Hello,
Due to some issues after upgrading to linux58 (e.g. encountering black blank screen when system wakes up), I decided to downgrade to see if things change, I’ve got linux57 installed as well, so I used (Manjaro Kernels - Manjaro Linux):
sudo mhwd-kernel -i linux57
Which completes properly, but after reboot the 5.8 kernel is still used.
Packages (1) linux57-5.7.19-2
Total Installed Size: 145.47 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [#####################################################] 100%
(1/1) checking package integrity [#####################################################] 100%
(1/1) loading package files [#####################################################] 100%
(1/1) checking for file conflicts [#####################################################] 100%
(1/1) checking available disk space [#####################################################] 100%
(1/1) Save Linux kernel modules
(1/1) reinstalling linux57 [#####################################################] 100%
>>> NOTE, 5.7.19 was the last maintenance release by Greg Kroah-Hartman.
This kernel series is now marked EOL (end of life).
It is recommend to move on to linux58 series.
Use followed cmd to do that: 'sudo mhwd-kernel -i linux58'
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> Starting build: 5.7.19-2-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.7-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.7-x86_64-fallback.img
(4/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.7-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.7-x86_64.img
Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
done
(5/5) Restore Linux kernel modules
==> Warning:
-> Kernel has been updated. Modules of the current kernel
-> have been backed up so you can continue to use your
-> computer. However, the new kernel will only work
-> at next boot.
Also there is no option to run 5.7 from the GUI:
