Stuck in fsck after update
I updated my PC this morning and received a notification about breaking dependencies associated with nVidia drivers. Not thinking much of it, I proceed with the update and rebooted as required.
After a reboot, I am stuck in the fsck screen with this language:
/dev/sda2: clean, 817617/122077184 files, 266143590/488300696 blocks
Having searched the forums and another website, I have:
-Checked for updates in GRUB as (here
-Tried changing the runlevel, like here
Earlier today I did manage to get it to boot in such a way that it provided EE error codes, which as I recall were associated with an nVidia device not detected. I’m unsure of how to replicate results.
At this time, I am unsure how to proceed past fsck.
Hi @kellick,
It seems you,ll have to chroot into you install from a live USB and check/reinstall Nvidia drivers and/or provide other logs.
  1. Boot into a Manjaro live ISO.
  2. Open a terminal and run:
manjaro-chroot -a
You should now be logged in as root on your actual installation, so be careful because any changes can and will persist.
From the chroot environment, run the following and provide the output here:
mhwd-kernel --listinstalled
Also
mhwd-kernel --list
And
And
mhwd --list
And finally
mhwd --listhardware
Also see [HowTo] Provide System Information and, if applicable, [HowTo] post screenshots and links.
Edit:
I don’t think I’ll be the one that provides assistance, I’ve to be off soon, but the info would be necessary for anyone trying to help.
Thanks, I’ll be sure to check the good information posts (I admit I struggled to find them amid some panic).
As for the chroot results:
mhwd-kernel --listinstalled:
*linux513
mhwd-kernel --list:
available kernels:
*linux414
*linux419
*linux44
*linux49
*linux510
*linux514
*linux515
*linux516
*linux54
*linux510-rt
*linux515-rt
inxi --admin --verbosity=7 --filter --no-host --width:
  Kernel 5.13.-1-MANJARO x86_64 bits 64 compiler gcc v 11.1.0
    parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2111 quiet systemd.show_status=1
    apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  Console N/A wm kwin_x11 Distro Manjaro Linux base Arch Linux
  Type Desktop System Micro-Star product MS-7C02 v 1.0 serial N/A
  Mobo Micro-Star model B450 TOMAHAWK (MS-7C02) v 1.0 serial <filter>
    UEFI American Megatrends v 1.E0 date 06/09/2020
  RAM total 15.58 GiB used 3.29 GiB (21.1%)
  Array-1 capacity 8 GiB slots 4 EC None max-module-size 32 GiB note est.
  Device-1 DIMM 0 size No Module Installed
  Device-2 DIMM 1 size 8 GiB speed 2133 MT/s type DDR4
    detail synchronous unbuffered (unregistered) bus-width 64 bits total 64 bits
    manufacturer N/A part-no CL16-18-18 D4-3000 serial N/A
  Device-3 DIMM 0 size No Module Installed
  Device-4 DIMM 1 size 8 GiB speed 2133 MT/s type DDR4
  Info model AMD Ryzen 5 2600 socket AM4 bits 64 type MT MCP arch Zen+
    family 0x17 (23) model-id 8 stepping 2 microcode 0x800820D
  Topology cpus 1x cores 6 tpc 2 threads  smt enabled cache L1 576 KiB
    desc d-6x32 KiB; i-6x64 KiB L2 3 MiB desc 6x5 KiB L3 16 MiB desc 2x8 MiB
  Speed (MHz) avg 1808 high 3400 min/max 1550/3400 boost enabled
    base/boost 3400/3900 scaling driver acpi-cpufreq governor schedutil
    volts 1.1 V ext-clock 100 MHz cores 1 1550 2 1550 3 1550 4 1550 5 1550
    6 3400 7 2800 8 1550 9 1550 10 1550 11 1550  1550 bogomips 81615
  Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
    sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Vulnerabilities
  Type itlb_multihit status Not affected
  Type l1tf status Not affected
  Type mds status Not affected
  Type meltdown status Not affected
  Type spec_store_bypass
    mitigation Speculative Store Bypass disabled via prctl and seccomp
  Type spectre_v1
    mitigation usercopy/swapgs barriers and __user pointer sanitization
  Type spectre_v2 mitigation Full AMD retpoline, IBPB: conditional, STIBP:
    disabled, RSB filling
  Type srbds status Not affected
  Type tsx_async_abort status Not affected
  Device-1 NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor eVga.com.
