Stuck at "/dev/sdb2 clean", no GUI
Hello team,
since grub restoral Grub-fix I can not boot Manjaro. I am using dual boot, 2 disks:
/dev/sda → efi partition, Windows
/dev/sdb → Manjaro /, /home
I have got live usb, as well as I can terminal with ctrl + alt + F2
Could you advise please ?
mhwd -li
e[1me[31m> e[mInstalled PCI configs:
           video-linux            2018.05.04                true            PCI
mhwd -l
e[1me[31mWarning: e[mNo installed USB configs!
e[1me[31m> e[m0000:01:00.0 (0380:1002:6600) Display controller ATI Technologies Inc:
e[1me[31m> e[m0000:00:02.0 (0300:8086:0166) Display controller Intel Corporation:
sudo pacman -Syu
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
 there is nothing to do
journalctl --boot 0 --no-page is too big to be attached here, forum error. I used pastebin: journalctl --boot 0 --no-pager
journalctl -b -e
Mar 02 12:09:29 computer systemd[1]: Listening on Device-mapper event daemon FIFOs.
Mar 02 12:09:29 computer systemd[1]: Listening on LVM2 poll daemon socket.
Mar 02 12:09:29 computer systemd[1]: Listening on Process Core Dump Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on Journal Audit Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on Journal Socket (/dev/log).
Mar 02 12:09:29 computer systemd[1]: Listening on Journal Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on udev Control Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on udev Kernel Socket.
Mar 02 12:09:29 computer systemd[1]: Mounting Huge Pages File System...
Mar 02 12:09:29 computer systemd[1]: Mounting POSIX Message Queue File System...
Mar 02 12:09:29 computer systemd[1]: Mounting Kernel Debug File System...
Mar 02 12:09:29 computer systemd[1]: Mounting Kernel Trace File System...
Mar 02 12:09:29 computer systemd[1]: Starting Create List of Static Device Nodes...
Mar 02 12:09:29 computer systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Module configfs...
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Module drm...
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Module fuse...
Mar 02 12:09:29 computer systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Modules...
Mar 02 12:09:29 computer systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 02 12:09:29 computer systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 02 12:09:29 computer systemd[1]: Starting Coldplug All udev Devices...
Mar 02 12:09:29 computer systemd[1]: Mounted Huge Pages File System.
Mar 02 12:09:29 computer systemd[1]: Mounted POSIX Message Queue File System.
Mar 02 12:09:29 computer systemd[1]: Mounted Kernel Debug File System.
Mar 02 12:09:29 computer systemd[1]: Mounted Kernel Trace File System.
Mar 02 12:09:29 computer systemd[1]: Finished Create List of Static Device Nodes.
Mar 02 12:09:29 computer systemd[1]: modprobe@configfs.service: Deactivated successfully.
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Module configfs.
Mar 02 12:09:29 computer systemd[1]: modprobe@drm.service: Deactivated successfully.
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Module drm.
Mar 02 12:09:29 computer systemd[1]: Mounting Kernel Configuration File System...
Mar 02 12:09:29 computer systemd[1]: Mounted Kernel Configuration File System.
Mar 02 12:09:29 computer kernel: EXT4-fs (sdb2): re-mounted. Opts: (null). Quota mode: none.
Mar 02 12:09:29 computer systemd[1]: Finished Remount Root and Kernel File Systems.
Mar 02 12:09:29 computer systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:29 computer systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 02 12:09:29 computer systemd[1]: Starting Load/Save Random Seed...
Mar 02 12:09:29 computer systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 02 12:09:29 computer systemd[1]: Starting Create Static Device Nodes in /dev...
Mar 02 12:09:29 computer kernel: fuse: init (API version 7.34)
Mar 02 12:09:29 computer systemd[1]: modprobe@fuse.service: Deactivated successfully.
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Module fuse.
Mar 02 12:09:29 computer systemd[1]: Mounting FUSE Control File System...
Mar 02 12:09:29 computer systemd[1]: Mounted FUSE Control File System.
Mar 02 12:09:29 computer systemd[1]: Finished Load/Save Random Seed.
Mar 02 12:09:29 computer systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:29 computer systemd[1]: Finished Coldplug All udev Devices.
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Modules.
Mar 02 12:09:29 computer systemd[1]: Starting Apply Kernel Variables...
Mar 02 12:09:29 computer systemd[1]: Finished Apply Kernel Variables.
Mar 02 12:09:29 computer systemd[1]: Finished Create Static Device Nodes in /dev.
Mar 02 12:09:29 computer systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 02 12:09:29 computer systemd[1]: Starting Journal Service...
Mar 02 12:09:29 computer systemd[1]: Starting Rule-based Manager for Device Events and Files...
Mar 02 12:09:29 computer systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Mar 02 12:09:29 computer systemd[1]: Reached target Preparation for Local File Systems.
Mar 02 12:09:29 computer systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
Mar 02 12:09:29 computer systemd-journald[254]: Journal started
Mar 02 12:09:29 computer systemd-journald[254]: Runtime Journal (/run/log/journal/da739cc6ab55434091bee8079b1e1ed4) is 8.0M, max 189.3M, 181.3M free.
Mar 02 12:09:29 computer systemd-modules-load[242]: Inserted module 'crypto_user'
Mar 02 12:09:29 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:29 computer systemd-modules-load[242]: Inserted module 'sg'
Mar 02 12:09:29 computer systemd-modules-load[242]: Inserted module 'uinput'
Mar 02 12:09:29 computer systemd[1]: Starting Flush Journal to Persistent Storage...
Mar 02 12:09:29 computer systemd[1]: Started Journal Service.
Mar 02 12:09:29 computer kernel: audit: type=1130 audit(1677755369.965:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:29 computer systemd-journald[254]: Time spent on flushing to /var/log/journal/da739cc6ab55434091bee8079b1e1ed4 is 295.723ms for 840 entries.
Mar 02 12:09:29 computer systemd-journald[254]: System Journal (/var/log/journal/da739cc6ab55434091bee8079b1e1ed4) is 1.9G, max 3.9G, 1.9G free.
Mar 02 12:09:35 computer systemd-journald[254]: Received client request to flush runtime journal.
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755370.742:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI: OSL: Resource conflict; ACPI support missing from driver?
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Mar 02 12:09:35 computer kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
Mar 02 12:09:35 computer kernel: i2c i2c-0: 1/2 memory slots populated (from DMI)
Mar 02 12:09:35 computer kernel: i2c i2c-0: Successfully instantiated SPD at 0x50
Mar 02 12:09:35 computer kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 02 12:09:35 computer kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mar 02 12:09:35 computer kernel: input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input6
Mar 02 12:09:35 computer kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
Mar 02 12:09:35 computer kernel: RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
Mar 02 12:09:35 computer kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Mar 02 12:09:35 computer kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
Mar 02 12:09:35 computer kernel: ideapad_acpi VPC2004:00: DYTC interface is not available
Mar 02 12:09:35 computer kernel: cryptd: max_cpu_qlen set to 1000
Mar 02 12:09:35 computer kernel: alx 0000:02:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [20:89:84:fe:a0:61]
Mar 02 12:09:35 computer kernel: at24 0-0050: supply vcc not found, using dummy regulator
Mar 02 12:09:35 computer kernel: at24 0-0050: 256 byte spd EEPROM, read-only
Mar 02 12:09:35 computer kernel: iTCO_vendor_support: vendor-support=0
Mar 02 12:09:35 computer kernel: Bluetooth: Core ver 2.22
Mar 02 12:09:35 computer kernel: NET: Registered PF_BLUETOOTH protocol family
Mar 02 12:09:35 computer kernel: Bluetooth: HCI device and connection manager initialized
Mar 02 12:09:35 computer kernel: Bluetooth: HCI socket layer initialized
Mar 02 12:09:35 computer kernel: Bluetooth: L2CAP socket layer initialized
Mar 02 12:09:35 computer kernel: Bluetooth: SCO socket layer initialized
Mar 02 12:09:35 computer kernel: alx 0000:02:00.0 enp2s0: renamed from eth0
Mar 02 12:09:35 computer kernel: Intel(R) Wireless WiFi driver for Linux
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0: loaded firmware version 17.3216344376.0 7260-17.ucode op_mode iwlmvm
Mar 02 12:09:35 computer kernel: usbcore: registered new interface driver btusb
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: Legacy ROM 2.5 revision 8.0 build 2 week 3 2013
Mar 02 12:09:35 computer kernel: [drm] radeon kernel modesetting enabled.
Mar 02 12:09:35 computer kernel: vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
Mar 02 12:09:35 computer kernel: ATPX version 1, functions 0x00000033
Mar 02 12:09:35 computer kernel: Console: switching to colour dummy device 80x25
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: enabling device (0000 -> 0003)
Mar 02 12:09:35 computer kernel: [drm] initializing kernel modesetting (OLAND 0x1002:0x6600 0x17AA:0x3800 0x00).
Mar 02 12:09:35 computer kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Mar 02 12:09:35 computer kernel: ATOM BIOS: Lenovo
Mar 02 12:09:35 computer kernel: [drm] GPU not posted. posting now...
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: GTT: 2048M 0x0000000080000000 - 0x00000000FFFFFFFF
Mar 02 12:09:35 computer kernel: [drm] Detected VRAM RAM=2048M, BAR=128M
Mar 02 12:09:35 computer kernel: [drm] RAM width 128bits DDR
Mar 02 12:09:35 computer kernel: [drm] radeon: 2048M of VRAM memory ready
Mar 02 12:09:35 computer kernel: [drm] radeon: 2048M of GTT memory ready.
Mar 02 12:09:35 computer kernel: [drm] Loading oland Microcode
Mar 02 12:09:35 computer kernel: iTCO_wdt iTCO_wdt.3.auto: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
Mar 02 12:09:35 computer kernel: iTCO_wdt iTCO_wdt.3.auto: initialized. heartbeat=30 sec (nowayout=0)
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755372.725:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x450f03)
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755372.725:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-EC40\x2dE2D4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
Mar 02 12:09:35 computer kernel: psmouse serio1: elantech: Synaptics capabilities query result 0x78, 0x17, 0x0b.
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0: base HW address: a0:a8:cd:eb:a4:e2
Mar 02 12:09:35 computer kernel: psmouse serio1: elantech: Elan sample query result 04, 5c, 85
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: Intel BT fw patch 0x57 completed & activated
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755372.785:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:platform::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: [drm] Internal thermal controller without fan control
Mar 02 12:09:35 computer kernel: [drm] radeon: dpm initialized
Mar 02 12:09:35 computer kernel: input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input5
Mar 02 12:09:35 computer kernel: [drm] GART: num cpu pages 524288, num gpu pages 524288
Mar 02 12:09:35 computer kernel: [drm] PCIE gen 2 link speeds already enabled
Mar 02 12:09:35 computer kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: WB enabled
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: radeon: MSI limited to 32-bit
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: radeon: using MSI.
Mar 02 12:09:35 computer kernel: [drm] radeon: irq initialized.
Mar 02 12:09:35 computer kernel: Adding 1048572k swap on /dev/sdb1.  Priority:-2 extents:1 across:1048572k FS
Mar 02 12:09:35 computer kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
Mar 02 12:09:35 computer kernel: mousedev: PS/2 mouse device common for all mice
Mar 02 12:09:35 computer kernel: intel_rapl_common: Found RAPL domain package
Mar 02 12:09:35 computer kernel: intel_rapl_common: Found RAPL domain core
Mar 02 12:09:35 computer kernel: intel_rapl_common: Found RAPL domain uncore
Mar 02 12:09:35 computer kernel: intel_rapl_common: RAPL package-0 domain package locked by BIOS
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
Mar 02 12:09:35 computer kernel: mc: Linux media interface: v0.10
Mar 02 12:09:35 computer kernel: videodev: Linux video capture interface: v2.00
Mar 02 12:09:35 computer kernel: [drm] ring test on 0 succeeded in 1 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 1 succeeded in 1 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 2 succeeded in 1 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 3 succeeded in 4 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 4 succeeded in 3 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 5 succeeded in 2 usecs
Mar 02 12:09:35 computer kernel: [drm] UVD initialized successfully.
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: usb 3-4: Found UVC 1.00 device Lenovo EasyCamera (0bda:5728)
Mar 02 12:09:35 computer kernel: input: Lenovo EasyCamera: Lenovo EasyC as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/input/input7
Mar 02 12:09:35 computer kernel: usbcore: registered new interface driver uvcvideo
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755373.472:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fcdff842\x2d3f01\x2d43f7\x2d8655\x2d900b7b489fd8 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 5 succeeded
Mar 02 12:09:35 computer kernel: [drm] Radeon Display Connectors
Mar 02 12:09:35 computer kernel: [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
Mar 02 12:09:35 computer kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
Mar 02 12:09:35 computer kernel: ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
Mar 02 12:09:35 computer kernel: ACPI: video: Video Device [PEGP] (multi-head: yes  rom: no  post: no)
Mar 02 12:09:35 computer kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/LNXVIDEO:00/input/input8
Mar 02 12:09:35 computer kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Mar 02 12:09:35 computer kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:03/input/input9
Mar 02 12:09:35 computer kernel: snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Mar 02 12:09:35 computer kernel: vga_switcheroo: enabled
Mar 02 12:09:35 computer kernel: fbcon: i915drmfb (fb0) is primary device
Mar 02 12:09:35 computer kernel: Console: switching to colour frame buffer device 170x48
Mar 02 12:09:35 computer kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755374.865:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0: CX20757: BIOS auto-probing.
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX20757: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    mono: mono_out=0x0
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    inputs:
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:      Mic=0x19
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    dig-in=0x1a
Mar 02 12:09:35 computer kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
Mar 02 12:09:35 computer kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
Mar 02 12:09:35 computer kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
Mar 02 12:09:30 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:32 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:32 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-EC40\x2dE2D4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:32 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:platform::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:33 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fcdff842\x2d3f01\x2d43f7\x2d8655\x2d900b7b489fd8 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:34 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:30 computer systemd[1]: Started Rule-based Manager for Device Events and Files.
Mar 02 12:09:32 computer mtp-probe[292]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4"
Mar 02 12:09:31 computer systemd[1]: Found device TOSHIBA_MQ02ABF050H Microsoft\x20basic\x20data.
Mar 02 12:09:32 computer mtp-probe[291]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd-fsck[316]: fsck.fat 4.2 (2021-01-31)
Mar 02 12:09:35 computer systemd-fsck[316]: /dev/sda2: 312 files, 48777/98304 clusters
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.448:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:31 computer systemd[1]: Starting File System Check on /dev/disk/by-uuid/EC40-E2D4...
Mar 02 12:09:32 computer mtp-probe[291]: bus: 3, device: 2 was not an MTP device
Mar 02 12:09:31 computer systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 02 12:09:32 computer mtp-probe[292]: bus: 1, device: 4 was not an MTP device
Mar 02 12:09:31 computer systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 02 12:09:32 computer systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 02 12:09:35 computer systemd-fsck[342]: /dev/sdb3: clean, 571851/3932160 files, 15097432/15728640 blocks
Mar 02 12:09:32 computer systemd[1]: Finished File System Check on /dev/disk/by-uuid/EC40-E2D4.
Mar 02 12:09:32 computer systemd[1]: Found device ST1000LM014-1EJ164 3.
Mar 02 12:09:32 computer systemd[1]: Created slice Slice /system/systemd-backlight.
Mar 02 12:09:32 computer systemd[1]: Mounting /boot/efi...
Mar 02 12:09:32 computer systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 02 12:09:32 computer systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight...
Mar 02 12:09:32 computer systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:32 computer systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:32 computer systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Mar 02 12:09:32 computer systemd[1]: Starting File System Check on /dev/disk/by-uuid/fcdff842-3f01-43f7-8655-900b7b489fd8...
Mar 02 12:09:32 computer systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 02 12:09:32 computer systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 02 12:09:32 computer systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 02 12:09:32 computer systemd[1]: Found device ST1000LM014-1EJ164 1.
Mar 02 12:09:32 computer systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight.
Mar 02 12:09:32 computer systemd[1]: Activating swap /dev/disk/by-uuid/62a959f8-998a-4b75-8c86-54f4a0461707...
Mar 02 12:09:32 computer systemd[1]: Activated swap /dev/disk/by-uuid/62a959f8-998a-4b75-8c86-54f4a0461707.
Mar 02 12:09:32 computer systemd[1]: Reached target Swaps.
Mar 02 12:09:33 computer systemd[1]: Mounting Temporary Directory /tmp...
Mar 02 12:09:33 computer systemd[1]: Mounted /boot/efi.
Mar 02 12:09:33 computer systemd[1]: Mounted Temporary Directory /tmp.
Mar 02 12:09:33 computer systemd[1]: Finished File System Check on /dev/disk/by-uuid/fcdff842-3f01-43f7-8655-900b7b489fd8.
Mar 02 12:09:33 computer systemd[1]: Mounting /home...
Mar 02 12:09:33 computer systemd[1]: Mounted /home.
Mar 02 12:09:33 computer systemd[1]: Reached target Local File Systems.
Mar 02 12:09:33 computer systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
Mar 02 12:09:33 computer systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Mar 02 12:09:33 computer systemd[1]: Store a System Token in an EFI Variable was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:33 computer systemd[1]: Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Mar 02 12:09:34 computer systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Mar 02 12:09:34 computer systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Mar 02 12:09:35 computer systemd[1]: Finished Flush Journal to Persistent Storage.
Mar 02 12:09:35 computer systemd[1]: Starting Create Volatile Files and Directories...
Mar 02 12:09:35 computer systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 02 12:09:35 computer systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Store a System Token in an EFI Variable was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:35 computer systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:35 computer systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:35 computer systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 02 12:09:35 computer systemd[1]: Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Mar 02 12:09:35 computer systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Finished Create Volatile Files and Directories.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
Mar 02 12:09:35 computer audit: BPF prog-id=21 op=LOAD
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.665:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.665:11): prog-id=21 op=LOAD
Mar 02 12:09:35 computer systemd[1]: Starting Network Time Synchronization...
Mar 02 12:09:35 computer systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Mar 02 12:09:35 computer kernel: [drm] amdgpu kernel modesetting enabled.
Mar 02 12:09:35 computer kernel: amdgpu: CRAT table not found
Mar 02 12:09:35 computer kernel: amdgpu: Virtual CRAT table created for CPU
Mar 02 12:09:35 computer kernel: amdgpu: Topology: Add CPU node
Mar 02 12:09:35 computer audit[375]: SYSTEM_BOOT pid=375 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1127 audit(1677755375.708:12): pid=375 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.715:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Started Network Time Synchronization.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Reached target System Initialization.
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.745:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Started CUPS Scheduler.
Mar 02 12:09:35 computer systemd[1]: Started Daily Cleanup of Temporary Directories.
Mar 02 12:09:35 computer systemd[1]: Reached target Path Units.
Mar 02 12:09:35 computer systemd[1]: Reached target System Time Set.
Mar 02 12:09:35 computer systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
Mar 02 12:09:35 computer systemd[1]: Started Daily rotation of log files.
Mar 02 12:09:35 computer systemd[1]: Started Daily man-db regeneration.
Mar 02 12:09:35 computer systemd[1]: Started Monthly clean packages cache.
Mar 02 12:09:35 computer systemd[1]: Started Generate mirrorlist weekly.
Mar 02 12:09:35 computer systemd[1]: Started pkgfile database update timer.
Mar 02 12:09:35 computer systemd[1]: Started Daily verification of password and group files.
Mar 02 12:09:35 computer systemd[1]: Reached target Timer Units.
Mar 02 12:09:35 computer systemd[1]: Listening on CUPS Scheduler.
Mar 02 12:09:35 computer systemd[1]: Listening on D-Bus System Message Bus Socket.
Mar 02 12:09:35 computer systemd[1]: Reached target Socket Units.
Mar 02 12:09:35 computer systemd[1]: TPM2 PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:35 computer systemd[1]: Reached target Basic System.
Mar 02 12:09:35 computer systemd[1]: Starting Save/Restore Sound Card State...
Mar 02 12:09:35 computer systemd[1]: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
Mar 02 12:09:35 computer systemd[1]: Starting Bluetooth service...
Mar 02 12:09:35 computer systemd[378]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mar 02 12:09:35 computer systemd[1]: Started Periodic Command Scheduler.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.755:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Starting D-Bus System Message Bus...
Mar 02 12:09:35 computer systemd[1]: Starting Authorization Manager...
Mar 02 12:09:35 computer audit: BPF prog-id=22 op=LOAD
Mar 02 12:09:35 computer audit: BPF prog-id=23 op=LOAD
Mar 02 12:09:35 computer audit: BPF prog-id=24 op=LOAD
Mar 02 12:09:35 computer systemd[1]: Starting User Login Management...
