Steam: Some game dont work
Hello,
Several Steam games do not work. Under Ubuntu I used to play Counter-Strike: GO from time to time, but since I am on Manjaro, the game does not work. I did a brief passage through Garuda (3-4 days but too buggy for me), it didn’t work on Garuda either.
Some games/software work with Manjaro:
  • Blender
  • Hacknet
  • Ryzom
  • Godot Engine
  • RimWorld
  • Middle-earth: Shadow of Mordor
Tested games that don’t work:
  • Counter-Strike: GO
  • The Witcher: Enhanced Edition
  • Elite Dangerous
  • Fallout 1
  • Rogue System
When I was on Ubuntu, CSGO, The Witcher and Elite Dangerous worked without problems.
This is the result of launching 3 games in terminal (Steam runtime).
CS:GO
steam.sh[12482]: Running Steam on manjarolinux 21.2.6 64-bit
steam.sh[12482]: STEAM_RUNTIME is enabled automatically
setup.sh[12556]: Steam runtime environment up-to-date!
steam.sh[12482]: Steam client's requirements are satisfied
[2022-06-01 15:22:23] Startup - updater built May 28 2022 01:45:31
Installing breakpad exception handler for appid(steam)/version(1653947812)
[2022-06-01 15:22:23] Loading cached metrics from disk (/home/daxime/.local/share/Steam/package/steam_client_metrics.bin)
[2022-06-01 15:22:23] Using the following download hosts for Public, Realm steamglobal
[2022-06-01 15:22:23] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-06-01 15:22:23] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-06-01 15:22:23] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-06-01 15:22:23] Vérification de l'installation...
[2022-06-01 15:22:23] Verification complete
Loaded SDL version 2.0.22-7215337
ComputeStartupMode: found registry default startup mode: 0Installing breakpad exception handler for appid(steam)/version(1653947812)
steamwebhelper.sh[12690]: Runtime for steamwebhelper: defaulting to /home/daxime/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[12690]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 202 milliseconds to initialize
(steam:12648): Gtk-WARNING **: 15:22:28.163: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 244 bytes.
roaming config store loaded successfully - 244 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 69ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/daxime/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 8.83 seconds
BuildCompleteAppOverviewChange: 468
RegisterForAppOverview 1: 84ms
RegisterForAppOverview 2: 86ms
ExecuteSteamURL: "steam://rungameid/730"
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to UpdatingAppInfo with ""
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 730, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 730, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam\0
Game process added : AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 13069, IP 0.0.0.0:0
chdir /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive
ERROR: ld.so: object '/home/daxime/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/daxime/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 730, ActionID 1] : LaunchApp changed task to Completed with ""
pid 13072 != 13070, skipping destruction (fork without exec?)
SDL video target is 'x11'
This system supports the OpenGL extension GL_EXT_framebuffer_object.
This system supports the OpenGL extension GL_EXT_framebuffer_blit.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample.
This system DOES NOT support the OpenGL extension GL_APPLE_fence.
This system DOES NOT support the OpenGL extension GL_NV_fence.
This system supports the OpenGL extension GL_ARB_sync.
This system supports the OpenGL extension GL_EXT_draw_buffers2.
This system DOES NOT support the OpenGL extension GL_EXT_bindable_uniform.
This system DOES NOT support the OpenGL extension GL_APPLE_flush_buffer_range.
This system supports the OpenGL extension GL_ARB_map_buffer_range.
This system supports the OpenGL extension GL_ARB_vertex_buffer_object.
This system supports the OpenGL extension GL_ARB_occlusion_query.
This system DOES NOT support the OpenGL extension GL_APPLE_texture_range.
This system DOES NOT support the OpenGL extension GL_APPLE_client_storage.
This system DOES NOT support the OpenGL extension GL_ARB_uniform_buffer.
This system supports the OpenGL extension GL_ARB_vertex_array_bgra.
This system supports the OpenGL extension GL_EXT_vertex_array_bgra.
This system supports the OpenGL extension GL_ARB_framebuffer_object.
This system DOES NOT support the OpenGL extension GL_GREMEDY_string_marker.
This system supports the OpenGL extension GL_ARB_debug_output.
This system supports the OpenGL extension GL_EXT_direct_state_access.
This system DOES NOT support the OpenGL extension GL_NV_bindless_texture.
This system supports the OpenGL extension GL_AMD_pinned_memory.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample_blit_scaled.