    driver nvidia v 470.63.01 bus-ID 26:00.0 chip-ID 10de:1e87 class-ID 0300
  Display server X.Org 1.20.13 compositor kwin_x11 driver loaded nvidia
    note n/a (using device driver) failed nvidia display-ID :0 screens 1
  Screen-1 0 s-res 4480x1440 s-dpi 92 s-size 37x402mm (48.7x15.8")
    s-diag 1301mm (51.2")
  Monitor-1 HDMI-0 res 1920x1080 hz 60 dpi 93 size 527x296mm (20.7x11.7")
    diag 604mm (23.8")
  Monitor-2 DP-4 res 2560x1440 hz 60 dpi 3 size 527x296mm (20.7x11.7")
    diag 604mm (23.8")
  OpenGL renderer N/A v N/A direct render N/A
  Device-1 NVIDIA TU104 HD Audio vendor eVga.com. driver snd_hda_intel
    v kernel bus-ID 26:00.1 chip-ID 10de:10f8 class-ID 0403
  Device-2 AMD Family 17h HD Audio vendor Micro-Star MSI
    driver snd_hda_intel v kernel bus-ID 28:00.3 chip-ID 1022:1457 class-ID 0403
  Device-3 Corsair HS60 Surround Adapter type USB
    driver hid-generic,snd-usb-audio,usbhid bus-ID 1-9:2 chip-ID 1b1c:0a3b
    class-ID 0300 serial <filter>
  Sound Server-1 ALSA v k5.13.-1-MANJARO running yes
  Sound Server-2 JACK v 1.9.20 running no
  Sound Server-3 PulseAudio v 15.0 running yes
  Sound Server-4 PipeWire v 0.3.43 running yes
  Device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor Micro-Star MSI driver r8169 v kernel port f000 bus-ID 22:00.0
    chip-ID 10ec:8168 class-ID 0200
  IF enp34s0 state up speed 1000 Mbps duplex full mac <filter>
  IP v4 <filter> type dynamic noprefixroute scope global broadcast <filter>
  IP v6 <filter> type dynamic noprefixroute scope global
  IP v6 <filter> type noprefixroute scope link
  Device-2 Intel Wireless 7265 driver iwlwifi v kernel bus-ID 25:00.0
    chip-ID 8086:095a class-ID 0280
  IF wlp37s0 state down mac <filter>
  WAN IP <filter>
  Device-1 Intel Bluetooth wireless interface type USB driver btusb v 0.8
    bus-ID 1-10:3 chip-ID 8087:0a2a class-ID e001
  Report rfkill ID hci0 rfk-id 1 state up address see --recommends
  Message No logical block device data found.
  Message No RAID data found.
  Local Storage total 3.2 TiB used 984.96 GiB (30.1%)
  ID-1 /dev/sda maj-min 8:0 vendor Seagate model ST2000LX001-1RG174
    family FireCuda 2.5 size 1.82 TiB block-size physical 4096 B logical 5 B
    sata 3.1 speed 6.0 Gb/s type HDD rpm 5400 serial <filter> rev SDM1
    temp 25 C
  SMART yes state enabled health PASSED on 298d 16h cycles 1449
    read 15.11 TiB written 10.11 TiB Pre-Fail attribute Spin_Retry_Count
    value 100 worst 100 threshold 97
  ID-2 /dev/sdb maj-min 8:16 vendor Western Digital model WD10EZEX-22MFCA0
    family Blue size 931.51 GiB block-size physical 4096 B logical 5 B
    sata 3.1 speed 6.0 Gb/s type HDD rpm 7200 serial <filter> rev 1A01
    temp 30 C
  SMART yes state enabled health PASSED on 329d 20h cycles 1593
  ID-3 /dev/sdc maj-min 8:32 vendor Western Digital model WDS500G2B0B-00YS70
    family WD Blue / Red / Green SSDs size 465.76 GiB block-size physical 5 B
    logical 5 B sata 3.3 speed 6.0 Gb/s type SSD serial <filter> rev 00WD
    temp 31 C
  SMART yes state enabled health PASSED on 330d 10h cycles 1594
  ID-4 /dev/sdd maj-min 8:48 type USB vendor SanDisk model Ultra
    size 14.32 GiB block-size physical 5 B logical 5 B type N/A
    serial <filter> rev 1.00
  SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  Message No optical or floppy data found.
