I’m guessing that the UNIX philosophy couldn’t be further from the systemd author’s mind; especially now that he is employed by Microsoft; a company that traditionally breaks the wheel and covers it up with strings and ceiling wax.
Wowza, I may need to figure out how to restore a timeshift backup on an ext4 system as I just applied the 2024-10-01 + 2024-10-10 combo on my framework 16 laptop… and system performance in games has dropped.
I thought all was well after I launched a couple low resource casual games, but then I launched Starfield and knew something wasn’t right when I got sub-10 fps.
Initially I suspected I might have an issue with DRI_PRIME=1 (in my steam game launch options), but it looks like DRI_PRIME works with glxinfo…
$ glxinfo | grep 'OpenGL renderer'
OpenGL renderer string: AMD Radeon 780M (radeonsi, gfx1103_r1, LLVM 18.1.8, DRM 3.54, 6.6.54-2-MANJARO)
$ DRI_PRIME=1 glxinfo | grep 'OpenGL renderer'
OpenGL renderer string: AMD Radeon RX 7700S (radeonsi, navi33, LLVM 18.1.8, DRM 3.54, 6.6.54-2-MANJARO)
vulkaninfo --summary
VULKANINFO
Vulkan Instance Version: 1.3.295
Instance Extensions: count = 24
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_EXT_headless_surface : extension revision 1
VK_EXT_surface_maintenance1 : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 4
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_LUNARG_direct_driver_loading : extension revision 1
Instance Layers: count = 10
VK_LAYER_FROG_gamescope_wsi_x86_64 Gamescope WSI (XWayland Bypass) Layer (x86_64) 1.3.221 version 1
VK_LAYER_INTEL_nullhw INTEL NULL HW 1.1.73 version 1
VK_LAYER_MANGOAPP_overlay Mangoapp Layer 1.3.0 version 1
VK_LAYER_MANGOHUD_overlay_x86_64 Vulkan Hud Overlay 1.3.0 version 1
VK_LAYER_MESA_device_select Linux device selection layer 1.3.211 version 1
VK_LAYER_MESA_overlay Mesa Overlay layer 1.3.211 version 1
VK_LAYER_VALVE_steam_fossilize_32 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_fossilize_64 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_32 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_64 Steam Overlay Layer 1.3.207 version 1
Devices:
GPU0:
apiVersion = 1.3.289
driverVersion = 24.2.4
vendorID = 0x1002
deviceID = 0x15bf
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = AMD Radeon 780M (RADV GFX1103_R1)
driverID = DRIVER_ID_MESA_RADV
driverName = radv
driverInfo = Mesa 24.2.4-arch1.0.1
conformanceVersion = 1.3.0.0
deviceUUID = 00000000-c500-0000-0000-000000000000
driverUUID = 414d442d-4d45-5341-2d44-525600000000
GPU1:
vendorID = 0x1002
deviceID = 0x7480
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = AMD Radeon RX 7700S (RADV NAVI33)
driverName = radv
deviceUUID = 00000000-0300-0000-0000-000000000000
Anyone else experiencing a drop in gaming performance after this update?
EDIT: Figured it out! PPD 0.23-1 tanked my FrameWork 16’s performance!
See details re: why I downgraded PPD to `0.21-1`
In plasma 5.x and 6.0.5 it looked like power-profiles-daemon (PPD) 0.21-1 did suggest/set a lower idle CPU frequency, but everything would ramp up and deliver full power performance when I’d launch something beefy, So I just defaulted to leaving PPD set to Power Save to at least get the advantage of lower idle temps… and most games hit the 100 FPS rating of the monitor’s HDMI connection.
Alongside Plasma 6.1.5… PPD 0.23-1 and amd-ucode 20240928 were also updated.
Well, it looks like PPD 0.23-1 is more serious/broken, because my FPS in many games seemed to tank to the point where my Framework 16 Laptop was delivering less performance than my SteamDeck… i.e. Grim Dawn performance dropped from 100 FPS to 23-35 FPS
An initial “workaround”/troubleshooting step I made was to increase the PPD setting to Balanced. The downside with this is that previously I was getting respectable frame rates while keeping the CPU in the 70-80C range in Power Save, now with PPD in Power Save the temps still stay in the 70-80C range but frame rates are 23-35 FPS… while Balanced restores frame fates to normal, the cost of CPU temp being pinned at 100C is not a happy place.
