[Stable Update] 2024-12-06 - Systemd, Qt 6.8.1, Mesa, Gstreamer, Wireplumber
Give back by donating to Manjaro
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development.
These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active.
Moreover, being a volunteer-driven project, donations play a crucial role in compensating the hard work and dedication of Manjaro’s developers and maintainers.
By providing them with the necessary support, donations help to ensure that the project remains well-supported and actively maintained. In conclusion, donations are an essential part of the Manjaro project’s long-term sustainability and growth. They help to keep the project accessible and of high-quality, ensuring that it remains a valuable resource for its users.
So consider to donate to the project, as giving back by donations is a wonderful way to appreciate our work we do.
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
  • Kernels
    • Rebuilds of RT kernels
    • 6.13-rc1 with Nvidia drivers
  • Systemd 256.9
  • Mesa 24.2.8
  • More updates to Deepin
  • Qt 6.8.1
  • Wireplumber 0.5.7
  • Gstreamer 1.24.10
  • fix for pamac not showing gibberish conflict messages
  • BoxBuddy 2.5.0
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Get our latest daily developer images now from Github: Plasma, GNOME, XFCE. You can get the latest stable releases of Manjaro from CDN77. Latest review ISOs are available here: Release 202412060323 · manjaro/release-review · GitHub
Our current supported kernels
  • linux419 4.19.324
  • linux54 5.4.286
  • linux510 5.10.230
  • linux515 5.15.173
  • linux61 6.1.119
  • linux66 6.6.63
  • linux611 6.11.10
  • linux612 6.12.1
  • linux613 6.13-rc1
  • linux61-rt 6.1.119_rt45
  • linux66-rt 6.6.63_rt46
Package Changes (Thu Dec 5 04:30:22 CET 2024)
  • stable core x86_64: 29 new and 30 removed package(s)
  • stable extra x86_64: 685 new and 686 removed package(s)
  • stable multilib x86_64: 21 new and 13 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2024-12-06
Nvidia 470xx driver may create a ghost screen which leads to a black screen with mouse in Plasma on Wayland
When you try to use Wayland with the Nvidia 470xx driver you may have an activated ghost screen, which leads to a so called ghost screen.
You can still use the right-click context menu and go to screen settings. Choose your other screen as primary and deactivate your ghost screen. Else you can use X11, which should not have that issue. More information about it here: Help testing Nvidia drivers with Kernel 6.12 - #20 by Arrababiski
2024-11-30
Plasma 6.2 might create a black screen when using X11 and default theme
For a while we are tracking the following bug of Plasma 6.2: https://bugs.kde.org/show_bug.cgi?id=483163. There seems to be a regression when using X11 and the default theme breeze. A workaround is to use some other variant of Breeze or use Wayland. People who have issues could comment on that bug report in a polite and helpful way, so the KDE developers may fix it soon.
GTK4 apps may not start due to Vulkan GSK Renderer by Default on Wayland
With GTK 4.16 release GNOME switched to Vulkan GSK Renderer by default. When you have not setup Vulkan support properly your GTK4 apps might not work as expected. Also users with Nvidia drivers might have issues, such as people using RasberryPi and older hardware. You can override it by setting the GSK_RENDERER=ngl or GDK_DISABLE=vulkan environment variable in /etc/environment file. For much more older PCs even GSK_RENDERER=gl is recommended. To boost rendering you can also set GDK_GL_DISABLE=buffer-storage, so the ngl renderer would perform similar to what you knew from GNOME 46.
Graphical interface might not start due to missing libpixbufloader-svg.so
Seems there was a so-name naming change within librsvg: Making sure you're not a bot!. To fix it issue: sudo gdk-pixbuf-query-loaders --update-cache
More information here: After today's update my machine is stuck on loading lightdm, no TTY access possible either - #36 by Photon
Pamac might not find AUR database
It is a known bug to have a message like this:
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
You can fix it by doing this: pamac upgrade --aur --force-refresh --dry-run
If it does not work that way try without --dry-run parameter.
Cursor sizes may vary when Wayland is used
If you enabled global scaling in Wayland within Plasma 6, especially with a fractional scale like 2.5x, cursor sizes would be a mess across various apps. For more information see this blog post: Cursor Size Problems In Wayland, Explained - KDE Blogs
Cinnamon 6.4 might change the default theme to a dark one
With Cinnamon 6.4 a lot of changes were made. The theme is significantly darker and offers more contrast than previous versions. Objects within the interface are now rounded, and a gap has been introduced between applets and the panel, giving the desktop environment a modern and polished appearance.
Nvidia: drivers might not work with 6.12 kernel
See also this open issue: 6.12: drm_open_helper RIP · Issue #712 · NVIDIA/open-gpu-kernel-modules · GitHub Nvidia provided a patch and shipped it in their 550.135 driver. More information here: Patch for 565.57.01 + Linux kernel 6.12 - Linux - NVIDIA Developer Forums.
We also patched 470xx and 390xx driver series as needed. Based on the current feedback, it seems that 470xx and 390xx drivers might not work at all with 6.12 kernel. 390xx got its last update by end of 2022, and we managed to keep it alive with kernel patches. If you have a legacy gpu you may consider to use the FOSS nouveau driver or exchange the GPU for a newer hardware.
Those who face issues with current provided drivers, may politely voice-up at the Nvidia developer forums in a civil manner and report their issue there: »»»»»»»»»» If you have a problem, PLEASE read this first «««««««««« - Linux - NVIDIA Developer Forums
2024-10-13
Kernel 6.10 has been marked [EOL] on kernel.org
:warning: Linux 6.10 is EOL
Linux 6.10 is EOL and got removed from the repo.
Please ensure your system use a supported kernel mhwd-kernel -l
:zap: KERNELS REMOVED
Linux 6.9 and 6.10 have been removed from repo.
2024-10-10
Steam games may not launch
Those who have issues with steam games may check this thread for help: Steam games won't launch after 2024-10-10 stable update
Electron apps may crash and flatpak apps may not start
It got reported that electron apps may crash. Also flatpaks might not work. Most likely fixed via adwaita-icon-theme-legacy 46.2-3. More information about it here
2024-10-01
Introducing linux-meta package to deal with EOL kernels more automated
Since we got several reports about issues around linux69 removal we created meta packages called linux-meta and packages for the extramodules. It will detect end of life Kernels and replace them with the current recommended kernel. For now with linux610 series. Please report back if you have any issues with this provided solution.
Users with Nvidia graphic cards may get unbootable systems into graphical environments
Since we removed the linux69 kernel from our repositories and most users will use pamac to update their systems, there is a chance that you may land in a TTY after you reboot your system. Here is why:
  • pamac has an auto-conflict resolution and might have put the linux69-nvidia package on the removal list.
  • you only had linux69 as your kernel installed, since it got shipped by default in Manjaro 24.0 ISOs
  • you rebooted your system without noticing that possible issue
How to fix:
  • first don’t panic and log in to your TTY with your user name and password
  • then install a kernel like 6.6 LTS or 6.10 to your system via: sudo mhwd-kernel -i linux66 or sudo mhwd-kernel -i linux610
  • then install the nvidia drivers via: sudo mhwd --auto pci ${DRIVER} 0300
VirtualBox: might show an error message after update to 7.1
You may have an error message like this: Failed to acquire the VirtualBox COM object. The application will now terminate.Callee RC%3ANS_ERROR_FAILURE (0x80004005). Simply restart the application
Random QML widgets and System Settings pages failing to launch in Plasma settings
… until Qt’s QML cache folder is cleared (if you do this, please save it first and attach it to the bug report).
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
– Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
:information_source: 2024-09-09
Added by @linux-arhus
[Service]
2024-08-20
Some GTK apps on Gnome suddenly changed to other (bright) theme
The adw-gtk3 package is now called adw-gtk-theme which replaces the old adw-gtk-theme.