  ID-1 / raw-size 1.82 TiB size 1.79 TiB (98.37%) used 984.95 GiB (53.8%)
    fs ext4 block-size 4096 B dev /dev/sda2 maj-min 8:2 label N/A
    uuid cbce3f07-5638-4b02-a6fd-688a4f0ec6e9
  ID-2 /boot/efi raw-size 300 MiB size 299.4 MiB (99.80%)
    used 288 KiB (0.1%) fs vfat block-size 5 B dev /dev/sda1 maj-min 8:1
    label NO_LABEL uuid 5BF1-A72B
  Alert No swap data was found.
  ID-1 /dev/sdb1 maj-min 8:17 size 16 MiB fs N/A label N/A uuid N/A
  ID-2 /dev/sdb2 maj-min 8:18 size 931.5 GiB fs N/A label N/A uuid N/A
  ID-3 /dev/sdc1 maj-min 8:33 size 499 MiB fs ntfs label Recovery
    uuid 26DA08A9DA087779
  ID-4 /dev/sdc2 maj-min 8:34 size 99 MiB fs fat (32 bit) label N/A
    uuid 5E09-638D
  ID-5 /dev/sdc3 maj-min 8:35 size 16 MiB fs N/A label N/A uuid N/A
  ID-6 /dev/sdc4 maj-min 8:36 size 465.16 GiB fs ntfs label Turbo
    uuid 38320AD2320A94D2
  ID-7 /dev/sdd1 maj-min 8:49 size 2.97 GiB fs N/A label MANJARO_KDE_2111
    uuid 2021-08-27-13-22-26-00
  ID-8 /dev/sdd2 maj-min 8:50 size 4 MiB fs N/A label MISO_EFI
    uuid 0AF1-FA50
  Hub-1 1-0:1 info Hi-speed hub with single TT ports 10 rev 2.0 speed 480 Mb/s
    chip-ID 1d6b:0002 class-ID 0900
  Device-1 1-9:2 info Corsair HS60 Surround Adapter type Audio,HID
    driver hid-generic,snd-usb-audio,usbhid interfaces 4 rev 1.1 speed  Mb/s
    power 500mA chip-ID 1b1c:0a3b class-ID 0300 serial <filter>
  Device-2 1-10:3 info Intel Bluetooth wireless interface type Bluetooth
    driver btusb interfaces 2 rev 2.0 speed  Mb/s power 100mA
  Hub-2 2-0:1 info Super-speed hub ports 4 rev 3.1 speed 10 Gb/s
    chip-ID 1d6b:0003 class-ID 0900
  Device-1 2-3:2 info SanDisk Ultra type Mass Storage driver usb-storage
    interfaces 1 rev 3.0 speed 5 Gb/s power 896mA chip-ID 0781:5581
    class-ID 0806 serial <filter>
  Hub-3 3-0:1 info Hi-speed hub with single TT ports 2 rev 2.0
    speed 480 Mb/s chip-ID 1d6b:0002 class-ID 0900
  Hub-4 4-0:1 info Super-speed hub ports 4 rev 3.1 speed 10 Gb/s
  Hub-5 5-0:1 info Hi-speed hub with single TT ports 4 rev 2.0
  Device-1 5-1:2 info Logitech G203 Gaming Mouse type Mouse,HID
    driver hid-generic,usbhid interfaces 2 rev 2.0 speed  Mb/s power 300mA
    chip-ID 046d:c084 class-ID 0300 serial <filter>
  Device-2 5-2:3 info Areson Corp Keyboard type Keyboard,Mouse
    driver hid-generic,usbhid interfaces 2 rev 1.1 speed  Mb/s power 498mA
    chip-ID 25a7:fa71 class-ID 0301
  Hub-6 6-0:1 info Super-speed hub ports 4 rev 3.0 speed 5 Gb/s
  System Temperatures cpu 27.8 C mobo N/A gpu nvidia temp 41 C
  Fan Speeds (RPM) N/A gpu nvidia fan 0%
  Processes 313 Uptime 11m wakeups 1 Init systemd v 250 tool systemctl
  Compilers gcc 11.1.0 clang 13.0.0 Packages 1458 pacman 1453 lib 429
  flatpak 5 Client Unknown Client: systemd inxi 3.3.
