I have black screen instead of XFCE panels. .xsession-errors says:
/usr/bin/iceauth: creating new authority file /run/user/1000/ICEauthority
gpg-agent: a gpg-agent is already running - not starting a new one
xfce4-panel: symbol lookup error: xfce4-panel: undefined symbol: xfce_gdk_device_grab
Thunar: symbol lookup error: Thunar: undefined symbol: xfce_g_file_is_trusted
I have replaced dbus-x11 with dbus. Should I replace libxfce4ui-devel and libxfce4util-devel with libxfce4ui and libxfce4util?
I’m just a regular user, so please give clear instructions. Thank you!
UPDATE: I did install standard libxfce4ui and libxfce4util instead of -devel but it did nothing. The same .xsession-errors.
How can I learn where those xfce_gdk_device_grab and xfce_g_file_is_trusted happen?
I also have an error window because of Birdtray:
Fatal error: Sorry, system tray cannot be controlled through this add-on on your operating system.
Log file is written into file /tmp/birdtray-log.txt
and that log file is empty.
UPDATE2: I removed birdtray (a flatpack application), it sped up the loading, but didn’t help otherwise. How should I debug the problem of the absent XFCE panels?
Seems mostly good on my KDE Plasma system, except for the annoyance that when I open a konsole, the journal gets hit with messages saying:
Dec 21 12:02:11 konsole[13113]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Dec 21 12:02:11 konsole[13113]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
then every now and then the journal gets spammed with lots of messages saying:
konsole[8999]: QPen::setWidth: Setting a pen width that is out of range
I can’t find anything about these messages with a Web search.
I had extremely glitchy KDE with this version of Mesa. Opening anything would make it glitch a lot. journalctl did not show anything obvious nor any coredumpctl.
Used downgrade to downgrade everything and got it back working properly. In my case it was:
Same thing for me, on Thinkpad T420, iGPU.
I’ll try installing dbus, and reboot and see how it goes.
issue started after updating and switching to kernel 6.1
UPDATE:
Yup, iT’s the kernek 6.1 issues, also CPU temps are very high with 6.1
