System freezes completely
The last couple of weeks my computer has started to freeze completely. It is not responding to anything and I have to do a hard reboot by holding in the start button.
I have absolutely no idea where to start troubleshooting to identify the culprit. Sometimes I suspect some script running in the browser and other times I suspect Slack (snap).
If anybody have any suggestion on how to go about to identify the problem, I would appreciate it.
I am on Manjaro 20.1.2 with KDE Plasma
inxi -Fazy
  Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=1abc3790-00bf-497e-8909-496ce929e4fb rw quiet apparmor=1
  security=apparmor resume=UUID=6217e660-c646-4374-beaa-84bc9f6014ea
  udev.log_priority=3
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: Z370 Pro4 serial: <filter>
  UEFI: American Megatrends v: P4.30 date: 10/31/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  Device-2: hidpp_battery_1 model: Logitech M705 serial: <filter> charge: 100%
  Topology: 6-Core model: Intel Core i5-8400 bits: 64 type: MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
  L2 cache: 9216 KiB
  bogomips: 33613
  Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: ASRock driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e92
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
  s-diag: 1052mm (41.4")
  Monitor-1: DP1 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4")
  diag: 587mm (23.1")
  Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4")
  diag: 587mm (23.1")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
  v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
  Device-2: Logitech Headset H390 type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-13:4 chip ID: 046d:0a44
  Sound Server: ALSA v: k5.8.16-2-MANJARO
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: 3.2.6-k
  port: f040 bus ID: 00:1f.6 chip ID: 8086:15b8
  Local Storage: total: 2.05 TiB used: 518.53 GiB (24.7%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00ZF5A0
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 0A80 scheme: MBR
  ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 1B6Q scheme: GPT
  ID-3: /dev/sdc type: USB vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
  block size: physical: 512 B logical: 512 B rotation: 5400 rpm
  serial: <filter> scheme: MBR
  ID-1: / raw size: 228.48 GiB size: 223.89 GiB (97.99%)
  used: 37.49 GiB (16.7%) fs: ext4 dev: /dev/sdb2
  ID-1: swap-1 type: partition size: 3.91 GiB used: 33.8 MiB (0.8%)
  priority: -2 dev: /dev/sdb1
  System Temperatures: cpu: 35.0 C mobo: N/A
  Processes: 277 Uptime: 16m Memory: 7.45 GiB used: 2.12 GiB (28.4%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1302 pacman: 1285
  lib: 356 flatpak: 11 snap: 6 Shell: Bash v: 5.0.18 running in: konsole
  inxi: 3.1.05
We need this kind of information to know how to help you out:
@ bogdancovaciu
Thank you. I ran the first command and added the output in the original posting.
Running them all and added would perhaps be a bit too much?
I will see if I can add the “Manjaro Log Helper”. However I only have small windows here and there for troubleshooting, so this has the potential for being a painful process.
I see you use swap on a SSD. I usually recommend a swapfile or systemd.swap instead.
Schedulers are also important, take a look:
Are you also using /etc/X11/xorg.conf.d/20-intel.conf file with one of this options ?
Section "Device"
   Identifier  "Intel Graphics"
   Driver      "intel"
   Option      "AccelMethod"  "uxa"
EndSection
or maybe this
Section "Device"
   Driver      "intel"
   Option      "TearFree"    "true"
EndSection
both are taken from the Intel graphics - ArchWiki
I should probably have added that I am a basic user, and when it comes to code I am pretty much lost.
Is there an easy way to change from swap to swapfile or systemd.swap?
And does it affect negatively on the system to use swap instead of swapfile or systemd.swap?
I don’t think my issue has to do with scheduling because the freezes usually happens after the system has finished booted and I am happily working away. That is why I have this feeling that it is related to some program I am using, but also there I am pretty basic and I use the office suite libreoffice, browsers firefox, chromium and brave and slack and skype (both installed via snap),
About /etc/X11/xorg.conf.d/20-intel.conf, I was not sure what you meant so I took a look inside the /etc/X11/xorg.conf.d/ and there were two files only:
00-keyboard.conf
30-touchpad.conf
I also use two monitors, one with HDMI and the other with VGA.
Thank you!
So, what actually seems to be my problem is that plasma for some reason clogs up and eventually freezes the whole system. If it freezes completely then I can only reboot. But if I, when I start to notice the signs, open a konsole and run:
plasmashell --replace
Then I will be able to continue to work.
So if somebody else has the same problem, try this and see if it helps.