mhwd --list
0000:26:00.0 (0300:10de:1e87) Display controller nVidia Corporation:
          video-nvidia            2021..18               false            PCI
    video-nvidia-470xx            2021..18               false            PCI
           video-linux            2018.05.04                true            PCI
            video-vesa            2017.03.                true            PCI
0000:22:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
mhwd --listhardware
PCI devices:
                          TYPE            BUS   CLASS  VENDOR  DEVICE   CONFIGS
         Serial bus controller   0000:03:00.0    0c03    1022    43d5         0
                        Bridge   0000:00:03.1    0604    1022    1453         0
                        Bridge   0000:20:00.0    0604    1022    43c7         0
                        Bridge   0000:00:08.0    0600    1022    1452         0
                        Bridge   0000:00:18.3    0600    1022    1463         0
            Display controller   0000:26:00.0    0300    10de    1e87         5
         Multimedia controller   0000:28:00.3    0403    1022    1457         0
                        Bridge   0000:00:18.1    0600    1022    1461         0
                        Bridge   0000:00:01.0    0600    1022    1452         0
            Network controller   0000:25:00.0    0200    8086    095a         0
                        Bridge   0000:00:04.0    0600    1022    1452         0
                        Bridge   0000:00:14.3    0601    1022    790e         0
         Serial bus controller   0000:27:00.3    0c03    1022    145f         0
                        Bridge   0000:00:07.0    0600    1022    1452         0
     Generic system peripheral   0000:00:00.2    0806    1022    1451         0
                        Bridge   0000:00:18.6    0600    1022    1466         0
         Serial bus controller   0000:26:00.3    0c80    10de    1ad9         0
       Mass storage controller   0000:03:00.1    0106    1022    43c8         0
                        Bridge   0000:00:00.0    0600    1022    1450         0
                        Bridge   0000:00:08.1    0604    1022    1454         0
                        Bridge   0000:00:18.4    0600    1022    1464         0
                        Bridge   0000:00:01.3    0604    1022    1453         0
         Multimedia controller   0000:26:00.1    0403    10de    10f8         0
                        Bridge   0000:00:03.0    0600    1022    1452         0
                        Bridge   0000:00:18.2    0600    1022    1462         0
       Mass storage controller   0000:28:00.2    0106    1022    7901         0
                        Bridge   0000:00:18.0    0600    1022    1460         0
            Network controller   0000:22:00.0    0200    10ec    8168         1
                        Bridge   0000:20:01.0    0604    1022    43c7         0
 Non-Essential Instrumentation   0000:28:00.0    1300    1022    1455         0
                        Bridge   0000:00:07.1    0604    1022    1454         0
                        Bridge   0000:20:04.0    0604    1022    43c7         0
         Encryption controller   0000:27:00.2    1080    1022    1456         0
                        Bridge   0000:00:02.0    0600    1022    1452         0
                        Bridge   0000:00:18.7    0600    1022    1467         0
                        Bridge   0000:03:00.2    0604    1022    43c6         0
         Serial bus controller   0000:00:14.0    0c05    1022    790b         0
 Non-Essential Instrumentation   0000:27:00.0    1300    1022    145a         0
                        Bridge   0000:00:18.5    0600    1022    1465         0
         Serial bus controller   0000:26:00.2    0c03    10de    1ad8         0
USB devices:
           Mass Storage Device       11:0:0:0   10600    0781    5581         0
         Multimedia controller        1-9:1.0    0401    1b1c    0a3b         0
                         Mouse        5-1:1.0   10503    046d    c084         0
                           Hub        6-0:1.0   10a00    1d6b    0003         0
              Bluetooth Device       1-10:1.0   11500    8087    0a2a         0
                           Hub        3-0:1.0   10a00    1d6b    0002         0
                      Keyboard        5-2:1.0   10800    25a7    fa71         0
           Unclassified device        1-9:1.3    0000    1b1c    0a3b         0
           Unclassified device        5-1:1.1    0000    046d    c084         0
                           Hub        4-0:1.0   10a00    1d6b    0003         0
                           Hub        1-0:1.0   10a00    1d6b    0002         0
                         Mouse        5-2:1.1   10503    25a7    fa71         0
                           Hub        5-0:1.0   10a00    1d6b    0002         0
                           Hub        2-0:1.0   10a00    1d6b    0003         0
Let this be a lesson to start reading the errors and the update announcements before updating. Kernel 5.13 is EOL. And has been for some time. You’ll have to install another one:
In the chroot environment, run the following to install kernel 5.15:
mhwd-kernel --install linux515
Followed by rebooting, hammering the Esc frrom the BIOS splash screen until the GRUB boot loader screen appears.
On the screen navigate to the Advanced… option, and press Enter to enter the menu. On the screen, navigate to kernel 5.15, and press Enter when on it to boot using that kernel.
You should now be able to use your computer, but don’t. First open a terminal and remove the old kernel:
sudo mhwd-kernel --remove linux513
And reboot again. Then synchronise your system again:
pamac upgrade --enable-downgrade
I’ve run the install command as specified, and have rebooted the computer.