With that change, you may need to set Legacy Applications to Adw-gtk3-dark in the Tweaks application under Appearance. It may have been set to the now removed Adw-dark previously.
2024-08-08
pipewire-pulse conflicts with pulseaudio-ctl
pulseaudio-ctl is not compatible with PipeWire and should be removed:
pamac remove pulseaudio-ctl
Noisetorch from Extra repository cannot be updated
noisetorch on AUR has been updated to change pulseaudio dependency to pulse-native-provider
A similar change has not been implemented for repository package yet, so pipewire-pulse users may need to remove package before update
pamac remove noisetorch
Noisetorch 0.12.2-4 with pulse-native-provider dependency has been released to all Manjaro branches - Branch compare for Manjaro - noisetorch
2024-07-01
The sshd service needs to be restarted after upgrading to openssh-9.8p1
2024-07-01 - Robin Candau
After upgrading to openssh-9.8p1, the existing SSH daemon will be unable to accept new connections (see Can't login after openssh 9.8p1-1 upgrade, MUST restart sshd (#5) · Issues · Arch Linux / Packaging / Packages / openssh · GitLab).
When upgrading remote hosts, please make sure to restart the sshd service using systemctl try-restart sshd right after upgrading.
We are evaluating the possibility to automatically apply a restart of the sshd service on upgrade in a future release of the openssh-9.8p1 package.
– Arch Linux - News: The sshd service needs to be restarted after upgrading to openssh-9.8p1
Virtual machines using libvirt have no internet if the host uses UFW
This is a known bug. “Workaround” is to change the firewall with firewalld or to disable UFW.
Another easier workaround is to edit /etc/libvirt/network.conf, and add
firewall_backend = "iptables"
older than 6 months:
2024-05-14
No plasma interface with kernel 6.9 + Nvidia gpu + Wayland
If you encouter a black screen with no inteface after login in, it’s probably a problem with simpledrm loading.
To solve it add nvidia_drm.fbdev=1 to /etc/default/grub
in the line begining with GRUB_CMDLINE_LINUX=" .
Verify that you also have nvidia_drm.modeset=1 in the same line.
Then exec sudo update-grub
Also, verify that you have nvidia_drm in /etc/mkinitcpio.conf in the MODULES= or HOOKS= line.
Exemple :
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
If it was not present, then run sudo mkinitcpio -P after adding it.
2024-05-13
Python interpreter upgrade
If you have a lot of pip/AUR packages to upgrade to Python 3.12, read this.
If you installed python312 from the AUR, you need to uninstall it before running this update.
Qemu: MacOS is not bootable with 9.0
Due to a bug MacOS is not bootable with 9.0: [9.0.0] qemu breaks mac os vm (#2334) · Issues · QEMU / QEMU · GitLab
Workaround: remove virtio-serial and org.qemu.guest_agent.0 from libvirt XML until bug will be fixed.
If you use KDE you better logout of your session and do the update via Pacman or Pamac in tty.
Helper script to reset plasma The balance of power and brought up from that fact. The Party said that. @liinux-aarhus
Also I would, before the update:
  • make a Timeshift snapshot if you ain’t got no recent one.
  • ( export content of widgets like your radio stations in Advanced Radio Player or your Podcasts in Kasts or any podcatcher as a backup )
  • make a fresh boot, but before that even:
  • System Settings > Appearance > Global Theme > set to Breath and tick both options for defaults
  • You might go to the hamburger menu in System Settings and look what changes you made away from default by selecting: Highlight Changed Settings and see if you want to make the effort to get back more defaults
  • System Settings > Workspace > Startup and Shutdown: SDDM defaults and Desktop Session: Start with empty session
  • disable all user-installed widgets that are still on your desktop, panels and even lock screen or wallpaper (e.g. Active Blur)
  • Export your custom shortcuts or mouse gestures in SS> Workspace > Shortcuts
  • Reboot, Timeshift snapshot, reboot
  • then do not log in, do the update via tty (CTRL+ALT+F3, same with F2 gets you back)
  • reboot, login, check through System Settings
  • reboot again
  • enjoy 8)
post-install:
  • look for Plasma 6 replacements for your widgets after the install
  • in case you have Github-installed theming: uninstall the KDE5-version of klassy, install the Plasma 6 version of klassy, maybe reinstall lightly
(greetings, @1efaf7d71a8637c6800a , PS: these are just my thoughts; I didn’t do this update yet!)