This system supports the OpenGL extension GL_EXT_texture_sRGB_decode.
This system supports the OpenGL extension GL_NVX_gpu_memory_info.
This system supports the OpenGL extension GL_ATI_meminfo.
This system supports the OpenGL extension GL_EXT_texture_compression_s3tc.
This system supports the OpenGL extension GL_EXT_texture_compression_dxt1.
This system supports the OpenGL extension GL_ANGLE_texture_compression_dxt3.
This system supports the OpenGL extension GL_ANGLE_texture_compression_dxt5.
This system supports the OpenGL extension GL_ARB_buffer_storage.
This system supports the OpenGL extension GLX_EXT_swap_control_tear.
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/engine_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/engine_client.so: wrong ELF class: ELFCLASS32
Installing breakpad exception handler for appid(gameoverlayui)/version(20220528014544)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/filesystem_stdio_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/filesystem_stdio_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/inputsystem_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/inputsystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vphysics_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vphysics_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/materialsystem_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/materialsystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/datacache_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/datacache_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/studiorender_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/studiorender_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/soundemittersystem_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/soundemittersystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vscript_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vscript_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vguimatsurface_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vguimatsurface_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vgui2_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vgui2_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/shaderapidx9_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/shaderapidx9_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/localize_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/localize_client.so: wrong ELF class: ELFCLASS32
Created D3D9 device successfully
WARNING: unable to link grab_window and grab_window because one or more is a ConCommand.
Using breakpad minidump system 730/13832.1463.JC
Using breakpad crash handler
[S_API] SteamAPI_Init(): Loaded '/home/daxime/.local/share/Steam/linux64/steamclient.so' OK.
Game process updated : AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 13074, IP 0.0.0.0:0
Setting breakpad minidump AppID = 730
Forcing breakpad minidump interfaces to load
Looking up breakpad interfaces from steamclient
Calling BreakpadMiniDumpSystemInit
SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561197979665026 [API loaded yes]
SteamInternal_SetMinidumpSteamID:  Setting Steam ID:  76561197979665026
Initialized low level socket/threading support.
Set SteamNetworkingSockets P2P_STUN_ServerList to '162.254.196.84:3478' as per SteamNetworkingSocketsSerialized
Got ISteamNetworkingSockets user interfaces from standalone lib
Pending ping measurement until network config is obtained.
SDR RelayNetworkStatus:  avail=Attempting  config=Attempting  anyrelay=Waiting   (Attempt #1 to fetch config from https://api.steampowered.com/ISteamApps/GetSDRConfig/v1?appid=730)
AuthStatus (steamid:76561197979665026):  Attempting  (Requesting cert)
USRLOCAL path using Steam profile data folder:
/home/daxime/.local/share/Steam/userdata/19399298/730/local
Did not detect any valid joysticks.
Timed out waiting for game mapping!
RESZ NOT SUPPORTED!
INTZ NOT SUPPORTED!
RESZ NOT SUPPORTED!
INTZ NOT SUPPORTED!
 ##### swap interval = 0     swap limit = 1 #####
CGLMShaderPair::SetProgramPair: Centroid masks differ at link time of vertex shader screenspaceeffect_vs30 and pixel shader underwater_ps30!
Filesystem successfully switched to safe whitelist mode
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/matchmaking_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/matchmaking_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/client_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/client_client.so: wrong ELF class: ELFCLASS32
CClientSteamContext logged on = 1
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/server_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/server_client.so: wrong ELF class: ELFCLASS32
Game.dll loaded for "Counter-Strike: Global Offensive"
 failed to dlopen /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/scenefilecache_client.so error=/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/scenefilecache_client.so: wrong ELF class: ELFCLASS32
CGameEventManager::AddListener: event 'server_pre_shutdown' unknown.
CGameEventManager::AddListener: event 'game_newmap' unknown.
CGameEventManager::AddListener: event 'finale_start' unknown.
CGameEventManager::AddListener: event 'round_start' unknown.
CGameEventManager::AddListener: event 'round_end' unknown.
CGameEventManager::AddListener: event 'difficulty_changed' unknown.
CGameEventManager::AddListener: event 'player_death' unknown.
CGameEventManager::AddListener: event 'hltv_replay' unknown.
CGameEventManager::AddListener: event 'player_connect' unknown.
CGameEventManager::AddListener: event 'player_disconnect' unknown.
GameTypes: missing mapgroupsSP entry for game type/mode (custom/custom).
GameTypes: missing mapgroupsSP entry for game type/mode (cooperative/cooperative).
GameTypes: missing mapgroupsSP entry for game type/mode (cooperative/coopmission).
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/conf.d/41-repl-os-win.conf", line 148: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/conf.d/41-repl-os-win.conf", line 160: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 31: Use of ambiguous path in <dir> element. please add prefix="cwd" if current behavior is desired.
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 38: unknown element "fontpattern"
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 39: unknown element "fontpattern"
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 40: unknown element "fontpattern"
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 41: unknown element "fontpattern"
Fontconfig warning: "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 42: unknown element "fontpattern"
crash_20220601152342_2.dmp[13240]: Uploading dump (out-of-process)
/tmp/dumps/crash_20220601152342_2.dmp
crash_20220601152342_2.dmp[13240]: Finished uploading minidump (out-of-process): success = yes
crash_20220601152342_2.dmp[13240]: response: CrashID=bp-da9aaa0a-fad2-4462-b472-97ec92220601
crash_20220601152342_2.dmp[13240]: file ''/tmp/dumps/crash_20220601152342_2.dmp'', upload yes: ''CrashID=bp-da9aaa0a-fad2-4462-b472-97ec92220601''
pid 13240 != 13239, skipping destruction (fork without exec?)
/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh: line 88: 13074 Bus error               (core dumped) ${DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Game process removed: AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 13074
ThreadGetProcessExitCode: no such process 13239
ThreadGetProcessExitCode: no such process 13074
ThreadGetProcessExitCode: no such process 13073
ThreadGetProcessExitCode: no such process 13070
Game 730 created interface STEAMAPPLIST_INTERFACE_VERSION001 /
Game 730 created interface STEAMAPPS_INTERFACE_VERSION008 /
Game 730 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_005 /
Game 730 created interface STEAMHTTP_INTERFACE_VERSION003 /
Game 730 created interface STEAMHTTP_INTERFACE_VERSION003 / HTTP
Game 730 created interface STEAMINVENTORY_INTERFACE_V003 /
Game 730 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 /
Game 730 created interface STEAMMUSIC_INTERFACE_VERSION001 /
Game 730 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 /
Game 730 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION016 /
Game 730 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 /
Game 730 created interface STEAMUGC_INTERFACE_VERSION016 /
Game 730 created interface STEAMUSERSTATS_INTERFACE_VERSION012 /
Game 730 created interface STEAMVIDEO_INTERFACE_V002 /
Game 730 created interface SteamAppDisableUpdate001 /
Game 730 created interface SteamController008 /
Game 730 created interface SteamFriends017 /
Game 730 created interface SteamGameCoordinator001 /
Game 730 created interface SteamGameStats001 /
Game 730 created interface SteamInput006 /
Game 730 created interface SteamMatchGameSearch001 /
Game 730 created interface SteamMatchMaking009 /
Game 730 created interface SteamMatchMakingServers002 /
Game 730 created interface SteamNetworking006 /
Game 730 created interface SteamNetworkingSocketsSerialized005 /
Game 730 created interface SteamUser021 /
Game 730 created interface SteamUser021 / User
Game 730 created interface SteamUtils010 /
Game 730 created interface SteamUtils010 / Utils
Game 730 method call count for IClientNetworkingSocketsSerialized::GetSTUNServer : 2
Game 730 method call count for IClientNetworkingSocketsSerialized::GetCachedRelayTicketCount : 1
Game 730 method call count for IClientNetworkingSocketsSerialized::GetCertAsync : 1
Game 730 method call count for IClientControllerSerialized::BCheckGameDirectoryAndReloadConfigIfNecessary : 1
Game 730 method call count for IClientControllerSerialized::EnableDeviceCallbacks : 1
Game 730 method call count for IClientControllerSerialized::HasGameMapping : 11
Game 730 method call count for IClientControllerSerialized::GetAnalogActionHandle : 94
Game 730 method call count for IClientControllerSerialized::GetDigitalActionHandle : 94
Game 730 method call count for IClientControllerSerialized::GetActionSetHandle : 20
Game 730 method call count for IClientHTTP::SendHTTPRequest : 1
Game 730 method call count for IClientHTTP::SetHTTPRequestHeaderValue : 1
Game 730 method call count for IClientHTTP::CreateHTTPRequest : 1
Game 730 method call count for IClientGameStats::GetNewSession : 1
Game 730 method call count for IClientGameCoordinator::SendMessage : 1
Game 730 method call count for IClientRemoteStorage::EnumerateUserSubscribedFiles : 1
Game 730 method call count for IClientRemoteStorage::FileExists : 1
Game 730 method call count for IClientRemoteStorage::GetFileSize : 2
Game 730 method call count for IClientRemoteStorage::FileRead : 2
Game 730 method call count for IClientNetworking::AllowP2PPacketRelay : 1
Game 730 method call count for IClientUserStats::RequestCurrentStats : 1
Game 730 method call count for IClientAppManager::GetCurrentLanguage : 2
Game 730 method call count for IClientAppManager::GetAppStateInfo : 1
Game 730 method call count for IClientAppManager::GetActiveBeta : 1
Game 730 method call count for IClientUtils::RecordSteamInterfaceCreation : 118
Game 730 method call count for IClientUtils::InitFilterText : 1
Game 730 method call count for IClientUtils::IsSteamChina : 5
Game 730 method call count for IClientUtils::GetLauncherType : 1
Game 730 method call count for IClientUtils::GetAppID : 125
Game 730 method call count for IClientUtils::GetIPCountry : 1
Game 730 method call count for IClientUtils::GetServerRealTime : 2
Game 730 method call count for IClientUtils::GetConnectedUniverse : 4
Game 730 method call count for IClientFriends::GetFriendPersonaName_Public : 5
Game 730 method call count for IClientFriends::GetFriendGamePlayed : 16
Game 730 method call count for IClientFriends::GetFriendByIndex : 16
Game 730 method call count for IClientFriends::GetFriendCount : 1
Game 730 method call count for IClientFriends::GetFriendPersonaState : 16
Game 730 method call count for IClientFriends::GetFriendRelationship : 16
Game 730 method call count for IClientFriends::GetPersonaName : 1
Game 730 method call count for IClientUser::BSetDurationControlOnlineState : 1
Game 730 method call count for IClientUser::BIsSubscribedApp : 1
Game 730 method call count for IClientUser::GetUserDataFolder : 1
Game 730 method call count for IClientUser::GetSteamID : 22
Game 730 method call count for IClientUser::BLoggedOn : 8
Uploaded AppInterfaceStats to Steam
(process:13102): GLib-GObject-CRITICAL **: 15:24:09.019: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
src/steamexe/main.cpp (253) : Assertion Failed: reaping pid: 13102 -- gameoverlayui
assert_20220601152419_31.dmp[13324]: Uploading dump (out-of-process)
/tmp/dumps/assert_20220601152419_31.dmp
The Witcher:
steam.sh[20200]: Running Steam on manjarolinux 21.2.6 64-bit
steam.sh[20200]: STEAM_RUNTIME is enabled automatically
setup.sh[20274]: Steam runtime environment up-to-date!
steam.sh[20200]: Steam client's requirements are satisfied
[2022-06-01 15:48:46] Startup - updater built May 28 2022 01:45:31
[2022-06-01 15:48:46] Loading cached metrics from disk (/home/daxime/.local/share/Steam/package/steam_client_metrics.bin)
[2022-06-01 15:48:46] Using the following download hosts for Public, Realm steamglobal
[2022-06-01 15:48:46] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-06-01 15:48:46] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-06-01 15:48:46] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-06-01 15:48:46] Vérification de l'installation...
[2022-06-01 15:48:46] Verification complete
steamwebhelper.sh[20407]: Runtime for steamwebhelper: defaulting to /home/daxime/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[20407]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 213 milliseconds to initialize
(steam:20364): Gtk-WARNING **: 15:48:51.296: gtk_disable_setlocale() must be called before gtk_init()
BRefreshApplicationsInLibrary 1: 46ms
System startup time: 9.87 seconds
(steam:20364): LIBDBUSMENU-GLIB-WARNING **: 15:48:56.539: Trying to remove a child that doesn't believe we're it's parent.
(steam:20364): LIBDBUSMENU-GLIB-WARNING **: 15:48:56.540: Trying to remove a child that doesn't believe we're it's parent.