Mar 02 12:09:35 computer systemd[1]: TPM2 PCR Barrier (User) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.765:16): prog-id=22 op=LOAD
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.765:17): prog-id=23 op=LOAD
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.765:18): prog-id=24 op=LOAD
Mar 02 12:09:35 computer systemd[1]: Finished Save/Restore Sound Card State.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Reached target Sound Card.
Mar 02 12:09:35 computer crond[379]: (CRON) STARTUP (1.6.1)
Mar 02 12:09:35 computer crond[379]: (CRON) INFO (Syslog will be used instead of sendmail.)
Mar 02 12:09:35 computer crond[379]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 38% if used.)
Mar 02 12:09:35 computer crond[379]: (CRON) INFO (running with inotify support)
Mar 02 12:09:35 computer systemd-logind[382]: New seat seat0.
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event2 (Power Button)
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event0 (Power Button)
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event1 (Lid Switch)
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event3 (AT Translated Set 2 keyboard)
Mar 02 12:09:35 computer polkitd[381]: Started polkitd version 122
Mar 02 12:09:36 computer bluetoothd[378]: Bluetooth daemon 5.66
Mar 02 12:09:37 computer systemd[1]: Started D-Bus System Message Bus.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 02 12:09:37 computer systemd[1]: Starting Network Manager...
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Started Bluetooth service.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Started User Login Management.
Mar 02 12:09:37 computer systemd[1]: Reached target Bluetooth Support.
Mar 02 12:09:37 computer polkitd[381]: Loading rules from directory /etc/polkit-1/rules.d
Mar 02 12:09:37 computer bluetoothd[378]: Starting SDP server
Mar 02 12:09:37 computer bluetoothd[378]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 02 12:09:37 computer bluetoothd[378]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 02 12:09:37 computer bluetoothd[378]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 02 12:09:37 computer bluetoothd[378]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 02 12:09:37 computer bluetoothd[378]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 02 12:09:37 computer bluetoothd[378]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 02 12:09:37 computer polkitd[381]: Loading rules from directory /usr/share/polkit-1/rules.d
Mar 02 12:09:37 computer kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 02 12:09:37 computer kernel: Bluetooth: BNEP filters: protocol multicast
Mar 02 12:09:37 computer kernel: Bluetooth: BNEP socket layer initialized
Mar 02 12:09:37 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.2' (uid=0 pid=378 comm="/usr/lib/bluetooth/bluetoothd")
Mar 02 12:09:37 computer bluetoothd[378]: Bluetooth management interface 1.21 initialized
Mar 02 12:09:37 computer audit: BPF prog-id=25 op=LOAD
Mar 02 12:09:37 computer audit: BPF prog-id=26 op=LOAD
Mar 02 12:09:37 computer audit: BPF prog-id=27 op=LOAD
Mar 02 12:09:37 computer kernel: NET: Registered PF_ALG protocol family
Mar 02 12:09:37 computer systemd[1]: Starting Hostname Service...
Mar 02 12:09:37 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mar 02 12:09:37 computer systemd[1]: Started Hostname Service.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer polkitd[381]: Finished loading, compiling and executing 7 rules
Mar 02 12:09:37 computer systemd[1]: Started Authorization Manager.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer polkitd[381]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Mar 02 12:09:37 computer systemd[1]: Starting Modem Manager...
Mar 02 12:09:37 computer NetworkManager[392]: <info>  [1677755377.8832] NetworkManager (version 1.42.2-0) is starting... (boot:e7c04cf2-a178-4cf0-876e-ef3841191af9)
Mar 02 12:09:37 computer NetworkManager[392]: <info>  [1677755377.8833] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Mar 02 12:09:37 computer systemd[1]: Started Network Manager.
Mar 02 12:09:37 computer NetworkManager[392]: <info>  [1677755377.9062] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Reached target Network.
Mar 02 12:09:37 computer systemd[1]: Starting Network Manager Wait Online...
Mar 02 12:09:37 computer systemd[1]: Starting CUPS Scheduler...
Mar 02 12:09:37 computer systemd[1]: Starting Permit User Sessions...
Mar 02 12:09:37 computer systemd[1]: Finished Permit User Sessions.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Started Simple Desktop Display Manager.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:38 computer systemd[1]: systemd-rfkill.service: Deactivated successfully.
Mar 02 12:09:38 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:38 computer ModemManager[416]: <info>  ModemManager (version 1.20.4-1) starting in system bus...
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2498] manager[0x560a5ea61000]: monitoring kernel firmware directory '/lib/firmware'.
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2738] hostname: hostname: using hostnamed
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2738] hostname: static hostname changed from (none) to "computer"
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2923] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2947] rfkill3: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/ieee80211/phy0/rfkill3) (driver iwlwifi)
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2949] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/rfkill/rfkill0) (platform driver ideapad_acpi)
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2964] manager[0x560a5ea61000]: rfkill: Wi-Fi hardware radio set enabled
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2964] manager[0x560a5ea61000]: rfkill: WWAN hardware radio set enabled
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.7763] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-wifi.so)
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.8057] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-adsl.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.1025] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-team.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.1691] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-wwan.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2498] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-bluetooth.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2512] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-ovs.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2515] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2516] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2517] manager: Networking is enabled by state file
Mar 02 12:09:39 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2534] settings: Loaded settings plugin: keyfile (internal)
Mar 02 12:09:39 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 02 12:09:39 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 02 12:09:39 computer systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 02 12:09:39 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3802] dhcp: init: Using DHCP client 'internal'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3835] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3850] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3855] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3863] device (lo): Activation: starting connection 'lo' (71df1d6e-e4f2-4f26-ac2d-43bcbd6d722c)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3874] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3888] settings: (enp2s0): created default wired connection 'Wired connection 1'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3888] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3936] device (wlp3s0): driver supports Access Point (AP) mode
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3945] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3949] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:39 computer systemd[1]: Started CUPS Scheduler.
Mar 02 12:09:39 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.6679] device (wlp3s0): set-hw-addr: set MAC address to 9A:C6:69:51:7D:D0 (scanning)
Mar 02 12:09:39 computer dbus-daemon[380]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:39 computer systemd[1]: Starting WPA supplicant...
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2058] ovsdb: disconnected from ovsdb
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2060] device (lo): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2068] device (lo): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2074] device (lo): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2094] device (lo): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2135] manager: (74:9E:F5:0A:0F:20): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/4)
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2142] device (74:9E:F5:0A:0F:20): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2157] device (74:9E:F5:0A:0F:20): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2564] device (lo): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2568] device (lo): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2582] device (lo): Activation: successful, device activated.
Mar 02 12:09:40 computer dbus-daemon[380]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Mar 02 12:09:40 computer systemd[1]: Started WPA supplicant.
Mar 02 12:09:40 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer kernel: kauditd_printk_skb: 15 callbacks suppressed
Mar 02 12:09:40 computer kernel: audit: type=1130 audit(1677755380.488:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer kernel: NET: Registered PF_QIPCRTR protocol family
Mar 02 12:09:40 computer systemd[1]: Started Modem Manager.
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.5093] modem-manager: ModemManager not available
Mar 02 12:09:40 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer kernel: audit: type=1130 audit(1677755380.505:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer wpa_supplicant[434]: Successfully initialized wpa_supplicant
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.6156] modem-manager: ModemManager now available
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7778] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7779] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7782] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7787] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7797] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7806] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:41 computer sddm[422]: Initializing...
Mar 02 12:09:41 computer sddm[422]: Starting...
Mar 02 12:09:41 computer sddm[422]: Logind interface found
Mar 02 12:09:41 computer sddm[422]: Adding new display on vt 1 ...
Mar 02 12:09:41 computer sddm[422]: Loading theme configuration from ""
Mar 02 12:09:41 computer sddm[422]: Display server starting...
Mar 02 12:09:41 computer sddm[422]: Adding cookie to "/var/run/sddm/{056fe443-54c4-4588-98bd-aa9341285262}"
Mar 02 12:09:41 computer sddm[422]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{056fe443-54c4-4588-98bd-aa9341285262} -noreset -displayfd 17
Mar 02 12:09:41 computer kernel: [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
Mar 02 12:09:41 computer kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: WB enabled
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_cp1' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_cp2' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_dma2' in directory '0' already present!
Mar 02 12:09:41 computer kernel: [drm] ring test on 0 succeeded in 1 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 1 succeeded in 1 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 2 succeeded in 1 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 3 succeeded in 4 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 4 succeeded in 3 usecs
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Mar 02 12:09:41 computer kernel: [drm] ring test on 5 succeeded in 2 usecs
Mar 02 12:09:41 computer kernel: [drm] UVD initialized successfully.
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Mar 02 12:09:42 computer kernel: [drm] ib test on ring 5 succeeded
Mar 02 12:09:43 computer ModemManager[416]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0': not supported by any plugin
Mar 02 12:09:43 computer ModemManager[416]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0': not supported by any plugin
Mar 02 12:09:46 computer NetworkManager[392]: <info>  [1677755386.7400] manager: startup complete
Mar 02 12:09:46 computer systemd[1]: Finished Network Manager Wait Online.
Mar 02 12:09:46 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:46 computer kernel: audit: type=1130 audit(1677755386.748:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:46 computer systemd[1]: Reached target Network is Online.
Mar 02 12:09:46 computer systemd[1]: Starting Samba NMB Daemon...
Mar 02 12:09:49 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 02 12:09:49 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:49 computer kernel: audit: type=1131 audit(1677755389.288:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:49 computer nmbd[449]: [2023/03/02 12:09:49.347294,  0] ../../source3/nmbd/nmbd.c:901(main)
Mar 02 12:09:49 computer nmbd[449]:   nmbd version 4.17.5 started.
Mar 02 12:09:49 computer nmbd[449]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Mar 02 12:09:49 computer nmbd[449]: [2023/03/02 12:09:49.421278,  0] ../../lib/util/become_daemon.c:150(daemon_status)
Mar 02 12:09:49 computer nmbd[449]:   daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mar 02 12:09:49 computer nmbd[449]: [2023/03/02 12:09:49.433243,  0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mar 02 12:09:49 computer nmbd[449]:   NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mar 02 12:09:49 computer sddm[422]: Setting default cursor
Mar 02 12:09:49 computer sddm[422]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Mar 02 12:09:49 computer sddm[422]: Display server started.
Mar 02 12:09:50 computer sddm[422]: Reading from "/usr/share/xsessions/plasma.desktop"
Mar 02 12:09:50 computer sddm[422]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Starting...
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Authenticating...
Mar 02 12:09:50 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: pam_sm_authenticate
Mar 02 12:09:50 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: Couldn't get password (it is empty)
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Preparing to converse...
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Conversation with 1 messages
Mar 02 12:09:50 computer audit[457]: USER_AUTH pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] returning.
Mar 02 12:09:50 computer kernel: audit: type=1100 audit(1677755390.375:38): pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.14' (uid=0 pid=457 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth5")
Mar 02 12:09:50 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:09:50 computer sddm-helper[457]: pam_systemd_home(sddm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:09:50 computer audit[457]: USER_ACCT pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer sddm[422]: Authenticated successfully
Mar 02 12:09:50 computer kernel: audit: type=1101 audit(1677755390.442:39): pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
Mar 02 12:09:50 computer audit[457]: CRED_ACQ pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer audit[457]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe262e4f30 a2=4 a3=0 items=0 ppid=422 pid=457 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Mar 02 12:09:50 computer audit: PROCTITLE proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746835333463356538352D613731342D343432642D613838312D623762616361346430313161002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Mar 02 12:09:50 computer sddm-helper[457]: pam_unix(sddm-autologin:session): session opened for user tomas(uid=1000) by (uid=0)
Mar 02 12:09:50 computer kernel: audit: type=1103 audit(1677755390.455:40): pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer kernel: audit: type=1006 audit(1677755390.455:41): pid=457 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
Mar 02 12:09:50 computer kernel: audit: type=1300 audit(1677755390.455:41): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe262e4f30 a2=4 a3=0 items=0 ppid=422 pid=457 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Mar 02 12:09:50 computer kernel: audit: type=1327 audit(1677755390.455:41): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746835333463356538352D613731342D343432642D613838312D623762616361346430313161002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Mar 02 12:09:50 computer systemd[1]: Created slice User Slice of UID 1000.
Mar 02 12:09:50 computer systemd[1]: Starting User Runtime Directory /run/user/1000...
Mar 02 12:09:50 computer systemd-logind[382]: New session 1 of user tomas.
Mar 02 12:09:50 computer systemd[1]: Finished User Runtime Directory /run/user/1000.
Mar 02 12:09:50 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer systemd[1]: Starting User Manager for UID 1000...
Mar 02 12:09:50 computer kernel: audit: type=1130 audit(1677755390.588:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.16' (uid=0 pid=459 comm="(systemd)")
Mar 02 12:09:50 computer systemd[459]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:09:50 computer audit[459]: USER_ACCT pid=459 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer audit[459]: CRED_ACQ pid=459 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mar 02 12:09:50 computer systemd[459]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[tomas] ruser=[<unknown>] rhost=[<unknown>]
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffe2ea69b40 a2=4 a3=0 items=0 ppid=1 pid=459 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: PROCTITLE proctitle="(systemd)"
Mar 02 12:09:50 computer kernel: audit: type=1101 audit(1677755390.612:43): pid=459 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer systemd[459]: pam_unix(systemd-user:session): session opened for user tomas(uid=1000) by (uid=0)
Mar 02 12:09:50 computer audit[459]: USER_START pid=459 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer audit: BPF prog-id=28 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150f570 a2=90 a3=0 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=28 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=29 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150e3e0 a2=74 a3=2 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=29 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=30 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150e530 a2=80 a3=0 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=30 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=31 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150f340 a2=80 a3=2 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=31 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=32 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150f200 a2=40 a3=1 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=32 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=33 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=10 a0=5 a1=7ffd3150f0c0 a2=80 a3=5 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=33 op=UNLOAD
Mar 02 12:09:51 computer systemd[459]: Queued start job for default target Main User Target.
Mar 02 12:09:51 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:51 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_session
Mar 02 12:09:51 computer systemd[459]: Created slice User Application Slice.
Mar 02 12:09:51 computer systemd[459]: Reached target Paths.
Mar 02 12:09:51 computer systemd[459]: Reached target Timers.
Mar 02 12:09:51 computer systemd[459]: Starting D-Bus User Message Bus Socket...
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG network certificate management daemon.
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 02 12:09:51 computer systemd[459]: Listening on p11-kit server.
Mar 02 12:09:51 computer systemd[459]: Listening on PipeWire Multimedia System Socket.
Mar 02 12:09:51 computer systemd[459]: Listening on Sound System.
Mar 02 12:09:51 computer sddm-helper[470]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
Mar 02 12:09:51 computer systemd[459]: Listening on D-Bus User Message Bus Socket.
Mar 02 12:09:51 computer systemd[459]: Reached target Sockets.
Mar 02 12:09:51 computer systemd[459]: Reached target Basic System.
Mar 02 12:09:51 computer systemd[1]: Started User Manager for UID 1000.
Mar 02 12:09:51 computer systemd[459]: Starting Update XDG user dir configuration...
Mar 02 12:09:51 computer systemd[1]: Started Session 1 of User tomas.
Mar 02 12:09:51 computer systemd[459]: Finished Update XDG user dir configuration.
Mar 02 12:09:51 computer systemd[459]: Reached target Main User Target.
Mar 02 12:09:51 computer systemd[459]: Startup finished in 1.038s.
Mar 02 12:09:51 computer audit[457]: USER_START pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:51 computer kernel: kauditd_printk_skb: 30 callbacks suppressed
Mar 02 12:09:51 computer kernel: audit: type=1105 audit(1677755391.865:60): pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:51 computer sddm-helper[457]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Mar 02 12:09:51 computer sddm-helper[472]: Adding cookie to "/home/tomas/.Xauthority"
Mar 02 12:09:52 computer sddm[422]: Session started
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3214] policy: auto-activating connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3225] device (wlp3s0): Activation: starting connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3228] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3235] manager: NetworkManager state is now CONNECTING
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3256] device (wlp3s0): set-hw-addr: reset MAC address to A0:A8:CD:EB:A4:E2 (preserve)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3274] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3281] device (wlp3s0): Activation: (wifi) access point 'UPC8127731' has security, but secrets are required.
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3281] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3284] sup-iface[98297733aecb18f1,0,wlp3s0]: wps: type pbc start...
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3296] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3302] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3308] device (wlp3s0): Activation: (wifi) connection 'UPC8127731' has security, and secrets exist.  No new secrets needed.
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3309] Config: added 'ssid' value 'UPC8127731'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3309] Config: added 'scan_ssid' value '1'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3310] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3310] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3310] Config: added 'auth_alg' value 'OPEN'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3311] Config: added 'psk' value '<hidden>'
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: WPS-CANCEL
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: SME: Trying to authenticate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:09:52 computer kernel: wlp3s0: authenticate with 38:43:7d:62:ff:bb
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4211] device (wlp3s0): supplicant interface state: disconnected -> authenticating
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4211] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> authenticating
Mar 02 12:09:52 computer kernel: wlp3s0: send auth to 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: Trying to associate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4417] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4417] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 02 12:09:52 computer kernel: wlp3s0: authenticated
Mar 02 12:09:52 computer kernel: wlp3s0: associate with 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:09:52 computer kernel: wlp3s0: RX AssocResp from 38:43:7d:62:ff:bb (capab=0x511 status=0 aid=1)
Mar 02 12:09:52 computer kernel: wlp3s0: associated
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: Associated with 38:43:7d:62:ff:bb
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4886] device (wlp3s0): supplicant interface state: associating -> associated
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4887] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5090] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5091] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: WPA: Key negotiation completed with 38:43:7d:62:ff:bb [PTK=CCMP GTK=TKIP]
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to 38:43:7d:62:ff:bb completed [id=0 id_str=]
Mar 02 12:09:52 computer kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5889] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5889] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "UPC8127731"
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5889] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5891] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5898] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=866700
Mar 02 12:09:52 computer systemd[459]: Created slice User Core Session Slice.
Mar 02 12:09:52 computer systemd[459]: Starting D-Bus User Message Bus...
Mar 02 12:09:53 computer systemd[459]: Started D-Bus User Message Bus.
Mar 02 12:09:53 computer dbus-daemon[498]: [session uid=1000 pid=498] Successfully activated service 'org.freedesktop.systemd1'
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:54 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 02 12:09:54 computer kernel: audit: type=1130 audit(1677755394.788:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8330] dhcp4 (wlp3s0): state changed new lease, address=192.168.0.164
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8336] policy: set 'UPC8127731' (wlp3s0) as default for IPv4 routing and DNS
Mar 02 12:09:54 computer audit: BPF prog-id=34 op=LOAD
Mar 02 12:09:54 computer audit[392]: SYSCALL arch=c000003e syscall=321 success=yes exit=27 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:09:54 computer audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 02 12:09:54 computer kernel: audit: type=1334 audit(1677755394.868:62): prog-id=34 op=LOAD
Mar 02 12:09:54 computer kernel: audit: type=1300 audit(1677755394.868:62): arch=c000003e syscall=321 success=yes exit=27 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:09:54 computer kernel: audit: type=1327 audit(1677755394.868:62): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8865] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8900] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8904] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8910] manager: NetworkManager state is now CONNECTED_SITE
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8920] device (wlp3s0): Activation: successful, device activated.
Mar 02 12:09:54 computer systemd[1]: Started Samba NMB Daemon.
Mar 02 12:09:54 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer kernel: audit: type=1130 audit(1677755394.968:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer systemd[1]: Starting Samba SMB Daemon...
Mar 02 12:09:55 computer NetworkManager[392]: <info>  [1677755395.0450] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 02 12:09:55 computer smbd[504]: [2023/03/02 12:09:55.878886,  0] ../../source3/smbd/server.c:1741(main)
Mar 02 12:09:55 computer smbd[504]:   smbd version 4.17.5 started.
Mar 02 12:09:55 computer smbd[504]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Mar 02 12:09:56 computer sddm-helper[457]: [PAM] Closing session
Mar 02 12:09:56 computer sddm-helper[457]: pam_unix(sddm-autologin:session): session closed for user tomas
Mar 02 12:09:56 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_close_session
Mar 02 12:09:56 computer audit[457]: USER_END pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer kernel: audit: type=1106 audit(1677755396.298:64): pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer kernel: audit: type=1104 audit(1677755396.298:65): pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer audit[457]: CRED_DISP pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
Mar 02 12:09:56 computer sddm-helper[457]: [PAM] Ended.
Mar 02 12:09:56 computer sddm[422]: Auth: sddm-helper exited with 1
Mar 02 12:09:56 computer systemd-logind[382]: Session 1 logged out. Waiting for processes to exit.