How to fix `plasma-firewall` error in System Settings GUI when running `ufw`
Open /usr/lib/kde_ufw_plugin_helper.py and change the first line from #!/usr/bin/python3.11 to #!/usr/bin/python3.12. This fixed the issue for me immediately and makes sense since Manjaro is currently on Python 3.12.
Xfce has inconsistent themes for Qt applications
Qt 6 is now default but some apps are still using Qt 5
To restore the look of QT apps after this update
pamac install kvantum-qt5
Manjaro-settings-manager has light theme instead of dark
2024-04-04
DKMS fails for v4l2loopback on 6.8 kernel
DKMS fails for v4l2loopback on 6.8 kernel (#2) · Issues · Arch Linux / Packaging / Packages / v4l2loopback · GitLab
issues with auto-mount of ntfs filesystem using Kernel 6.8
The kernel changed default ntfs driver from FUSE one to ntfs3.
These two are not fully compatible, mainly as far as mount options go. If you have custom mount options in the fstab (or any other application, such as VeraCrypt) they need to be changed.
Symptoms:
Mount fails with: Device or resource busy
DMesg reports: Can't open blockdev
Solution:
Migrate your mount options. For me the changes were:
  • allow_other → umask=000
  • default_permissions → [drop]
  • user_id=1000 → uid=1000
  • group_id=1000 → gid=1000
2024-03-06
gnome-keyring: ssh component is not included
ssh component is not included (#3) · Issues · Arch Linux / Packaging / Packages / gnome-keyring · GitLab
2024-02-21
plymouth update may cause black screens
With a newer version of plymouth than 22.02.122 you may experience an unbootable system with a black screen. This might be due to not having early KMS enabled. If you have an Nvidia GPU you could set nvidia_drm.modeset=1 nvidia_drm.fbdev=1 to the kernel parameters in your bootloader config to avoid the need of KMS. However, with Wayland around the corner, KMS will be needed.
To “fix” the current problem, we have downgraded plymouth once again to have more time to find a proper solution to migrate most of your installations to a working state with newer plymouth versions.
sudo pacman -Syuu
Those who don’t have issues can enjoy the newer version of plymouth.
Directions for adding kms to your system configuration and how you can help troubleshooting by providing some sysinfo, read more → Black Screen with Plymouth - Cause and Solution
polkit update might remove your local modified config
With polkit 124-1 there were changes made to etc/pam.d/polkit-1. So check if you made local changes to the file. See also: https://www.reddit.com/r/archlinux/comments/19bnj0i/comment/kit2v33/
bashrc-manjaro is now merged into bash
  • Yes, replace bashrc-manjaro with bash
  • Please also compare your:
    /etc/bash.bashrc
    with the generated
    /etc/bash.bashrc.pacsave
    and retrofit all of your customisations as there was no .pacnew file generated.
  • Same goes for /etc/skel/.bashrc
pacman and pacman-contrib changes
pacman-contrib is now split out from pacman. If you have anything installed that depends on pacman-contrib, update (after you finished the Release Update) with:
sudo pacman -Syu pacman-contrib
2024-01-13
Initramfs image can be bigger on 6.7 kernel due to Nvidia GSP Boot firmware
We all known that kernel 6.7 is very feature rich. One of the features is the inclusion of Nvidia’s GSP Boot firmware into Initramfs. However this will increase your image by 150 MB and the fallback image might be 240 MB in size. A way would be to remove kms from mkinitcpio.conf and redo your initramfs images. A discussion regarding that can be found at Arch Gitlab: kms hook increases the initramfs size heavily starting with 6.7 kernel (#238) · Issues · Arch Linux / Mkinitcpio / mkinitcpio · GitLab
To reduce size add fallback_options="-S autodetect -S kms" to /etc/mkinitcpio.d/linux67.preset
Making dbus-broker our default D-Bus daemon
2024-01-09 - Jan Alexander Steffens
We are making dbus-broker our default implementation of D-Bus, for improved performance, reliability and integration with systemd.