RegisterForAppOverview 1: 68ms
RegisterForAppOverview 2: 69ms
CAPIJobRequestUserStats - Server response failed 2
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 20900, ActionID 1] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 20900, ActionID 1] : LaunchApp continues with user response "0"
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
wine: '/mnt/SSD_Partagé/SteamLibrary/steamapps/compatdata/20900/pfx' is not owned by you
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 20900, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 20900, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=20900 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/The Witcher Enhanced Edition/System/witcher.exe'\0
Game process added : AppID 20900 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=20900 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/The Witcher Enhanced Edition/System/witcher.exe'", ProcID 20982, IP 0.0.0.0:0
chdir /mnt/SSD_Partagé/SteamLibrary/steamapps/common/The Witcher Enhanced Edition
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 20900, ActionID 1] : LaunchApp changed task to Completed with ""
pid 20986 != 20983, skipping destruction (fork without exec?)
wineserver: /mnt/SSD_Partagé/SteamLibrary/steamapps/compatdata/20900/pfx is not owned by you
Game process removed: AppID 20900 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=20900 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/The Witcher Enhanced Edition/System/witcher.exe'", ProcID 20982
ThreadGetProcessExitCode: no such process 21166
ThreadGetProcessExitCode: no such process 21165
ThreadGetProcessExitCode: no such process 21164
ThreadGetProcessExitCode: no such process 20984
ThreadGetProcessExitCode: no such process 20983
Rogue System
steam.sh[21520]: Running Steam on manjarolinux 21.2.6 64-bit
steam.sh[21520]: STEAM_RUNTIME is enabled automatically
setup.sh[21597]: Steam runtime environment up-to-date!
steam.sh[21520]: Steam client's requirements are satisfied
[2022-06-01 15:51:26] Startup - updater built May 28 2022 01:45:31
[2022-06-01 15:51:26] Loading cached metrics from disk (/home/daxime/.local/share/Steam/package/steam_client_metrics.bin)
[2022-06-01 15:51:26] Using the following download hosts for Public, Realm steamglobal
[2022-06-01 15:51:26] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-06-01 15:51:26] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-06-01 15:51:26] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-06-01 15:51:26] Vérification de l'installation...
[2022-06-01 15:51:26] Verification complete
steamwebhelper.sh[21726]: Runtime for steamwebhelper: defaulting to /home/daxime/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[21726]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 215 milliseconds to initialize
(steam:21687): Gtk-WARNING **: 15:51:31.566: gtk_disable_setlocale() must be called before gtk_init()
BRefreshApplicationsInLibrary 1: 19ms
System startup time: 8.64 seconds
RegisterForAppOverview 1: 66ms
RegisterForAppOverview 2: 68ms
ExecuteSteamURL: "steam://rungameid/366000"
GameAction [AppID 366000, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
wine: '/mnt/SSD_Partagé/SteamLibrary/steamapps/compatdata/366000/pfx' is not owned by you
GameAction [AppID 366000, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 366000, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 366000, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 366000, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=366000 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Rogue System/RogueSystemSim.exe'\0
Game process added : AppID 366000 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=366000 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Rogue System/RogueSystemSim.exe'", ProcID 22239, IP 0.0.0.0:0
chdir /mnt/SSD_Partagé/SteamLibrary/steamapps/common/Rogue System
GameAction [AppID 366000, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 366000, ActionID 1] : LaunchApp changed task to Completed with ""
pid 22243 != 22240, skipping destruction (fork without exec?)
wineserver: /mnt/SSD_Partagé/SteamLibrary/steamapps/compatdata/366000/pfx is not owned by you
Game process removed: AppID 366000 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=366000 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Rogue System/RogueSystemSim.exe'", ProcID 22239
ThreadGetProcessExitCode: no such process 22417
ThreadGetProcessExitCode: no such process 22416
ThreadGetProcessExitCode: no such process 22411
ThreadGetProcessExitCode: no such process 22241
ThreadGetProcessExitCode: no such process 22240
Nobody can help me ? :pensive:
First things first:
These games work so you’ll need to dig more to find what’s wrong on your side.
Witcher
Rogue System
Looks like a permission problem here for the proton prefixes for the windows games. You need to correct that.
About CS:GO, since STEAM_RUNTIME is enabled it uses the runtime libs and then system libs. Try without steamruntime:
STEAM_RUNTIME=0 steam
# or
steam-native
Hope that helps :wink:
For context, there is not much to say. This was a fresh installation of Manjaro. I did the updates and then installed Steam-runtime and Steam-native.
Then I tried to play CS:GO but it didn’t work. I tried some games, some worked, some didn’t.
