Hi, thanks for helping so quickly, first.
The message is normal, yes. Only the behaviour at this point was my last stop.
I have done as you’ve told.
Oct 06 21:08:56 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:08:56 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:08:56 shaka2u1u-hpzbook17g4 kwin_x11[1014]: file:///usr/lib/qt/qml/org/kde/kwin/private/effects/WindowHeap.qml:56:9: Unable to assign null to QUuid
Oct 06 21:08:57 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:08:57 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:09:00 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 152 (BadDamage), sequence: 27631, resource id: 18875625, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 06 21:09:00 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27664, resource id: 73400375, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:13:07 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:13:55 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 19819, resource id: 25166041, major code: 18 (ChangeProperty), minor code: 0
~ sudo pacman -S xdg-desktop-portal xdg-desktop-portal-kde ✔
[sudo] Passwort für shaka2u1u:
warning: xdg-desktop-portal-1.15.0-1 is up to date -- reinstalling
warning: xdg-desktop-portal-kde-5.25.5-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) xdg-desktop-portal-1.15.0-1 xdg-desktop-portal-kde-5.25.5-1
Total Installed Size: 2.67 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring [#######################################################################] 100%
(2/2) checking package integrity [#######################################################################] 100%
(2/2) loading package files [#######################################################################] 100%
(2/2) checking for file conflicts [#######################################################################] 100%
(2/2) checking available disk space [#######################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/2) reinstalling xdg-desktop-portal-kde [#######################################################################] 100%
(2/2) reinstalling xdg-desktop-portal [#######################################################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
(3/3) Updating the desktop file MIME type cache...
~ kate /etc/environment ✔ 14s
~ journalctl -b0 -p4 --no-pager ✔
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: x86/cpu: SGX disabled by BIOS.
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: #5 #6 #7
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 exceeds size of target Buffer (64 bits) (20210730/dsopcode-198)
Oct 06 21:07:19 shaka2u1u-hpzbook17g4 kernel: ACPI Error: Aborting method \_SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (20210730/psparse-529)
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20210730/exoparg2-393)
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529)
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529)
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: ACPI: thermal: [Firmware Bug]: No valid trip found
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: hpet_acpi_add: no address or irqs in _CRS
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: usb: port power management may be unreliable
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: vboxdrv: loading out-of-tree module taints kernel.
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: VBoxNetAdp: Successfully started.
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: VBoxNetFlt: Successfully started.
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Oct 06 21:07:20 shaka2u1u-hpzbook17g4 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Oct 06 21:07:21 shaka2u1u-hpzbook17g4 kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 06 21:07:21 shaka2u1u-hpzbook17g4 kernel: Disabling lock debugging due to kernel taint
Oct 06 21:07:21 shaka2u1u-hpzbook17g4 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.76 Mon Sep 12 19:21:56 UTC 2022
Oct 06 21:07:22 shaka2u1u-hpzbook17g4 kernel: hp_wmi: query 0x4 returned error 0x5
Oct 06 21:07:22 shaka2u1u-hpzbook17g4 kernel: hp_wmi: query 0xd returned error 0x5
Oct 06 21:07:22 shaka2u1u-hpzbook17g4 kernel: hp_wmi: query 0x1b returned error 0x5
Oct 06 21:07:22 shaka2u1u-hpzbook17g4 kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
Oct 06 21:07:23 shaka2u1u-hpzbook17g4 kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Oct 06 21:07:23 shaka2u1u-hpzbook17g4 systemd[686]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 06 21:07:24 shaka2u1u-hpzbook17g4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Oct 06 21:07:25 shaka2u1u-hpzbook17g4 kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Oct 06 21:07:27 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 222 callbacks suppressed
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 systemd[828]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 systemd[828]: Failed to start Update XDG user dir configuration.
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 sddm-greeter[837]: QFont::fromString: Invalid description '(empty)'
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 xdg-desktop-portal-kde[863]: qt.qpa.xcb: could not connect to display
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 sddm-greeter[837]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd71ad4940), parent's thread is QThread(0x556a4fb08440), current thread is QThread(0x556a4fc2b510)
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 sddm-greeter[837]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 systemd-coredump[875]: [🡕] Process 863 (xdg-desktop-por) of user 962 dumped core.
