facae410a866ebfbd5cceb8
Module VBoxSVC with build-id cf69a2bd54c07a73342394c826b9c3e9c7381457
Stack trace of thread 12346:
#0 0x00007fbb8aed2d83 n/a (VBoxXPCOMIPCC.so + 0xed83)
#1 0x00007fbb8aed5655 n/a (VBoxXPCOMIPCC.so + 0x11655)
#2 0x000056194ce08ef2 n/a (VBoxSVC + 0x368ef2)
#3 0x000056194cea3afe n/a (VBoxSVC + 0x403afe)
#4 0x000056194cd422dd n/a (VBoxSVC + 0x2a22dd)
#5 0x000056194cdde456 n/a (VBoxSVC + 0x33e456)
#6 0x000056194cdde4c7 n/a (VBoxSVC + 0x33e4c7)
#7 0x000056194ccccf4a n/a (VBoxSVC + 0x22cf4a)
#8 0x000056194cf40d3a n/a (VBoxSVC + 0x4a0d3a)
#9 0x00007fbb8afafa44 _ZN13nsCOMPtr_baseD1Ev (VBoxXPCOM.so + 0xc8a44)
#10 0x00007fbb8aed352a n/a (VBoxXPCOMIPCC.so + 0xf52a)
#11 0x00007fbb8aed9775 n/a (VBoxXPCOMIPCC.so + 0x15775)
#12 0x00007fbb8af5300d VBoxNsplPL_DHashTableEnumerate (VBoxXPCOM.so + 0x6c00d)
#13 0x00007fbb8aed4465 n/a (VBoxXPCOMIPCC.so + 0x10465)
#14 0x00007fbb8aed7a9b n/a (VBoxXPCOMIPCC.so + 0x13a9b)
#15 0x00007fbb8aed7c47 n/a (VBoxXPCOMIPCC.so + 0x13c47)
#16 0x00007fbb8afafa44 _ZN13nsCOMPtr_baseD1Ev (VBoxXPCOM.so + 0xc8a44)
#17 0x00007fbb8aed1b15 n/a (VBoxXPCOMIPCC.so + 0xdb15)
#18 0x00007fbb8aed1b50 n/a (VBoxXPCOMIPCC.so + 0xdb50)
#19 0x00007fbb8af52d4f VBoxNsplPL_DHashTableFinish (VBoxXPCOM.so + 0x6bd4f)
#20 0x00007fbb8aed1638 n/a (VBoxXPCOMIPCC.so + 0xd638)
#21 0x00007fbb8aecf5eb n/a (VBoxXPCOMIPCC.so + 0xb5eb)
#22 0x00007fbb8aed22fc n/a (VBoxXPCOMIPCC.so + 0xe2fc)
#23 0x00007fbb8afaf1e0 n/a (VBoxXPCOM.so + 0xc81e0)
#24 0x00007fbb8afaf22f n/a (VBoxXPCOM.so + 0xc822f)
#25 0x00007fbb8afaf2a7 n/a (VBoxXPCOM.so + 0xc82a7)
#26 0x00007fbb8af6e0cb n/a (VBoxXPCOM.so + 0x870cb)
#27 0x00007fbb8af6efbb n/a (VBoxXPCOM.so + 0x87fbb)
#28 0x00007fbb8af6f004 n/a (VBoxXPCOM.so + 0x88004)
#29 0x00007fbb8af4d7ed n/a (VBoxXPCOM.so + 0x667ed)
#30 0x00007fbb8af5300d VBoxNsplPL_DHashTableEnumerate (VBoxXPCOM.so + 0x6c00d)
#31 0x00007fbb8af4de92 _ZN11nsHashtable9EnumerateEPFiP9nsHashKeyPvS2_ES2_ (VBoxXPCOM.so + 0x66e92)
#32 0x00007fbb8af6f041 n/a (VBoxXPCOM.so + 0x88041)
#33 0x00007fbb8af7636d n/a (VBoxXPCOM.so + 0x8f36d)
#34 0x00007fbb8af76471 n/a (VBoxXPCOM.so + 0x8f471)
#35 0x00007fbb8afb1b88 VBoxNsxpNS_ShutdownXPCOM (VBoxXPCOM.so + 0xcab88)
#36 0x000056194cfb4607 n/a (VBoxSVC + 0x514607)
#37 0x000056194cc4088e n/a (VBoxSVC + 0x1a088e)
