Shutter crashed , i couldnt do anything so i force shutdown my pc and now it wont boot anymore
Check if the filesystem is damaged.
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
- Please press the three dots ⌠below your post and then press the
- If you give us information about your system, we can see what weâre talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading
