Hello everyone! I tried rebuilding the python thingies but this happens…
pacman -Qoq /usr/lib/python3.11/
Output:
python-contextlib2
python-manjaro-sdk
Then:
pamac build $(pacman -Qoq /usr/lib/python3.11)
Output:
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
Error: target not found: python-manjaro-sdk
Error: target not found: python-contextlib2
Any tips, suggestions or magic spells to fix this?
sometime during the last update (or the 11/30 update)
my apparmor whitelist file (for samba) got renamed with a
.pacsave extension. This broke one of my shares.
I forgot about this apparmor stuff for samba
Until I read my own post from 2022…when I first had the problem.
It’s a drive mounted at /mnt that I (occasionally) connect to an old Win7 box.
the /home shares (2) work fine. Just thought I’d mention it.
MPV on Intel Meteor-Lake, vaapi hardware acceleration fails.
Addendum
Second test on Intel Alder-Lake System. No problems, no segfault, the older architecture is not affected.
[vo/gpu] Loading hwdec drivers for format: 'vaapi'
[vo/gpu] Loading hwdec driver 'vaapi'
[vo/gpu/vaapi] Using EGL dmabuf interop via GL_EXT_EGL_image_storage
[vo/gpu/vaapi] Trying to open a x11 VA display...
[vo/gpu/vaapi] Trying to open a wayland VA display...
[vo/gpu/vaapi/vaapi] libva: VA-API version 1.22.0
[vo/gpu/vaapi/vaapi] libva: Trying to open /usr/lib/dri/iHD_drv_video.so
[vo/gpu/vaapi/vaapi] libva: Found init function __vaDriverInit_1_22
[vo/gpu/vaapi/vaapi] libva: va_openDriver() returns 0
[vo/gpu/vaapi/vaapi] Initialized VAAPI: version 1.22
[vo/gpu/vaapi] Going to probe surface formats (may log bogus errors)...
[statusline] AV: 00:00:09 / 02:07:46 (0%) A-V: 0.000zsh: segmentation fault (core dumped) mpv -v RO.mkv
dmesg
[10390.847895] vo[17938]: segfault at 79f5fcd39 ip 000079f62cf84a68 sp 000079f6363b80b0 error 4 in iHD_drv_video.so[584a68,79f62ca1e000+985000] likely on CPU 3 (core 12, socket 0)
[10390.847903] Code: 8b 03 48 8b 38 48 85 ff 74 0e be 28 02 00 00 ff 15 4d be d2 01 48 8b 03 48 c7 00 00 00 00 00 31 c0 e9 a3 00 00 00 0f 1f 40 00 <4c> 8b a9 b0 00 00 00 31 c0 4d 85 ed 74 34 4c 89 ef ff 15 39 bf d2
The above commands require having the pacman-contrib & meld packages installed on your system.
manjaro-pacnew-checker is also available from the repos - I believe it automatically runs a check for .pacnew & .pacsave files after system updates.
Note that these files should always be inspected first before merging/deleting/replacing. Full instructions for dealing with .pacnew & .pacsave files can be viewed at:
This update, and previous also (30nov), on updating, turned all my monitors to maximum brightness. Last time I thought it’s something to do with plasma getting version bump. But this time it’s not the case…
also previous update made mpv stutter/stop_playback randomly every 3-10minutes for ~1 second and then continue like nothing happened…
I seriously doubt that, because I too have that widget on one of my panels.
What is more likely is that the configuration file got corrupted, and by removing the widget, a new and correct copy of the file was written to your ~/.config.
Update went well, and everything apparently works.
However, after the update Tilix is crashing every time I try to activate a conda environment (GNOME Terminal works fine).
This is what is logged:
[ 1845.461248] tilix[18031]: segfault at 9 ip 00007fac33ea0d98 sp 00007ffc6b63daa0 error 4 in libgobject-2.0.so.0.8200.2[7fac33e6b000+38000] likely on CPU 4 (core 0, socket 0)
Strange behaviour today: Pamac suggested 4 updates for
pamac-tray-icon-plasma
zsh-theme-powerlevel10k
ckbcomp
tlpui
All of them are listed as coming from AUR, but no updates possible, in fact.
I tried to remove most of them, obviously I lost my Pamac tray icon ^^
For ckbcomp, it would be a bad idea to remove it as its a dependency of manjaro-settings-manager.
I tried to update my database, as well as my mirrors, with no changes after that.
Since moving to 6.13 kernel some days ago (and moving to the nnn file manager) i experienced some CPU soft locks. (in the logs)
This will hang the entire system, no mouse movement, no keyboard light activity and TTY also not showing.
Running Intel 13600KF (Raptor lake)
Almost always with the system pretty much idle but heavy I/O activities to a USB thumb drive.
Could this be related to 6.13?
I moved back to 6.12 for now.