#38 0x00007fbb8aa3d290 n/a (libc.so.6 + 0x23290)
#39 0x00007fbb8aa3d34a __libc_start_main (libc.so.6 + 0x2334a)
#40 0x000056194cc40e15 n/a (VBoxSVC + 0x1a0e15)
Stack trace of thread 12352:
#0 0x00007fbb8aa9d306 n/a (libc.so.6 + 0x83306)
#1 0x00007fbb8aa9fb20 pthread_cond_wait (libc.so.6 + 0x85b20)
#2 0x00007fbb8b257133 RTSemEventWaitNoResume (VBoxRT.so + 0x257133)
#3 0x000056194ceb5c36 n/a (VBoxSVC + 0x415c36)
#4 0x000056194ceb5cec n/a (VBoxSVC + 0x415cec)
#5 0x00007fbb8b191640 n/a (VBoxRT.so + 0x191640)
#6 0x00007fbb8b254a11 n/a (VBoxRT.so + 0x254a11)
#7 0x00007fbb8aaa074d n/a (libc.so.6 + 0x8674d)
#8 0x00007fbb8ab22700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 12348:
#2 0x00007fbb8b256da3 RTSemEventWait (VBoxRT.so + 0x256da3)
#3 0x00007fbb8b18ec07 RTReqQueueProcess (VBoxRT.so + 0x18ec07)
#4 0x00007fbb8b254607 n/a (VBoxRT.so + 0x254607)
Stack trace of thread 12353:
#1 0x00007fbb8aa9fe24 pthread_cond_timedwait (libc.so.6 + 0x85e24)
#2 0x00007fbb8b256c1e RTSemEventWait (VBoxRT.so + 0x256c1e)
#3 0x00007fbb8b1fde53 n/a (VBoxRT.so + 0x1fde53)
#4 0x00007fbb8b191640 n/a (VBoxRT.so + 0x191640)
#5 0x00007fbb8b254a11 n/a (VBoxRT.so + 0x254a11)
#6 0x00007fbb8aaa074d n/a (libc.so.6 + 0x8674d)
#7 0x00007fbb8ab22700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 12363:
#0 0x00007fbb8ab14e5f __poll (libc.so.6 + 0xfae5f)
#1 0x000056194cebf1cb n/a (VBoxSVC + 0x41f1cb)
#2 0x00007fbb8b191640 n/a (VBoxRT.so + 0x191640)
#3 0x00007fbb8b254a11 n/a (VBoxRT.so + 0x254a11)
#4 0x00007fbb8aaa074d n/a (libc.so.6 + 0x8674d)
#5 0x00007fbb8ab22700 n/a (libc.so.6 + 0x108700)
Stack trace of thread 12364:
#1 0x00007fbb86c5b625 n/a (libdbus-1.so.3 + 0x2f625)
#2 0x00007fbb86c4136e n/a (libdbus-1.so.3 + 0x1536e)
#3 0x00007fbb86c45ed2 n/a (libdbus-1.so.3 + 0x19ed2)
#4 0x000056194cebf5f6 n/a (VBoxSVC + 0x41f5f6)
Stack trace of thread 12369:
#3 0x000056194cccc391 n/a (VBoxSVC + 0x22c391)
Stack trace of thread 12370:
#3 0x000056194cfb0386 n/a (VBoxSVC + 0x510386)
#4 0x000056194ce05d4e n/a (VBoxSVC + 0x365d4e)
Stack trace of thread 12354:
#1 0x000056194cebc5f1 n/a (VBoxSVC + 0x41c5f1)
#2 0x000056194cec0edc n/a (VBoxSVC + 0x420edc)
#3 0x000056194cea644c n/a (VBoxSVC + 0x40644c)
Oct 12 12:06:07 shaka2u1u-hpzbook17g4 systemd-coredump[14407]: [🡕] Process 13178 (VBoxHeadless) of user 1000 dumped core.