I tried with Steam-native and Steam-runtime. No change.
inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=88061728-d243-4162-85f1-4aa235202d1a rw quiet splash apparmor=1
    security=apparmor resume=UUID=457dba17-bb75-4c30-8acc-5324a11181ef
    udev.log_priority=3
  Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3211
    date: 08/10/2021
  RAM: total: 47.01 GiB used: 9.29 GiB (19.8%)
  RAM Report:
  Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
    built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
    microcode: 0x800820D
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3785 high: 3848 min/max: 1550/3850 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3761 2: 3848
    3: 3814 4: 3784 5: 3841 6: 3812 7: 3612 8: 3833 9: 3823 10: 3702 11: 3795
    12: 3798 bogomips: 92428
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
    smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
  Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: ASRock
    driver: amdgpu v: kernel arch: RDNA 1 process: TSMC n7 (7nm) built: 2019-20
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
    empty: DP-2,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 1002:7340 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: MSI G271 serial: <filter> built: 2021
    res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: DP-3 model: Samsung SyncMaster serial: <filter> built: 2008
    res: 1440x900 dpi: 89 gamma: 1.35 size: 410x257mm (16.14x10.12")
    diag: 484mm (19.1") ratio: 16:10 modes: max: 1440x900 min: 720x400
  OpenGL: renderer: AMD Radeon RX 5500 XT (navi14 LLVM 13.0.1 DRM 3.42
  5.15.49-1-MANJARO)
    v: 4.6 Mesa 22.1.2 direct render: Yes
  Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab38
    class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
    vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: anbox0 state: down mac: <filter>
  IP v4: <filter> scope: global
  Local Storage: total: 10.68 TiB used: 6.97 TiB (65.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: LDLC model: N/A size: 223.57 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
    serial: <filter> rev: 2A0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD40PURZ-85AKKY0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0B80 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM005-2DP166
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 5980 serial: <filter> rev: 0001 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST500DM002-1ER14C
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
    model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
    scheme: MBR
  ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate model: Expansion
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 0710 scheme: MBR
  ID-1: / raw-size: 214.47 GiB size: 210.05 GiB (97.94%)
    used: 137.62 GiB (65.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 88061728-d243-4162-85f1-4aa235202d1a
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 9E6A-A704
  ID-3: /mnt/Multimedia raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 3.38 TiB (94.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
    label: Multimedia uuid: 3d5840af-dee3-4a13-bd71-738584d61e85
  ID-4: /mnt/SSD_Partagé raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 781.85 GiB (83.9%) fs: ntfs dev: /dev/sde1 maj-min: 8:65
    label: SSD_Partag\xc3\xa9 uuid: 1C919CB27C4F8552
  ID-5: /mnt/Sauvegardes raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 1.68 TiB (46.9%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: Sauvegardes uuid: d8a5e342-d134-4f2d-92a1-a010222b8469
  ID-6: /run/media/daxime/Seagate Expansion Drive raw-size: 1.82 TiB
    size: 1.82 TiB (100.00%) used: 1.02 TiB (55.9%) fs: ntfs dev: /dev/sdf1
    maj-min: 8:81 label: Seagate Expansion Drive uuid: 30BEA7D1BEA78E42
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 457dba17-bb75-4c30-8acc-5324a11181ef
  ID-1: /dev/sdd1 maj-min: 8:49 size: 100 MiB fs: vfat label: N/A
    uuid: C4A3-62B4
  ID-2: /dev/sdd2 maj-min: 8:50 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sdd3 maj-min: 8:51 size: 465.05 GiB fs: ntfs label: N/A
    uuid: AE2AA6FA2AA6BF29
  ID-4: /dev/sdd4 maj-min: 8:52 size: 606 MiB fs: ntfs label: N/A
    uuid: CEBE2DB8BE2D99CB
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-2:2 info: Seagate RSS LLC Expansion Portable
    type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 0bc2:231a class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: Winbond Gaming Keyboard type: Keyboard,Mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
    power: 400mA chip-ID: 0416:a0f8 class-ID: 0301 serial: <filter>
  Device-2: 3-4:3 info: Logitech M-R0017 [G700s Rechargeable Gaming Mouse]
    type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 498mA chip-ID: 046d:c07c class-ID: 0300
    serial: <filter>
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 86.0 C mem: 0.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 2053
  Processes: 373 Uptime: 32m wakeups: 0 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
  Packages: 1506 pacman: 1503 lib: 475 flatpak: 0 snap: 3 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.19
I changed the ownership of files and folders, but it still doesn’t work. I tested with The Witcher:
ExecuteSteamURL: "steam://rungameid/20900"
pressure-vessel-LOG-0x100: Unable to set mode of "./bin/[" in "/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier/var/tmp-IVNZO1/usr": fchmod: Opération non permise
Game process added : AppID 20900 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=20900 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/The Witcher Enhanced Edition/System/witcher.exe'", ProcID 14599, IP 0.0.0.0:0
pid 14603 != 14600, skipping destruction (fork without exec?)
