Suspend fails. System suspends and then immediately restarts
Hi All
Suspend was working well for weeks. After an update suspend now goes into suspend but immediately restarts.
I tried from the terminal with ‘systemctl suspend’ and it worked perfectly but only once. Normal Gnome Suspend and terminal manual suspend no longer work.
Using Manjaro 24.2.0. Tried linux kernels 61, 611, 66. No success
SysInfo
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="24.2.0"
DISTRIB_CODENAME="Yonada"
DISTRIB_DESCRIPTION="Manjaro Linux"
 mhwd-kernel -li                                                 ✔
Currently running: 6.11.10-2-MANJARO (linux611)
   * linux61
   * linux611
   * linux66
 Hardware Information:
- **Hardware Model:**                            ASUSTeK COMPUTER INC. PRIME B350-PLUS
- **Memory:**                                         16.0 GiB
- **Processor:**                                      AMD Ryzen™ 3 2200G with Radeon™ Vega Graphics × 4
- **Graphics:**                                       AMD Radeon™ Vega 8 Graphics
- **Disk Capacity:**                               2.0 TB
Software Information:
- **Firmware Version:**                         4602
- **OS Name:**                                     Manjaro Linux
- **OS Build:**                                      rolling
- **OS Type:**                                      64-bit
- **GNOME Version:**                         47
- **Windowing System:**                     Wayland
- **Kernel Version:**                             Linux 6.11.10-2-MANJARO
For many weeks suspend worked unfailingly. A few weeks ago Firefox would lock up from time to time requiring a reboot. Then suspend began to fail.
It suspended but immediately restarted. I am on Wayland with Manjaro(Gnome).
  • Turning Gnome extensions off has had no effect. On kernel Linux 6.11.10-2-MANJARO.
Kindly advise.
Thanks,
Kenneth Wagner
Mod edit:- Formatting
Hello beaucoder, I don’t have an answer for your problem, but have you looked at the kernel ring log messages for any clues? You can do this with the following command:
sudo dmesg
You may consider including more detail about your system that may help others troubleshoot your issue.
Regarding :point_up: I would say to always provide the full output from sudo inxi --filter --verbosity 8 as that is usually far more helpful information than people summarize in their requests for help.
I did check the Arch Wiki for anything on “instantaneous wakeup after suspending”, and did find some interesting information, but for other motherboards, so probably doesn’t apply to your situation. Still, you may find this worth researching:
For some Intel Haswell systems with the LynxPoint and LynxPoint-LP chipset, instantaneous wakeups after suspending are reported. They are linked to erroneous BIOS ACPI implementations and how the xhci_hcd module interprets it during boot. As a work-around reported affected systems are added to a denylist (named XHCI_SPURIOUS_WAKEUP) by the kernel case-by-case [3].
Wakeup may happen, for example, if a USB device is plugged during suspending and ACPI wakeup triggers are enabled. A viable workaround for such a system is to disable the relevant wakeup triggers. An example to disable wakeup through USB is described as follows… Power management/Wakeup triggers - ArchWiki
After a few more updates suspend has started working properly again.
Thanks for your reply.
2 posts were split to a new topic: Suspend fails and immediately restarts
This topic was automatically closed after 7 days. New replies are no longer allowed.