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.3107] device (wlp3s0): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.3117] manager: NetworkManager state is now DISCONNECTING
Mar 02 12:09:56 computer kernel: wlp3s0: deauthenticating from 38:43:7d:62:ff:bb by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 02 12:09:56 computer systemd[1]: Started Samba SMB Daemon.
Mar 02 12:09:56 computer kernel: audit: type=1130 audit(1677755396.402:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:56 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:56 computer systemd[1]: Reached target Multi-User System.
Mar 02 12:09:56 computer systemd[1]: Reached target Graphical Interface.
Mar 02 12:09:56 computer systemd[1]: Startup finished in 6.983s (kernel) + 31.749s (userspace) = 38.733s.
Mar 02 12:09:56 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.20' (uid=0 pid=504 comm="/usr/bin/smbd --foreground --no-process-group")
Mar 02 12:09:56 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Mar 02 12:09:56 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=38:43:7d:62:ff:bb reason=3 locally_generated=1
Mar 02 12:09:56 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 02 12:09:56 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5011] device (wlp3s0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5223] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5224] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5224] dhcp4 (wlp3s0): state changed no lease
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5253] device (wlp3s0): set-hw-addr: set MAC address to 7E:F3:E8:B4:D5:68 (scanning)
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5913] manager: NetworkManager state is now DISCONNECTED
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5926] device (wlp3s0): supplicant interface state: completed -> disconnected
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5926] device (p2p-dev-wlp3s0): supplicant management interface state: completed -> disconnected
Mar 02 12:09:56 computer audit: BPF prog-id=34 op=UNLOAD
Mar 02 12:09:56 computer kernel: audit: type=1334 audit(1677755396.608:67): prog-id=34 op=UNLOAD
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.977549,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.977858,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19510 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.977940,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978013,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19511 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978081,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978152,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19512 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978219,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978285,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19513 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978352,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978430,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19514 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978499,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978561,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19516 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.979829,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.979973,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19510 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980046,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980117,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19511 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980191,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980261,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19512 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980329,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980394,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19513 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980465,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980545,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19514 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980616,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980680,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19516 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.981929,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982094,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19510 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982215,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982316,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19511 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982389,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982463,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19512 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982528,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982596,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19513 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982663,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982743,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19514 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982844,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982906,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19516 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:10:04 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 02 12:10:04 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:04 computer kernel: audit: type=1131 audit(1677755404.802:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:08 computer systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mar 02 12:10:08 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:08 computer kernel: audit: type=1131 audit(1677755408.302:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:08 computer audit: BPF prog-id=27 op=UNLOAD
Mar 02 12:10:08 computer audit: BPF prog-id=26 op=UNLOAD
Mar 02 12:10:08 computer audit: BPF prog-id=25 op=UNLOAD
Mar 02 12:10:08 computer kernel: audit: type=1334 audit(1677755408.382:70): prog-id=27 op=UNLOAD
Mar 02 12:10:08 computer kernel: audit: type=1334 audit(1677755408.382:71): prog-id=26 op=UNLOAD
Mar 02 12:10:08 computer kernel: audit: type=1334 audit(1677755408.382:72): prog-id=25 op=UNLOAD
Mar 02 12:10:10 computer nmbd[449]: [2023/03/02 12:10:10.996896,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:10 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:12 computer nmbd[449]: [2023/03/02 12:10:12.999454,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:12 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:15 computer nmbd[449]: [2023/03/02 12:10:15.002022,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:15 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:17 computer nmbd[449]: [2023/03/02 12:10:17.004714,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:17 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005563,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:18 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005748,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:18 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005826,  0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mar 02 12:10:18 computer nmbd[449]:   send_netbios_packet: send_packet() to IP 192.168.0.255 port 137 failed
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005895,  0] ../../source3/nmbd/nmbd_nameregister.c:582(register_name)
Mar 02 12:10:18 computer nmbd[449]: [82B blob data]
Mar 02 12:11:08 computer nmbd[449]: [2023/03/02 12:11:08.056836,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:11:08 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:12:02 computer kernel: [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
Mar 02 12:12:02 computer kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: WB enabled
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_cp1' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_cp2' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_dma2' in directory '0' already present!
Mar 02 12:12:02 computer kernel: [drm] ring test on 0 succeeded in 1 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 1 succeeded in 1 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 2 succeeded in 1 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 3 succeeded in 3 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 4 succeeded in 3 usecs
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Mar 02 12:12:02 computer kernel: [drm] ring test on 5 succeeded in 2 usecs
Mar 02 12:12:02 computer kernel: [drm] UVD initialized successfully.
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Mar 02 12:12:03 computer kernel: [drm] ib test on ring 5 succeeded
Mar 02 12:12:03 computer systemd[1]: Started Getty on tty2.
Mar 02 12:12:03 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:03 computer kernel: audit: type=1130 audit(1677755523.442:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:08 computer nmbd[449]: [2023/03/02 12:12:08.121356,  0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mar 02 12:12:08 computer nmbd[449]:   reload_interfaces: No subnets to listen to. Waiting..
Mar 02 12:12:09 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.21' (uid=0 pid=511 comm="/bin/login -p --      ")
Mar 02 12:12:09 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:12:09 computer login[511]: pam_systemd_home(login:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:12:12 computer audit[511]: USER_AUTH pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer audit[511]: USER_ACCT pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1100 audit(1677755532.335:74): pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1101 audit(1677755532.335:75): pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1103 audit(1677755532.338:76): pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1006 audit(1677755532.338:77): pid=511 uid=0 old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=3 res=1
Mar 02 12:12:12 computer kernel: audit: type=1300 audit(1677755532.338:77): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7fff5e913d70 a2=4 a3=0 items=0 ppid=1 pid=511 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=3 comm="login" exe="/usr/bin/login" key=(null)
Mar 02 12:12:12 computer kernel: audit: type=1327 audit(1677755532.338:77): proctitle=2F62696E2F6C6F67696E002D70002D2D
Mar 02 12:12:12 computer audit[511]: CRED_ACQ pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer audit[511]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7fff5e913d70 a2=4 a3=0 items=0 ppid=1 pid=511 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=3 comm="login" exe="/usr/bin/login" key=(null)
Mar 02 12:12:12 computer audit: PROCTITLE proctitle=2F62696E2F6C6F67696E002D70002D2D
Mar 02 12:12:12 computer login[511]: pam_unix(login:session): session opened for user tomas(uid=1000) by LOGIN(uid=0)
Mar 02 12:12:12 computer systemd-logind[382]: New session 3 of user tomas.
Mar 02 12:12:12 computer systemd[1]: Started Session 3 of User tomas.
Mar 02 12:12:12 computer audit[511]: USER_START pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer audit[511]: CRED_REFR pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1105 audit(1677755532.362:78): pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1110 audit(1677755532.362:79): pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer login[511]: LOGIN ON tty2 BY tomas
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4328] policy: auto-activating connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4335] device (wlp3s0): Activation: starting connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4337] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4342] manager: NetworkManager state is now CONNECTING
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4358] device (wlp3s0): set-hw-addr: reset MAC address to A0:A8:CD:EB:A4:E2 (preserve)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4374] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4378] device (wlp3s0): Activation: (wifi) access point 'UPC8127731' has security, but secrets are required.
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4378] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4381] sup-iface[98297733aecb18f1,0,wlp3s0]: wps: type pbc start...
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4390] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4393] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4397] device (wlp3s0): Activation: (wifi) connection 'UPC8127731' has security, and secrets exist.  No new secrets needed.
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4397] Config: added 'ssid' value 'UPC8127731'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'scan_ssid' value '1'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'auth_alg' value 'OPEN'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'psk' value '<hidden>'
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: WPS-CANCEL
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: SME: Trying to authenticate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:12:14 computer kernel: wlp3s0: authenticate with 38:43:7d:62:ff:bb
Mar 02 12:12:14 computer kernel: wlp3s0: send auth to 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4832] device (wlp3s0): supplicant interface state: disconnected -> authenticating
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4833] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> authenticating
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: Trying to associate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5038] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5039] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 02 12:12:14 computer kernel: wlp3s0: authenticated
Mar 02 12:12:14 computer kernel: wlp3s0: associate with 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:12:14 computer kernel: wlp3s0: RX AssocResp from 38:43:7d:62:ff:bb (capab=0x511 status=0 aid=1)
Mar 02 12:12:14 computer kernel: wlp3s0: associated
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: Associated with 38:43:7d:62:ff:bb
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5522] device (wlp3s0): supplicant interface state: associating -> associated
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5524] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5742] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5743] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: WPA: Key negotiation completed with 38:43:7d:62:ff:bb [PTK=CCMP GTK=TKIP]
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to 38:43:7d:62:ff:bb completed [id=0 id_str=]
Mar 02 12:12:14 computer kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6494] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6495] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "UPC8127731"
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6495] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6497] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6506] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=866700
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9526] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9538] policy: set 'UPC8127731' (wlp3s0) as default for IPv6 routing and DNS
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9867] dhcp6 (wlp3s0): state changed new lease
Mar 02 12:12:16 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9880] dhcp4 (wlp3s0): state changed new lease, address=192.168.0.164
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9899] policy: set 'UPC8127731' (wlp3s0) as default for IPv4 routing and DNS
Mar 02 12:12:16 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 02 12:12:16 computer audit: BPF prog-id=35 op=LOAD
Mar 02 12:12:16 computer audit[392]: SYSCALL arch=c000003e syscall=321 success=yes exit=29 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:12:16 computer audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 02 12:12:17 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 02 12:12:17 computer systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 02 12:12:16 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:17 computer kernel: audit: type=1334 audit(1677755536.995:80): prog-id=35 op=LOAD
Mar 02 12:12:17 computer kernel: audit: type=1300 audit(1677755536.995:80): arch=c000003e syscall=321 success=yes exit=29 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0108] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0127] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0130] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0134] manager: NetworkManager state is now CONNECTED_SITE
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0141] device (wlp3s0): Activation: successful, device activated.
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0861] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 02 12:12:27 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 02 12:12:27 computer kernel: kauditd_printk_skb: 2 callbacks suppressed
Mar 02 12:12:27 computer kernel: audit: type=1131 audit(1677755547.008:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:27 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 11:12:38 computer systemd-timesyncd[374]: Contacted time server 81.25.28.124:123 (0.manjaro.pool.ntp.org).
Mar 02 11:12:38 computer systemd-journald[254]: Time jumped backwards, rotating.
Mar 02 11:12:38 computer systemd-timesyncd[374]: Initial clock synchronization to Thu 2023-03-02 11:12:38.251878 CET.
Mar 02 11:12:39 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=866700
Mar 02 11:17:02 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.23' (uid=0 pid=537 comm="sudo journalctl --boot 0 --no-pager")
Mar 02 11:17:02 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 11:17:02 computer sudo[537]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 11:17:04 computer audit[537]: USER_AUTH pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer audit[537]: USER_ACCT pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1100 audit(1677752224.582:83): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1101 audit(1677752224.582:84): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer audit[537]: CRED_REFR pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer sudo[537]:    tomas : TTY=tty2 ; PWD=/home/tomas ; USER=root ; COMMAND=/usr/bin/journalctl --boot 0 --no-pager
Mar 02 11:17:04 computer audit[537]: USER_START pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer sudo[537]: pam_unix(sudo:session): session opened for user root(uid=0) by tomas(uid=1000)
Mar 02 11:17:04 computer kernel: audit: type=1110 audit(1677752224.586:85): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1105 audit(1677752224.586:86): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer sudo[537]: pam_unix(sudo:session): session closed for user root
Mar 02 11:17:04 computer audit[537]: USER_END pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer audit[537]: CRED_DISP pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1106 audit(1677752224.629:87): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1104 audit(1677752224.629:88): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:19:51 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.24' (uid=0 pid=543 comm="sudo journalctl -b -e")
Mar 02 11:19:51 computer audit[543]: USER_ACCT pid=543 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:19:51 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 11:19:51 computer sudo[543]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 11:19:51 computer kernel: audit: type=1101 audit(1677752391.986:89): pid=543 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:19:51 computer sudo[543]:    tomas : TTY=tty2 ; PWD=/home/tomas ; USER=root ; COMMAND=/usr/bin/journalctl -b -e
Mar 02 11:19:51 computer audit[543]: CRED_REFR pid=543 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:19:51 computer sudo[543]: pam_unix(sudo:session): session opened for user root(uid=0) by tomas(uid=1000)
Mar 02 11:19:51 computer audit[543]: USER_START pid=543 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:19:51 computer kernel: audit: type=1110 audit(1677752391.989:90): pid=543 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:19:51 computer kernel: audit: type=1105 audit(1677752391.989:91): pid=543 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Please DONT post images of command output that can be posted as text, only post images if there is NO-OTHER-WAY to provide that info…
Do you mean you can access the console with those keys from your normal boot or only from the Live-USB?
(If it is only from Live-USB, there is no need to mention that as that is the expected behavior.)
Why do you believe your problem is caused by Grub?
Your second image shows that you already past the Grub stage…
Please provide output of the following commands in their own code blocks, as explained in the link i provided above:
lsblk --fs --all
efibootmgr --verbose
I appreciate your willingness to help, but I think there is misunderstanding.
I took pictures, because there was no other choice.
Once the boot fails and shows /dev/sdb2: clean - how can I copy the text ? There is no choice, therefore I took pictures. It is stuck at that step.
Second pictures is the terminal I ran by ctrl + alt + F2.
So I can execute commnad, but how can I copy the text ?
It is not taken by live usb, however I have used live usb to restore the grub before.
That is all what I have for now, I am beginner, if you advise some steps, I can follow up.
what is your actuall problem and was it working previously? what did you do prior to this issue…
and its not related to grub since you are past it…
First, try to update your system with pacman -Syyu
Also, you can show your logs with journalctl -b -e and you can look for relevant errors/messages
Ok so you are able to boot your normal system and change to a different console using CTRL+ALT+F2 ?
If that is the case then:
  1. Perform this command right after booted in your normal system and changed to a different text console:
    journalctl --boot 0 --no-pager > ~/lastlog.txt
  2. Boot using your Live-USB, and post the contents of lastlog.txt, which will be located inside your /home directory of your normal system.
    Use a codeblock for output formating as explained in: [HowTo] Post command output and file content as formatted text
Note you have to mount your /home partition from your normal system somewhere before you can access this file.
For example using:
  • systemd-mount /dev/sdXXX /tmp/home_partition
    Where /dev/sdXXX means your /home partition of your normal Linux install.
After the above command from the live-USB, your output can be accessed as /tmp/home_partition/YOUR_USERNAME/lastlog.txt.
Where YOUR_USERNAME is obviously the username you use to login into your normal Linux system, which you need to change in the above command.
PS:
Because you are able to boot and change to a different console, i will rename the topic to prevent confusions about your problem.
To copy the contents of text files you can make use of the xclip command, which you might need to install first.
For example, the below command will copy the contents of somefile.txt into your clipboard, which you then can use to paste in the forum:
cat somefile.txt | xclip -selection clipboard
  • Handy alias to use: alias xc=‘xclip -selection clipboard’
    Using this alias you can perform | xc instead of | xclip …
:vulcan_salute:
pacman -Syu I tried before and it was OK with message: there is nothing to do.
I will do pacman -Syyu and let you know.
Please do what i asked before doing that…
Yes, I did it. I updated the first topic with all details.
I have not performed pacman -Syyu, yet. Let me know, whether I should do that.
Because i cant acess the pastebin, like i already said before, i could only view the posted logs which is missing the essential start of boot parts…
But as far as i could tell you have a problem with your Radeon graphics drivers.
Please uninstall that and use your Integrated graphics to at least be able to boot into your GUI.
From there you can try to re-install your Radeon graphics drivers again.
As i don’t use any GFX card using Radeon, i’m unable to assist further… :woman_shrugging:
Maybe this topic can help you, as it is similar to yours i think:
journalctl --boot 0 --no-pager part 1
Mar 02 12:09:29 computer kernel: microcode: microcode updated early to revision 0x21, date = 2019-02-13
Mar 02 12:09:29 computer kernel: Linux version 5.15.94-1-MANJARO (builduser@fv-az462-116) (gcc (GCC) 12.2.1 20230201, GNU ld (GNU Binutils) 2.40) #1 SMP PREEMPT Tue Feb 14 19:45:58 UTC 2023
Mar 02 12:09:29 computer kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=1d12580d-22e2-4db1-abf8-cebbb9ee4c49 rw quiet resume=UUID=62a959f8-998a-4b75-8c86-54f4a0461707 udev.log_priority=3
Mar 02 12:09:29 computer kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Mar 02 12:09:29 computer kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Mar 02 12:09:29 computer kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Mar 02 12:09:29 computer kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Mar 02 12:09:29 computer kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
Mar 02 12:09:29 computer kernel: signal: max sigframe size: 1776
Mar 02 12:09:29 computer kernel: BIOS-provided physical RAM map:
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000087fff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000000088000-0x00000000000bffff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000040005000-0x00000000b3fecfff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000b3fed000-0x00000000b4d6dfff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000b4d6e000-0x00000000b4daffff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000b4db0000-0x00000000b61affff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000b61b0000-0x00000000ba7befff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba7bf000-0x00000000ba84efff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba84f000-0x00000000ba850fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba851000-0x00000000ba863fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba864000-0x00000000ba864fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba865000-0x00000000ba87bfff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba87c000-0x00000000ba87cfff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba87d000-0x00000000ba887fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba888000-0x00000000ba888fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba889000-0x00000000ba892fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba893000-0x00000000ba893fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba894000-0x00000000ba899fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba89a000-0x00000000ba89afff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba89b000-0x00000000ba8a8fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba8a9000-0x00000000ba8a9fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba8aa000-0x00000000ba8b8fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba8b9000-0x00000000ba8b9fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba8ba000-0x00000000ba8f2fff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba8f3000-0x00000000ba937fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba938000-0x00000000ba9befff] type 20
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ba9bf000-0x00000000baebefff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000baebf000-0x00000000bafbefff] ACPI NVS
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000bafbf000-0x00000000baffefff] ACPI data
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000bafff000-0x00000000baffffff] usable
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000bb000000-0x00000000bf9fffff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f3ffffff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x00000000ffb80000-0x00000000ffffffff] reserved
Mar 02 12:09:29 computer kernel: BIOS-e820: [mem 0x0000000100000000-0x000000013f5fffff] usable
Mar 02 12:09:29 computer kernel: NX (Execute Disable) protection: active
Mar 02 12:09:29 computer kernel: efi: EFI v2.31 by INSYDE Corp.
Mar 02 12:09:29 computer kernel: efi: ACPI=0xbaffe000 ACPI 2.0=0xbaffe014 SMBIOS=0xbaebef98
Mar 02 12:09:29 computer kernel: SMBIOS 2.7 present.
