Hello,
I assigned “Mousepad” for txt files, but the assignement does not work.
The txt files are still shown with the wrong icons and opening with the wrong software. What can I do?
Thank you all
Cant upload pics, sorry
Hello,
Thank you all
How did you do so?
Also:
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
the output to inxi --admin --verbosity=7 --filter --no-host --width is:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=af51509c-91b1-429d-8134-469fa4f7b044 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: Precision M4800 v: 00 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0T3YTY v: A00 serial: <filter> UEFI: Dell v: A23
date: 02/01/2018
Device-1: hid-20:20:01:2c:ea:d3-battery model: Bluetooth 3.0 Keyboard
serial: N/A charge: N/A status: Discharging
RAM: total: 15.54 GiB used: 3.48 GiB (22.4%)
Info: Quad Core model: Intel Core i7-4900MQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 8 MiB bogomips: 44714
Speed: 798 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 798 5: 799 6: 799 7: 799 8: 799
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0416 class ID: 0300
Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Dell driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:0ff6 class ID: 0300
Device-3: Microdia Integrated Webcam type: USB driver: uvcvideo
bus ID: 1-1.5:3 chip ID: 0c45:64d0 class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
class ID: 0403
Device-3: NVIDIA GK107 HDMI Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e1b class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus ID: 00:19.0 chip ID: 8086:153a class ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:08b1 class ID: 0280
bus ID: 3-1.5:3 chip ID: 8087:07dc class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus ID: 00:1f.2 chip ID: 8086.282a rev: 04
Local Storage: total: 238.47 GiB used: 33.23 GiB (13.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Innovation IT model: N/A
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 4A0 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GS40N rev: A100
dev-links: cdrom
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 33.23 GiB (14.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: af51509c-91b1-429d-8134-469fa4f7b044
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 94AD-BDA2
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
speed: 480 Mb/s chip ID: 8087:8008 class ID: 0900
Device-1: 1-1.5:3 info: Microdia Integrated Webcam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 0c45:64d0
class ID: 0e02
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 15 rev: 2.0
Device-1: 2-3:2 info: Kingsis ZOWIE Gaming mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 1af3:0001 class ID: 0301
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000 class ID: 0900
Device-1: 3-1.5:3 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:07dc
class ID: e001
Device-2: 3-1.8:4 info: Broadcom BCM5880 Secure Applications Processor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 0a5c:5800 class ID: 0b00 serial: <filter>
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 49.0 C mobo: 43.0 C sodimm: SODIMM C gpu: nouveau
temp: 47.0 C
Fan Speeds (RPM): cpu: 2111
Processes: 296 Uptime: 52m wakeups: 4 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1233 pacman: 1215 lib: 386 flatpak: 9 snap: 9
Shell: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.3.01
I used the GUI to set Mousepad as standard.
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of posting a link to another site that might delete the output in the future…
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above your post I just fixed.
go to a terminal by pressing Ctrl+Alt+T and provide the output to:
cat $HOME/.config/mimeapps.lst
@maycne.sonahoz If that doesn’t help me solve it, I’ll need your help as I’m on KDE, but you’re on XFCE…
Did you try to do it within Thunar itself ?
Like so :
Now below is what i have in $HOME/.config/mimeapps.list related to Mousepad
[Default Applications]
application/octet-stream=mousepad.desktop
application/x-gettext-translation=mousepad.desktop
application/xml=mousepad.desktop
application/x-wine-extension-ini=mousepad.desktop
text/plain=mousepad.desktop
Hope this helps
XFCE Settings Manager > Default Applications > Others
Filter: text
The icon in Thunar, doesn’t look like Mousepad, but a piece of paper with a folded corne
