Hello everyone - I’m relatively new as a Manjaro user, and this is my first time on a forum. I’ll try my best to be courteous and helpful as a forum user and to describe my problems as comprehensibly as possible.
Since yesterday I can no longer start some games that I run on Steam with Proton. The first error thrown was: “CREATEDXGIFactory: FAILED”. PROTON_USE_WINED3D works, but the performance is really really bad. I also tried installing proprietary AMDGPU drivers, reinstalled Vulkan, reinstalled Steam and all games - nothing changed.
vkcube results in
vkEnumeratePhysicalDevices reported zero accessible devices.
Do you have a compatible Vulkan installable client driver (ICD) installed?
Please look at the Getting Started guide for additional information.
I can’t remember making any changes to my system, nor updating/upgrading. I read that there were similar issues with Vulkan with updates, but I could not find a solution that helped me.
Also, installing the amdgpu-pro package via AUR has not changed anything. Video driver is still video-linux.
sudo mhwd -a pci nonfree 0300
and
sudo mhwd -a pci free 0300
both result in
Skipping already installed config 'video-linux' for device: 0000:2d:00.0 (0300:1002:73ef) Display controller ATI Technologies Inc
Starting steam via terminal also hints that there is a problem with video drivers/vulkan:
vkEnumeratePhysicalDevices failed, unable to init and enumerate GPUs with Vulkan.
BInit - Unable to initialize Vulkan!
Maybe you have some ideas? I’d be so happy if someone could help me, I was really satisfied with my Manjaro experience until now!
Thanks in advance.
Also, here is my inxi -v7azy
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e6b227d2-4986-4b6c-8c55-a7afce334551 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 with: latte-dock vt: 2 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C56 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: A.B2 date: 08/04/2022
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.54 GiB used: 3.85 GiB (24.8%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK16GX4M2B3200C16 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2572 high: 3599 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 2200
3: 2877 4: 2876 5: 2879 6: 2200 7: 2200 8: 2200 9: 2200 10: 2554 11: 2880
12: 2200 bogomips: 88843
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 2d:00.0 chip-ID: 1002:73ef
class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung S22F350
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 1 drv: swrast
surfaceless: drv: swrast x11: drv: radeonsi inactive: gbm,wayland,device-0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6650 XT (radeonsi
navi23 LLVM 16.0.6 DRM 3.54 6.6.16-2-MANJARO) device-ID: 1002:73ef
memory: 7.81 GiB unified: no
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: ZOOM UAC-2 driver: snd-usb-audio type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 1686:f029
class-ID: 0103 serial: <filter>
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: a2jmidid status: off
tools: cadence,jack_control
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager
Local Storage: total: 1.82 TiB used: 234.02 GiB (12.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-ASM2NE6100TTTD
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM13.2 temp: 37.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WD Blue SN570 1TB SSD size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 34.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 234.01 GiB (25.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e6b227d2-4986-4b6c-8c55-a7afce334551
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: E17E-0E6A
ID-1: swap-1 type: file size: 512 MiB used: 256 KiB (0.0%) priority: -2
file: /swapfile
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-3:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-5:4 info: Logitech Logi TKL Mechanical Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c345 class-ID: 0300
Device-3: 1-7:5 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: ZOOM UAC-2 type: audio driver: snd-usb-audio
interfaces: 5 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 8mA chip-ID: 1686:f029 class-ID: 0103 serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Sensors: System Temperatures: cpu: 40.2 C mobo: N/A gpu: amdgpu temp: 35.0 C
mem: 30.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Info: Processes: 320 Power: uptime: 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1687 pm: dpkg pkgs: 0 pm: pacman pkgs: 1672 libs: 529
tools: octopi,pamac,yay pm: flatpak pkgs: 15 Compilers: clang: 16.0.6
gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.33
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