Mar 02 12:09:29 computer kernel: DMI: LENOVO 20236/INVALID, BIOS 78CN25WW(V2.03) 11/19/2013
Mar 02 12:09:29 computer kernel: tsc: Fast TSC calibration using PIT
Mar 02 12:09:29 computer kernel: tsc: Detected 2394.602 MHz processor
Mar 02 12:09:29 computer kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Mar 02 12:09:29 computer kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Mar 02 12:09:29 computer kernel: last_pfn = 0x13f600 max_arch_pfn = 0x400000000
Mar 02 12:09:29 computer kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Mar 02 12:09:29 computer kernel: last_pfn = 0xbb000 max_arch_pfn = 0x400000000
Mar 02 12:09:29 computer kernel: Secure boot disabled
Mar 02 12:09:29 computer kernel: RAMDISK: [mem 0x36379000-0x371b3fff]
Mar 02 12:09:29 computer kernel: ACPI: Early table checksum verification disabled
Mar 02 12:09:29 computer kernel: ACPI: RSDP 0x00000000BAFFE014 000024 (v02 LENOVO)
Mar 02 12:09:29 computer kernel: ACPI: XSDT 0x00000000BAFFE210 0000AC (v01 LENOVO CB-01    00000001      01000013)
Mar 02 12:09:29 computer kernel: ACPI: FACP 0x00000000BAFFA000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: DSDT 0x00000000BAFEC000 00A06F (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: FACS 0x00000000BAFBB000 000040
Mar 02 12:09:29 computer kernel: ACPI: SLIC 0x00000000BAFFD000 000176 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: UEFI 0x00000000BAFFC000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: ASF! 0x00000000BAFFB000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: HPET 0x00000000BAFF9000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: APIC 0x00000000BAFF8000 00008C (v03 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: MCFG 0x00000000BAFF7000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0x00000000BAFEB000 0006FE (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: BOOT 0x00000000BAFE9000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: ASPT 0x00000000BAFE7000 000034 (v07 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: DBGP 0x00000000BAFE6000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: FPDT 0x00000000BAFE4000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: MSDM 0x00000000BAFE3000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0x00000000BAFE2000 0008E4 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0x00000000BAFE1000 000B22 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0x00000000BAFDE000 001EED (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: BGRT 0x00000000BAFE0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Mar 02 12:09:29 computer kernel: ACPI: Reserving FACP table memory at [mem 0xbaffa000-0xbaffa10b]
Mar 02 12:09:29 computer kernel: ACPI: Reserving DSDT table memory at [mem 0xbafec000-0xbaff606e]
Mar 02 12:09:29 computer kernel: ACPI: Reserving FACS table memory at [mem 0xbafbb000-0xbafbb03f]
Mar 02 12:09:29 computer kernel: ACPI: Reserving SLIC table memory at [mem 0xbaffd000-0xbaffd175]
Mar 02 12:09:29 computer kernel: ACPI: Reserving UEFI table memory at [mem 0xbaffc000-0xbaffc235]
Mar 02 12:09:29 computer kernel: ACPI: Reserving ASF! table memory at [mem 0xbaffb000-0xbaffb0a4]
Mar 02 12:09:29 computer kernel: ACPI: Reserving HPET table memory at [mem 0xbaff9000-0xbaff9037]
Mar 02 12:09:29 computer kernel: ACPI: Reserving APIC table memory at [mem 0xbaff8000-0xbaff808b]
Mar 02 12:09:29 computer kernel: ACPI: Reserving MCFG table memory at [mem 0xbaff7000-0xbaff703b]
Mar 02 12:09:29 computer kernel: ACPI: Reserving SSDT table memory at [mem 0xbafeb000-0xbafeb6fd]
Mar 02 12:09:29 computer kernel: ACPI: Reserving BOOT table memory at [mem 0xbafe9000-0xbafe9027]
Mar 02 12:09:29 computer kernel: ACPI: Reserving ASPT table memory at [mem 0xbafe7000-0xbafe7033]
Mar 02 12:09:29 computer kernel: ACPI: Reserving DBGP table memory at [mem 0xbafe6000-0xbafe6033]
Mar 02 12:09:29 computer kernel: ACPI: Reserving FPDT table memory at [mem 0xbafe4000-0xbafe4043]
Mar 02 12:09:29 computer kernel: ACPI: Reserving MSDM table memory at [mem 0xbafe3000-0xbafe3054]
Mar 02 12:09:29 computer kernel: ACPI: Reserving SSDT table memory at [mem 0xbafe2000-0xbafe28e3]
Mar 02 12:09:29 computer kernel: ACPI: Reserving SSDT table memory at [mem 0xbafe1000-0xbafe1b21]
Mar 02 12:09:29 computer kernel: ACPI: Reserving SSDT table memory at [mem 0xbafde000-0xbafdfeec]
Mar 02 12:09:29 computer kernel: ACPI: Reserving BGRT table memory at [mem 0xbafe0000-0xbafe0037]
Mar 02 12:09:29 computer kernel: No NUMA configuration found
Mar 02 12:09:29 computer kernel: Faking a node at [mem 0x0000000000000000-0x000000013f5fffff]
Mar 02 12:09:29 computer kernel: NODE_DATA(0) allocated [mem 0x13f5fa000-0x13f5fdfff]
Mar 02 12:09:29 computer kernel: Zone ranges:
Mar 02 12:09:29 computer kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Mar 02 12:09:29 computer kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Mar 02 12:09:29 computer kernel:   Normal   [mem 0x0000000100000000-0x000000013f5fffff]
Mar 02 12:09:29 computer kernel:   Device   empty
Mar 02 12:09:29 computer kernel: Movable zone start for each node
Mar 02 12:09:29 computer kernel: Early memory node ranges
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x0000000000001000-0x0000000000087fff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x0000000000100000-0x000000001fffffff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x0000000020200000-0x0000000040003fff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x0000000040005000-0x00000000b3fecfff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x00000000b4d6e000-0x00000000b4daffff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x00000000b61b0000-0x00000000ba7befff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x00000000bafff000-0x00000000baffffff]
Mar 02 12:09:29 computer kernel:   node   0: [mem 0x0000000100000000-0x000000013f5fffff]
Mar 02 12:09:29 computer kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000013f5fffff]
Mar 02 12:09:29 computer kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone DMA: 120 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone DMA32: 512 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone DMA32: 1 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone DMA32: 3457 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone DMA32: 5120 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone DMA32: 2112 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone Normal: 20480 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: On node 0, zone Normal: 2560 pages in unavailable ranges
Mar 02 12:09:29 computer kernel: Reserving Intel graphics memory at [mem 0xbba00000-0xbf9fffff]
Mar 02 12:09:29 computer kernel: ACPI: PM-Timer IO Port: 0x408
Mar 02 12:09:29 computer kernel: IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
Mar 02 12:09:29 computer kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Mar 02 12:09:29 computer kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Mar 02 12:09:29 computer kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Mar 02 12:09:29 computer kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Mar 02 12:09:29 computer kernel: e820: update [mem 0xb7438000-0xb74b2fff] usable ==> reserved
Mar 02 12:09:29 computer kernel: TSC deadline timer available
Mar 02 12:09:29 computer kernel: smpboot: Allowing 8 CPUs, 4 hotplug CPUs
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0x00088000-0x000bffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0x000c0000-0x000fffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0x40004000-0x40004fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xb3fed000-0xb4d6dfff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xb4db0000-0xb61affff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xb7438000-0xb74b2fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba7bf000-0xba84efff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba84f000-0xba850fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba851000-0xba863fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba864000-0xba864fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba865000-0xba87bfff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba87c000-0xba87cfff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba87d000-0xba887fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba888000-0xba888fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba889000-0xba892fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba893000-0xba893fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba894000-0xba899fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba89a000-0xba89afff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba89b000-0xba8a8fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba8a9000-0xba8a9fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba8aa000-0xba8b8fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba8b9000-0xba8b9fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba8ba000-0xba8f2fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba8f3000-0xba937fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba938000-0xba9befff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xba9bf000-0xbaebefff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xbaebf000-0xbafbefff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xbafbf000-0xbaffefff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xbb000000-0xbf9fffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xbfa00000-0xefffffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf3ffffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xf4000000-0xfeafffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb03fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfeb04000-0xfebfffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffb7ffff]
Mar 02 12:09:29 computer kernel: PM: hibernation: Registered nosave memory: [mem 0xffb80000-0xffffffff]
Mar 02 12:09:29 computer kernel: [mem 0xbfa00000-0xefffffff] available for PCI devices
Mar 02 12:09:29 computer kernel: Booting paravirtualized kernel on bare hardware
Mar 02 12:09:29 computer kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Mar 02 12:09:29 computer kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
Mar 02 12:09:29 computer kernel: percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
Mar 02 12:09:29 computer kernel: pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
Mar 02 12:09:29 computer kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Mar 02 12:09:29 computer kernel: Built 1 zonelists, mobility grouping on.  Total pages: 998229
Mar 02 12:09:29 computer kernel: Policy zone: Normal
Mar 02 12:09:29 computer kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=1d12580d-22e2-4db1-abf8-cebbb9ee4c49 rw quiet resume=UUID=62a959f8-998a-4b75-8c86-54f4a0461707 udev.log_priority=3
Mar 02 12:09:29 computer kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Mar 02 12:09:29 computer kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Mar 02 12:09:29 computer kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Mar 02 12:09:29 computer kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
Mar 02 12:09:29 computer kernel: Memory: 3801584K/4056852K available (16392K kernel code, 2086K rwdata, 10944K rodata, 2016K init, 3656K bss, 255008K reserved, 0K cma-reserved)
Mar 02 12:09:29 computer kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Mar 02 12:09:29 computer kernel: Kernel/User page tables isolation: enabled
Mar 02 12:09:29 computer kernel: ftrace: allocating 44504 entries in 174 pages
Mar 02 12:09:29 computer kernel: ftrace: allocated 174 pages with 5 groups
Mar 02 12:09:29 computer kernel: rcu: Preemptible hierarchical RCU implementation.
Mar 02 12:09:29 computer kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
Mar 02 12:09:29 computer kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
Mar 02 12:09:29 computer kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Mar 02 12:09:29 computer kernel:         Trampoline variant of Tasks RCU enabled.
Mar 02 12:09:29 computer kernel:         Rude variant of Tasks RCU enabled.
Mar 02 12:09:29 computer kernel:         Tracing variant of Tasks RCU enabled.
Mar 02 12:09:29 computer kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Mar 02 12:09:29 computer kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Mar 02 12:09:29 computer kernel: NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
Mar 02 12:09:29 computer kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Mar 02 12:09:29 computer kernel: Console: colour dummy device 80x25
Mar 02 12:09:29 computer kernel: printk: console [tty0] enabled
Mar 02 12:09:29 computer kernel: ACPI: Core revision 20210730
Mar 02 12:09:29 computer kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
Mar 02 12:09:29 computer kernel: APIC: Switch to symmetric I/O mode setup
Mar 02 12:09:29 computer kernel: x2apic: IRQ remapping doesn't support X2APIC mode
Mar 02 12:09:29 computer kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Mar 02 12:09:29 computer kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x22844c144c7, max_idle_ns: 440795221231 ns
Mar 02 12:09:29 computer kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4791.75 BogoMIPS (lpj=7982006)
Mar 02 12:09:29 computer kernel: pid_max: default: 32768 minimum: 301
Mar 02 12:09:29 computer kernel: LSM: Security Framework initializing
Mar 02 12:09:29 computer kernel: landlock: Up and running.
Mar 02 12:09:29 computer kernel: Yama: becoming mindful.
Mar 02 12:09:29 computer kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mar 02 12:09:29 computer kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mar 02 12:09:29 computer kernel: CPU0: Thermal monitoring enabled (TM1)
Mar 02 12:09:29 computer kernel: process: using mwait in idle threads
Mar 02 12:09:29 computer kernel: Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
Mar 02 12:09:29 computer kernel: Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
Mar 02 12:09:29 computer kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Mar 02 12:09:29 computer kernel: Spectre V2 : Mitigation: Retpolines
Mar 02 12:09:29 computer kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Mar 02 12:09:29 computer kernel: Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
Mar 02 12:09:29 computer kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
Mar 02 12:09:29 computer kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Mar 02 12:09:29 computer kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
Mar 02 12:09:29 computer kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Mar 02 12:09:29 computer kernel: MDS: Mitigation: Clear CPU buffers
Mar 02 12:09:29 computer kernel: MMIO Stale Data: Unknown: No mitigations
Mar 02 12:09:29 computer kernel: Freeing SMP alternatives memory: 36K
Mar 02 12:09:29 computer kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1024
Mar 02 12:09:29 computer kernel: smpboot: CPU0: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz (family: 0x6, model: 0x3a, stepping: 0x9)
Mar 02 12:09:29 computer kernel: Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
Mar 02 12:09:29 computer kernel: ... version:                3
Mar 02 12:09:29 computer kernel: ... bit width:              48
Mar 02 12:09:29 computer kernel: ... generic registers:      4
Mar 02 12:09:29 computer kernel: ... value mask:             0000ffffffffffff
Mar 02 12:09:29 computer kernel: ... max period:             00007fffffffffff
Mar 02 12:09:29 computer kernel: ... fixed-purpose events:   3
Mar 02 12:09:29 computer kernel: ... event mask:             000000070000000f
Mar 02 12:09:29 computer kernel: rcu: Hierarchical SRCU implementation.
Mar 02 12:09:29 computer kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Mar 02 12:09:29 computer kernel: smp: Bringing up secondary CPUs ...
Mar 02 12:09:29 computer kernel: x86: Booting SMP configuration:
Mar 02 12:09:29 computer kernel: .... node  #0, CPUs:      #1
Mar 02 12:09:29 computer kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Mar 02 12:09:29 computer kernel:  #2 #3
Mar 02 12:09:29 computer kernel: smp: Brought up 1 node, 4 CPUs
Mar 02 12:09:29 computer kernel: smpboot: Max logical packages: 2
Mar 02 12:09:29 computer kernel: smpboot: Total of 4 processors activated (19164.01 BogoMIPS)
Mar 02 12:09:29 computer kernel: devtmpfs: initialized
Mar 02 12:09:29 computer kernel: x86/mm: Memory block size: 128MB
Mar 02 12:09:29 computer kernel: ACPI: PM: Registering ACPI NVS region [mem 0xbaebf000-0xbafbefff] (1048576 bytes)
Mar 02 12:09:29 computer kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Mar 02 12:09:29 computer kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Mar 02 12:09:29 computer kernel: pinctrl core: initialized pinctrl subsystem
Mar 02 12:09:29 computer kernel: PM: RTC time: 11:09:18, date: 2023-03-02
Mar 02 12:09:29 computer kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Mar 02 12:09:29 computer kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
Mar 02 12:09:29 computer kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Mar 02 12:09:29 computer kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Mar 02 12:09:29 computer kernel: audit: initializing netlink subsys (disabled)
Mar 02 12:09:29 computer kernel: audit: type=2000 audit(1677755358.056:1): state=initialized audit_enabled=0 res=1
Mar 02 12:09:29 computer kernel: thermal_sys: Registered thermal governor 'fair_share'
Mar 02 12:09:29 computer kernel: thermal_sys: Registered thermal governor 'bang_bang'
Mar 02 12:09:29 computer kernel: thermal_sys: Registered thermal governor 'step_wise'
Mar 02 12:09:29 computer kernel: thermal_sys: Registered thermal governor 'user_space'
Mar 02 12:09:29 computer kernel: thermal_sys: Registered thermal governor 'power_allocator'
Mar 02 12:09:29 computer kernel: cpuidle: using governor ladder
Mar 02 12:09:29 computer kernel: cpuidle: using governor menu
Mar 02 12:09:29 computer kernel: Simple Boot Flag at 0x44 set to 0x1
Mar 02 12:09:29 computer kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Mar 02 12:09:29 computer kernel: ACPI: bus type PCI registered
Mar 02 12:09:29 computer kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Mar 02 12:09:29 computer kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
Mar 02 12:09:29 computer kernel: PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in E820
Mar 02 12:09:29 computer kernel: PCI: Using configuration type 1 for base access
Mar 02 12:09:29 computer kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
Mar 02 12:09:29 computer kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mar 02 12:09:29 computer kernel: Kprobes globally optimized
Mar 02 12:09:29 computer kernel: HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
Mar 02 12:09:29 computer kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(Module Device)
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(Processor Device)
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(Processor Aggregator Device)
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(Linux-Dell-Video)
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Mar 02 12:09:29 computer kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Mar 02 12:09:29 computer kernel: ACPI: 5 ACPI AML tables successfully acquired and loaded
Mar 02 12:09:29 computer kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Mar 02 12:09:29 computer kernel: ACPI: Dynamic OEM Table Load:
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0xFFFF8F6DC0AB7000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20120518)
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0xFFFF8F6DC0283000 000303 (v01 PmRef  ApIst    00003000 INTL 20120518)
Mar 02 12:09:29 computer kernel: ACPI: SSDT 0xFFFF8F6DC0216E00 000119 (v01 PmRef  ApCst    00003000 INTL 20120518)
Mar 02 12:09:29 computer kernel: ACPI: EC: EC started
Mar 02 12:09:29 computer kernel: ACPI: EC: interrupt blocked
Mar 02 12:09:29 computer kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Mar 02 12:09:29 computer kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
Mar 02 12:09:29 computer kernel: ACPI: Interpreter enabled
Mar 02 12:09:29 computer kernel: ACPI: PM: (supports S0 S3 S4 S5)
Mar 02 12:09:29 computer kernel: ACPI: Using IOAPIC for interrupt routing
Mar 02 12:09:29 computer kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Mar 02 12:09:29 computer kernel: ACPI: Enabled 8 GPEs in block 00 to 3F
Mar 02 12:09:29 computer kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
Mar 02 12:09:29 computer kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Mar 02 12:09:29 computer kernel: acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_ERROR)
Mar 02 12:09:29 computer kernel: PCI host bridge to bus 0000:00
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [mem 0xbfa00000-0xfeafffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
Mar 02 12:09:29 computer kernel: pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
Mar 02 12:09:29 computer kernel: pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
Mar 02 12:09:29 computer kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: reg 0x10: [mem 0xd8000000-0xd83fffff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Mar 02 12:09:29 computer kernel: pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
Mar 02 12:09:29 computer kernel: pci 0000:00:14.0: reg 0x10: [mem 0xd8700000-0xd870ffff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
Mar 02 12:09:29 computer kernel: pci 0000:00:16.0: reg 0x10: [mem 0xd8714000-0xd871400f 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
Mar 02 12:09:29 computer kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xd8719000-0xd87193ff]
Mar 02 12:09:29 computer kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
Mar 02 12:09:29 computer kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xd8710000-0xd8713fff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
Mar 02 12:09:29 computer kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xd8718000-0xd87183ff]
Mar 02 12:09:29 computer kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.0: [8086:1e59] type 00 class 0x060100
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: reg 0x10: [io  0x4088-0x408f]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: reg 0x14: [io  0x4094-0x4097]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: reg 0x18: [io  0x4080-0x4087]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: reg 0x1c: [io  0x4090-0x4093]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: reg 0x20: [io  0x4060-0x407f]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xd8717000-0xd87177ff]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.2: PME# supported from D3hot
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xd8715000-0xd87150ff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:00:1f.3: reg 0x20: [io  0x4040-0x405f]
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: [1002:6600] type 00 class 0x038000
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: reg 0x10: [mem 0xd0000000-0xd7ffffff 64bit pref]
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: reg 0x18: [mem 0xd8600000-0xd863ffff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: reg 0x20: [io  0x3000-0x30ff]
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: enabling Extended Tags
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: supports D1 D2
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: PME# supported from D1 D2 D3hot
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 63.008 Gb/s with 8.0 GT/s PCIe x8 link)
Mar 02 12:09:29 computer kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Mar 02 12:09:29 computer kernel: pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
Mar 02 12:09:29 computer kernel: pci 0000:00:01.0:   bridge window [mem 0xd8600000-0xd86fffff]
Mar 02 12:09:29 computer kernel: pci 0000:00:01.0:   bridge window [mem 0xd0000000-0xd7ffffff 64bit pref]
Mar 02 12:09:29 computer kernel: pci 0000:02:00.0: [1969:10a0] type 00 class 0x020000
Mar 02 12:09:29 computer kernel: pci 0000:02:00.0: reg 0x10: [mem 0xd8500000-0xd853ffff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:02:00.0: reg 0x18: [io  0x2000-0x207f]
Mar 02 12:09:29 computer kernel: pci 0000:02:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
Mar 02 12:09:29 computer kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.0:   bridge window [mem 0xd8500000-0xd85fffff]
Mar 02 12:09:29 computer kernel: pci 0000:03:00.0: [8086:08b1] type 00 class 0x028000
Mar 02 12:09:29 computer kernel: pci 0000:03:00.0: reg 0x10: [mem 0xd8400000-0xd8401fff 64bit]
Mar 02 12:09:29 computer kernel: pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.1: PCI bridge to [bus 03]
Mar 02 12:09:29 computer kernel: pci 0000:00:1c.1:   bridge window [mem 0xd8400000-0xd84fffff]
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKA disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKB disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKC disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKD disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKE disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKF disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKG disabled
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
Mar 02 12:09:29 computer kernel: ACPI: PCI: Interrupt link LNKH disabled
Mar 02 12:09:29 computer kernel: ACPI: EC: interrupt unblocked
Mar 02 12:09:29 computer kernel: ACPI: EC: event unblocked
Mar 02 12:09:29 computer kernel: ACPI: EC: GPE=0x17
Mar 02 12:09:29 computer kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
Mar 02 12:09:29 computer kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
Mar 02 12:09:29 computer kernel: iommu: Default domain type: Translated
Mar 02 12:09:29 computer kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Mar 02 12:09:29 computer kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Mar 02 12:09:29 computer kernel: vgaarb: loaded
Mar 02 12:09:29 computer kernel: SCSI subsystem initialized
Mar 02 12:09:29 computer kernel: libata version 3.00 loaded.
