Known issues and solutions
Please don’t post to say everything was great on my side or yes, I have the same error but leave the space for people having issues, or even better: for people having solutions!
Use
instead to let us know you’re suffering from the same so we can respond to the highest impacted issues first!
2022-07-29
[details=“FIXED with qt5-wayland 5.15.5+kde+r38-3 (KDE Wayland: Kickoff “KDE menu”, notifications and tooltips show in the upper left corner)”]
- This is due to an upstream packaging bug, which has since been reverted.
- In the meantime, you can (temporarily) disable the associated Wayland feature (thanks @ufo_driver):
sudo echo 'export QT_WAYLAND_DISABLE_FIXED_POSITIONS=1' > /etc/profile.d/qt5-wayland-regression.sh
[/details]
FIXED missing dependency 'gcc8-libs=8.5.0-1' required by gcc8
- This happens even while gcc8-libs are already installed (8.5.0-1).
- Fixed by manually uninstalling gcc8 and gcc8-libs.
2022-07-18
wxWidgets 3.2 update may need manual intervention
Packages have been renamed from wxgtk- to wxwidgets-. The GTK2 frontend is no longer provided. If you have wxgtk2 installed, the upgrade will fail with:
In such case, uninstall wxgtk2 first and then proceed with the upgrade.
2022-07-12
Wireplumber 0.4.11 may crash for GDM users
Currently there is an issue with 0.4.11 and GDM crashing on boot-up. More in the upstream bugtracker issue: Making sure you're not a bot!
2022-06-12
Akonadi (KMail / Kontact / KOrganizer...) fails to start
touch ~/.local/share/akonadi/db_data/ib_logfile0
akonadictl start
mariadb-upgrade --defaults-file=~/.local/share/akonadi/mysql.conf --socket=/run/user/$(id -u)/akonadi/mysql.socket
Locale file changes
C.UTF8 locale is now included in glibc:
Credits @diabonas for this change. Systemd wants us to include C.UTF8 by default and it seems the locale may be in included by glibc upstream in the future. To fix building and avoid nasty fixing in devtools, we include the locale in the package. See systemd/systemd#23252 (comment) FS#74864 : [systemd] >= 251 breaks devtools' locale
There is a pacsave for /etc/locale.conf as it has been removed from the filesystem package. /etc/locale.conf will automatically be restored if it did not already exist.
There is a pacnew for /etc/locale.gen. Please review it and regenerate your locale if necessary.
2022-05-13
Chromium / Google Chrome cannot save files to most folders (GNOME and Xfce)
This is an upstream bug with the package xdg-desktop-portal-gnome
In the meantime, you can try to remove the package xdg-desktop-portal-gnome (if feasible, without any dependency issues or conflicts), or wait for the bug to be fixed upstream.
Without any xdg-desktop-portal-* packages, Chromium and Google Chrome should correctly detect the environment and present either KDialog (KDE) or GTK file picker (GNOME, Xfce) upon saving and downloading files.
An alternative workaround, for now, is to intentionally click on the filename field, and then press Enter to save / download the file.
GNOME 42: theming and COSMIC packages changes, Bluetooth disabled by default
libkipi: Pamac fails to build the package from AUR
- libkipi is a deprecated dependency for some KDE applications, and has been moved to AUR.
- When using Pamac graphically, you can disable the update for libkipi, before removing it from your system.
- When using Pamac from the terminal, you can proceed the update in multiple steps:
pamac upgrade --no-aur
pamac remove libkipi
pamac upgrade --aur
Timeshift: new rsync snapshots do not show
Wine: cannot be built locally
2022-05-10
QEMU >= 7.0.0 changes split package setup
2022-05-09 - David Runge
With the update to qemu 7.0.0 the package has been turned into a more fine grained split package utilizing meta packages.
- The
qemu package is now virtually provided by the meta packages qemu-base, qemu-desktop and qemu-full.
- The functionality of
qemu prior to 7.0.0 is replaced by qemu-desktop
qemu-headless is replaced by qemu-base
qemu-arch-extra and qemu-headless-arch-extra is replaced by qemu-emulators-full
- The meta package
qemu-full provides all QEMU related packages (excluding qemu-guest-agent)