pressure-vessel-LOG-0x100: Unable to set mode of "./bin/[" in "/mnt/SSD_Partag?/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier/var/tmp-NZT8O1/usr": fchmod: Operation not permitted
Game process removed: AppID 20900 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=20900 -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/Proton 7.0'/proton waitforexitandrun  '/mnt/SSD_Partagé/SteamLibrary/steamapps/common/The Witcher Enhanced Edition/System/witcher.exe'", ProcID 14599
ThreadGetProcessExitCode: no such process 14601
ThreadGetProcessExitCode: no such process 14600
Do not use a NTFS drive as a steam library, you will run into issues, there is a fix but test it with a 2nd library first?
https://wiki.archlinux.org/title/Steam/Troubleshooting#Steam_Library_in_NTFS_partition
“Middle-earth: Shadow of Mordor” use Proton, but it work very well. Anyway I’ll try to move the folder and create a symbolic link.
I use this SSD in Windows too, so i need a file sytem that Windows can use. I tried exFat, but Steam dont want it…
Edit: it didn’t work
I suggest reading some forum posts about steam and ntfs drives. You are not the only one with this issue and the solution for most is to not use ntfs.
If you share what didn’t work, the commands used, and the output of said commands & the log of the starting of the game others might be able to help you. Now all we know is that you might have tried the arch workaround but something went wrong. Other forum users can’t read your console history so be more specific.
I have moved the two folder like in your link and created a symbolic link.
Now i have moved all the Steam Library on a ext4 HDD with enought space. All game that was not working now work. But CS:GO still dont work (Steam-native and Steam-runtime) …
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to UpdatingAppInfo with ""
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 730, ActionID 3] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 730, ActionID 3] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam\0
Game process added : AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 58801, IP 0.0.0.0:0
chdir /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive
pid 58803 != 58802, skipping destruction (fork without exec?)
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 730, ActionID 3] : LaunchApp changed task to Completed with ""
*** MESA_GLSL_CACHE_DIR is deprecated; use MESA_SHADER_CACHE_DIR instead ***
*** MESA_GLSL_CACHE_MAX_SIZE is deprecated; use MESA_SHADER_CACHE_MAX_SIZE instead ***
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/engine_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/engine_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/filesystem_stdio_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/filesystem_stdio_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/inputsystem_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/inputsystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vphysics_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vphysics_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/materialsystem_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/materialsystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/datacache_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/datacache_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/studiorender_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/studiorender_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/soundemittersystem_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/soundemittersystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vscript_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vscript_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vguimatsurface_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vguimatsurface_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vgui2_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/vgui2_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/shaderapidx9_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/shaderapidx9_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/localize_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/localize_client.so: wrong ELF class: ELFCLASS32
Using breakpad minidump system 730/13836.1488.JC
Game process updated : AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 58805, IP 0.0.0.0:0
Set SteamNetworkingSockets P2P_STUN_ServerList to '162.254.196.83:3478' as per SteamNetworkingSocketsSerialized
RESZ NOT SUPPORTED!
INTZ NOT SUPPORTED!
RESZ NOT SUPPORTED!
INTZ NOT SUPPORTED!
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/matchmaking_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/matchmaking_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/client_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/client_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/server_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/bin/server_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/scenefilecache_client.so error=/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/bin/scenefilecache_client.so: wrong ELF class: ELFCLASS32
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/conf.d/41-repl-os-win.conf", line 148: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/conf.d/41-repl-os-win.conf", line 160: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 31: Use of ambiguous path in <dir> element. please add prefix="cwd" if current behavior is desired.
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 38: unknown element "fontpattern"
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 39: unknown element "fontpattern"
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 40: unknown element "fontpattern"
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 41: unknown element "fontpattern"
Fontconfig warning: "/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo/panorama/fonts/fonts.conf", line 42: unknown element "fontpattern"
crash_20220712014621_2.dmp[58879]: Uploading dump (out-of-process)
/tmp/dumps/crash_20220712014621_2.dmp
crash_20220712014621_2.dmp[58879]: Finished uploading minidump (out-of-process): success = yes
crash_20220712014621_2.dmp[58879]: response: Discarded=1
crash_20220712014621_2.dmp[58879]: file ''/tmp/dumps/crash_20220712014621_2.dmp'', upload yes: ''Discarded=1''
pid 58879 != 58878, skipping destruction (fork without exec?)