For the foreseeable future we will still support the use of dbus-daemon, the previous implementation. Pacman will ask you whether to install dbus-broker-units or dbus-daemon-units. We recommend picking the default.
For a more detailed rationale, please see our RFC 25.
– Arch Linux - News: Making dbus-broker our default D-Bus daemon
In some cases, however it is better to keep the legacy way. Here are some examples: Dbus-broker warnings
Edit: False alarm! See my reply to this post for the cause.
Either this update or the previous 11/30 update broke my plasma wayland session (both were applied at the same time). Selecting Wayland on SDDM on login goes to a black screen and then kicks me back to SDDM. I am on kernel 6.12, but 6.11 exhibits the same symptoms.
X11 works fine. This is an AMD laptop with a Ryzen 7 7840U
.local/share/sddm/wayland-session.log :
org.kde.startup: "kdeinit5_shutdown" QList() exited with code 255
startplasma-wayland: Shutting down...
startplasmacompositor: Shutting down...
startplasmacompositor: Done.
journalctl -xe :
Dec 05 22:11:43 framy systemd-coredump[1975]: [🡕] Process 1960 (baloo_file_extr) of user 1000 dumped core.
                                              Stack trace of thread 1960:
                                              #0  0x00007833f0b693f4 n/a (libc.so.6 + 0x963f4)
                                              #1  0x00007833f0b10120 raise (libc.so.6 + 0x3d120)
                                              #2  0x00007833f0af74c3 abort (libc.so.6 + 0x244c3)
                                              #3  0x00007833efc905e8 n/a (libQt6Core.so.6 + 0x905e8)
                                              #4  0x00007833efc91571 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x91571)
                                              #5  0x00007833f02def8b n/a (libQt6Gui.so.6 + 0xdef8b)
                                              #6  0x00007833f038bc18 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x18bc18)
                                              #7  0x00007833efd5727d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x15727d)
                                              #8  0x00007833f038bcae _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x18bcae)
                                              #9  0x00007833f038cf8d _ZN15QGuiApplicationC2ERiPPci (libQt6Gui.so.6 + 0x18cf8d)
                                              #10 0x000055918672325c n/a (baloo_file_extractor + 0x825c)
                                              #11 0x00007833f0af8e08 n/a (libc.so.6 + 0x25e08)
                                              #12 0x00007833f0af8ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                              #13 0x0000559186723525 n/a (baloo_file_extractor + 0x8525)
                                              Stack trace of thread 1967:
                                              #0  0x00007833f0bdebb0 ppoll (libc.so.6 + 0x10bbb0)
                                              #1  0x00007833ef43b227 n/a (libglib-2.0.so.0 + 0xc0227)
                                              #2  0x00007833ef3d7a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
                                              #3  0x00007833effc22fd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3c22fd)
                                              #4  0x00007833efd61ee6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x161ee6)
                                              #5  0x00007833efe57f22 _ZN7QThread4execEv (libQt6Core.so.6 + 0x257f22)
                                              #6  0x00007833ef7735ae n/a (libQt6DBus.so.6 + 0x2e5ae)
                                              #7  0x00007833efed90cd n/a (libQt6Core.so.6 + 0x2d90cd)
                                              #8  0x00007833f0b6739d n/a (libc.so.6 + 0x9439d)
                                              #9  0x00007833f0bec49c n/a (libc.so.6 + 0x11949c)
â–‘â–‘ Subject: Process 1960 (baloo_file_extr) dumped core
â–‘â–‘ Defined-By: systemd
â–‘â–‘ Support: https://forum.manjaro.org/c/support
â–‘â–‘ Documentation: man:core(5)
â–‘â–‘
â–‘â–‘ Process 1960 (baloo_file_extr) crashed and dumped core.
