theres no reason to save the logs, just run the command when in chroot, and copy the output here
Hi, still haven’t done this so far. I will do soon.
But during an update over terminal I have received this info:
(14/22) Updating Grub boot menu
Creating GRUB configuration file...
Theme found: /usr/share/grub/themes/manjaro/theme.txt
Linux image found: /boot/vmlinuz-5.15-x86_64
initrd image found: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Warning: os-prober runs to detect other bootable partitions.
Its output is used to detect bootable program files and create new boot entries.
grub-probe: error: no GRUB drive found for /dev/sda1. Check your device.map.
Adding boot menu entry for UEFI firmware settings...
Root filesystem isn't btrfs
It was translated by me with translate cause these messages appear in german sometimes.
Can you check? It should support your idea, right?
it looks ok… so did the reinstall of grub helped?
Hi, I had many other challenges, had to relocate and all.
Till today I haven’t tried the steps of your solution.
Am still using the boot stick to get into a running system.
So, to go on with trying to fix this, I need to do this from your post, right?
Could you also take a look at the grub conf?
I made a bigger upgrade after a longer time waiting to do it. And it seems grub is installed now.
But why is it set to saved when the corresponding line is not commented out?
cat /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=55fbbe79-fe73-437c-8888-f1eafbd43f72 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
yes do that:
and the grub output looks ok…