Module linux-vdso.so.1 with build-id 67833441db018a149e7d23dfead684f2edcb2d3d
Module libcomposeplatforminputcontextplugin.so with build-id b7d75f89aa42cbf4504bce73360cd2bb3fe2535c
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-xinput.so.0 with build-id 409ee697e2b16243bf1fc6429e672f2359033388
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-xinerama.so.0 with build-id 5d2ab2683447d9bb7bcc49c058dfa06bcb65560d
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb-render-util.so.0 with build-id 32609134bf1b73183d07a66f6bd65c94b4542460
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-image.so.0 with build-id 0e6feae23e34658646dbd63d11f899c92c5d3c79
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libxcb-damage.so.0 with build-id d18fa3897f9041bfe25380abd9834332896cda81
Module libxcb-composite.so.0 with build-id e8b69e2806d928f66445390cc50ab33a0b98bef0
Module libxcb-shape.so.0 with build-id f9aab9846b5e3523bd534f8a845f36a37d42b3fa
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-icccm.so.4 with build-id 5eb9288df14c7f50af1e8db26c37e19d78bf0978
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libQt5XcbQpa.so.5 with build-id 22a26a78db099a7a86274c88f67252ec78b8cc41
Module libdxcb.so with build-id 957c88bb2446189b430c9a5c0dfc106806e601a1
Module libdl.so.2 with build-id 414d1d630bc04818a150b9c73e4493f3395e8869
Module libgmp.so.10 with build-id 26cec2ebe94cc5c4cb99e6988717347222b324fd
Module libhogweed.so.6 with build-id 5c4a99ad0aabe13bd9b517f92ab339436a2bc1f2
Module libnettle.so.8 with build-id 6a26cbe6819abc8c57668f80ca8c8160fd85e29e
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libidn2.so.0 with build-id b16e7570b102789b13ff77289762dbfe3f8f46bc
Module libbrotlienc.so.1 with build-id 74adbc62e4fbb5da9d37b5aa458471f4130862ff
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libresolv.so.2 with build-id 2e70cfe9f2972fb13487eeefcb10e4afafed6157
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 9a22a372b2157fb05da1bad94b92d9617513af81
Module libcom_err.so.2 with build-id 3360a28740ffbbd5a5c0c21d09072445908707e5
Module libk5crypto.so.3 with build-id 47d53a3ea2b172eb3db1be0ae0272c7c045267e8
Module libkrb5.so.3 with build-id 1fc969c1f54103d87e400237751b4804569a2730
Module libpthread.so.0 with build-id 3954d7fd57fa4db438d0ccdd8e2c6f7cc97c2e46
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libtasn1.so.6 with build-id fa2f7a5bfbcda1481ab5875d5744730ea1be8fb1
Module libgnutls.so.30 with build-id e849ad24d363553f5ddc88d43926e1ab2601ada9
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libexpat.so.1 with build-id 52f685635e8711c1164d20a1ef8acd3840312094
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libpcre2-8.so.0 with build-id 917fc43d2c9f8539a3e324555c6c73886e8000a8
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 9b38b08de708f439a9d0a4f8b9914151bc8d4b50
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libGLX.so.0 with build-id d2c37fb8ec3bc53c67c013b0c6ac63ec086c8883
Module libGLdispatch.so.0 with build-id 7879a881271650eff97c35aff7a8674859c5ae94
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libcrypto.so.1.1 with build-id 7981ea3d69f3c28e46ee312a815af96eab93775c
Module libssl.so.1.1 with build-id e6b1f97a5b60b4248c49dfc5b11f53f281b507d0
Module libgssapi_krb5.so.2 with build-id a10eaeef6e9969e80048d247666a3af155716afc
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libudev.so.1 with build-id 8c459883f08a1890f2f1daa9f6eeaae357e9e790