/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh: line 88: 58805 Bus error               (core dumped) ${DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Game process removed: AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 58805
ThreadGetProcessExitCode: no such process 58878
ThreadGetProcessExitCode: no such process 58805
ThreadGetProcessExitCode: no such process 58804
ThreadGetProcessExitCode: no such process 58802
Game 730 method call count for IClientFriends::GetFriendPersonaName_Public : 2
This might be a issue, I’m not sure, but I don’t run wayland and don’t play CS:GO.
When logging in you can choose the session type from the gdm login screen, (cogwheel) choose classic, this will log you into a x11 session and check if that makes a difference.
How to find out what kind of session you are running:
Info from the proton DB, that always helps me get games to run since there are so much tips and examples.
GNOME Classic use Wayland too. GNOME Xorg and GNOME Classic Xorg use X11. In both Xorg, with runtime and native, the game dont launch
steam.sh[109797]: Running Steam on manjarolinux 21.3.1 64-bit
steam.sh[109797]: STEAM_RUNTIME is disabled by the user
steam.sh[109797]: Can't find 'steam-runtime-check-requirements', continuing anyway
[2022-07-12 22:30:21] Startup - updater built Jun  7 2022 03:18:19
Installing breakpad exception handler for appid(steam)/version(1654574690)
[2022-07-12 22:30:21] Loading cached metrics from disk (/home/daxime/.local/share/Steam/package/steam_client_metrics.bin)
[2022-07-12 22:30:21] Using the following download hosts for Public, Realm steamglobal
[2022-07-12 22:30:21] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-07-12 22:30:21] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2022-07-12 22:30:21] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-07-12 22:30:21] Vérification de l'installation...
[2022-07-12 22:30:21] Verification complete
ComputeStartupMode: found registry default startup mode: 0Installing breakpad exception handler for appid(steam)/version(1654574690)
steamwebhelper.sh[109915]: Runtime for steamwebhelper: disabled by environment (this is unsupported)
steamwebhelper.sh[109915]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 122 milliseconds to initialize
(steam:109878): Gtk-WARNING **: 22:30:24.957: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 497 bytes.
roaming config store loaded successfully - 497 bytes.
BRefreshApplicationsInLibrary 1: 21ms
System startup time: 6.94 seconds
BuildCompleteAppOverviewChange: 476
RegisterForAppOverview 1: 48ms
RegisterForAppOverview 2: 48ms
Game process added : AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 110188, IP 0.0.0.0:0
pid 110190 != 110189, skipping destruction (fork without exec?)
Game process updated : AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 110192, IP 0.0.0.0:0
Set SteamNetworkingSockets P2P_STUN_ServerList to '162.254.196.68:3478' as per SteamNetworkingSocketsSerialized
RESZ NOT SUPPORTED!
INTZ NOT SUPPORTED!
RESZ NOT SUPPORTED!
INTZ NOT SUPPORTED!
crash_20220712223056_2.dmp[110261]: Uploading dump (out-of-process)
/tmp/dumps/crash_20220712223056_2.dmp
crash_20220712223056_2.dmp[110261]: Finished uploading minidump (out-of-process): success = yes
crash_20220712223056_2.dmp[110261]: response: CrashID=bp-4bb6a550-5c61-4785-ad2d-d9abe2220712
crash_20220712223056_2.dmp[110261]: file ''/tmp/dumps/crash_20220712223056_2.dmp'', upload yes: ''CrashID=bp-4bb6a550-5c61-4785-ad2d-d9abe2220712''
pid 110261 != 110260, skipping destruction (fork without exec?)
/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh: line 88: 110192 Bus error               (core dumped) ${DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Game process removed: AppID 730 "/home/daxime/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=730 -- '/mnt/Sauvegardes/# SSD Backup/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/csgo.sh' -steam", ProcID 110192
ThreadGetProcessExitCode: no such process 110260
ThreadGetProcessExitCode: no such process 110192
ThreadGetProcessExitCode: no such process 110191
ThreadGetProcessExitCode: no such process 110189
Game 730 method call count for IClientFriends::GetFriendPersonaName_Public : 6
Have you checked the game entry on [https://www.protondb.com] yet?
