Switching refresh rate
I just managed to finally upgrade my display drivers without borking my system, but now another issue has come up: I have a 144Hz monitor that I could use fully with the previous drivers (Nvidia 440xx). But if I now try to switch refresh rate from the standard 60Hz the screen goes black and says ‘No signal’. I can’t press ‘Confirm changes’, of course, so the screen reverts to the previous setting (60Hz) and it starts working again.
Could someone help me?
Since you use XFCE, just check or remove the file:
~/.config/xfce4/xfconf/xfce-perchannel-xml/displays.xml
It will regenerate after reboot with the correct values.
Also, did you manually tweaked /etc/X11/mhwd.d/nvidia.conf - can we see the content of it ?
Thanks for your usual prompt presence, Bogdan. Please see under.
# nvidia-xconfig:  version 440.82
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
	Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
EDIT: this is the output of /etc/X11/mhwd.d/nvidia.conf.nvidia-xconfig-original
Ok, that is indeed the default, but is important to know if the one used, aka nvidia.conf has something changed/custom. The goal is to make your displays to run at their native resolution and refresh rate.
No, I haven’t been messing around inside the file.
And removing the
didn’t helped either?
You need to reboot after you remove that file.
Oh, lol, okay. I’ll do it now then and check. Thanks :slight_smile:
Didn’t work :confused:
EDIT: but I notice the file says nvidia-xconfig: version 440.82
Ok, try this for the nvidia.conf
    Screen      0  "Screen0"
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    ModelName      "Unknown"
    VertRefresh     144.0
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    Option  "ConnectToAcpid"    "Off"
    Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline = On}
EndSection
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
then reboot once you modify it.
Didn’t work either.
Can you please open Nvidia X Server Settings and see if the 144Hz is available for that Monitor, and if is, set it and see how that config is written, share it here, then we can append it to the nvidia.conf
You can create a fixed layout too, for each port and Monitor.
Also the XFCE Display Settings should give you some options … but i can’t test right now.
Hmmm… maybe x server is the culprit. It appears to be installed, but it won’t open :question::question::question:
Open up Terminal and run this command:
nvidia-settings
What do you get?
Surprise!
✘ zeno@linux-desktop  ~  nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
Ok, we start from zero then :slight_smile:
inxi -Fxza --no-host
mhwd -li
cat /etc/modprobe.d/mhwd-gpu.conf
cat /etc/modules-load.d/mhwd-gpu.conf
cat /etc/X11/mhwd.d/nvidia.conf
 zeno@linux-desktop  ~  sudo mousepad /etc/X11/mhwd.d/nvidia.conf.nvidia-xconfig-original
[sudo] password for zeno:
 zeno@linux-desktop  ~  inxi -Fxza --no-host
System:    Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=a95e2a41-0994-4bfd-a4ac-fbffb27f2236 rw quiet apparmor=1
           security=apparmor resume=UUID=a2d8244b-5073-464f-94e7-ca19d033980e udev.log_priority=3
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx serial: <filter> UEFI: American Megatrends
           v: 1901 date: 02/20/2020
CPU:       Topology: 8-Core model: Intel Core i7-9700F bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
           stepping: D (13) microcode: D6 L2 cache: 12.0 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 48016
           Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
           Type: srbds mitigation: TSX disabled
Graphics:  Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: ASUSTeK driver: nouveau v: kernel
           alternate: nvidia_drm,nvidia bus ID: 01:00.0 chip ID: 10de:1e81
           Display: x11 server: X.Org 1.20.8 driver: modesetting alternate: fbdev,nouveau,nv,vesa display ID: :0.0 screens: 1
           Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0") s-diag: 777mm (30.6")
           Monitor-1: DP-1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
           OpenGL: renderer: llvmpipe (LLVM 10.0.1 256 bits) v: 3.3 Mesa 20.1.7 compat-v: 3.1 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