Module libKF5GlobalAccel.so.5 with build-id dfc766d1818cc24b9e82d7dc6977bff57162e616
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libltdl.so.7 with build-id 6a619e7b85ea9702e595881863bc9e599565e8a0
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libglib-2.0.so.0 with build-id 3ef8f9239c93af698703b12c5c6738fe0129eaa7
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libpcre2-16.so.0 with build-id 8ad49680a3f743a5241632a400d0de30aeaa54dd
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id 74bfa78f70f9ae1f759f0ae383fbc7f6f7faf6f8
Module libsystemd.so.0 with build-id ef3e323faf54271c824851913c119a7767c6bff1
Module libdbus-1.so.3 with build-id 6dece245a58f1549ed98431e1242f487e8ebf9a2
Module libKF5DBusAddons.so.5 with build-id 5eb888d8927faddb8d56c8ff6a693e2cce655e5c
Module ld-linux-x86-64.so.2 with build-id 075a6ad9f1c3f9cbb5f3301186bbe68c6a477808
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libKF5AuthCore.so.5 with build-id da9ff08c6e52c1ef73cfb30a8c37201731c688fc
Module libKF5Crash.so.5 with build-id 5ab2ca0fc5fa2dea833bb39525117bf40b85d137
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 0083e085bcb9cb3869e5cb05fbcd9736c41434ab
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libpng16.so.16 with build-id 14d3b3cc9d61ec1b7c1f86bdf108218a99364945
Module libGL.so.1 with build-id 6f65953140bc8a2aba47c9d492658dc61891393e
Module libQt5QmlModels.so.5 with build-id 75ac4ba2a588a639d18be70e47f2b106930ac1a5
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libKF5Archive.so.5 with build-id 819ae3371588dfb743e88c23a417bcbcc2a94694
Module libQt5Svg.so.5 with build-id 7db0284946e4871e7f9effc797f1dee6b7cb1be6
Module libxcb-keysyms.so.1 with build-id 507bdc94868b9b1f9d95e31c492694f2513da88d
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libm.so.6 with build-id 2c8ff1d29b255da5b7371efd5caf57444d622838
Module libQt5Xml.so.5 with build-id f67bcabb5df91d3dd74fb54fd53421bcd089b9f4
Module libKF5Codecs.so.5 with build-id bf96c60657188e783178682f28ba9db0ea507aa2
Module libKF5WidgetsAddons.so.5 with build-id f0abc3bee1fad21ec45b3188ce079b852e2fee80
Module libKF5GuiAddons.so.5 with build-id d02d92f5bdc155cea56f6c8a709ad60fa56b9317
Module libKF5ConfigWidgets.so.5 with build-id 60a779885da8389a2d94e258c09a9877b10c4b23
Module libQt5Network.so.5 with build-id 4ef4fd4a75511783248e62c378fe446cfa4ccc91
Module libKF5Completion.so.5 with build-id 0b50881b27f40a463706296b458b6f68c99f672d
Module libKF5JobWidgets.so.5 with build-id 58ac1e987656afcbecf92a8400a13f4dbd458a92
Module libKF5KIOGui.so.5 with build-id 15fb3141a045d1d4c63535c25cebe7332ee72efe
Module libKF5Solid.so.5 with build-id e74245c3a71b508d6d27dd5c30fef851c784d4ae
Module libKF5XmlGui.so.5 with build-id 12dbceba1d2c8b4024175f04c32c7ce59921c767
Module libKF5Bookmarks.so.5 with build-id 6008e6c2825cba8cea47c90aa66622d0c7006a57
Module libffi.so.8 with build-id fb5dba105458f179a9153659f3ccd8e1056a2f35
Module libQt5WaylandClient.so.5 with build-id 032f7f11d4e8511b03ff65222f387e69913adfbf
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id eaf941ac9100f7854ebc0d512979d2fc6e87d461
Module libQt5X11Extras.so.5 with build-id 78547956b3be2e12eece7fa5e9fa9f161b022c50
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libQt5TextToSpeech.so.5 with build-id 593099f8617753c871f48e5951f368c3a863e1cf
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libc.so.6 with build-id 90b9e4f641f8752292698389f241cbf0ff49d687