â–‘â–‘
â–‘â–‘ This usually indicates a programming error in the crashing program and
â–‘â–‘ should be reported to its vendor as a bug.
Dec 05 22:11:43 framy kernel: Bluetooth: RFCOMM TTY layer initialized
Dec 05 22:11:43 framy kernel: Bluetooth: RFCOMM socket layer initialized
Dec 05 22:11:43 framy kernel: Bluetooth: RFCOMM ver 1.11
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/ldac
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/aptx_hd
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_hd
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/aac
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aac
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/opus_g
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/opus_g
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/sbc
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/sbc
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/faststream
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/opus_05
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/opus_05
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 05 22:11:43 framy bluetoothd[632]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Dec 05 22:11:43 framy baloo_file[870]: kf.baloo: Extractor crashed
Dec 05 22:11:43 framy systemd[1]: systemd-coredump@64-1968-0.service: Deactivated successfully.
â–‘â–‘ Subject: Unit succeeded
â–‘â–‘
â–‘â–‘ The unit systemd-coredump@64-1968-0.service has successfully entered the 'dead' state.
Dec 05 22:11:43 framy baloo_file_extractor[2017]: Failed to create wl_display (No such file or directory)
Dec 05 22:11:43 framy baloo_file_extractor[2017]: qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
Dec 05 22:11:43 framy baloo_file_extractor[2017]: qt.qpa.xcb: could not connect to display
Dec 05 22:11:43 framy baloo_file_extractor[2017]: qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
Dec 05 22:11:43 framy baloo_file_extractor[2017]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Dec 05 22:11:43 framy baloo_file_extractor[2017]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                  Available platform plugins are: offscreen, linuxfb, xcb, minimalegl, wayland, vnc, eglfs, wayland-egl, vkkhrdisplay, minimal.
Dec 05 22:11:43 framy systemd-coredump[2027]: Process 2017 (baloo_file_extr) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Dec 05 22:11:43 framy systemd[1]: Started Process Core Dump (PID 2027/UID 0).
Let me know if there are any other interesting logs I should include. Thanks!
You have some issue with wayland itself. X11 seems to work for you as the needed plugin is not needed there. What is the output of pacman -Q | grep wayland'? Also are qt5-waylandandqt6-wayland` packages installed? @etbusch
You can try export QT_QPA_PLATFORM=xcb to force applications to run via X11. For that make sure you have xorg-xwayland installed.
Hello, I wanted to use Kleopatra to manage certificates, but there seems to be a problem with the current version. It takes a long time to start and creating a new key pair fails.
kleo
I’m getting this error when trying pacman -Syu
error: could not read db 'extra' (Damaged tar archive)
I’ve updated my mirror list and tried again but it doesn’t seem to work
try renaming the .db file at /lib/pacman/sync and then resync. that seemed to work last time i had the same problem
I mentioned this with the last update. The Gnome GUI password input when requesting authentication has transparent entry buttons.
Apparently this has introduced a few bugs… :point_down:
  1. I always update my system with pacman from a tty, after logging out of Plasma and shutting down sddm. Considering that this update included qt, I also emptied ~/.cache before running the update process. After the reboot and subsequent login, my bottom panel — which is configured as a dock with adaptive size and dodging — was abridged and none of the pinned icons were visible anymore. It was also slightly off-center to the left. Entering Edit Mode (without changing anything) restored it to its normal size and position.
  2. Normally, if you lock the widgets in Plasma, the “Enter Edit Mode” entry in the popup menu when clicking an empty space on the desktop is greyed-out and cannot be selected. This is no longer the case now, although selecting it doesn’t do anything when the widgets are locked.