Mar 02 12:09:29 computer kernel: ACPI: bus type USB registered
Mar 02 12:09:29 computer kernel: usbcore: registered new interface driver usbfs
Mar 02 12:09:29 computer kernel: usbcore: registered new interface driver hub
Mar 02 12:09:29 computer kernel: usbcore: registered new device driver usb
Mar 02 12:09:29 computer kernel: pps_core: LinuxPPS API ver. 1 registered
Mar 02 12:09:29 computer kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Mar 02 12:09:29 computer kernel: PTP clock support registered
Mar 02 12:09:29 computer kernel: EDAC MC: Ver: 3.0.0
Mar 02 12:09:29 computer kernel: Registered efivars operations
Mar 02 12:09:29 computer kernel: NetLabel: Initializing
Mar 02 12:09:29 computer kernel: NetLabel:  domain hash size = 128
Mar 02 12:09:29 computer kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Mar 02 12:09:29 computer kernel: NetLabel:  unlabeled traffic allowed by default
Mar 02 12:09:29 computer kernel: PCI: Using ACPI for IRQ routing
Mar 02 12:09:29 computer kernel: PCI: pci_cache_line_size set to 64 bytes
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0x00088000-0x0008ffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0xb3fed000-0xb3ffffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0xb4db0000-0xb7ffffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0xb7438000-0xb7ffffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0xba7bf000-0xbbffffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0xbb000000-0xbbffffff]
Mar 02 12:09:29 computer kernel: e820: reserve RAM buffer [mem 0x13f600000-0x13fffffff]
Mar 02 12:09:29 computer kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Mar 02 12:09:29 computer kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Mar 02 12:09:29 computer kernel: clocksource: Switched to clocksource tsc-early
Mar 02 12:09:29 computer kernel: VFS: Disk quotas dquot_6.6.0
Mar 02 12:09:29 computer kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Mar 02 12:09:29 computer kernel: pnp: PnP ACPI init
Mar 02 12:09:29 computer kernel: system 00:00: [io  0x0680-0x069f] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0x1000-0x100f] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0xffff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0x0400-0x0453] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0x0458-0x047f] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0x0500-0x057f] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0x164e-0x164f] has been reserved
Mar 02 12:09:29 computer kernel: system 00:00: [io  0xfd60-0xfd63] has been reserved
Mar 02 12:09:29 computer kernel: system 00:02: [io  0x0454-0x0457] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfed1c000-0xfed1ffff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xf0000000-0xf3ffffff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfed90000-0xfed93fff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xff000000-0xff000fff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xff010000-0xffffffff] could not be reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
Mar 02 12:09:29 computer kernel: system 00:05: [mem 0xbfa00000-0xbfa00fff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:06: [mem 0x20000000-0x201fffff] has been reserved
Mar 02 12:09:29 computer kernel: system 00:06: [mem 0x40004000-0x40004fff] has been reserved
Mar 02 12:09:29 computer kernel: pnp: PnP ACPI: found 7 devices
Mar 02 12:09:29 computer kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Mar 02 12:09:29 computer kernel: NET: Registered PF_INET protocol family
Mar 02 12:09:29 computer kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
Mar 02 12:09:29 computer kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Mar 02 12:09:29 computer kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Mar 02 12:09:29 computer kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Mar 02 12:09:29 computer kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Mar 02 12:09:29 computer kernel: TCP: Hash tables configured (established 32768 bind 32768)
Mar 02 12:09:29 computer kernel: MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
Mar 02 12:09:29 computer kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Mar 02 12:09:29 computer kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Mar 02 12:09:29 computer kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Mar 02 12:09:29 computer kernel: NET: Registered PF_XDP protocol family
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: can't claim BAR 6 [mem 0xfffe0000-0xffffffff pref]: no compatible bridge window
Mar 02 12:09:29 computer kernel: pci 0000:01:00.0: BAR 6: assigned [mem 0xd8640000-0xd865ffff pref]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:00: resource 15 [mem 0xbfa00000-0xfeafffff window]
Mar 02 12:09:29 computer kernel: pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
Mar 02 12:09:29 computer kernel: pci_bus 0000:01: resource 1 [mem 0xd8600000-0xd86fffff]
Mar 02 12:09:29 computer kernel: pci_bus 0000:01: resource 2 [mem 0xd0000000-0xd7ffffff 64bit pref]
Mar 02 12:09:29 computer kernel: pci_bus 0000:02: resource 0 [io  0x2000-0x2fff]
Mar 02 12:09:29 computer kernel: pci_bus 0000:02: resource 1 [mem 0xd8500000-0xd85fffff]
Mar 02 12:09:29 computer kernel: pci_bus 0000:03: resource 1 [mem 0xd8400000-0xd84fffff]
Mar 02 12:09:29 computer kernel: pci 0000:00:1a.0: EHCI: BIOS handoff failed (BIOS bug?) 01010001
Mar 02 12:09:29 computer kernel: pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x750 took 1624831 usecs
Mar 02 12:09:29 computer kernel: pci 0000:00:1d.0: EHCI: BIOS handoff failed (BIOS bug?) 01010001
Mar 02 12:09:29 computer kernel: pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x750 took 1627574 usecs
Mar 02 12:09:29 computer kernel: pci 0000:02:00.0: set MSI_INTX_DISABLE_BUG flag
Mar 02 12:09:29 computer kernel: PCI: CLS 64 bytes, default 64
Mar 02 12:09:29 computer kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Mar 02 12:09:29 computer kernel: software IO TLB: mapped [mem 0x00000000af1c0000-0x00000000b31c0000] (64MB)
Mar 02 12:09:29 computer kernel: Trying to unpack rootfs image as initramfs...
Mar 02 12:09:29 computer kernel: Initialise system trusted keyrings
Mar 02 12:09:29 computer kernel: Key type blacklist registered
Mar 02 12:09:29 computer kernel: workingset: timestamp_bits=41 max_order=20 bucket_order=0
Mar 02 12:09:29 computer kernel: zbud: loaded
Mar 02 12:09:29 computer kernel: Key type asymmetric registered
Mar 02 12:09:29 computer kernel: Asymmetric key parser 'x509' registered
Mar 02 12:09:29 computer kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
Mar 02 12:09:29 computer kernel: io scheduler mq-deadline registered
Mar 02 12:09:29 computer kernel: io scheduler kyber registered
Mar 02 12:09:29 computer kernel: io scheduler bfq registered
Mar 02 12:09:29 computer kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Mar 02 12:09:29 computer kernel: ACPI: AC: AC Adapter [ACAD] (on-line)
Mar 02 12:09:29 computer kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input0
Mar 02 12:09:29 computer kernel: ACPI: button: Power Button [PWRB]
Mar 02 12:09:29 computer kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
Mar 02 12:09:29 computer kernel: ACPI: button: Lid Switch [LID0]
Mar 02 12:09:29 computer kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Mar 02 12:09:29 computer kernel: ACPI: button: Power Button [PWRF]
Mar 02 12:09:29 computer kernel: thermal LNXTHERM:00: registered as thermal_zone0
Mar 02 12:09:29 computer kernel: ACPI: thermal: Thermal Zone [TZ00] (47 C)
Mar 02 12:09:29 computer kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Mar 02 12:09:29 computer kernel: Non-volatile memory driver v1.3
Mar 02 12:09:29 computer kernel: Linux agpgart interface v0.103
Mar 02 12:09:29 computer kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
Mar 02 12:09:29 computer kernel: ahci 0000:00:1f.2: version 3.0
Mar 02 12:09:29 computer kernel: ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
Mar 02 12:09:29 computer kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
Mar 02 12:09:29 computer kernel: ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems apst
Mar 02 12:09:29 computer kernel: scsi host0: ahci
Mar 02 12:09:29 computer kernel: scsi host1: ahci
Mar 02 12:09:29 computer kernel: scsi host2: ahci
Mar 02 12:09:29 computer kernel: scsi host3: ahci
Mar 02 12:09:29 computer kernel: scsi host4: ahci
Mar 02 12:09:29 computer kernel: scsi host5: ahci
Mar 02 12:09:29 computer kernel: ata1: SATA max UDMA/133 abar m2048@0xd8717000 port 0xd8717100 irq 25
Mar 02 12:09:29 computer kernel: ata2: DUMMY
Mar 02 12:09:29 computer kernel: ata3: SATA max UDMA/133 abar m2048@0xd8717000 port 0xd8717200 irq 25
Mar 02 12:09:29 computer kernel: ata4: DUMMY
Mar 02 12:09:29 computer kernel: ata5: DUMMY
Mar 02 12:09:29 computer kernel: ata6: DUMMY
Mar 02 12:09:29 computer kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mar 02 12:09:29 computer kernel: ehci-pci: EHCI PCI platform driver
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1a.0: debug port 2
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xd8719000
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Mar 02 12:09:29 computer kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
Mar 02 12:09:29 computer kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 02 12:09:29 computer kernel: usb usb1: Product: EHCI Host Controller
Mar 02 12:09:29 computer kernel: usb usb1: Manufacturer: Linux 5.15.94-1-MANJARO ehci_hcd
Mar 02 12:09:29 computer kernel: usb usb1: SerialNumber: 0000:00:1a.0
Mar 02 12:09:29 computer kernel: hub 1-0:1.0: USB hub found
Mar 02 12:09:29 computer kernel: hub 1-0:1.0: 2 ports detected
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1d.0: debug port 2
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xd8718000
Mar 02 12:09:29 computer kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Mar 02 12:09:29 computer kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
Mar 02 12:09:29 computer kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 02 12:09:29 computer kernel: usb usb2: Product: EHCI Host Controller
Mar 02 12:09:29 computer kernel: usb usb2: Manufacturer: Linux 5.15.94-1-MANJARO ehci_hcd
Mar 02 12:09:29 computer kernel: usb usb2: SerialNumber: 0000:00:1d.0
Mar 02 12:09:29 computer kernel: hub 2-0:1.0: USB hub found
Mar 02 12:09:29 computer kernel: hub 2-0:1.0: 2 ports detected
Mar 02 12:09:29 computer kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Mar 02 12:09:29 computer kernel: ohci-pci: OHCI PCI platform driver
Mar 02 12:09:29 computer kernel: uhci_hcd: USB Universal Host Controller Interface driver
Mar 02 12:09:29 computer kernel: usbcore: registered new interface driver usbserial_generic
Mar 02 12:09:29 computer kernel: usbserial: USB Serial support registered for generic
Mar 02 12:09:29 computer kernel: rtc_cmos 00:01: RTC can wake from S4
Mar 02 12:09:29 computer kernel: rtc_cmos 00:01: registered as rtc0
Mar 02 12:09:29 computer kernel: rtc_cmos 00:01: setting system clock to 2023-03-02T11:09:21 UTC (1677755361)
Mar 02 12:09:29 computer kernel: rtc_cmos 00:01: alarms up to one month, 242 bytes nvram, hpet irqs
Mar 02 12:09:29 computer kernel: intel_pstate: Intel P-state driver initializing
Mar 02 12:09:29 computer kernel: ledtrig-cpu: registered to indicate activity on CPUs
Mar 02 12:09:29 computer kernel: efifb: probing for efifb
Mar 02 12:09:29 computer kernel: efifb: showing boot graphics
Mar 02 12:09:29 computer kernel: efifb: framebuffer at 0xc0000000, using 4160k, total 4160k
Mar 02 12:09:29 computer kernel: efifb: mode is 1366x768x32, linelength=5504, pages=1
Mar 02 12:09:29 computer kernel: efifb: scrolling: redraw
Mar 02 12:09:29 computer kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Mar 02 12:09:29 computer kernel: fbcon: Deferring console take-over
Mar 02 12:09:29 computer kernel: fb0: EFI VGA frame buffer device
Mar 02 12:09:29 computer kernel: hid: raw HID events driver (C) Jiri Kosina
Mar 02 12:09:29 computer kernel: ashmem: initialized
Mar 02 12:09:29 computer kernel: drop_monitor: Initializing network drop monitor service
Mar 02 12:09:29 computer kernel: Initializing XFRM netlink socket
Mar 02 12:09:29 computer kernel: NET: Registered PF_INET6 protocol family
Mar 02 12:09:29 computer kernel: ACPI: battery: Slot [BAT1] (battery present)
Mar 02 12:09:29 computer kernel: Freeing initrd memory: 14572K
Mar 02 12:09:29 computer kernel: Segment Routing with IPv6
Mar 02 12:09:29 computer kernel: RPL Segment Routing with IPv6
Mar 02 12:09:29 computer kernel: In-situ OAM (IOAM) with IPv6
Mar 02 12:09:29 computer kernel: NET: Registered PF_PACKET protocol family
Mar 02 12:09:29 computer kernel: microcode: sig=0x306a9, pf=0x10, revision=0x21
Mar 02 12:09:29 computer kernel: microcode: Microcode Update Driver: v2.2.
Mar 02 12:09:29 computer kernel: IPI shorthand broadcast: enabled
Mar 02 12:09:29 computer kernel: sched_clock: Marking stable (3893038181, 403114)->(3912408021, -18966726)
Mar 02 12:09:29 computer kernel: registered taskstats version 1
Mar 02 12:09:29 computer kernel: Loading compiled-in X.509 certificates
Mar 02 12:09:29 computer kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a89fa4392a495a4bf711331aeeb4ce66e1196d5f'
Mar 02 12:09:29 computer kernel: zswap: loaded using pool zstd/z3fold
Mar 02 12:09:29 computer kernel: Key type .fscrypt registered
Mar 02 12:09:29 computer kernel: Key type fscrypt-provisioning registered
Mar 02 12:09:29 computer kernel: PM:   Magic number: 15:910:174
Mar 02 12:09:29 computer kernel: acpi device:37: hash matches
Mar 02 12:09:29 computer kernel: acpi device:0a: hash matches
Mar 02 12:09:29 computer kernel: RAS: Correctable Errors collector initialized.
Mar 02 12:09:29 computer kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
Mar 02 12:09:29 computer kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
Mar 02 12:09:29 computer kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mar 02 12:09:29 computer kernel: ata1.00: ATA-8: TOSHIBA MQ02ABF050H, HDF01K, max UDMA/100
Mar 02 12:09:29 computer kernel: ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Mar 02 12:09:29 computer kernel: ata1.00: Features: NCQ-sndrcv
Mar 02 12:09:29 computer kernel: ata1.00: configured for UDMA/100
Mar 02 12:09:29 computer kernel: scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ02ABF0 1K   PQ: 0 ANSI: 5
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: [sda] Write Protect is off
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 02 12:09:29 computer kernel:  sda: sda1 sda2 sda3
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Mar 02 12:09:29 computer kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
Mar 02 12:09:29 computer kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 02 12:09:29 computer kernel: hub 1-1:1.0: USB hub found
Mar 02 12:09:29 computer kernel: hub 1-1:1.0: 6 ports detected
Mar 02 12:09:29 computer kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
Mar 02 12:09:29 computer kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 02 12:09:29 computer kernel: hub 2-1:1.0: USB hub found
Mar 02 12:09:29 computer kernel: hub 2-1:1.0: 6 ports detected
Mar 02 12:09:29 computer kernel: ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Mar 02 12:09:29 computer kernel: usb 1-1.3: new full-speed USB device number 3 using ehci-pci
Mar 02 12:09:29 computer kernel: ata3.00: ATA-9: ST1000LM014-1EJ164, LVD1, max UDMA/133
Mar 02 12:09:29 computer kernel: ata3.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 32), AA
Mar 02 12:09:29 computer kernel: ata3.00: configured for UDMA/133
Mar 02 12:09:29 computer kernel: scsi 2:0:0:0: Direct-Access     ATA      ST1000LM014-1EJ1 LVD1 PQ: 0 ANSI: 5
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: [sdb] 4096-byte physical blocks
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: [sdb] Write Protect is off
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 02 12:09:29 computer kernel:  sdb: sdb1 sdb2 sdb3 sdb4
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: [sdb] Attached SCSI disk
Mar 02 12:09:29 computer kernel: Freeing unused decrypted memory: 2036K
Mar 02 12:09:29 computer kernel: Freeing unused kernel image (initmem) memory: 2016K
Mar 02 12:09:29 computer kernel: Write protecting the kernel read-only data: 30720k
Mar 02 12:09:29 computer kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
Mar 02 12:09:29 computer kernel: Freeing unused kernel image (rodata/data gap) memory: 1344K
Mar 02 12:09:29 computer kernel: usb 1-1.3: New USB device found, idVendor=8087, idProduct=07dc, bcdDevice= 0.01
Mar 02 12:09:29 computer kernel: usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 02 12:09:29 computer kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Mar 02 12:09:29 computer kernel: rodata_test: all tests were successful
Mar 02 12:09:29 computer kernel: x86/mm: Checking user space page tables
Mar 02 12:09:29 computer kernel: usb 1-1.4: new high-speed USB device number 4 using ehci-pci
Mar 02 12:09:29 computer kernel: Run /init as init process
Mar 02 12:09:29 computer kernel:   with arguments:
Mar 02 12:09:29 computer kernel:     /init
Mar 02 12:09:29 computer kernel:   with environment:
Mar 02 12:09:29 computer kernel:     HOME=/
Mar 02 12:09:29 computer kernel:     TERM=linux
Mar 02 12:09:29 computer kernel:     BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
Mar 02 12:09:29 computer kernel: tsc: Refined TSC clocksource calibration: 2394.559 MHz
Mar 02 12:09:29 computer kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2284235ba97, max_idle_ns: 440795203400 ns
Mar 02 12:09:29 computer kernel: usb 1-1.4: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
Mar 02 12:09:29 computer kernel: usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 02 12:09:29 computer kernel: usb 1-1.4: Product: USB2.0-CRW
Mar 02 12:09:29 computer kernel: usb 1-1.4: Manufacturer: Generic
Mar 02 12:09:29 computer kernel: usb 1-1.4: SerialNumber: 20100201396000000
Mar 02 12:09:29 computer kernel: usbcore: registered new interface driver rtsx_usb
Mar 02 12:09:29 computer kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Mar 02 12:09:29 computer kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
Mar 02 12:09:29 computer kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
Mar 02 12:09:29 computer kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
Mar 02 12:09:29 computer kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Mar 02 12:09:29 computer kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
Mar 02 12:09:29 computer kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 02 12:09:29 computer kernel: usb usb3: Product: xHCI Host Controller
Mar 02 12:09:29 computer kernel: usb usb3: Manufacturer: Linux 5.15.94-1-MANJARO xhci-hcd
Mar 02 12:09:29 computer kernel: usb usb3: SerialNumber: 0000:00:14.0
Mar 02 12:09:29 computer kernel: hub 3-0:1.0: USB hub found
Mar 02 12:09:29 computer kernel: hub 3-0:1.0: 4 ports detected
Mar 02 12:09:29 computer kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:MSS4] at 0x60,0x64 irq 1,12
Mar 02 12:09:29 computer kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
Mar 02 12:09:29 computer kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 02 12:09:29 computer kernel: usb usb4: Product: xHCI Host Controller
Mar 02 12:09:29 computer kernel: usb usb4: Manufacturer: Linux 5.15.94-1-MANJARO xhci-hcd
Mar 02 12:09:29 computer kernel: usb usb4: SerialNumber: 0000:00:14.0
Mar 02 12:09:29 computer kernel: hub 4-0:1.0: USB hub found
Mar 02 12:09:29 computer kernel: hub 4-0:1.0: 4 ports detected
Mar 02 12:09:29 computer kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Mar 02 12:09:29 computer kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Mar 02 12:09:29 computer kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Mar 02 12:09:29 computer kernel: usb 3-4: new high-speed USB device number 2 using xhci_hcd
Mar 02 12:09:29 computer kernel: PM: Image not found (code -22)
Mar 02 12:09:29 computer kernel: usb 3-4: New USB device found, idVendor=0bda, idProduct=5728, bcdDevice= 0.09
Mar 02 12:09:29 computer kernel: usb 3-4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Mar 02 12:09:29 computer kernel: usb 3-4: Product: Lenovo EasyCamera
Mar 02 12:09:29 computer kernel: usb 3-4: Manufacturer: CF0D77T60
Mar 02 12:09:29 computer kernel: usb 3-4: SerialNumber: 200901010001
Mar 02 12:09:29 computer kernel: fbcon: Taking over console
Mar 02 12:09:29 computer kernel: Console: switching to colour frame buffer device 170x48
Mar 02 12:09:29 computer kernel: EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
Mar 02 12:09:29 computer kernel: random: crng init done
Mar 02 12:09:29 computer systemd[1]: systemd 252.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
Mar 02 12:09:29 computer systemd[1]: Detected architecture x86-64.
Mar 02 12:09:29 computer systemd[1]: Hostname set to <computer>.
Mar 02 12:09:29 computer systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
Mar 02 12:09:29 computer systemd[1]: Queued start job for default target Graphical Interface.
Mar 02 12:09:29 computer systemd[1]: Created slice Slice /system/getty.
Mar 02 12:09:29 computer systemd[1]: Created slice Slice /system/modprobe.
Mar 02 12:09:29 computer systemd[1]: Created slice Slice /system/systemd-fsck.
Mar 02 12:09:29 computer systemd[1]: Created slice User and Session Slice.