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module libQt5Core.so.5 with build-id 10f403c84cef570e5302c7b1f0d8db34f8293f71
Module libQt5DBus.so.5 with build-id 80839ec0184277ea0382ce3fdc7f84eaebb4dff9
Module libKF5CoreAddons.so.5 with build-id 0c1e61a987dcc5a413145ce6f4b3e9130d478885
Module libKF5I18n.so.5 with build-id 8b01b131521ee05f8dd1cdc649e8989a403f89e2
Module libKF5ConfigCore.so.5 with build-id 3a7aadabb9f7166cacb72f765b328e10c66fbfa8
Module libKF5Service.so.5 with build-id 9aa3259c2748aaa0c6bb8ad3a2d2a5c2a12264d5
Module libKF5KIOCore.so.5 with build-id 259587c6684343e9bd0ea1b998e84d57033cad09
Module libQt5Qml.so.5 with build-id 22231cfcf29a284259109c7862fb6e72406b131a
Module libQt5Gui.so.5 with build-id c3306c1f059a4d83b3ece5ca28ce2a147fc154e3
Module libQt5Quick.so.5 with build-id 7943b27c49d44215357f6219398a7b376dcf4cbd
Module libQt5Widgets.so.5 with build-id 7948b4cf67a2e204665689ba69adedcb6ec9f7e7
Module libKF5ConfigGui.so.5 with build-id 7ceed534598952ecd8bf33ad51b7d0b6db177d07
Module libKF5ItemViews.so.5 with build-id 056d51112983ee6da4ebeab5da319f58b3543f3f
Module libQt5PrintSupport.so.5 with build-id c2adb3cc1c1891fbd2099b4285dc59e045edfe1c
Module libKF5IconThemes.so.5 with build-id 4df7a5f6480a88fd05d6643cdf07638b2c76d4cc
Module libKF5WindowSystem.so.5 with build-id afc9a1c136b0d640c853e1f451c15bcda90d0575
Module libKF5KIOWidgets.so.5 with build-id 7c732f0ef6ac9a794468dd6562bcb4fe50bc60fe
Module libKF5KIOFileWidgets.so.5 with build-id 65786d4c4e326b7284b114c610ddbaf28610c974
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libKF5WaylandClient.so.5 with build-id 3bc9e53fdd7340d5d77aa731c529189626b61533
Module libKF5Notifications.so.5 with build-id b80091b385d6d74d1492928b2c465a0bc6822772
Module xdg-desktop-portal-kde with build-id 27e57ac12655c1d88c4f219fb1d0fa5d2f87403c
Stack trace of thread 863:
#0 0x00007f8397998817 _ZN15QXcbIntegration10initializeEv (libQt5XcbQpa.so.5 + 0x42817)
#1 0x00007f839d72c162 _ZN22QGuiApplicationPrivate20eventDispatcherReadyEv (libQt5Gui.so.5 + 0x13d162)
#2 0x00007f839cb8b0f7 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2920f7)
#3 0x00007f839d72c1b9 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13d1b9)
#4 0x00007f839e308e0e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175e0e)
#5 0x0000564ca1c5b0c6 n/a (xdg-desktop-portal-kde + 0x1e0c6)
#6 0x00007f839c4ff290 n/a (libc.so.6 + 0x23290)
#7 0x00007f839c4ff34a __libc_start_main (libc.so.6 + 0x2334a)
#8 0x0000564ca1c5c535 n/a (xdg-desktop-portal-kde + 0x1f535)
Stack trace of thread 873:
#0 0x00007f839c5d6e5f __poll (libc.so.6 + 0xfae5f)
#1 0x00007f839ae9fe2f n/a (libglib-2.0.so.0 + 0xabe2f)
#2 0x00007f839ae480d2 g_main_context_iteration (libglib-2.0.so.0 + 0x540d2)
#3 0x00007f839cbd050c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d750c)
#4 0x00007f839cb7e32c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28532c)
#5 0x00007f839c9e049f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe749f)
#6 0x00007f839ce3dcba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007f839c9dd2ba n/a (libQt5Core.so.5 + 0xe42ba)
#8 0x00007f839c56274d n/a (libc.so.6 + 0x8674d)
#9 0x00007f839c5e4700 n/a (libc.so.6 + 0x108700)
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 systemd[828]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=11/SEGV
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 systemd[828]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Oct 06 21:07:28 shaka2u1u-hpzbook17g4 systemd[828]: Failed to start Xdg Desktop Portal For KDE.