This is Plasma 6.2.4 on Wayland, by the way, and on Intel graphics — not that this would matter.
I did see a suggested fix in an unlisted topic that may be related to your issue:
Reading this, I had my fingers crossed to update, but Wayland session turned out to work fine for me.
Pamac has some strange problem:
(Background info: I manually refreshed my mirrors with sudo pacman-mirrors --fasttrack)
I just updated to the new stable release on my PC in a mistake, because Pamac only showed me 3 updates in the GUI (Flatpak,nvidia 470xx and nvidia 390xx package).
To my surprise it downloaded around 90 packages instead only 3.
In addition, the Pamac GUI on my Laptop won’t show me any updates again, the same as last stable update (few days ago).
sudo pacman-mirrors --fasttrack dont changed that.
I think i have to click on the Top right register page and “Refresh Database” to do the update, without the option to inspecting the packages first.
:roll_eyes:
Edit: I also just see in Pamac (GUI) under Foreign that AUR Packages no longer has (AUR) written on my Laptop. While on my PC i still can see (AUR) written in Pamac.
Besides X11 and Wayland, both systems use (almost) the same duplicated system settings.
Spoiler Alert: Eddie-UI is a AUR Package but it isnt marked here.
Edit2: With the help of a exploit bug that i just luckily found in the last minute, i clicked on refresh database on Pamac, aborted the authencification and the stable update (overview/list) showed up (350 MB) as it should be.
:space_invader:
For Plasma it is recommended to use pamac-gtk3 instead of the gtk4 version.
This isn’t the entire theme, though. It’s just different pop-up windows from various programs. The Keepass error box also does this, but not the regular input when it asks for a password upon being opened.
Also, that post was unlisted saying they “didn’t know what the problem was” when it was clearly shown. The buttons are transparent in the photo of that users post. That is what I’m experiencing as well.
I did just try turning on that extension and it did work for Pamac but not for Keepass, though.
Close but no cigar.
I got two lighted screens, a mouse cursor that moves through them, AND my psensor on autostart appeared on the screen.
I can even launch an app I have a shortcut for. I launch Focuswriter by pressing Control F.
Hmm. Feeling cute. Maybe I will make a windowed plasma script to launch a Kicker menu. Boowaawaaa!
But no plasma desktop. :frowning:
I was able to solve it by refreshing pacman mirrors with
and then updating with
sudo pacman -Syu
Mod edit:- Corrected syntax.
Please use only one (1) Y when performing an update .
Using two (2) YYs will unnecessarily force a database refresh. :eyes:
Update without problems. Thanks.
I was able to fix this by removing and reinstalling all-ways-gpu, which I use for switching my eGPU on and off.
Appreciate the assistance!
The update just failed for me with a couple of problems.
The first a warning about qt6-multimedia.
The second about gamescope-plus. I’m not sure if I need gamescope-plus or why it’s installed vs gamescope. Here’s the log. Any suggestions?