Mar 02 12:09:29 computer systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Mar 02 12:09:29 computer systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Mar 02 12:09:29 computer systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Mar 02 12:09:29 computer systemd[1]: Reached target Local Encrypted Volumes.
Mar 02 12:09:29 computer systemd[1]: Reached target Login Prompts.
Mar 02 12:09:29 computer systemd[1]: Reached target Local Integrity Protected Volumes.
Mar 02 12:09:29 computer systemd[1]: Reached target Remote File Systems.
Mar 02 12:09:29 computer systemd[1]: Reached target Slice Units.
Mar 02 12:09:29 computer systemd[1]: Reached target Local Verity Protected Volumes.
Mar 02 12:09:29 computer systemd[1]: Listening on Device-mapper event daemon FIFOs.
Mar 02 12:09:29 computer systemd[1]: Listening on LVM2 poll daemon socket.
Mar 02 12:09:29 computer systemd[1]: Listening on Process Core Dump Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on Journal Audit Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on Journal Socket (/dev/log).
Mar 02 12:09:29 computer systemd[1]: Listening on Journal Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on udev Control Socket.
Mar 02 12:09:29 computer systemd[1]: Listening on udev Kernel Socket.
Mar 02 12:09:29 computer systemd[1]: Mounting Huge Pages File System...
Mar 02 12:09:29 computer systemd[1]: Mounting POSIX Message Queue File System...
Mar 02 12:09:29 computer systemd[1]: Mounting Kernel Debug File System...
Mar 02 12:09:29 computer systemd[1]: Mounting Kernel Trace File System...
Mar 02 12:09:29 computer systemd[1]: Starting Create List of Static Device Nodes...
Mar 02 12:09:29 computer systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Module configfs...
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Module drm...
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Module fuse...
Mar 02 12:09:29 computer systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Mar 02 12:09:29 computer systemd[1]: Starting Load Kernel Modules...
Mar 02 12:09:29 computer systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 02 12:09:29 computer systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 02 12:09:29 computer systemd[1]: Starting Coldplug All udev Devices...
Mar 02 12:09:29 computer systemd[1]: Mounted Huge Pages File System.
Mar 02 12:09:29 computer systemd[1]: Mounted POSIX Message Queue File System.
Mar 02 12:09:29 computer systemd[1]: Mounted Kernel Debug File System.
Mar 02 12:09:29 computer systemd[1]: Mounted Kernel Trace File System.
Mar 02 12:09:29 computer systemd[1]: Finished Create List of Static Device Nodes.
Mar 02 12:09:29 computer systemd[1]: modprobe@configfs.service: Deactivated successfully.
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Module configfs.
Mar 02 12:09:29 computer systemd[1]: modprobe@drm.service: Deactivated successfully.
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Module drm.
Mar 02 12:09:29 computer systemd[1]: Mounting Kernel Configuration File System...
Mar 02 12:09:29 computer systemd[1]: Mounted Kernel Configuration File System.
Mar 02 12:09:29 computer kernel: EXT4-fs (sdb2): re-mounted. Opts: (null). Quota mode: none.
Mar 02 12:09:29 computer systemd[1]: Finished Remount Root and Kernel File Systems.
Mar 02 12:09:29 computer systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:29 computer systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 02 12:09:29 computer systemd[1]: Starting Load/Save Random Seed...
Mar 02 12:09:29 computer systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 02 12:09:29 computer systemd[1]: Starting Create Static Device Nodes in /dev...
Mar 02 12:09:29 computer kernel: fuse: init (API version 7.34)
Mar 02 12:09:29 computer systemd[1]: modprobe@fuse.service: Deactivated successfully.
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Module fuse.
Mar 02 12:09:29 computer systemd[1]: Mounting FUSE Control File System...
Mar 02 12:09:29 computer systemd[1]: Mounted FUSE Control File System.
Mar 02 12:09:29 computer systemd[1]: Finished Load/Save Random Seed.
Mar 02 12:09:29 computer systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:29 computer systemd[1]: Finished Coldplug All udev Devices.
Mar 02 12:09:29 computer kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar 02 12:09:29 computer kernel: sd 2:0:0:0: Attached scsi generic sg1 type 0
Mar 02 12:09:29 computer systemd[1]: Finished Load Kernel Modules.
Mar 02 12:09:29 computer systemd[1]: Starting Apply Kernel Variables...
Mar 02 12:09:29 computer systemd[1]: Finished Apply Kernel Variables.
Mar 02 12:09:29 computer systemd[1]: Finished Create Static Device Nodes in /dev.
Mar 02 12:09:29 computer systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 02 12:09:29 computer systemd[1]: Starting Journal Service...
Mar 02 12:09:29 computer systemd[1]: Starting Rule-based Manager for Device Events and Files...
Mar 02 12:09:29 computer systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Mar 02 12:09:29 computer systemd[1]: Reached target Preparation for Local File Systems.
Mar 02 12:09:29 computer systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
Mar 02 12:09:29 computer systemd-journald[254]: Journal started
Mar 02 12:09:29 computer systemd-journald[254]: Runtime Journal (/run/log/journal/da739cc6ab55434091bee8079b1e1ed4) is 8.0M, max 189.3M, 181.3M free.
Mar 02 12:09:29 computer systemd-modules-load[242]: Inserted module 'crypto_user'
Mar 02 12:09:29 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:29 computer systemd-modules-load[242]: Inserted module 'sg'
Mar 02 12:09:29 computer systemd-modules-load[242]: Inserted module 'uinput'
Mar 02 12:09:29 computer systemd[1]: Starting Flush Journal to Persistent Storage...
Mar 02 12:09:29 computer systemd[1]: Started Journal Service.
Mar 02 12:09:29 computer kernel: audit: type=1130 audit(1677755369.965:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:29 computer systemd-journald[254]: Time spent on flushing to /var/log/journal/da739cc6ab55434091bee8079b1e1ed4 is 295.723ms for 840 entries.
Mar 02 12:09:29 computer systemd-journald[254]: System Journal (/var/log/journal/da739cc6ab55434091bee8079b1e1ed4) is 1.9G, max 3.9G, 1.9G free.
Mar 02 12:09:35 computer systemd-journald[254]: Received client request to flush runtime journal.
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755370.742:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI: OSL: Resource conflict; ACPI support missing from driver?
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000055F (\_SB.PCI0.PEG0.PEGP.GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Mar 02 12:09:35 computer kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Mar 02 12:09:35 computer kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
Mar 02 12:09:35 computer kernel: i2c i2c-0: 1/2 memory slots populated (from DMI)
Mar 02 12:09:35 computer kernel: i2c i2c-0: Successfully instantiated SPD at 0x50
Mar 02 12:09:35 computer kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 02 12:09:35 computer kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mar 02 12:09:35 computer kernel: input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input6
Mar 02 12:09:35 computer kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
Mar 02 12:09:35 computer kernel: RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
Mar 02 12:09:35 computer kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Mar 02 12:09:35 computer kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
Mar 02 12:09:35 computer kernel: ideapad_acpi VPC2004:00: DYTC interface is not available
Mar 02 12:09:35 computer kernel: cryptd: max_cpu_qlen set to 1000
Mar 02 12:09:35 computer kernel: alx 0000:02:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [20:89:84:fe:a0:61]
Mar 02 12:09:35 computer kernel: at24 0-0050: supply vcc not found, using dummy regulator
Mar 02 12:09:35 computer kernel: at24 0-0050: 256 byte spd EEPROM, read-only
Mar 02 12:09:35 computer kernel: iTCO_vendor_support: vendor-support=0
Mar 02 12:09:35 computer kernel: Bluetooth: Core ver 2.22
Mar 02 12:09:35 computer kernel: NET: Registered PF_BLUETOOTH protocol family
Mar 02 12:09:35 computer kernel: Bluetooth: HCI device and connection manager initialized
Mar 02 12:09:35 computer kernel: Bluetooth: HCI socket layer initialized
Mar 02 12:09:35 computer kernel: Bluetooth: L2CAP socket layer initialized
Mar 02 12:09:35 computer kernel: Bluetooth: SCO socket layer initialized
Mar 02 12:09:35 computer kernel: alx 0000:02:00.0 enp2s0: renamed from eth0
Mar 02 12:09:35 computer kernel: Intel(R) Wireless WiFi driver for Linux
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0: loaded firmware version 17.3216344376.0 7260-17.ucode op_mode iwlmvm
Mar 02 12:09:35 computer kernel: usbcore: registered new interface driver btusb
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: Legacy ROM 2.5 revision 8.0 build 2 week 3 2013
Mar 02 12:09:35 computer kernel: [drm] radeon kernel modesetting enabled.
Mar 02 12:09:35 computer kernel: vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
Mar 02 12:09:35 computer kernel: ATPX version 1, functions 0x00000033
Mar 02 12:09:35 computer kernel: Console: switching to colour dummy device 80x25
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: enabling device (0000 -> 0003)
Mar 02 12:09:35 computer kernel: [drm] initializing kernel modesetting (OLAND 0x1002:0x6600 0x17AA:0x3800 0x00).
Mar 02 12:09:35 computer kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Mar 02 12:09:35 computer kernel: ATOM BIOS: Lenovo
Mar 02 12:09:35 computer kernel: [drm] GPU not posted. posting now...
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: GTT: 2048M 0x0000000080000000 - 0x00000000FFFFFFFF
Mar 02 12:09:35 computer kernel: [drm] Detected VRAM RAM=2048M, BAR=128M
Mar 02 12:09:35 computer kernel: [drm] RAM width 128bits DDR
Mar 02 12:09:35 computer kernel: [drm] radeon: 2048M of VRAM memory ready
Mar 02 12:09:35 computer kernel: [drm] radeon: 2048M of GTT memory ready.
Mar 02 12:09:35 computer kernel: [drm] Loading oland Microcode
Mar 02 12:09:35 computer kernel: iTCO_wdt iTCO_wdt.3.auto: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
Mar 02 12:09:35 computer kernel: iTCO_wdt iTCO_wdt.3.auto: initialized. heartbeat=30 sec (nowayout=0)
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755372.725:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x450f03)
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755372.725:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-EC40\x2dE2D4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
Mar 02 12:09:35 computer kernel: psmouse serio1: elantech: Synaptics capabilities query result 0x78, 0x17, 0x0b.
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0: base HW address: a0:a8:cd:eb:a4:e2
Mar 02 12:09:35 computer kernel: psmouse serio1: elantech: Elan sample query result 04, 5c, 85
Mar 02 12:09:35 computer kernel: Bluetooth: hci0: Intel BT fw patch 0x57 completed & activated
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755372.785:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:platform::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: [drm] Internal thermal controller without fan control
Mar 02 12:09:35 computer kernel: [drm] radeon: dpm initialized
Mar 02 12:09:35 computer kernel: input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input5
Mar 02 12:09:35 computer kernel: [drm] GART: num cpu pages 524288, num gpu pages 524288
Mar 02 12:09:35 computer kernel: [drm] PCIE gen 2 link speeds already enabled
Mar 02 12:09:35 computer kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: WB enabled
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: radeon: MSI limited to 32-bit
Mar 02 12:09:35 computer kernel: radeon 0000:01:00.0: radeon: using MSI.
Mar 02 12:09:35 computer kernel: [drm] radeon: irq initialized.
Mar 02 12:09:35 computer kernel: Adding 1048572k swap on /dev/sdb1.  Priority:-2 extents:1 across:1048572k FS
Mar 02 12:09:35 computer kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
Mar 02 12:09:35 computer kernel: mousedev: PS/2 mouse device common for all mice
Mar 02 12:09:35 computer kernel: intel_rapl_common: Found RAPL domain package
Mar 02 12:09:35 computer kernel: intel_rapl_common: Found RAPL domain core
Mar 02 12:09:35 computer kernel: intel_rapl_common: Found RAPL domain uncore
Mar 02 12:09:35 computer kernel: intel_rapl_common: RAPL package-0 domain package locked by BIOS
Mar 02 12:09:35 computer kernel: iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
Mar 02 12:09:35 computer kernel: mc: Linux media interface: v0.10
Mar 02 12:09:35 computer kernel: videodev: Linux video capture interface: v2.00
Mar 02 12:09:35 computer kernel: [drm] ring test on 0 succeeded in 1 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 1 succeeded in 1 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 2 succeeded in 1 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 3 succeeded in 4 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 4 succeeded in 3 usecs
Mar 02 12:09:35 computer kernel: [drm] ring test on 5 succeeded in 2 usecs
Mar 02 12:09:35 computer kernel: [drm] UVD initialized successfully.
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Mar 02 12:09:35 computer kernel: usb 3-4: Found UVC 1.00 device Lenovo EasyCamera (0bda:5728)
Mar 02 12:09:35 computer kernel: input: Lenovo EasyCamera: Lenovo EasyC as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/input/input7
Mar 02 12:09:35 computer kernel: usbcore: registered new interface driver uvcvideo
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755373.472:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fcdff842\x2d3f01\x2d43f7\x2d8655\x2d900b7b489fd8 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
Mar 02 12:09:35 computer kernel: [drm] ib test on ring 5 succeeded
Mar 02 12:09:35 computer kernel: [drm] Radeon Display Connectors
Mar 02 12:09:35 computer kernel: [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
Mar 02 12:09:35 computer kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
Mar 02 12:09:35 computer kernel: ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
Mar 02 12:09:35 computer kernel: ACPI: video: Video Device [PEGP] (multi-head: yes  rom: no  post: no)
Mar 02 12:09:35 computer kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/LNXVIDEO:00/input/input8
Mar 02 12:09:35 computer kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Mar 02 12:09:35 computer kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:03/input/input9
Mar 02 12:09:35 computer kernel: snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Mar 02 12:09:35 computer kernel: vga_switcheroo: enabled
Mar 02 12:09:35 computer kernel: fbcon: i915drmfb (fb0) is primary device
Mar 02 12:09:35 computer kernel: Console: switching to colour frame buffer device 170x48
Mar 02 12:09:35 computer kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755374.865:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0: CX20757: BIOS auto-probing.
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX20757: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    mono: mono_out=0x0
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    inputs:
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:      Mic=0x19
Mar 02 12:09:35 computer kernel: snd_hda_codec_conexant hdaudioC0D0:    dig-in=0x1a
Mar 02 12:09:35 computer kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
Mar 02 12:09:35 computer kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
Mar 02 12:09:35 computer kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
Mar 02 12:09:30 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:32 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:32 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-EC40\x2dE2D4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:32 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:platform::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:33 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fcdff842\x2d3f01\x2d43f7\x2d8655\x2d900b7b489fd8 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:34 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:30 computer systemd[1]: Started Rule-based Manager for Device Events and Files.
Mar 02 12:09:32 computer mtp-probe[292]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4"
Mar 02 12:09:31 computer systemd[1]: Found device TOSHIBA_MQ02ABF050H Microsoft\x20basic\x20data.
Mar 02 12:09:32 computer mtp-probe[291]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd-fsck[316]: fsck.fat 4.2 (2021-01-31)
Mar 02 12:09:35 computer systemd-fsck[316]: /dev/sda2: 312 files, 48777/98304 clusters
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.448:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:31 computer systemd[1]: Starting File System Check on /dev/disk/by-uuid/EC40-E2D4...
Mar 02 12:09:32 computer mtp-probe[291]: bus: 3, device: 2 was not an MTP device
Mar 02 12:09:31 computer systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 02 12:09:32 computer mtp-probe[292]: bus: 1, device: 4 was not an MTP device
Mar 02 12:09:31 computer systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 02 12:09:32 computer systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 02 12:09:35 computer systemd-fsck[342]: /dev/sdb3: clean, 571851/3932160 files, 15097432/15728640 blocks
Mar 02 12:09:32 computer systemd[1]: Finished File System Check on /dev/disk/by-uuid/EC40-E2D4.
Mar 02 12:09:32 computer systemd[1]: Found device ST1000LM014-1EJ164 3.
Mar 02 12:09:32 computer systemd[1]: Created slice Slice /system/systemd-backlight.
Mar 02 12:09:32 computer systemd[1]: Mounting /boot/efi...
Mar 02 12:09:32 computer systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 02 12:09:32 computer systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight...
Mar 02 12:09:32 computer systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:32 computer systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:32 computer systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
Mar 02 12:09:32 computer systemd[1]: Starting File System Check on /dev/disk/by-uuid/fcdff842-3f01-43f7-8655-900b7b489fd8...
Mar 02 12:09:32 computer systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 02 12:09:32 computer systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 02 12:09:32 computer systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 02 12:09:32 computer systemd[1]: Found device ST1000LM014-1EJ164 1.
Mar 02 12:09:32 computer systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight.
Mar 02 12:09:32 computer systemd[1]: Activating swap /dev/disk/by-uuid/62a959f8-998a-4b75-8c86-54f4a0461707...
Mar 02 12:09:32 computer systemd[1]: Activated swap /dev/disk/by-uuid/62a959f8-998a-4b75-8c86-54f4a0461707.
Mar 02 12:09:32 computer systemd[1]: Reached target Swaps.
Mar 02 12:09:33 computer systemd[1]: Mounting Temporary Directory /tmp...
Mar 02 12:09:33 computer systemd[1]: Mounted /boot/efi.
Mar 02 12:09:33 computer systemd[1]: Mounted Temporary Directory /tmp.
Mar 02 12:09:33 computer systemd[1]: Finished File System Check on /dev/disk/by-uuid/fcdff842-3f01-43f7-8655-900b7b489fd8.
Mar 02 12:09:33 computer systemd[1]: Mounting /home...
Mar 02 12:09:33 computer systemd[1]: Mounted /home.
Mar 02 12:09:33 computer systemd[1]: Reached target Local File Systems.
Mar 02 12:09:33 computer systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
Mar 02 12:09:33 computer systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Mar 02 12:09:33 computer systemd[1]: Store a System Token in an EFI Variable was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:33 computer systemd[1]: Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Mar 02 12:09:34 computer systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Mar 02 12:09:34 computer systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Mar 02 12:09:35 computer systemd[1]: Finished Flush Journal to Persistent Storage.
Mar 02 12:09:35 computer systemd[1]: Starting Create Volatile Files and Directories...
Mar 02 12:09:35 computer systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Mar 02 12:09:35 computer systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Store a System Token in an EFI Variable was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
journalctl --boot 0 --no-pager part 2
Mar 02 12:09:35 computer systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:35 computer systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Mar 02 12:09:35 computer systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Mar 02 12:09:35 computer systemd[1]: Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
Mar 02 12:09:35 computer systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Finished Create Volatile Files and Directories.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Rebuild Journal Catalog was skipped because of an unmet condition check (ConditionNeedsUpdate=/var).
Mar 02 12:09:35 computer audit: BPF prog-id=21 op=LOAD
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.665:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.665:11): prog-id=21 op=LOAD
Mar 02 12:09:35 computer systemd[1]: Starting Network Time Synchronization...
Mar 02 12:09:35 computer systemd[1]: Update is Completed was skipped because no trigger condition checks were met.
Mar 02 12:09:35 computer systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Mar 02 12:09:35 computer kernel: [drm] amdgpu kernel modesetting enabled.
Mar 02 12:09:35 computer kernel: amdgpu: CRAT table not found
Mar 02 12:09:35 computer kernel: amdgpu: Virtual CRAT table created for CPU
Mar 02 12:09:35 computer kernel: amdgpu: Topology: Add CPU node
Mar 02 12:09:35 computer audit[375]: SYSTEM_BOOT pid=375 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1127 audit(1677755375.708:12): pid=375 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.715:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Started Network Time Synchronization.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Reached target System Initialization.
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.745:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Started CUPS Scheduler.
Mar 02 12:09:35 computer systemd[1]: Started Daily Cleanup of Temporary Directories.
Mar 02 12:09:35 computer systemd[1]: Reached target Path Units.
Mar 02 12:09:35 computer systemd[1]: Reached target System Time Set.
Mar 02 12:09:35 computer systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
Mar 02 12:09:35 computer systemd[1]: Started Daily rotation of log files.
Mar 02 12:09:35 computer systemd[1]: Started Daily man-db regeneration.
Mar 02 12:09:35 computer systemd[1]: Started Monthly clean packages cache.
Mar 02 12:09:35 computer systemd[1]: Started Generate mirrorlist weekly.
Mar 02 12:09:35 computer systemd[1]: Started pkgfile database update timer.
Mar 02 12:09:35 computer systemd[1]: Started Daily verification of password and group files.
Mar 02 12:09:35 computer systemd[1]: Reached target Timer Units.
Mar 02 12:09:35 computer systemd[1]: Listening on CUPS Scheduler.
Mar 02 12:09:35 computer systemd[1]: Listening on D-Bus System Message Bus Socket.