Module VBoxGuestControlSvc.so with build-id 35f869ad852f411fb81903a5a433e45a3e2e85d7
Module VBoxSVCM.so with build-id f9433ac88f37cd182d18cb2b40007e5973b734ba
Module libvpx.so.7 with build-id accaef32c955264d758e0348e7da476c5979d711
Module VBoxC.so with build-id a87a4df75b44e282d03fb89802e443d398f8bebe
Module VBoxHeadless.so with build-id 501d5f3372ad678603b21b9e6a3eb60f892d949a
Module VBoxHeadless with build-id e9349a70916f24c956424ac4a299790c9f484abf
Stack trace of thread 13178:
#0 0x00007f215244ad83 n/a (VBoxXPCOMIPCC.so + 0xed83)
#1 0x00007f215244d655 n/a (VBoxXPCOMIPCC.so + 0x11655)
#2 0x00007f214dd3a481 n/a (VBoxC.so + 0x13a481)
#3 0x00007f214dd3a46d n/a (VBoxC.so + 0x13a46d)
#4 0x00007f214dd3a82e n/a (VBoxC.so + 0x13a82e)
#5 0x00007f214ddae5f0 n/a (VBoxC.so + 0x1ae5f0)
#6 0x00007f214de7e18a n/a (VBoxC.so + 0x27e18a)
#7 0x00007f214dd60a70 n/a (VBoxC.so + 0x160a70)
#8 0x00007f214dd5f59f n/a (VBoxC.so + 0x15f59f)
#9 0x00007f2150003a44 _ZN13nsCOMPtr_baseD1Ev (VBoxXPCOM.so + 0xc8a44)
#10 0x00007f215244b52a n/a (VBoxXPCOMIPCC.so + 0xf52a)
#11 0x00007f2152451775 n/a (VBoxXPCOMIPCC.so + 0x15775)
#12 0x00007f214ffa700d VBoxNsplPL_DHashTableEnumerate (VBoxXPCOM.so + 0x6c00d)
#13 0x00007f215244c465 n/a (VBoxXPCOMIPCC.so + 0x10465)
#14 0x00007f215244fa9b n/a (VBoxXPCOMIPCC.so + 0x13a9b)
#15 0x00007f215244fc47 n/a (VBoxXPCOMIPCC.so + 0x13c47)
#16 0x00007f2150003a44 _ZN13nsCOMPtr_baseD1Ev (VBoxXPCOM.so + 0xc8a44)
#17 0x00007f2152449b15 n/a (VBoxXPCOMIPCC.so + 0xdb15)
#18 0x00007f2152449b50 n/a (VBoxXPCOMIPCC.so + 0xdb50)
#19 0x00007f214ffa6d4f VBoxNsplPL_DHashTableFinish (VBoxXPCOM.so + 0x6bd4f)
#20 0x00007f2152449638 n/a (VBoxXPCOMIPCC.so + 0xd638)
#21 0x00007f21524475eb n/a (VBoxXPCOMIPCC.so + 0xb5eb)
#22 0x00007f215244a2fc n/a (VBoxXPCOMIPCC.so + 0xe2fc)
#23 0x00007f21500031e0 n/a (VBoxXPCOM.so + 0xc81e0)
#24 0x00007f215000322f n/a (VBoxXPCOM.so + 0xc822f)
#25 0x00007f21500032a7 n/a (VBoxXPCOM.so + 0xc82a7)
#26 0x00007f214ffc20cb n/a (VBoxXPCOM.so + 0x870cb)
#27 0x00007f214ffc2fbb n/a (VBoxXPCOM.so + 0x87fbb)
#28 0x00007f214ffc3004 n/a (VBoxXPCOM.so + 0x88004)
#29 0x00007f214ffa17ed n/a (VBoxXPCOM.so + 0x667ed)
#30 0x00007f214ffa700d VBoxNsplPL_DHashTableEnumerate (VBoxXPCOM.so + 0x6c00d)
#31 0x00007f214ffa1e92 _ZN11nsHashtable9EnumerateEPFiP9nsHashKeyPvS2_ES2_ (VBoxXPCOM.so + 0x66e92)
#32 0x00007f214ffc3041 n/a (VBoxXPCOM.so + 0x88041)
#33 0x00007f214ffca36d n/a (VBoxXPCOM.so + 0x8f36d)
#34 0x00007f214ffca471 n/a (VBoxXPCOM.so + 0x8f471)
#35 0x00007f2150005b88 VBoxNsxpNS_ShutdownXPCOM (VBoxXPCOM.so + 0xcab88)
#36 0x00007f21530c2757 n/a (VBoxHeadless.so + 0x11757)
#37 0x00007f21530b92ae TrustedMain (VBoxHeadless.so + 0x82ae)
#38 0x00007f21530fb290 n/a (libc.so.6 + 0x23290)
#39 0x00007f21530fb34a __libc_start_main (libc.so.6 + 0x2334a)
#40 0x0000558672766065 n/a (VBoxHeadless + 0x3065)
Stack trace of thread 13181:
#0 0x00007f215315b306 n/a (libc.so.6 + 0x83306)
#1 0x00007f215315db20 pthread_cond_wait (libc.so.6 + 0x85b20)
#2 0x00007f2152e56da3 RTSemEventWait (VBoxRT.so + 0x256da3)
#3 0x00007f2152d8ec07 RTReqQueueProcess (VBoxRT.so + 0x18ec07)
#4 0x00007f2152e54607 n/a (VBoxRT.so + 0x254607)
#5 0x00007f2152d91640 n/a (VBoxRT.so + 0x191640)
#6 0x00007f2152e54a11 n/a (VBoxRT.so + 0x254a11)
#7 0x00007f215315e74d n/a (libc.so.6 + 0x8674d)
#8 0x00007f21531e0700 n/a (libc.so.6 + 0x108700)
Oct 12 12:06:08 shaka2u1u-hpzbook17g4 NetworkManager[574]: <warn> [1665565568.4345] device (wlp3s0): no secrets: No agents were available for this request.