Oct 06 21:07:29 shaka2u1u-hpzbook17g4 sddm-greeter[837]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Unsupported image format
Oct 06 21:07:29 shaka2u1u-hpzbook17g4 sddm-greeter[837]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Oct 06 21:07:29 shaka2u1u-hpzbook17g4 sddm-greeter[837]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Oct 06 21:07:29 shaka2u1u-hpzbook17g4 sddm-greeter[837]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Oct 06 21:07:29 shaka2u1u-hpzbook17g4 sddm-greeter[837]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Oct 06 21:07:29 shaka2u1u-hpzbook17g4 sddm-greeter[837]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.25'
Oct 06 21:07:33 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 22 callbacks suppressed
Oct 06 21:07:40 shaka2u1u-hpzbook17g4 NetworkManager[714]: <warn> [1665079660.8827] device (wlp3s0): no secrets: No agents were available for this request.
Oct 06 21:07:40 shaka2u1u-hpzbook17g4 NetworkManager[714]: <warn> [1665079660.8833] device (wlp3s0): Activation: failed for connection 'Shaka2u1unet'
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 ksplashqml[948]: file:///usr/share/plasma/look-and-feel/org.kde.oxygen/contents/splash/Splash.qml:76: ReferenceError: bottomRect is not defined
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 ksplashqml[948]: file:///usr/share/plasma/look-and-feel/org.kde.oxygen/contents/splash/Splash.qml:75: ReferenceError: bottomRect is not defined
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 pipewire-media-session[998]: mod.rt: Can't find xdg-portal: (null)
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 pipewire-media-session[998]: mod.rt: found session bus but no portal
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 pipewire[997]: mod.rt: Can't find xdg-portal: (null)
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 pipewire[997]: mod.rt: found session bus but no portal
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 ksmserver[1011]: Qt: Session management error: networkIdsList argument is NULL
Oct 06 21:07:41 shaka2u1u-hpzbook17g4 ksmserver[1011]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.20'
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 plasmashell[1032]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 plasmashell[1032]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 147 (BadOutput), sequence: 443, resource id: 8, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 147 (BadOutput), sequence: 444, resource id: 8, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 147 (BadOutput), sequence: 445, resource id: 8, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 147 (BadOutput), sequence: 446, resource id: 37, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 org_kde_powerdevil[1067]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kded5[1013]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 org_kde_powerdevil[1067]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 kded5[1013]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
Oct 06 21:07:42 shaka2u1u-hpzbook17g4 zeitgeist-datah[1236]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1350, resource id: 4194340, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55e9eb30b9e0)
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55e9eb513ad0)
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55e9eb513d50)
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55e9eb513c10)
Oct 06 21:07:43 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55e9eb5138c0)
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: + [ -f /home/shaka2u1u/snap/skype/common/.config/skypeforlinux/settings.json ]
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: + export SKYPE_LOGS=/home/shaka2u1u/snap/skype/226/logs
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: + [ ! -d /home/shaka2u1u/snap/skype/226/logs ]
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: + exec /snap/skype/226/usr/share/skypeforlinux/skypeforlinux
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: Both point size and pixel size set. Using pixel size.