However, I’m unsure in my situation how to get to the GRUB bootloader. Is that the GNU GRUB command line interface? If it is, it’s at version 2.06~1~ and only has the command line, not advanced options showing kernel 5.15.
Then how do I get to desktop after that menu? Do I have to enter commands in GRUB or the Edit mode?
After implementing some of Mirdarthos’s recommendations, I reentered a live boot ISO to use chroot again and try to gain some information.
To that end, when I ran manjaro-chroot -a, I received this output (I am unsure if this relates to my difficulty booting to my Manjaro installation):
grub-probe: error: cannot find a GRUB drive for /dev/sdd1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
Additionally, having run the commands within chroot to update to kernel 5.15, I re-ran
  RAM total 15.58 GiB used 3.38 GiB (21.7%)
  Speed (MHz) avg 1704 high 3400 min/max 1550/3400 boost enabled
    6 3400 7 1550 8 1550 9 1550 10 1550 11 1550  1550 bogomips 81616
  Vulnerabilities
  Type spectre_v1
    diag 604mm (23.8")
    diag 604mm (23.8")
  WAN IP <filter>
  Local Storage total 3.2 TiB used 985.27 GiB (30.1%)
    temp 26 C
  SMART yes state enabled health PASSED on 298d 17h cycles 1452
    temp 29 C
  SMART yes state enabled health PASSED on 329d 21h cycles 1596
    temp 32 C
  SMART yes state enabled health PASSED on 330d 11h cycles 1597
  ID-1 / raw-size 1.82 TiB size 1.79 TiB (98.37%) used 985.27 GiB (53.8%)
    uuid 5E09-638D
    uuid 0AF1-FA50
  System Temperatures cpu 29.5 C mobo N/A gpu nvidia temp 40 C
  Processes 318 Uptime 5m wakeups 1 Init systemd v 250 tool systemctl
  Compilers gcc 11.1.0 clang 13.0.0 Packages 1459 pacman 1454 lib 429
To that end, it doesn’t appear I finalized my Kernel 5.15 installation, and I am stuck at how to follow the specified commands to boot where indicated.
Please excuse me if I’m completely wrong here. I’ve been a Manjaro user for 2 years but I’m not an expert.
Can you not do nomodeset at boot to get into the system and then do the driver installation fix once you are in? I’ve done things like this before.
Sorry if this is a useless suggestion. Hope it’s not though.
That’s ok! I’m not sure what the nomodeset command is. And, at this point, I’m more concerned with getting my installation to the right kernel than attending to drivers.
I am not able to complete boot into my desktop, so I would have to run the commands with chroot or GRUB within the live ISO.
Hi kellick,
just had the same problem, and solved it this way:
  1. Install linux515 in a chroot environment as mentioned before
  2. Additionally, install linux515-nvidia
  3. Reboot and make sure to boot Kernel 5.15
Problem is, the nvidia-package for Kernel 5.13 (linux513-nvidia) does not exist the Manjaro repository.
Hope this helps.
If you can still chroot as Mirdarthos explained, enter in and rerun mhwd-kernel --install linux515 and post the output here. Also take @Frawo 's advice and install linux515-nvidia. Then reboot, and remove the USB for the live iso, and hit Esc a bunch as as soon as your computer turns on until a menu appears (there may be a menu in between rebooting and grub, just hit enter on grub). There should be an option marked something like Boot to 5.15 in either that screen or an Advanced screen. Navigate with arrow keys and press enter on that.
If you do this, and see the fsck message you got earlier without getting into your system, hit Esc again and take a picture of the output if something appears (might be [ OK ] a bunch of times with words trailing).
If you have any questions, error codes, etc. please post & ask.
Good Luck!
There have been some spectacular replies to this thread, however I have moved forward with a clean re-install (largely out of my own frustration). Thank you very much though for the support!
I hope you downloaded the latest version of the installation medium. The one you had installed has an end-of-life (unsupported) kernel, which was probably causing your problems with nvidia.
Tip: When pasting terminal output on Discourse forums, one can either…
  • Use the Preformatted text </> toolbar button–NOT the Quote " button.
  • Add three backticks ` above and below the text (Markdown):
    type or paste code here
  • Use HTML:
    <pre><code>
    </pre></code>
I’ve done it for you this time. :wink:
P.S. Where in Tarnation did the 12 on every line come from? :thinking:
I’ll make it a point to reference back to this whenever I need to post terminal output, thank you!