sudo pacman -Syu         ✔
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
warning: dependency cycle detected:
warning: qt6-multimedia-ffmpeg will be installed before its qt6-multimedia dependency
Packages (94) btrfs-progs-6.12-1  c-ares-1.34.3-1  cpupower-6.12-1  dav1d-1.5.0-1  electron32-32.2.6-1  ffmpeg-2:7.1-3  file-5.46-1
              fluidsynth-2.4.1-1  fwupd-2.0.2-1  gamescope-plus-3.15.13.plus1-1  glslang-15.0.0-2  gnupg-2.4.7-1  gst-libav-1.24.10-1
              gst-plugins-bad-1.24.10-1  gst-plugins-bad-libs-1.24.10-1  gst-plugins-base-1.24.10-1  gst-plugins-base-libs-1.24.10-1
              gst-plugins-good-1.24.10-1  gst-plugins-ugly-1.24.10-1  gst-python-1.24.10-1  gstreamer-1.24.10-1  kirigami-addons-1.6.0-1
              kwin-6.2.4-2  layer-shell-qt-6.2.4-2  less-1:668-1  lib32-gamescope-plus-3.15.13.plus1-1  lib32-gst-plugins-base-1.24.10-1
              lib32-gst-plugins-base-libs-1.24.10-1  lib32-gst-plugins-good-1.24.10-1  lib32-gstreamer-1.24.10-1
              lib32-libltdl-2.5.4+r1+gbaa1fe41-1  lib32-mesa-1:24.2.8-1  lib32-openal-1.24.1-1  lib32-pixman-0.44.2-1  lib32-systemd-256.9-1
              libbpf-1.5.0-1  libcdr-0.1.8-1  libetonyek-0.1.12-1  libldap-2.6.9-1  libplacebo-7.349.0-3  libsidplayfp-2.12.0-1
              libsysprof-capture-47.2-1  libtool-2.5.4+r1+gbaa1fe41-1  luajit-2.1.1731601260-1  lutris-0.5.18-1  manjaro-hello-0.7.2-9
              manjaro-release-24.2.0-1  mesa-1:24.2.8-1  mhwd-nvidia-470xx-470.256.02-9  mpd-0.23.16-1  noto-fonts-1:2024.12.01-1  npth-1.8-1
              nvidia-utils-550.135-2  openal-1.24.1-1  pixman-0.44.2-1  pkgconf-2.3.0-1  pyside6-6.8.0.2-3  python-fonttools-4.55.1-1
              python-matplotlib-3.9.3-1  qt6-5compat-6.8.1-1  qt6-base-6.8.1-1  qt6-connectivity-6.8.1-1  qt6-declarative-6.8.1-1
              qt6-imageformats-6.8.1-1  qt6-multimedia-6.8.1-1  qt6-multimedia-ffmpeg-6.8.1-1  qt6-positioning-6.8.1-1  qt6-quick3d-6.8.1-1
              qt6-quicktimeline-6.8.1-1  qt6-sensors-6.8.1-1  qt6-shadertools-6.8.1-1  qt6-speech-6.8.1-1  qt6-svg-6.8.1-1  qt6-tools-6.8.1-1
              qt6-translations-6.8.1-1  qt6-virtualkeyboard-6.8.1-1  qt6-wayland-6.8.1-1  qt6-webchannel-6.8.1-1  qt6-webengine-6.8.1-1
              qt6-websockets-6.8.1-1  ruby-rexml-3.3.9-1  rust-1:1.83.0-1  screenfetch-3.9.9-1  shaderc-2024.3-2  shiboken6-6.8.0.2-3
              spirv-tools-2024.4.rc1-1  sqlite-3.47.1-1  sudo-1.9.16.p2-1  systemd-256.9-1  systemd-libs-256.9-1  systemd-sysvcompat-256.9-1
              timeshift-24.06.4-1  traceroute-2.1.6-1  xterm-396-2
Total Installed Size:  2334.88 MiB
Net Upgrade Size:         7.92 MiB
:: Proceed with installation? [Y/n] y
(94/94) checking keys in keyring                                                        [###################################################] 100%
(94/94) checking package integrity                                                      [###################################################] 100%
(94/94) loading package files                                                           [###################################################] 100%
(94/94) checking for file conflicts                                                     [###################################################] 100%
error: failed to commit transaction (conflicting files)
/usr/share/gamescope/scripts/00-gamescope/common/inspect.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/00-gamescope/common/modegen.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/00-gamescope/common/util.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/00-gamescope/displays/asus.rogally.lcd.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/00-gamescope/displays/deckhd.steamdeck.deckhd-lcd.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/00-gamescope/displays/valve.steamdeck.lcd.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/00-gamescope/displays/valve.steamdeck.oled.lua exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
/usr/share/gamescope/scripts/README.md exists in both 'gamescope-plus' and 'lib32-gamescope-plus'
sudo pacman -Syu --overwrite="/usr/share/gamescope/*"