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:55:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 pulseaudio[1394]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Oct 06 21:07:44 shaka2u1u-hpzbook17g4 plasmashell[1032]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 06 21:07:45 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/DeviceItem.qml:33:32: QML Action: Accessible must be attached to an Item
Oct 06 21:07:46 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 23 callbacks suppressed
Oct 06 21:07:47 shaka2u1u-hpzbook17g4 plasmashell[1032]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 06 21:07:48 shaka2u1u-hpzbook17g4 skypeforlinux[1253]: Theme parsing error: gtk.css:3536:25: 'font-feature-settings' is not a valid property name
Oct 06 21:07:49 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1520]: WARNING: Kernel has no file descriptor comparison support: Operation not permitted
Oct 06 21:07:50 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2617, resource id: 18874530, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:07:50 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2620, resource id: 18874533, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:07:50 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2621, resource id: 18874533, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 xdg-desktop-por[841]: Failed to create settings proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 xdg-desktop-por[841]: No skeleton to export
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 xdg-desktop-por[841]: Error while sending AddMatch() message: The connection is closed
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 xdg-desktop-por[841]: Failed to create file chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 xdg-desktop-por[841]: Failed to create app chooser proxy: Error calling StartServiceByName for org.freedesktop.impl.portal.desktop.kde: The connection is closed
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 systemd[828]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 06 21:07:51 shaka2u1u-hpzbook17g4 systemd[828]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 06 21:07:53 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: Error occurred in handler for 'keychain:get-password': Error: No stored credentials fetched from keytar.
Oct 06 21:07:53 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: at /snap/skype/226/usr/share/skypeforlinux/resources/app.asar/main.js:2:504069
Oct 06 21:07:53 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: at async node:electron/js2c/browser_init:193:563
Oct 06 21:07:53 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 86 callbacks suppressed
Oct 06 21:07:54 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3461, resource id: 25165971, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:07:54 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3462, resource id: 25165971, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:07:54 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3463, resource id: 25165971, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:07:56 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 152 (BadDamage), sequence: 4742, resource id: 18874586, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 06 21:07:57 shaka2u1u-hpzbook17g4 kded5[1013]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Oct 06 21:07:57 shaka2u1u-hpzbook17g4 kded5[1013]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Oct 06 21:07:58 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:07:58 shaka2u1u-hpzbook17g4 plasmashell[1032]: trying to show an empty dialog
Oct 06 21:07:59 shaka2u1u-hpzbook17g4 pulseaudio[1394]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_30_8C_18_31_60_18/sep1/fd0 Volume property not (yet) available
Oct 06 21:08:03 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6700, resource id: 25165992, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:08:03 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6715, resource id: 25165993, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:08:07 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 8 callbacks suppressed
Oct 06 21:08:13 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7653, resource id: 69206033, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:08:13 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7665, resource id: 25165994, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:08:19 shaka2u1u-hpzbook17g4 plasmashell[1032]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Oct 06 21:08:19 shaka2u1u-hpzbook17g4 plasmashell[1032]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Oct 06 21:08:19 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: ioctl failed for wlan0, errno = 19 (No such device)
Oct 06 21:08:19 shaka2u1u-hpzbook17g4 skypeforlinux.desktop[1253]: ioctl failed for wlp2s0, errno = 19 (No such device)
Oct 06 21:08:19 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:08:24 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10268, resource id: 25166013, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:08:25 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11164, resource id: 18875233, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:08:25 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 11165, resource id: 18875233, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:08:30 shaka2u1u-hpzbook17g4 kwin_x11[1014]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:08:30 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:08:31 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15067, resource id: 18875626, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:08:31 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:08:37 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 47 callbacks suppressed
Oct 06 21:08:54 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:08:54 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:08:54 shaka2u1u-hpzbook17g4 kwin_x11[1014]: file:///usr/lib/qt/qml/org/kde/kwin/private/effects/WindowHeap.qml:56:9: Unable to assign null to QUuid
Oct 06 21:08:55 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:08:55 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:16:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:18:14 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63653, resource id: 71303306, major code: 15 (QueryTree), minor code: 0
Oct 06 21:19:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:22:20 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:25:06 shaka2u1u-hpzbook17g4 zeitgeist-datah[1187]: zeitgeist-datahub.vala:207: Error during inserting events: GDBus.Error:org.gnome.zeitgeist.EngineError.InvalidArgument: Incomplete event: interpretation, manifestation and actor are required
Oct 06 21:25:06 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42856, resource id: 75497478, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:25:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:28:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:29:08 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:86:9: QML ScrollView: Binding loop detected for property "bottomPadding"
Oct 06 21:29:12 shaka2u1u-hpzbook17g4 zeitgeist-datah[1187]: zeitgeist-datahub.vala:207: Error during inserting events: GDBus.Error:org.gnome.zeitgeist.EngineError.InvalidArgument: Incomplete event: interpretation, manifestation and actor are required
Oct 06 21:29:24 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42311, resource id: 77594630, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:31:28 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57899, resource id: 18907436, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:31:28 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 57900, resource id: 18907436, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:31:29 shaka2u1u-hpzbook17g4 kioslave5[5243]: kf.kio.slaves.thumbnail.comic: A suitable version of unrar is not available.