Mar 02 12:09:35 computer systemd[1]: Reached target Socket Units.
Mar 02 12:09:35 computer systemd[1]: TPM2 PCR Barrier (Initialization) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:35 computer systemd[1]: Reached target Basic System.
Mar 02 12:09:35 computer systemd[1]: Starting Save/Restore Sound Card State...
Mar 02 12:09:35 computer systemd[1]: Manage Sound Card State (restore and store) was skipped because of an unmet condition check (ConditionPathExists=/etc/alsa/state-daemon.conf).
Mar 02 12:09:35 computer systemd[1]: Starting Bluetooth service...
Mar 02 12:09:35 computer systemd[378]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mar 02 12:09:35 computer systemd[1]: Started Periodic Command Scheduler.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer kernel: audit: type=1130 audit(1677755375.755:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Starting D-Bus System Message Bus...
Mar 02 12:09:35 computer systemd[1]: Starting Authorization Manager...
Mar 02 12:09:35 computer audit: BPF prog-id=22 op=LOAD
Mar 02 12:09:35 computer audit: BPF prog-id=23 op=LOAD
Mar 02 12:09:35 computer audit: BPF prog-id=24 op=LOAD
Mar 02 12:09:35 computer systemd[1]: Starting User Login Management...
Mar 02 12:09:35 computer systemd[1]: TPM2 PCR Barrier (User) was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.765:16): prog-id=22 op=LOAD
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.765:17): prog-id=23 op=LOAD
Mar 02 12:09:35 computer kernel: audit: type=1334 audit(1677755375.765:18): prog-id=24 op=LOAD
Mar 02 12:09:35 computer systemd[1]: Finished Save/Restore Sound Card State.
Mar 02 12:09:35 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:35 computer systemd[1]: Reached target Sound Card.
Mar 02 12:09:35 computer crond[379]: (CRON) STARTUP (1.6.1)
Mar 02 12:09:35 computer crond[379]: (CRON) INFO (Syslog will be used instead of sendmail.)
Mar 02 12:09:35 computer crond[379]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 38% if used.)
Mar 02 12:09:35 computer crond[379]: (CRON) INFO (running with inotify support)
Mar 02 12:09:35 computer systemd-logind[382]: New seat seat0.
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event2 (Power Button)
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event0 (Power Button)
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event1 (Lid Switch)
Mar 02 12:09:35 computer systemd-logind[382]: Watching system buttons on /dev/input/event3 (AT Translated Set 2 keyboard)
Mar 02 12:09:35 computer polkitd[381]: Started polkitd version 122
Mar 02 12:09:36 computer bluetoothd[378]: Bluetooth daemon 5.66
Mar 02 12:09:37 computer systemd[1]: Started D-Bus System Message Bus.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.systemd1'
Mar 02 12:09:37 computer systemd[1]: Starting Network Manager...
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Started Bluetooth service.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Started User Login Management.
Mar 02 12:09:37 computer systemd[1]: Reached target Bluetooth Support.
Mar 02 12:09:37 computer polkitd[381]: Loading rules from directory /etc/polkit-1/rules.d
Mar 02 12:09:37 computer bluetoothd[378]: Starting SDP server
Mar 02 12:09:37 computer bluetoothd[378]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 02 12:09:37 computer bluetoothd[378]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 02 12:09:37 computer bluetoothd[378]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 02 12:09:37 computer bluetoothd[378]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 02 12:09:37 computer bluetoothd[378]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 02 12:09:37 computer bluetoothd[378]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 02 12:09:37 computer polkitd[381]: Loading rules from directory /usr/share/polkit-1/rules.d
Mar 02 12:09:37 computer kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 02 12:09:37 computer kernel: Bluetooth: BNEP filters: protocol multicast
Mar 02 12:09:37 computer kernel: Bluetooth: BNEP socket layer initialized
Mar 02 12:09:37 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.2' (uid=0 pid=378 comm="/usr/lib/bluetooth/bluetoothd")
Mar 02 12:09:37 computer bluetoothd[378]: Bluetooth management interface 1.21 initialized
Mar 02 12:09:37 computer audit: BPF prog-id=25 op=LOAD
Mar 02 12:09:37 computer audit: BPF prog-id=26 op=LOAD
Mar 02 12:09:37 computer audit: BPF prog-id=27 op=LOAD
Mar 02 12:09:37 computer kernel: NET: Registered PF_ALG protocol family
Mar 02 12:09:37 computer systemd[1]: Starting Hostname Service...
Mar 02 12:09:37 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mar 02 12:09:37 computer systemd[1]: Started Hostname Service.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer polkitd[381]: Finished loading, compiling and executing 7 rules
Mar 02 12:09:37 computer systemd[1]: Started Authorization Manager.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer polkitd[381]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Mar 02 12:09:37 computer systemd[1]: Starting Modem Manager...
Mar 02 12:09:37 computer NetworkManager[392]: <info>  [1677755377.8832] NetworkManager (version 1.42.2-0) is starting... (boot:e7c04cf2-a178-4cf0-876e-ef3841191af9)
Mar 02 12:09:37 computer NetworkManager[392]: <info>  [1677755377.8833] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Mar 02 12:09:37 computer systemd[1]: Started Network Manager.
Mar 02 12:09:37 computer NetworkManager[392]: <info>  [1677755377.9062] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Reached target Network.
Mar 02 12:09:37 computer systemd[1]: Starting Network Manager Wait Online...
Mar 02 12:09:37 computer systemd[1]: Starting CUPS Scheduler...
Mar 02 12:09:37 computer systemd[1]: Starting Permit User Sessions...
Mar 02 12:09:37 computer systemd[1]: Finished Permit User Sessions.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:37 computer systemd[1]: Started Simple Desktop Display Manager.
Mar 02 12:09:37 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:38 computer systemd[1]: systemd-rfkill.service: Deactivated successfully.
Mar 02 12:09:38 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:38 computer ModemManager[416]: <info>  ModemManager (version 1.20.4-1) starting in system bus...
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2498] manager[0x560a5ea61000]: monitoring kernel firmware directory '/lib/firmware'.
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2738] hostname: hostname: using hostnamed
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2738] hostname: static hostname changed from (none) to "computer"
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2923] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2947] rfkill3: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/ieee80211/phy0/rfkill3) (driver iwlwifi)
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2949] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/rfkill/rfkill0) (platform driver ideapad_acpi)
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2964] manager[0x560a5ea61000]: rfkill: Wi-Fi hardware radio set enabled
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.2964] manager[0x560a5ea61000]: rfkill: WWAN hardware radio set enabled
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.7763] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-wifi.so)
Mar 02 12:09:38 computer NetworkManager[392]: <info>  [1677755378.8057] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-adsl.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.1025] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-team.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.1691] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-wwan.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2498] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-bluetooth.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2512] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.42.2-0/libnm-device-plugin-ovs.so)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2515] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2516] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2517] manager: Networking is enabled by state file
Mar 02 12:09:39 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.2534] settings: Loaded settings plugin: keyfile (internal)
Mar 02 12:09:39 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 02 12:09:39 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 02 12:09:39 computer systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 02 12:09:39 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3802] dhcp: init: Using DHCP client 'internal'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3835] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3850] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3855] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3863] device (lo): Activation: starting connection 'lo' (71df1d6e-e4f2-4f26-ac2d-43bcbd6d722c)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3874] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3888] settings: (enp2s0): created default wired connection 'Wired connection 1'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3888] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3936] device (wlp3s0): driver supports Access Point (AP) mode
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3945] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.3949] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:39 computer systemd[1]: Started CUPS Scheduler.
Mar 02 12:09:39 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:39 computer NetworkManager[392]: <info>  [1677755379.6679] device (wlp3s0): set-hw-addr: set MAC address to 9A:C6:69:51:7D:D0 (scanning)
Mar 02 12:09:39 computer dbus-daemon[380]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:39 computer systemd[1]: Starting WPA supplicant...
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2058] ovsdb: disconnected from ovsdb
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2060] device (lo): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2068] device (lo): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2074] device (lo): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2094] device (lo): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2135] manager: (74:9E:F5:0A:0F:20): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/4)
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2142] device (74:9E:F5:0A:0F:20): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2157] device (74:9E:F5:0A:0F:20): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2564] device (lo): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2568] device (lo): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.2582] device (lo): Activation: successful, device activated.
Mar 02 12:09:40 computer dbus-daemon[380]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Mar 02 12:09:40 computer systemd[1]: Started WPA supplicant.
Mar 02 12:09:40 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer kernel: kauditd_printk_skb: 15 callbacks suppressed
Mar 02 12:09:40 computer kernel: audit: type=1130 audit(1677755380.488:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer kernel: NET: Registered PF_QIPCRTR protocol family
Mar 02 12:09:40 computer systemd[1]: Started Modem Manager.
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.5093] modem-manager: ModemManager not available
Mar 02 12:09:40 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer kernel: audit: type=1130 audit(1677755380.505:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:40 computer wpa_supplicant[434]: Successfully initialized wpa_supplicant
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.6156] modem-manager: ModemManager now available
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7778] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7779] Wi-Fi P2P device controlled by interface wlp3s0 created
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7782] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7787] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7797] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mar 02 12:09:40 computer NetworkManager[392]: <info>  [1677755380.7806] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:41 computer sddm[422]: Initializing...
Mar 02 12:09:41 computer sddm[422]: Starting...
Mar 02 12:09:41 computer sddm[422]: Logind interface found
Mar 02 12:09:41 computer sddm[422]: Adding new display on vt 1 ...
Mar 02 12:09:41 computer sddm[422]: Loading theme configuration from ""
Mar 02 12:09:41 computer sddm[422]: Display server starting...
Mar 02 12:09:41 computer sddm[422]: Adding cookie to "/var/run/sddm/{056fe443-54c4-4588-98bd-aa9341285262}"
Mar 02 12:09:41 computer sddm[422]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{056fe443-54c4-4588-98bd-aa9341285262} -noreset -displayfd 17
Mar 02 12:09:41 computer kernel: [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
Mar 02 12:09:41 computer kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: WB enabled
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Mar 02 12:09:41 computer kernel: radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_cp1' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_cp2' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_dma2' in directory '0' already present!
Mar 02 12:09:41 computer kernel: [drm] ring test on 0 succeeded in 1 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 1 succeeded in 1 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 2 succeeded in 1 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 3 succeeded in 4 usecs
Mar 02 12:09:41 computer kernel: [drm] ring test on 4 succeeded in 3 usecs
Mar 02 12:09:41 computer kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Mar 02 12:09:41 computer kernel: [drm] ring test on 5 succeeded in 2 usecs
Mar 02 12:09:41 computer kernel: [drm] UVD initialized successfully.
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Mar 02 12:09:41 computer kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Mar 02 12:09:42 computer kernel: [drm] ib test on ring 5 succeeded
Mar 02 12:09:43 computer ModemManager[416]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0': not supported by any plugin
Mar 02 12:09:43 computer ModemManager[416]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0': not supported by any plugin
Mar 02 12:09:46 computer NetworkManager[392]: <info>  [1677755386.7400] manager: startup complete
Mar 02 12:09:46 computer systemd[1]: Finished Network Manager Wait Online.
Mar 02 12:09:46 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:46 computer kernel: audit: type=1130 audit(1677755386.748:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:46 computer systemd[1]: Reached target Network is Online.
Mar 02 12:09:46 computer systemd[1]: Starting Samba NMB Daemon...
Mar 02 12:09:49 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 02 12:09:49 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:49 computer kernel: audit: type=1131 audit(1677755389.288:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:49 computer nmbd[449]: [2023/03/02 12:09:49.347294,  0] ../../source3/nmbd/nmbd.c:901(main)
Mar 02 12:09:49 computer nmbd[449]:   nmbd version 4.17.5 started.
Mar 02 12:09:49 computer nmbd[449]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Mar 02 12:09:49 computer nmbd[449]: [2023/03/02 12:09:49.421278,  0] ../../lib/util/become_daemon.c:150(daemon_status)
Mar 02 12:09:49 computer nmbd[449]:   daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mar 02 12:09:49 computer nmbd[449]: [2023/03/02 12:09:49.433243,  0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mar 02 12:09:49 computer nmbd[449]:   NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mar 02 12:09:49 computer sddm[422]: Setting default cursor
Mar 02 12:09:49 computer sddm[422]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Mar 02 12:09:49 computer sddm[422]: Display server started.
Mar 02 12:09:50 computer sddm[422]: Reading from "/usr/share/xsessions/plasma.desktop"
Mar 02 12:09:50 computer sddm[422]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Starting...
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Authenticating...
Mar 02 12:09:50 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: pam_sm_authenticate
Mar 02 12:09:50 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: Couldn't get password (it is empty)
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Preparing to converse...
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] Conversation with 1 messages
Mar 02 12:09:50 computer audit[457]: USER_AUTH pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer sddm-helper[457]: [PAM] returning.
Mar 02 12:09:50 computer kernel: audit: type=1100 audit(1677755390.375:38): pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.14' (uid=0 pid=457 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth5")
Mar 02 12:09:50 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:09:50 computer sddm-helper[457]: pam_systemd_home(sddm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:09:50 computer audit[457]: USER_ACCT pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer sddm[422]: Authenticated successfully
Mar 02 12:09:50 computer kernel: audit: type=1101 audit(1677755390.442:39): pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
Mar 02 12:09:50 computer audit[457]: CRED_ACQ pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer audit[457]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe262e4f30 a2=4 a3=0 items=0 ppid=422 pid=457 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Mar 02 12:09:50 computer audit: PROCTITLE proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746835333463356538352D613731342D343432642D613838312D623762616361346430313161002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Mar 02 12:09:50 computer sddm-helper[457]: pam_unix(sddm-autologin:session): session opened for user tomas(uid=1000) by (uid=0)
Mar 02 12:09:50 computer kernel: audit: type=1103 audit(1677755390.455:40): pid=457 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer kernel: audit: type=1006 audit(1677755390.455:41): pid=457 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
Mar 02 12:09:50 computer kernel: audit: type=1300 audit(1677755390.455:41): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffe262e4f30 a2=4 a3=0 items=0 ppid=422 pid=457 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Mar 02 12:09:50 computer kernel: audit: type=1327 audit(1677755390.455:41): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746835333463356538352D613731342D343432642D613838312D623762616361346430313161002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Mar 02 12:09:50 computer systemd[1]: Created slice User Slice of UID 1000.
Mar 02 12:09:50 computer systemd[1]: Starting User Runtime Directory /run/user/1000...
Mar 02 12:09:50 computer systemd-logind[382]: New session 1 of user tomas.
Mar 02 12:09:50 computer systemd[1]: Finished User Runtime Directory /run/user/1000.
Mar 02 12:09:50 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer systemd[1]: Starting User Manager for UID 1000...
Mar 02 12:09:50 computer kernel: audit: type=1130 audit(1677755390.588:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.16' (uid=0 pid=459 comm="(systemd)")
Mar 02 12:09:50 computer systemd[459]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:09:50 computer audit[459]: USER_ACCT pid=459 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer audit[459]: CRED_ACQ pid=459 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mar 02 12:09:50 computer systemd[459]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[tomas] ruser=[<unknown>] rhost=[<unknown>]
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffe2ea69b40 a2=4 a3=0 items=0 ppid=1 pid=459 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: PROCTITLE proctitle="(systemd)"
Mar 02 12:09:50 computer kernel: audit: type=1101 audit(1677755390.612:43): pid=459 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer systemd[459]: pam_unix(systemd-user:session): session opened for user tomas(uid=1000) by (uid=0)
Mar 02 12:09:50 computer audit[459]: USER_START pid=459 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="tomas" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:50 computer audit: BPF prog-id=28 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150f570 a2=90 a3=0 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=28 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=29 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150e3e0 a2=74 a3=2 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=29 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=30 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150e530 a2=80 a3=0 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=30 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=31 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150f340 a2=80 a3=2 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=31 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=32 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd3150f200 a2=40 a3=1 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=32 op=UNLOAD
Mar 02 12:09:50 computer audit: BPF prog-id=33 op=LOAD
Mar 02 12:09:50 computer audit[459]: SYSCALL arch=c000003e syscall=321 success=yes exit=10 a0=5 a1=7ffd3150f0c0 a2=80 a3=5 items=0 ppid=1 pid=459 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
Mar 02 12:09:50 computer audit: BPF prog-id=33 op=UNLOAD
Mar 02 12:09:51 computer systemd[459]: Queued start job for default target Main User Target.
Mar 02 12:09:51 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:51 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_session
Mar 02 12:09:51 computer systemd[459]: Created slice User Application Slice.
Mar 02 12:09:51 computer systemd[459]: Reached target Paths.
Mar 02 12:09:51 computer systemd[459]: Reached target Timers.
Mar 02 12:09:51 computer systemd[459]: Starting D-Bus User Message Bus Socket...
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG network certificate management daemon.
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 02 12:09:51 computer systemd[459]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 02 12:09:51 computer systemd[459]: Listening on p11-kit server.
Mar 02 12:09:51 computer systemd[459]: Listening on PipeWire Multimedia System Socket.
Mar 02 12:09:51 computer systemd[459]: Listening on Sound System.
Mar 02 12:09:51 computer sddm-helper[470]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
Mar 02 12:09:51 computer systemd[459]: Listening on D-Bus User Message Bus Socket.
Mar 02 12:09:51 computer systemd[459]: Reached target Sockets.
Mar 02 12:09:51 computer systemd[459]: Reached target Basic System.
Mar 02 12:09:51 computer systemd[1]: Started User Manager for UID 1000.
Mar 02 12:09:51 computer systemd[459]: Starting Update XDG user dir configuration...
Mar 02 12:09:51 computer systemd[1]: Started Session 1 of User tomas.
Mar 02 12:09:51 computer systemd[459]: Finished Update XDG user dir configuration.
Mar 02 12:09:51 computer systemd[459]: Reached target Main User Target.
Mar 02 12:09:51 computer systemd[459]: Startup finished in 1.038s.
Mar 02 12:09:51 computer audit[457]: USER_START pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:51 computer kernel: kauditd_printk_skb: 30 callbacks suppressed
Mar 02 12:09:51 computer kernel: audit: type=1105 audit(1677755391.865:60): pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:51 computer sddm-helper[457]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Mar 02 12:09:51 computer sddm-helper[472]: Adding cookie to "/home/tomas/.Xauthority"
Mar 02 12:09:52 computer sddm[422]: Session started
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3214] policy: auto-activating connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3225] device (wlp3s0): Activation: starting connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3228] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3235] manager: NetworkManager state is now CONNECTING
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3256] device (wlp3s0): set-hw-addr: reset MAC address to A0:A8:CD:EB:A4:E2 (preserve)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3274] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3281] device (wlp3s0): Activation: (wifi) access point 'UPC8127731' has security, but secrets are required.
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3281] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3284] sup-iface[98297733aecb18f1,0,wlp3s0]: wps: type pbc start...
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3296] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3302] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3308] device (wlp3s0): Activation: (wifi) connection 'UPC8127731' has security, and secrets exist.  No new secrets needed.
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3309] Config: added 'ssid' value 'UPC8127731'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3309] Config: added 'scan_ssid' value '1'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3310] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3310] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3310] Config: added 'auth_alg' value 'OPEN'
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.3311] Config: added 'psk' value '<hidden>'
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: WPS-CANCEL
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: SME: Trying to authenticate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:09:52 computer kernel: wlp3s0: authenticate with 38:43:7d:62:ff:bb
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4211] device (wlp3s0): supplicant interface state: disconnected -> authenticating
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4211] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> authenticating
Mar 02 12:09:52 computer kernel: wlp3s0: send auth to 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: Trying to associate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4417] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4417] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 02 12:09:52 computer kernel: wlp3s0: authenticated
Mar 02 12:09:52 computer kernel: wlp3s0: associate with 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:09:52 computer kernel: wlp3s0: RX AssocResp from 38:43:7d:62:ff:bb (capab=0x511 status=0 aid=1)
Mar 02 12:09:52 computer kernel: wlp3s0: associated
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: Associated with 38:43:7d:62:ff:bb
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4886] device (wlp3s0): supplicant interface state: associating -> associated
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.4887] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5090] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5091] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: WPA: Key negotiation completed with 38:43:7d:62:ff:bb [PTK=CCMP GTK=TKIP]
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to 38:43:7d:62:ff:bb completed [id=0 id_str=]
Mar 02 12:09:52 computer kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5889] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5889] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "UPC8127731"
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5889] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5891] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:52 computer NetworkManager[392]: <info>  [1677755392.5898] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:09:52 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-50 noise=9999 txrate=866700
Mar 02 12:09:52 computer systemd[459]: Created slice User Core Session Slice.
Mar 02 12:09:52 computer systemd[459]: Starting D-Bus User Message Bus...