           Device-2: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f8
           Device-3: Corsair Corsair VOID PRO USB Gaming Headset type: USB driver: hid-generic,snd-usb-audio,usbhid
           bus ID: 1-8:4 chip ID: 1b1c:0a1d serial: <filter>
           Sound Server: ALSA v: k5.8.6-1-MANJARO
Network:   Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
           chip ID: 8086:15bc
Drives:    Local Storage: total: 262.70 GiB used: 158.68 GiB (60.4%)
           ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB block size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S5Z42102 scheme: GPT
           ID-2: /dev/nvme1n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB block size: physical: 512 B logical: 512 B
           ID-3: /dev/sda type: USB vendor: SanDisk model: Cruzer Glide size: 29.82 GiB block size: physical: 512 B
           logical: 512 B serial: <filter> rev: 2.01 scheme: MBR
Partition: ID-1: / raw size: 914.10 GiB size: 898.75 GiB (98.32%) used: 158.68 GiB (17.7%) fs: ext4 dev: /dev/nvme0n1p2
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 17.12 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 27.8 C mobo: N/A gpu: nouveau temp: 55 C
           Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info:      Processes: 227 Uptime: 10m Memory: 15.56 GiB used: 1.46 GiB (9.4%) Init: systemd v: 246 Compilers: gcc: 10.2.0
           alt: 9 Packages: 1306 pacman: 1285 lib: 368 flatpak: 21 Shell: Zsh v: 5.8 running in: xfce4-terminal inxi: 3.1.05
 zeno@linux-desktop  ~  mhwd -li
> Installed PCI configs:
    video-nvidia-450xx            2019.10.25               false            PCI
 zeno@linux-desktop  ~  cat /etc/modprobe.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
 zeno@linux-desktop  ~  cat /etc/modules-load.d/mhwd-gpu.conf
 zeno@linux-desktop  ~  cat /etc/X11/mhwd.d/nvidia.conf
cat: /etc/X11/mhwd.d/nvidia.conf: No such file or directory
 ✘ zeno@linux-desktop  ~ 
EDIT: I see that I am using the nouveau driver, so I’m guessing something went wrong during the installation of the new drivers.
This is not in use by anything. Is a backup file. I’m not interested in it for now. Is good to have it there, but is not for our purpose now. :slight_smile:
yes, that is what the system uses now
That is why i asked for the other files and outputs.
Try to install the driver, and redo what we mentioned so far. It should work.
Did all of it and still it doesn’t work :sweat: :sweat:
 ✘ zeno@linux-desktop  ~  inxi -Fxza --no-host
  udev.log_priority=3
  serial: <filter> UEFI: American Megatrends v: 1901 date: 02/20/2020
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: D (13)
  bogomips: 48016
  driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1e81
  Display: x11 server: X.Org 1.20.8 driver: nvidia display ID: :0.0
  screens: 1
  Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 109
  OpenGL: renderer: GeForce RTX 2080 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
  direct render: Yes
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:a348
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-8:4 chip ID: 1b1c:0a1d
  serial: <filter>
  port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
  Local Storage: total: 961.33 GiB used: 159.48 GiB (16.6%)
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  size: 29.82 GiB block size: physical: 512 B logical: 512 B
  used: 159.48 GiB (17.7%) fs: ext4 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 47 C
  Processes: 247 Uptime: 2m Memory: 15.56 GiB used: 668.9 MiB (4.2%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 9 Packages: 1310
  pacman: 1287 lib: 368 flatpak: 23 Shell: Zsh v: 5.8
Don’t forget to share this tho:
Here is mhwd -li:
Here is cat /etc/modprobe.d/mhwd-gpu.conf
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
Here is cat /etc/modules-load.d/mhwd-gpu.conf
nvidia
nvidia-drm
Here is cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 450.66
    Screen      0  "Screen0"
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
	Option "NoLogo" "1"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
EDIT: now x server works, too.