Since I wasn’t happy with this workaround I performed the following downgrades/re-upgrades with hopes to isolate/reverse the issue:
- Downgraded
amd-ucodeto2024-0809…sudo mkinitcpio -P && sudo update-grub… rebooted and tested Grim Dawn performance @ 23 FPS in character select and 35 FPS in game. - Downgraded PPD to
0.21-1… rebooted and Grim Dawn performance returned to 100FPS in character select and in game - Upgraded
amd-ucodeback to20240928…sudo mkinitcpio -P && sudo update-grub… rebooted and Grim Dawn performance remained at 100FPS in character select and in game
3.1. Remembered my initial FPS drop experience was 10-ish FPS in Starfieild… retested and was getting 55-60 FPS inside a busy city… expected/normal on this very resource intensive game
Likely upstream issue… AMD iGPU frequencies are capped to 200MHz after last update (#164) · Issues · upower / power-profiles-daemon · GitLab
There’s a strange problem with sudo not sourcing /root/.zshrc since this upgrade. Which means that my $PATH variable isn’t being set so I can run locally-written scripts with sudo unless I specify the full path.
The problem seems not to be with sudo itself, as downgrading it makes no difference. I’ve raised a support thread for this.
https://forum.manjaro.org/t/strange-issue-with-sudo-after-update-2024-10-10/169540
[Edit]: solved! This was because /etc/sudoers now has Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/bin" uncommented. Commenting it out fixes the problem.
[Edit 2]: a better solution is to set the path I want in a similar line in a file in /etc/sudoers.d
Hmm this sounds interesting, i also just removed the AUR/Flatpak update checks in pamac (lets see how that goes).
Its a little bid annoying to see official repo packages, that turns into orphan because its no longer supported, which pamac then try to transform into aur that no one wants anyways.
Refresh Flatpaks with:
flatpak update --system
Is no big deal anyways and i guess for the 2 AUR Packages that i only need, i can use the search function and look for a new version from time to time.
6 posts were merged into an existing topic: Window decoration broke after update
A post was merged into an existing topic: Window decoration broke after update
xorg update applied on stable branch today morning, thanks for your reactivity.
[nls@lap ~]$ date -u
mer. 30 oct. 2024 06:15:56 UTC
[nls@lap ~]$ uname -a
Linux lap 6.6.54-2-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Oct 8 03:11:08 UTC 2024 x86_64 GNU/Linux
[nls@lap ~]$ sudo pacman -Syu
[sudo] password for nls:
:: Synchronising package databases...
core 141,5 KiB 937 KiB/s 00:00 [######################################################] 100%
extra 8,0 MiB 26,3 MiB/s 00:00 [######################################################] 100%
multilib 143,9 KiB 935 KiB/s 00:00 [######################################################] 100%
resolving dependencies...
Packages (4) xorg-server-21.1.14-0 xorg-server-common-21.1.14-0 xorg-server-xvfb-21.1.14-0 xorg-xwayland-24.1.4-0
Total Download Size: 3,76 MiB
Total Installed Size: 7,79 MiB
Net Upgrade Size: 0,09 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
xorg-server-common-21.1.14-0-x86_64 31,7 KiB 364 KiB/s 00:00 [######################################################] 100%
xorg-server-21.1.14-0-x86_64 1767,9 KiB 12,3 MiB/s 00:00 [######################################################] 100%
xorg-xwayland-24.1.4-0-x86_64 1113,6 KiB 7,40 MiB/s 00:00 [######################################################] 100%
xorg-server-xvfb-21.1.14-0-x86_64 941,5 KiB 5,86 MiB/s 00:00 [######################################################] 100%
Total (4/4) 3,8 MiB 20,9 MiB/s 00:00 [######################################################] 100%
(4/4) checking keys in keyring [######################################################] 100%
(4/4) checking package integrity [######################################################] 100%
(4/4) loading package files [######################################################] 100%
(4/4) checking for file conflicts [######################################################] 100%
(4/4) checking available disk space [######################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/4) upgrading xorg-server-common [######################################################] 100%
(2/4) upgrading xorg-server [######################################################] 100%
(3/4) upgrading xorg-server-xvfb [######################################################] 100%
(4/4) upgrading xorg-xwayland [######################################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
(3/3) Updating the desktop file MIME type cache...
