Sometimes this happens, especially when you use Gnome. Also bigger updates it is better not to use the graphical environment and their package managers. pamac and pacman both work fine in a TTY
I have two computers running XFCE.
On both computers, thunderbird starts only after the second attempt.
(First click to start thunderbird does not start it, the second time start thunderbird).
Donāt know for chromium, but on ungoogled-chromium (113.0.5672.126, using chaotic aur build) you can switch between classic (light theme) and gtk theme (hits the system theme).
This update was the strangest one for meā¦ Let me explain:
Update and reboot
Stuck on āFailed to start Load Kernel Moduleā (I used 5.15 LTS)
Somehow after 2-3 tries the only TTY-2 has been worked
I found out how to install a new kernel and then reboot (update to 6.1 LTS)
KDE Plasma totally lost its theme configurations and any commands in Konsole gave result like there wasnāt any arguments for anything (for example, pacman -Qoq /usr/lib/python3.10/ command gave me only the list of commands like āpacman list, install, updateā¦ā and pamac GUI couldnāt do anything and even didnāt ask password to enter the settings)
After resetting language to English and a few reboots later, everything has started to work normally as expected.
I still cannot run kernel 5.15 (see p.2)
Soā¦ What the was thatā¦ Idk, like I donāt know if I can fix the issue with 5.15 or should just wait for the further updates keep using 6.1
Jun 04 20:06:58 weingeist-PC avahi-daemon[885]: *** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is th>
Jun 04 20:06:58 weingeist-PC avahi-daemon[885]: *** WARNING: Detected another IPv6 mDNS stack running on this host. This makes mDNS unreliable and is th>
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Host name conflict, retrying with weingeist-PC-2
thats new
systemctl status systemd-resolved.service ī² INT ā ī² 3m 7s ļ
ā systemd-resolved.service - Network Name Resolution
Loaded: loaded (/usr/lib/systemd/system/systemd-resolved.service; enabled; preset: enabled)
Active: active (running) since Sun 2023-06-04 20:06:58 CEST; 11min ago
Docs: man:systemd-resolved.service(8)
man:org.freedesktop.resolve1(5)
https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers
https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
Main PID: 812 (systemd-resolve)
Status: "Processing requests..."
Tasks: 1 (limit: 14157)
Memory: 6.5M
CPU: 126ms
CGroup: /system.slice/systemd-resolved.service
āā812 /usr/lib/systemd/systemd-resolved
Jun 04 20:06:58 weingeist-PC systemd-resolved[812]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Jun 04 20:06:58 weingeist-PC systemd-resolved[812]: Negative trust anchors: home.arpa 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in->
Jun 04 20:06:58 weingeist-PC systemd-resolved[812]: Using system hostname 'weingeist-PC'.
Jun 04 20:06:58 weingeist-PC systemd[1]: Started Network Name Resolution.
Jun 04 20:07:03 weingeist-PC systemd-resolved[812]: enp0s25: Bus client set default route setting: yes
Jun 04 20:07:03 weingeist-PC systemd-resolved[812]: enp0s25: Bus client set DNS server list to: fd00::464e:6dff:feb2:1640, 2a03:e440:800:e800:464e:6dff:>
Jun 04 20:07:03 weingeist-PC systemd-resolved[812]: enp0s25: Bus client set search domain list to: fritz.box
Jun 04 20:07:03 weingeist-PC systemd-resolved[812]: enp0s25: Bus client set DNS server list to: 192.168.0.1, fd00::464e:6dff:feb2:1640, 2a03:e440:800:e8>
Jun 04 20:08:14 weingeist-PC systemd-resolved[812]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 192.168.0.1.
systemctl status avahi-daemon ī² ā ī² 1m 37s ļ
ā avahi-daemon.service - Avahi mDNS/DNS-SD Stack
Loaded: loaded (/usr/lib/systemd/system/avahi-daemon.service; enabled; preset: disabled)
Active: active (running) since Sun 2023-06-04 20:06:58 CEST; 12min ago
TriggeredBy: ā avahi-daemon.socket
Main PID: 885 (avahi-daemon)
Status: "avahi-daemon 0.8 starting up."
Tasks: 2 (limit: 14157)
Memory: 1.2M
CPU: 29ms
CGroup: /system.slice/avahi-daemon.service
āā885 "avahi-daemon: running [weingeist-PC-2.local]"
āā896 "avahi-daemon: chroot helper"
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Withdrawing address record for ::1 on lo.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Withdrawing address record for 127.0.0.1 on lo.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Registering new address record for 2a03:e440:800:e800:1119:de8c:5d01:d82c on enp0s25.*.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Registering new address record for ::1 on lo.*.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Joining mDNS multicast group on interface enp0s25.IPv4 with address 192.168.0.2.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: New relevant interface enp0s25.IPv4 for mDNS.
Jun 04 20:07:03 weingeist-PC avahi-daemon[885]: Registering new address record for 192.168.0.2 on enp0s25.IPv4.
Jun 04 20:07:05 weingeist-PC avahi-daemon[885]: Server startup complete. Host name is weingeist-PC-2.local. Local service cookie is 1992427314.
journalctl -b | grep "avahi" ī² ā ī² 19s ļ
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: Found user 'avahi' (UID 972) and group 'avahi' (GID 972).
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: Successfully dropped root privileges.
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: avahi-daemon 0.8 starting up.
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: Successfully called chroot().
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: Successfully dropped remaining capabilities.
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: No service file found in /etc/avahi/services.
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: Failed to create server: No suitable network protocol available
Jun 04 20:45:31 weingeist-PC avahi-daemon[813]: avahi-daemon 0.8 exiting.
Jun 04 20:45:31 weingeist-PC systemd[1]: avahi-daemon.service: Main process exited, code=exited, status=255/EXCEPTION
Jun 04 20:45:31 weingeist-PC systemd[1]: avahi-daemon.service: Failed with result 'exit-code'.
A note for anyone who has searx-ng installed from source (not AUR or Manjaro repos). The Python update breaks it. After wasting a lot of time trying to work out how to get everything in order for it, I found that the best (and quickest) way to get it working again was to completely delete the searxng userās home directory and reinstall it as per the step by step installation guide
[edit]: the Python update instructions linked at the top would probably have helped a bit in this, though I have a feeling searx-ng itself would still have needed a complete manual rebuild.
hamster-time-tracker does not work after python upgrade.
# hamster
File "/usr/bin/hamster", line 415, in <module>
i18n.setup_i18n()
File "/usr/lib/python3.11/site-packages/hamster/lib/i18n.py", line 24, in setup_i18n
module.bind_textdomain_codeset('hamster','utf8')
AttributeError: module 'gettext' has no attribute 'bind_textdomain_codeset'
This is a known issue, fixed upstreamā¦ workaround here:
I noticed both my browsers (Librewolf/Firefox, the latter being a flatpak) and applications like Screenshot, Libreoffice and Gnome-System-Monitor being incredibly slow and unresponsive for me after the update, when they werenāt before, they eventually start and work but it takes a good while, like a full minute+ in some cases, so I have no idea whatās going on there.