Oct 06 21:31:31 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59406, resource id: 77594641, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:31:32 shaka2u1u-hpzbook17g4 kate[5301]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 06 21:31:32 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59967, resource id: 18907673, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:31:32 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 59968, resource id: 18907673, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:31:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:33:28 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16518, resource id: 75497483, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:34:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:35:59 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29061, resource id: 79691787, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:36:02 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29102, resource id: 83886091, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:37:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:37:52 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46159, resource id: 77594647, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:37:52 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46167, resource id: 77594648, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:37:52 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46654, resource id: 18914213, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:37:52 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 46655, resource id: 18914213, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:38:09 shaka2u1u-hpzbook17g4 kwin_x11[1014]: kwin_core: XCB error: 152 (BadDamage), sequence: 54035, resource id: 18914380, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 06 21:40:14 shaka2u1u-hpzbook17g4 zeitgeist-datah[1187]: zeitgeist-datahub.vala:207: Error during inserting events: GDBus.Error:org.gnome.zeitgeist.EngineError.InvalidArgument: Incomplete event: interpretation, manifestation and actor are required
Oct 06 21:40:15 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 951, resource id: 83886086, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:40:45 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:42:19 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9980, resource id: 75497483, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:42:30 shaka2u1u-hpzbook17g4 plasmashell[1032]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e9edd2ea60) QQmlContext(0x55e9ebb24870) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 06 21:42:30 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Oct 06 21:42:30 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Oct 06 21:42:30 shaka2u1u-hpzbook17g4 plasmashell[1032]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Oct 06 21:42:30 shaka2u1u-hpzbook17g4 plasmashell[1032]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55e9ee40a280) QQmlContext(0x55e9ebb24870) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Oct 06 21:43:16 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:43:26 shaka2u1u-hpzbook17g4 kded5[1013]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Oct 06 21:43:26 shaka2u1u-hpzbook17g4 kded5[1013]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Oct 06 21:43:27 shaka2u1u-hpzbook17g4 plasmashell[1032]: libpng warning: iCCP: known incorrect sRGB profile
Oct 06 21:43:43 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:43:43 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:43:43 shaka2u1u-hpzbook17g4 kwin_x11[1014]: file:///usr/lib/qt/qml/org/kde/kwin/private/effects/WindowHeap.qml:56:9: Unable to assign null to QUuid
Oct 06 21:43:44 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:43:44 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:43:45 shaka2u1u-hpzbook17g4 kwin_x11[1014]: QQmlExpression: Expression file:///usr/share/kwin/effects/desktopgrid/qml/DesktopView.qml:73:13 depends on non-NOTIFYable properties:
Oct 06 21:43:45 shaka2u1u-hpzbook17g4 kwin_x11[1014]: KWin::X11Window::dock
Oct 06 21:43:49 shaka2u1u-hpzbook17g4 kate[5301]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 06 21:43:49 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26842, resource id: 18919356, major code: 3 (GetWindowAttributes), minor code: 0
Oct 06 21:43:49 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 26843, resource id: 18919356, major code: 14 (GetGeometry), minor code: 0
Oct 06 21:43:49 shaka2u1u-hpzbook17g4 kwin_x11[1014]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27058, resource id: 83886085, major code: 18 (ChangeProperty), minor code: 0
Oct 06 21:44:01 shaka2u1u-hpzbook17g4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 06 21:44:16 shaka2u1u-hpzbook17g4 kate[5301]: QIODevice::write (QFile, "/etc/.environment.kate-swp"): device not open
Oct 06 21:44:18 shaka2u1u-hpzbook17g4 kate[5301]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Oct 06 21:44:27 shaka2u1u-hpzbook17g4 kate[5301]: kf.sonnet.core: No language dictionaries for the language: "en_US"