Mar 02 12:09:53 computer systemd[459]: Started D-Bus User Message Bus.
Mar 02 12:09:53 computer dbus-daemon[498]: [session uid=1000 pid=498] Successfully activated service 'org.freedesktop.systemd1'
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:09:54 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 02 12:09:54 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 02 12:09:54 computer kernel: audit: type=1130 audit(1677755394.788:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8330] dhcp4 (wlp3s0): state changed new lease, address=192.168.0.164
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8336] policy: set 'UPC8127731' (wlp3s0) as default for IPv4 routing and DNS
Mar 02 12:09:54 computer audit: BPF prog-id=34 op=LOAD
Mar 02 12:09:54 computer audit[392]: SYSCALL arch=c000003e syscall=321 success=yes exit=27 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:09:54 computer audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 02 12:09:54 computer kernel: audit: type=1334 audit(1677755394.868:62): prog-id=34 op=LOAD
Mar 02 12:09:54 computer kernel: audit: type=1300 audit(1677755394.868:62): arch=c000003e syscall=321 success=yes exit=27 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:09:54 computer kernel: audit: type=1327 audit(1677755394.868:62): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8865] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8900] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8904] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8910] manager: NetworkManager state is now CONNECTED_SITE
Mar 02 12:09:54 computer NetworkManager[392]: <info>  [1677755394.8920] device (wlp3s0): Activation: successful, device activated.
Mar 02 12:09:54 computer systemd[1]: Started Samba NMB Daemon.
Mar 02 12:09:54 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer kernel: audit: type=1130 audit(1677755394.968:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:54 computer systemd[1]: Starting Samba SMB Daemon...
Mar 02 12:09:55 computer NetworkManager[392]: <info>  [1677755395.0450] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 02 12:09:55 computer smbd[504]: [2023/03/02 12:09:55.878886,  0] ../../source3/smbd/server.c:1741(main)
Mar 02 12:09:55 computer smbd[504]:   smbd version 4.17.5 started.
Mar 02 12:09:55 computer smbd[504]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Mar 02 12:09:56 computer sddm-helper[457]: [PAM] Closing session
Mar 02 12:09:56 computer sddm-helper[457]: pam_unix(sddm-autologin:session): session closed for user tomas
Mar 02 12:09:56 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_close_session
Mar 02 12:09:56 computer audit[457]: USER_END pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer kernel: audit: type=1106 audit(1677755396.298:64): pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer kernel: audit: type=1104 audit(1677755396.298:65): pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer audit[457]: CRED_DISP pid=457 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="tomas" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Mar 02 12:09:56 computer sddm-helper[457]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
Mar 02 12:09:56 computer sddm-helper[457]: [PAM] Ended.
Mar 02 12:09:56 computer sddm[422]: Auth: sddm-helper exited with 1
Mar 02 12:09:56 computer systemd-logind[382]: Session 1 logged out. Waiting for processes to exit.
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.3107] device (wlp3s0): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.3117] manager: NetworkManager state is now DISCONNECTING
Mar 02 12:09:56 computer kernel: wlp3s0: deauthenticating from 38:43:7d:62:ff:bb by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 02 12:09:56 computer systemd[1]: Started Samba SMB Daemon.
Mar 02 12:09:56 computer kernel: audit: type=1130 audit(1677755396.402:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:56 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:09:56 computer systemd[1]: Reached target Multi-User System.
Mar 02 12:09:56 computer systemd[1]: Reached target Graphical Interface.
Mar 02 12:09:56 computer systemd[1]: Startup finished in 6.983s (kernel) + 31.749s (userspace) = 38.733s.
Mar 02 12:09:56 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.20' (uid=0 pid=504 comm="/usr/bin/smbd --foreground --no-process-group")
Mar 02 12:09:56 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Mar 02 12:09:56 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=38:43:7d:62:ff:bb reason=3 locally_generated=1
Mar 02 12:09:56 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 02 12:09:56 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5011] device (wlp3s0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5223] dhcp4 (wlp3s0): canceled DHCP transaction
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5224] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5224] dhcp4 (wlp3s0): state changed no lease
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5253] device (wlp3s0): set-hw-addr: set MAC address to 7E:F3:E8:B4:D5:68 (scanning)
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5913] manager: NetworkManager state is now DISCONNECTED
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5926] device (wlp3s0): supplicant interface state: completed -> disconnected
Mar 02 12:09:56 computer NetworkManager[392]: <info>  [1677755396.5926] device (p2p-dev-wlp3s0): supplicant management interface state: completed -> disconnected
Mar 02 12:09:56 computer audit: BPF prog-id=34 op=UNLOAD
Mar 02 12:09:56 computer kernel: audit: type=1334 audit(1677755396.608:67): prog-id=34 op=UNLOAD
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.977549,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.977858,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19510 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.977940,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978013,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19511 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978081,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978152,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19512 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978219,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978285,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19513 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978352,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978430,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19514 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978499,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:56 computer nmbd[449]: [2023/03/02 12:09:56.978561,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:56 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19516 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.979829,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.979973,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19510 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980046,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980117,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19511 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980191,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980261,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19512 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980329,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980394,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19513 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980465,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980545,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19514 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980616,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:57 computer nmbd[449]: [2023/03/02 12:09:57.980680,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:57 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19516 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.981929,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982094,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19510 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982215,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982316,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19511 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982389,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982463,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19512 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982528,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982596,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19513 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982663,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982743,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19514 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982844,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:09:58 computer nmbd[449]: [2023/03/02 12:09:58.982906,  0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
Mar 02 12:09:58 computer nmbd[449]:   retransmit_or_expire_response_records: Failed to resend packet id 19516 to IP 192.168.0.255 on subnet 192.168.0.164
Mar 02 12:10:04 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 02 12:10:04 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:04 computer kernel: audit: type=1131 audit(1677755404.802:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:08 computer systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mar 02 12:10:08 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:08 computer kernel: audit: type=1131 audit(1677755408.302:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:10:08 computer audit: BPF prog-id=27 op=UNLOAD
Mar 02 12:10:08 computer audit: BPF prog-id=26 op=UNLOAD
Mar 02 12:10:08 computer audit: BPF prog-id=25 op=UNLOAD
Mar 02 12:10:08 computer kernel: audit: type=1334 audit(1677755408.382:70): prog-id=27 op=UNLOAD
Mar 02 12:10:08 computer kernel: audit: type=1334 audit(1677755408.382:71): prog-id=26 op=UNLOAD
Mar 02 12:10:08 computer kernel: audit: type=1334 audit(1677755408.382:72): prog-id=25 op=UNLOAD
Mar 02 12:10:10 computer nmbd[449]: [2023/03/02 12:10:10.996896,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:10 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:12 computer nmbd[449]: [2023/03/02 12:10:12.999454,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:12 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:15 computer nmbd[449]: [2023/03/02 12:10:15.002022,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:15 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:17 computer nmbd[449]: [2023/03/02 12:10:17.004714,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:17 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005563,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:18 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005748,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:10:18 computer nmbd[449]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005826,  0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mar 02 12:10:18 computer nmbd[449]:   send_netbios_packet: send_packet() to IP 192.168.0.255 port 137 failed
Mar 02 12:10:18 computer nmbd[449]: [2023/03/02 12:10:18.005895,  0] ../../source3/nmbd/nmbd_nameregister.c:582(register_name)
Mar 02 12:10:18 computer nmbd[449]: [82B blob data]
Mar 02 12:11:08 computer nmbd[449]: [2023/03/02 12:11:08.056836,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mar 02 12:11:08 computer nmbd[449]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
Mar 02 12:12:02 computer kernel: [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
Mar 02 12:12:02 computer kernel: [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: WB enabled
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
Mar 02 12:12:02 computer kernel: radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_cp1' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_cp2' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_dma2' in directory '0' already present!
Mar 02 12:12:02 computer kernel: [drm] ring test on 0 succeeded in 1 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 1 succeeded in 1 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 2 succeeded in 1 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 3 succeeded in 3 usecs
Mar 02 12:12:02 computer kernel: [drm] ring test on 4 succeeded in 3 usecs
Mar 02 12:12:02 computer kernel: debugfs: File 'radeon_ring_uvd' in directory '0' already present!
Mar 02 12:12:02 computer kernel: [drm] ring test on 5 succeeded in 2 usecs
Mar 02 12:12:02 computer kernel: [drm] UVD initialized successfully.
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 0 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 1 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 2 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 3 succeeded in 0 usecs
Mar 02 12:12:02 computer kernel: [drm] ib test on ring 4 succeeded in 0 usecs
Mar 02 12:12:03 computer kernel: [drm] ib test on ring 5 succeeded
Mar 02 12:12:03 computer systemd[1]: Started Getty on tty2.
Mar 02 12:12:03 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:03 computer kernel: audit: type=1130 audit(1677755523.442:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:08 computer nmbd[449]: [2023/03/02 12:12:08.121356,  0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mar 02 12:12:08 computer nmbd[449]:   reload_interfaces: No subnets to listen to. Waiting..
Mar 02 12:12:09 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.21' (uid=0 pid=511 comm="/bin/login -p --      ")
Mar 02 12:12:09 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:12:09 computer login[511]: pam_systemd_home(login:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 12:12:12 computer audit[511]: USER_AUTH pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer audit[511]: USER_ACCT pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1100 audit(1677755532.335:74): pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1101 audit(1677755532.335:75): pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1103 audit(1677755532.338:76): pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1006 audit(1677755532.338:77): pid=511 uid=0 old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=3 res=1
Mar 02 12:12:12 computer kernel: audit: type=1300 audit(1677755532.338:77): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7fff5e913d70 a2=4 a3=0 items=0 ppid=1 pid=511 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=3 comm="login" exe="/usr/bin/login" key=(null)
Mar 02 12:12:12 computer kernel: audit: type=1327 audit(1677755532.338:77): proctitle=2F62696E2F6C6F67696E002D70002D2D
Mar 02 12:12:12 computer audit[511]: CRED_ACQ pid=511 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer audit[511]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7fff5e913d70 a2=4 a3=0 items=0 ppid=1 pid=511 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=3 comm="login" exe="/usr/bin/login" key=(null)
Mar 02 12:12:12 computer audit: PROCTITLE proctitle=2F62696E2F6C6F67696E002D70002D2D
Mar 02 12:12:12 computer login[511]: pam_unix(login:session): session opened for user tomas(uid=1000) by LOGIN(uid=0)
Mar 02 12:12:12 computer systemd-logind[382]: New session 3 of user tomas.
Mar 02 12:12:12 computer systemd[1]: Started Session 3 of User tomas.
Mar 02 12:12:12 computer audit[511]: USER_START pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer audit[511]: CRED_REFR pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1105 audit(1677755532.362:78): pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer kernel: audit: type=1110 audit(1677755532.362:79): pid=511 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/login" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 12:12:12 computer login[511]: LOGIN ON tty2 BY tomas
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4328] policy: auto-activating connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4335] device (wlp3s0): Activation: starting connection 'UPC8127731' (212d40f5-cda3-47b9-b8fd-a3cb83fbdcdd)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4337] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4342] manager: NetworkManager state is now CONNECTING
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4358] device (wlp3s0): set-hw-addr: reset MAC address to A0:A8:CD:EB:A4:E2 (preserve)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4374] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4378] device (wlp3s0): Activation: (wifi) access point 'UPC8127731' has security, but secrets are required.
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4378] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4381] sup-iface[98297733aecb18f1,0,wlp3s0]: wps: type pbc start...
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4390] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4393] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4397] device (wlp3s0): Activation: (wifi) connection 'UPC8127731' has security, and secrets exist.  No new secrets needed.
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4397] Config: added 'ssid' value 'UPC8127731'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'scan_ssid' value '1'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'auth_alg' value 'OPEN'
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4398] Config: added 'psk' value '<hidden>'
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: WPS-CANCEL
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: SME: Trying to authenticate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:12:14 computer kernel: wlp3s0: authenticate with 38:43:7d:62:ff:bb
Mar 02 12:12:14 computer kernel: wlp3s0: send auth to 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4832] device (wlp3s0): supplicant interface state: disconnected -> authenticating
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.4833] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> authenticating
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: Trying to associate with 38:43:7d:62:ff:bb (SSID='UPC8127731' freq=5220 MHz)
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5038] device (wlp3s0): supplicant interface state: authenticating -> associating
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5039] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Mar 02 12:12:14 computer kernel: wlp3s0: authenticated
Mar 02 12:12:14 computer kernel: wlp3s0: associate with 38:43:7d:62:ff:bb (try 1/3)
Mar 02 12:12:14 computer kernel: wlp3s0: RX AssocResp from 38:43:7d:62:ff:bb (capab=0x511 status=0 aid=1)
Mar 02 12:12:14 computer kernel: wlp3s0: associated
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: Associated with 38:43:7d:62:ff:bb
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5522] device (wlp3s0): supplicant interface state: associating -> associated
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5524] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5742] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.5743] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: WPA: Key negotiation completed with 38:43:7d:62:ff:bb [PTK=CCMP GTK=TKIP]
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to 38:43:7d:62:ff:bb completed [id=0 id_str=]
Mar 02 12:12:14 computer kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6494] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6495] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "UPC8127731"
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6495] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6497] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:14 computer NetworkManager[392]: <info>  [1677755534.6506] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:12:14 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-51 noise=9999 txrate=866700
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9526] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9538] policy: set 'UPC8127731' (wlp3s0) as default for IPv6 routing and DNS
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9867] dhcp6 (wlp3s0): state changed new lease
Mar 02 12:12:16 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=392 comm="/usr/bin/NetworkManager --no-daemon")
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9880] dhcp4 (wlp3s0): state changed new lease, address=192.168.0.164
Mar 02 12:12:16 computer NetworkManager[392]: <info>  [1677755536.9899] policy: set 'UPC8127731' (wlp3s0) as default for IPv4 routing and DNS
Mar 02 12:12:16 computer systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 02 12:12:16 computer audit: BPF prog-id=35 op=LOAD
Mar 02 12:12:16 computer audit[392]: SYSCALL arch=c000003e syscall=321 success=yes exit=29 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:12:16 computer audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mar 02 12:12:17 computer dbus-daemon[380]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mar 02 12:12:17 computer systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 02 12:12:16 computer audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:17 computer kernel: audit: type=1334 audit(1677755536.995:80): prog-id=35 op=LOAD
Mar 02 12:12:17 computer kernel: audit: type=1300 audit(1677755536.995:80): arch=c000003e syscall=321 success=yes exit=29 a0=5 a1=7ffcbdb85600 a2=90 a3=cd items=0 ppid=1 pid=392 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" key=(null)
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0108] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0127] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0130] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0134] manager: NetworkManager state is now CONNECTED_SITE
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0141] device (wlp3s0): Activation: successful, device activated.
Mar 02 12:12:17 computer NetworkManager[392]: <info>  [1677755537.0861] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 02 12:12:27 computer systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 02 12:12:27 computer kernel: kauditd_printk_skb: 2 callbacks suppressed
Mar 02 12:12:27 computer kernel: audit: type=1131 audit(1677755547.008:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 12:12:27 computer audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 02 11:12:38 computer systemd-timesyncd[374]: Contacted time server 81.25.28.124:123 (0.manjaro.pool.ntp.org).
Mar 02 11:12:38 computer systemd-journald[254]: Time jumped backwards, rotating.
Mar 02 11:12:38 computer systemd-timesyncd[374]: Initial clock synchronization to Thu 2023-03-02 11:12:38.251878 CET.
Mar 02 11:12:39 computer wpa_supplicant[434]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=866700
Mar 02 11:17:02 computer dbus-daemon[380]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.23' (uid=0 pid=537 comm="sudo journalctl --boot 0 --no-pager")
Mar 02 11:17:02 computer dbus-daemon[380]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mar 02 11:17:02 computer sudo[537]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mar 02 11:17:04 computer audit[537]: USER_AUTH pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer audit[537]: USER_ACCT pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1100 audit(1677752224.582:83): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1101 audit(1677752224.582:84): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="tomas" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer audit[537]: CRED_REFR pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer sudo[537]:    tomas : TTY=tty2 ; PWD=/home/tomas ; USER=root ; COMMAND=/usr/bin/journalctl --boot 0 --no-pager
Mar 02 11:17:04 computer audit[537]: USER_START pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer sudo[537]: pam_unix(sudo:session): session opened for user root(uid=0) by tomas(uid=1000)
Mar 02 11:17:04 computer kernel: audit: type=1110 audit(1677752224.586:85): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
Mar 02 11:17:04 computer kernel: audit: type=1105 audit(1677752224.586:86): pid=537 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=computer addr=? terminal=/dev/tty2 res=success'
I pasted it in two recent replies. It was too big to be attached at once.
How did you recognize graphic card driver issue ? What are the indicators please ?
Lines like these (for example) make it clear don’t they?
I doubt it is Radeon graphic drivers issue.
First at all, I dont remember, I installed them. What I know, linux by default uses integrated graphic card for GUI.
Furthermore, as root, I can start Xserver/GUI by issuing sudo startx, whilst if I execute startx as an user, it fails with following error:
xauth:  unable to write authority file /home/tomas/.Xauthority-n
(EE)
Fatal server error:
(EE) Cannot open log file "/home/tomas/.local/share/xorg/Xorg.1.log"
(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE)
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
There is a file /home/tomas/.Xauthority-n however it shows 0b and timestamp from today
-rw-------   1 tomas tomas   53 Feb 17 10:19 .Xauthority
-rw-------   1 tomas tomas    0 Mar  2 16:40 .Xauthority-n
-rwxr-xr-x   1 tomas tomas  100 Oct 30  2017 .Xclients
-rwxr-xr-x   1 tomas tomas 1.6K Jan 30  2022 .xinitrc
If I rename .Xauthority-n and execute startx, new file is generated, again shows 0b and again Xserver fails to start.
As the sudo startx works well, I assume, there is no issue with integrated graphic card drivers.
Btw, there are also no logfiles :
ls: cannot access '.local/share/xorg/Xorg.1.log': No such file or directory
ls: cannot access '/home/root/.local/share/xorg/Xorg.1.log': No such file or directory
Could you advise please ?
Well you seem to know better as me, so you advise :wink:
I am just thinking loudly. Brainstorming :slight_smile:
Xserver works for root, but does not work for regular user. I guess, both are using the same graphic drivers, arent they ?
Summary
I could not fully boot. The boot process stopped at point: /dev/sdb2: clean. It was actually my / partition.
At that point, a cursor appeared, however black screen. Obviously X server did not start correctly.
What helped me
As it may look like stuck at boot, in fact, the linux booted, only the GUI was not loaded.
  1. At this point I opened and logged in to terminal by pressing following keys: ctrl + alt + F2
  2. From the console I tried to start X sever manually by issuing command: startx. It failed because of error:
(EE)
Fatal server error:
(EE)
(EE)
 for help.
(EE)
xinit: giving up
xinit: server error
  1. It was pointing to my home directory. Next time I tried to start X server as root, command: sudo startx. This attempt was successful and proved, there was no driver issue.
  2. Analyzing the errors from step 3) I found following: xauth: unable to write authority file /home/tomas/.Xauthority-n
    I checked that file - it was showing 0b.
I renamed that file, rebooted the computer, however it failed to boot again, with the same error. New file .Xauthority-n was created, again 0b size.
  1. Executing the df on /home partition revealed that my /home was full (out of disk space).
    Yes, it was full because of photorec recoved folders and files.
    Weird, I deleted a lot of manually, but df was still showing full fisk, lsof +L1 was not showing anything and fsck executed on /home partition showed clean, no errors.
    Finally, I was able to free up some disk space by deleting cache: rm -rf ~/.cache/*
    I confirmed, there was about 2% of free disk space (/home).
After reboot, I booted Manjaro successfully. Hip hip hurray :partying_face:
Conclusion
/home must not be full ! There must by always a free space, otherwise X server does not start. The xserver error is a valuable hint.
How does it work actually ?
When xauth is updating the .Xauthority file, it will initially write a new version of it as .Xauthority-n. Once the file is completely written, it will move/rename it to .Xauthority, causing the old version of the file to be deleted at the same time. More.
Because my /home was full (according to df), writting .Xauthority-n and updating .Xauthority was failing every boot attempt.
Do not let your /home to be full/out of disk space!
Summary:
Always provide inxi!
Your problem would have been obvious with inxi
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading :wink: )
with ext(2/3/4) filesystems, 5% of the space is only available for the root user when the file system is created with default options (as it usually is)
… for situations like this - root can still act and work, it is a safeguard
but normal users can’t create/write any more data
Depending on how large your disk is, this can be a huge amount of space that is not usable by you
(on todays large drives, 5% is always way too much)
It can be adapted:
man tune2fs
tune2fs -m 1 /dev/sdxX
for example
