Since quite a while my System boots to a blackscreen occasionally after successfully unlocking my LUKS-encrypted drives.
Opening a TTY with CTRL+Alt+Fx is not possible in those cases.
Most of the time I am able to boot normally to the usual login screen after resetting the laptop with the on/off switch. In some cases it takes 2 or more resets.
I found another thread with a similar problem, but there is no solution and no further feedback by the author.
After power-on’s, or reboots the system fails to boot, getting stuck on a black blank screen. However after a force shutdown, Manjaro usually boots on the 2nd (sometimes 3rd, 4th or 5th) time.
Downgrading the Kernel from 5.8 to 5.7 , didn’t solve the problem either.
Possibly related:
Any thoughts/solutions on/for this issue?
Zesko
30 July 2022 14:12
2
You need to run manjaro-chroot
using Manjaro Live USB to check and fix your system
Original author on old forum @AlManja
If you are stuck and you can’t log into your system, use one of these steps below. They are sorted from easiest at the top. Start with the first step and if it doesn’t work, try with the next one and so on…
Once you get access to the system, then proceed with updating the system or installing/removing packages, checking log files… Steps (you only need one) are:
1 - log to tty terminal
2 - boot without X
3 - chroot auto (with manjaro-chroot)
4 - chroot …
Well, the problem only occurs occasionally - as I already stated - and I know how to enter a system with chroot. But this alone does not fix any issues. The system is up-to-date and runs without problems when it boots normally.
Or do I get you wrong? What and how do you suggest to fix?
when the freeze happens next time provide logs from the failed boot:
journalctl -b-1 -p4 --no-pager
together with:
inxi -Fazy
Blackscreen is in most cases, especially when it happens sporadically, a UEFI/Linux issue.
Fastboot/partial init can be the culprit. → disable this function.
GPU initializes slow especially with hybrid GPUs, therefore the display-manager crashes. → Put the driver in early load.
That could be a reason. My laptop has a hybrid GPU. How do I put the driver in early load?
ok I expect that you are not total new.
In general it goes like this:
Find the needed modules. inxi -Gazy
Edit the file /etc/mkinitcpio.conf
and add the driver names to the modules array. (Order matters)
Run mkinitcpio -P
to generate the initcpio.
Now the drivers load when the linux image is loaded to ram and not later.
inxi -Gazy looks like this:
inxi -Gazy
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1ba1
class-ID: 0300
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:11
chip-ID: 5986:1140 class-ID: 0e02 serial: <filter>
Device-4: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3.4.3:12 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia unloaded: vesa alternate: fbdev,nouveau,nv
gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-1-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 hz: 120 dpi: 128
size: 381x214mm (15x8.43") diag: 437mm (17.2") modes: N/A
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
/etc/mkinitcpio.conf does not exist.
Do I have to create it first? Sorry, I am still a bit noobish to Linux…
Then there is something wrong…
Ok well… no. The file MUST exist.
sudo nano /etc/mkinitcpio.conf
replace MODULES=()
with
MODULES=(i915 nvidia nvidia_drm nvidia_uvm nvidia_modeset)
or just add the ones there.
Then recreate the initcpio.
@megavolt
Sorry, I did not mean to let your mind explode.
/etc/mkinitcpio.conf was hidden and so I couldn’t find it at first glance.
I edited everything in the way you suggested and hope the issue will be fixed.
So far, thank you very much for your help! I hope this boot issue is history now.
Well I hope you re-generate the images!? Editing it has zero effect. At least on the next kernel update it will take place…
Yes, I ran mkinitcpio -P
. So far, no more blackscreens.
system
Closed
2 August 2022 12:53
14
