[Stable Update] 2024-10-10 - Kernels, Pacman 7.0, KDE Frameworks 6.6, Virtualbox 7.1.2, Mesa
Access is still available. If you’re having issues with AUR packages, please create a new AUR topic for further troubleshooting.
No, it’s not.
13 posts were merged into an existing topic: Manjaro key-ring error, today(11/11/2024)
A post was split to a new topic: Issue with games since xorg-server 21.1.14-0
I’m running kernel 6.11.2-4-MANJARO and still see sense data errors in syslog from udisksd, when I connect a USB drive.
kernel: sd 6:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
kernel: sd 6:0:0:0: [sde] 35156590592 512-byte logical blocks: (18.0 TB/16.4 TiB)
kernel: sd 6:0:0:0: [sde] 4096-byte physical blocks
kernel: sd 6:0:0:0: [sde] Write Protect is off
kernel: sd 6:0:0:0: [sde] Mode Sense: 47 00 10 08
kernel: sd 6:0:0:0: [sde] No Caching mode page found
kernel: sd 6:0:0:0: [sde] Assuming drive cache: write through
kernel:  sde: sde1
kernel: sd 6:0:0:0: [sde] Attached SCSI disk
udisksd[1007]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sde': Unexpected sense data returned:
                                       0000: f0 00 01 00  00 00 00 0a  00 00 00 00  00 1d 00 00    ................
                                       0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
According to this (closed) post
https://forum.manjaro.org/t/ata-libata-scsi-sense-data-errors-breaking-hdparm-with-wd-drives/166634/8
the problem should be fixed in 6.10.6-1. Given that the fix was known in August, I’d assume it would also be fixed in kernel 6.11.2-4, which was built on 2024-10-08. Anybody knows what’s happening here?
I have an issue with KAlarm 3.9.1.
It freezes playing sound.
But if you choose “Beep” as sound, it doesn’t.
Here there is a workaround (downgrade):
For now, I prefer to wait and change my (few) alarms sounds, because it has been fixed for 3.9.2 version.
A post was merged into an existing topic: Update requests for packages imported from Arch Linux
Is this with the update for this thread or would it be better in this one?
Since there is a more recent raft of updates, I’d suggest closing this thread is a good option.
