Hello,
While playing a game through Lutris I noticed that the game is not able to use my dedicated radeon graphics card.
It is detected and can be used via DRI_PRIME=1 for other applications:
~ >>> inxi -G
Device-1: Intel Skylake GT2 [HD Graphics 520] driver: i915 v: kernel
Device-2: AMD Mars [Radeon HD 8670A/8670M/8750M / R7 M370] driver: radeon
v: kernel
Device-3: Intel RealSense 3D Camera (Front F200) driver: uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.10 driver: X:
loaded: modesetting,radeon dri: iris,radeonsi gpu: i915
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,radeonsi,swrast
platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
renderer: Mesa Intel HD Graphics 520 (SKL GT2)
API: Vulkan v: 1.3.274 drivers: intel surfaces: xcb,xlib
However, even though vulkan-radeon and lib32-vulkan-radeon are installed the API above does not detect it and running vulkaninfo gives an error message about an incompatible driver:
>>> vulkaninfo
ERROR: [../mesa-23.1.9/src/amd/vulkan/radv_physical_device.c:2160] Code 0 : Device '/dev/dri/renderD128' is not using the AMDGPU kernel driver: Invalid argument (VK_ERROR_INCOMPATIBLE_DRIVER)
VULKANINFO
Vulkan Instance Version: 1.3.274
even using a solution mentioned in the arch wiki does not help. I have to admit that I only exported it in the terminal and run vulkaninfo right afterwards. However it is not able to properly use the amd card:
>>> export DISABLE_LAYER_AMD_SWITCHABLE_GRAPHICS_1=1
>>> vulkaninfo
VULKANINFO
Using the the icd loader files explicitly even screws up vulkaninfo even more:
>>> VK_ICD_FILENAMES="/usr/share/vulkan/icd.d/radeon_icd.i686.json:/usr/share/vulkan/icd.d/radeon_icd.x86_64.json" vulkaninfo
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs: Failed to detect any valid GPUs in the current config
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools-1.3.269/vulkaninfo/./vulkaninfo.h:237:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
Does anyone have an idea how to set vulkan and a dedicated radeon gpu up properly?