Oct 12 12:06:08 shaka2u1u-hpzbook17g4 NetworkManager[574]: <warn> [1665565568.4349] device (wlp3s0): Activation: failed for connection 'Shaka2u1unet'
Oct 12 12:06:09 shaka2u1u-hpzbook17g4 pipewire-media-session[14501]: mod.rt: Can't find xdg-portal: (null)
Oct 12 12:06:09 shaka2u1u-hpzbook17g4 pipewire-media-session[14501]: mod.rt: found session bus but no portal
Oct 12 12:06:09 shaka2u1u-hpzbook17g4 pipewire[14500]: mod.rt: Can't find xdg-portal: (null)
Oct 12 12:06:09 shaka2u1u-hpzbook17g4 pipewire[14500]: mod.rt: found session bus but no portal
Oct 12 12:06:10 shaka2u1u-hpzbook17g4 zeitgeist-datah[14736]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
Oct 12 12:06:11 shaka2u1u-hpzbook17g4 pulseaudio[14841]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 xdg-desktop-por[14347]: Failed to create settings proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 xdg-desktop-por[14347]: No skeleton to export
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 xdg-desktop-por[14347]: Error while sending AddMatch() message: The connection is closed
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 xdg-desktop-por[14347]: Failed to create file chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 systemd[14334]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 systemd[14334]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 12 12:06:18 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 37 callbacks suppressed
Oct 12 12:06:33 shaka2u1u-hpzbook17g4 NetworkManager[574]: <warn> [1665565593.6660] device (wlp3s0): Activation: (wifi) association took too long, failing activation
Oct 12 12:06:33 shaka2u1u-hpzbook17g4 NetworkManager[574]: <warn> [1665565593.6976] device (wlp3s0): Activation: failed for connection 'airFiber'
Oct 12 12:07:30 shaka2u1u-hpzbook17g4 kernel: vboxdrv: 0000000081b86cd2 VMMR0.r0
Oct 12 12:07:30 shaka2u1u-hpzbook17g4 kernel: VBoxNetFlt: attached to 'vboxnet0' / 0a:00:27:00:00:00
Oct 12 12:07:30 shaka2u1u-hpzbook17g4 kernel: vboxdrv: 000000007c6e208b VBoxDDR0.r0
Oct 12 12:07:30 shaka2u1u-hpzbook17g4 kernel: VMMR0InitVM: eflags=246 fKernelFeatures=0x0 (SUPKERNELFEATURES_SMAP=0)
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Error sending STATISTICS_CMD: time out after 2000ms.
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Current CMD queue read_ptr 226 write_ptr 227
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Transport status: 0x0000004A, valid: 6
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Loaded firmware version: 36.ca7b901d.0 8265-36.ucode
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x200002B2 | trm_hw_status0
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00024A8C | branchlink2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0003AC1E | interruptlink1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0000E59E | interruptlink2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | data1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000080 | data2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x07830000 | data3
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xAC416F6B | beacon time
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xE6766093 | tsf low
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000003 | tsf hi
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | time gp1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xFB48833B | time gp2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000001 | uCode revision type
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000024 | uCode version major
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xCA7B901D | uCode version minor
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000230 | hw version
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00C89000 | board version
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x80D8F500 | hcmd
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x02222082 | isr0
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00800000 | isr1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x08200802 | isr2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x004000C0 | isr3
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | isr4
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x9AAC009D | last cmd Id
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | wait_event
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000080 | l2p_control
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00011420 | l2p_duration
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0000003F | l2p_mhvalid
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x000000CE | l2p_addr_match
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0000000D | lmpm_pmg_sel
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x10032209 | timestamp
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0034A0A8 | flow_handler
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Transport status: 0x0000004A, valid: 7
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000070 | NMI_INTERRUPT_LMAC_FATAL
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xC008694C | umac branchlink2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xC0083B0C | umac interruptlink1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xC0083B0C | umac interruptlink2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000800 | umac data1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xC0083B0C | umac data2
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xDEADBEEF | umac data3
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000024 | umac major
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xCA7B901D | umac minor
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xC088628C | frame pointer
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xC088628C | stack pointer
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00E2019C | last host cmd
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: IML/ROM dump:
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000000 | IML/ROM error/state
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000003 | IML/ROM data1
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Fseq Registers:
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xFEB7BE63 | FSEQ_ERROR_CODE
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x52B921AA | FSEQ_TOP_INIT_VERSION
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x29347421 | FSEQ_CNVIO_INIT_VERSION
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0000A10B | FSEQ_OTP_VERSION
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0EB11007 | FSEQ_TOP_CONTENT_VERSION
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xF7D841FE | FSEQ_ALIVE_TOKEN
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x06E04508 | FSEQ_CNVI_ID
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0xF5DFF904 | FSEQ_CNVR_ID
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x00000010 | CNVI_AUX_MISC_CHIP
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0BADCAFE | CNVR_AUX_MISC_CHIP
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Oct 12 12:25:12 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Collecting data: trigger 2 fired.