[nls@lap ~]$ reboot
The last xorg update has broken system performance in XFCE.
Firefox has became laggy, and CPU usage has jumped to the moon
And everything returned to normal behavior after timeshift recovery before 2024-10-10 update installation:
So the problem is definitely in this update.
System details
OS: Manjaro Linux x86_64
Host: GA-78LMT-S2PV
Kernel: 6.6.52-1-MANJARO
Uptime: 11 mins
Packages: 1594 (pacman)
Shell: bash 5.2.32
Resolution: 1920x1080
DE: Xfce 4.18
WM: Xfwm4
WM Theme: Matcha-sea
Theme: Matcha-sea [GTK2/3]
Icons: Papirus-Maia [GTK2/3]
Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: AMD FX-8350 (8) @ 4.000GHz
GPU: NVIDIA GeForce GT 1030
Memory: 1697MiB / 19984MiB
This is a really goofy bug, but since the last update I’ve had an issue where my desktop wallpaper on my ultrawide 3440x1440 modifies to a 1920x1080 size (same as my second monitor). The reset of the screen is black.
It might be related to the suspend issues from the last update which I experience every now and then, though this bug is happening independently (this bug happens almost every time I lock the screen and step away for a little. The suspend bug happens kind of rarely).
Hi, since the update to Manjaro 24.1 Xahea, I’ve been having problems when I want to shut down the computer.
If I’m using X11 Plasma desktop, the graphic environment and the behavour of some programs is smooth, better than it is with Wayland desktop. But when I’m gonna shut down the computer, it freezes until I must force the laptop to power off.
Instead, with Wayland it powers on and off without any trouble. But the graphic environment is of less quality. It has lack of definition for the icons in the task manager bar, as well as the text in the files name on the desktop. Also, the frame of some programs always opens really little when they are launched.
Well, I hope these notes serve to improve some manjaro features.
My laptop specifications are:
- Dell Inspiron 15 5570
- 8 × Intel® Core™ i7-8550U CPU @ 1.80GHz
- Mesa Intel® UHD Graphics 620
- Kernel 6.6.54-2-MANJARO (64 bits)
Hello and Welcome @Paulino !
It’s better to start your own thread for your issue, but I will suggest you read this:
Perhaps one of the Known issues and solutions listed in this very thread will provide some insight. Scroll up until you find:
- KDE Plasma hangs on Shutdown, Restart and Logout which was originally noted in the 2024-10-01 Update announcement.
Getting an “daemon error” pup-up/window when relaunching pamac-gtk3 after installing the freshly released pamac updates…
trans_refresh: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such method “StartTransRefreshAur”
Packages (5) libpamac-11.7.0-0 libpamac-flatpak-plugin-11.7.0-0 manjaro-release-24.1.2-1 pamac-cli-11.7.0-0 pamac-gtk3-10.7.0-0
sudo pacman -Syu
core is up to date
extra is up to date
multilib is up to date
warning: power-profiles-daemon: ignoring package upgrade (0.21-1 => 0.23-1)
Total Download Size: 1.15 MiB
Total Installed Size: 4.58 MiB
Net Upgrade Size: 0.05 MiB
libpamac-flatpak-plugin-11.7.0-0-x86_64 29.7 KiB 146 KiB/s 00:00 [################################################] 100%
pamac-cli-11.7.0-0-x86_64 77.4 KiB 328 KiB/s 00:00 [################################################] 100%
pamac-gtk3-10.7.0-0-x86_64 186.6 KiB 659 KiB/s 00:00 [################################################] 100%
manjaro-release-24.1.2-1-any 16.7 KiB 388 KiB/s 00:00 [################################################] 100%
libpamac-11.7.0-0-x86_64 867.3 KiB 2.45 MiB/s 00:00 [################################################] 100%
Total (5/5) 1177.6 KiB 2.88 MiB/s 00:00 [################################################] 100%
(5/5) checking keys in keyring [################################################] 100%
(5/5) checking package integrity [################################################] 100%
(5/5) loading package files [################################################] 100%
(5/5) checking for file conflicts [################################################] 100%
(5/5) checking available disk space [################################################] 100%
(1/5) upgrading libpamac [################################################] 100%
(2/5) upgrading libpamac-flatpak-plugin [################################################] 100%
(3/5) upgrading manjaro-release [################################################] 100%
(4/5) upgrading pamac-cli [################################################] 100%
(5/5) upgrading pamac-gtk3 [################################################] 100%
(1/6) Reloading system manager configuration...