Oct 12 12:25:13 shaka2u1u-hpzbook17g4 kernel: iwlwifi 0000:03:00.0: Queue 0 is active on fifo 7 and stuck for 2500 ms. SW [226, 227] HW [226, 227] FH TRB=0x07000e2
Oct 12 12:43:11 shaka2u1u-hpzbook17g4 kernel: vboxnetflt: 802599 out of 802810 packets were not sent (directed to host)
yes reinstalling is at this point probably the best solution…
Hi,
sorry for having been offline for so long.
I reinstalled the whole system with XFCE and was very happy at the beginning and probably am still.
Though a very weird thing happened then after the very first update after installing.
I use the Nvidia drivers (non-free) and the kernel 5.15.84-1 and it doesnt boot up after the update anymore.
It hangs right before the login screen just with a small cursor on the top left. Cannot enter tty.
Weird thing is, when I shutdown and enter the boot stick (the install flashdisk I used to install the manjaro with) it smoothly boots the system, but not to the boot stick but right to the manjaro installed on the hardware. I think. Am definitely working on the harddrive with a fully running system.
Whats this?
The out put of mhwd -l
> 0000:01:00.0 (0300:10de:1bb8) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
output of inxi -G
Device-1: NVIDIA GP104GLM [Quadro P3000 Mobile] driver: nvidia v: 525.60.11
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.6 driver: N/A resolution: 1600x900~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
This all because after trying to find solutions over the past month, I assume that the nvidia driver doesnt match the kernel or still isnt working.
I have tried not much, cause finding threads about that it “only starts when boot stick is added” is kind of impossible, the threads always lead to different cases. This is all I have tried about a grub entry
And then when update grub it says it cannot find a grub on drive /dev/sda1
Hope you can help me, bro.
So, I have researched a little more from another direction and found that my kernel-headers were missing for linux-515 and installed them
pacman -Q | grep headers
linux-api-headers 5.18.15-1
linux515-headers 5.15.84-1
vulkan-headers 1:1.3.235-1
Will try a fresh start without the boot stick inserted now.
EDIT: Okay, this has not had the demanded effect.
Now after starting again with inserted flash into the hardware installation it notifies me that there is a kernel update available.
Maybe the solution to update the initramfs could help?
im not sure if i understand your issue… so you cant boot into manjaro installation unless you plug in your usb?
Yes. And after I have tried to update initramfs it also did not help
i have no idea what that could be… maybe reinstalling grub could help… first post output from:
test -d /sys/firmware/efi && echo efi || echo bios
ho bios
efi
and BTW, I am grateful for every help. I never run into these kinds of problems in the years before I when I used Manjaro.
I have the brother workstation of mine, on which I was using it without any issues. It is only the laptop maybe. But should run. No negative reviews I ve found.
And BTW I can enter the tty2. Was just mistaken.
so boot into manjaro live usb, chroot:
manjaro-chroot -a
reinstall grub for uefi:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
if no errors, update it:
mkinitcpio -P && update-grub
exit chroot:
exit
reboot
Now, the day before it started to also make the same issue of the curser only showing WITH the flash drive inside.
Sometimes it loops into one bios start up screen gets black and into another and hangs then, or it hangs right after the first HP bios screen.
I will see if I can boot only in the boot live usb. Let me try soon.
Any logs you want to look at? have noted the exact time frame today when it happened. after the tenth startup attempt it gave me login screen.
you can post logs from chroot, when you will reinstall grub:
journalctl -b-1 -p4 --no-pager
Can I print that log in a text file in case only when I got locked out? Like to save a txt file jtcl.txt to /home?