(2/6) Arming ConditionNeedsUpdate...
(3/6) Updating the MIME type database...
(4/6) Reloading system bus configuration...
(5/6) Updating icon theme caches...
(6/6) Updating the desktop file MIME type cache...
EDIT:
Actually getting the same error on the command line as well
pamac update -a
pamac update -a
Error: Daemon Error: trans_refresh: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such method “StartTransRefreshAur”
Preparing...
Authenticating as: <userid>
Password:
please call pamac upgrade --aur --force-refresh else comment on the issue: Searching AUR points to unexpected db · Issue #1 · manjaro/pamac-cli · GitHub
Awesome, that command resolved the error message! Just for my understanding, the error was related to a pamac db location change, and this command put the expected files in the new location?
That command, specifically the --force-refresh part forces the databases to update, even if everything seems to be up-to-date, as was your case.
But note, it shouldn’t be used in all cases. Only when you have database problems like you did. It can cause a LOT of strain on the servers if everyone always uses only that.
Thanks for your suggestions @soundofthunder
Not sure if this is an issue with the current release, but I just wanted to use merkuro-calendar however I get an error message upon start. I believe a similar issue has been present in the past (on the testing branch), but on my testing branch device it is working just fine.
Here is the error I am getting:
merkuro-calendar ✔
qrc:/main.qml:663:9: QML ScheduleView: Created graphical object was not placed in the graphics scene.
org.kde.merkuro.calendar: Not resetting IOC from source as no core calendar set.
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
org.kde.pim.akonadicontrol: Service org.freedesktop.Akonadi.Control.lock already registered, terminating now.
org.kde.pim.akonadiserver: Starting up the Akonadi Server...
/usr/bin/mysqlcheck: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadb-check' instead
akonadi.collectionattributetable OK
akonadi.collectionmimetyperelation OK
akonadi.collectionpimitemrelation OK
akonadi.collectiontable OK
akonadi.flagtable OK
akonadi.mimetypetable OK
akonadi.parttable OK
akonadi.parttypetable OK
akonadi.pimitemflagrelation OK
akonadi.pimitemtable OK
akonadi.pimitemtagrelation OK
akonadi.resourcetable OK
akonadi.schemaversiontable OK
akonadi.tagattributetable OK
akonadi.tagremoteidresourcerelationtable OK
akonadi.tagtable OK
akonadi.tagtypetable OK
/usr/bin/mysql_upgrade: Deprecated program name. It will be removed in a future release, use '/usr/bin/mariadb-upgrade' instead
Reading datadir from the MariaDB server failed. Got the following error when executing the 'mysql' command line client
ERROR 1698 (28000): Access denied for user 'root'@'localhost'
FATAL ERROR: Upgrade failed
org.kde.pim.akonadiserver: Running DB initializer
org.kde.pim.akonadiserver: "\nSql error: Table 'akonadi.SchemaVersionTable' doesn't exist QMYSQL: Die Abfrage konnte nicht ausgeführt werden\nQuery: ALTER TABLE SchemaVersionTable ADD COLUMN version INTEGER NOT NULL DEFAULT 0"
org.kde.pim.akonadiserver: Unable to initialize database.
org.kde.pim.akonadiserver: Shutting down AkonadiServer...
org.kde.pim.akonadicontrol: Application '/usr/bin/akonadiserver' exited normally...
org.kde.pim.akonadicalendar: Search failed: ""
org.kde.pim.akonadicore: Job error: "" for collection: QList()
org.kde.pim.akonadicore: Could not start/stop Akonadi!
qrc:/main.qml:651:9: QML MonthView: Created graphical object was not placed in the graphics scene.
zsh: segmentation fault (core dumped) merkuro-calendar
Seems to have something to do with the switch from mysql to mariadb, but as mentioned before I believe this to be a regression, since such an issue(?) had already been fixed in the past.
The compositor no longer works. Transparent shadows have turned into solid black blocks and none of the desktop effects work.
Thanks to the developers for the pamac update! No more crashes.
Hopefully, access to the AUR will be restored soon. I’m guessing its user agent is just banned like in 2021: Pamac-AUR always showing no package found
Update: I created this topic: AUR not working on new install since 2024-10-10 update
