I had the conflict with jack2 and pipewire-jack too. Pacaur or pamac wouldn’t let me proceed, neither uninstall jack2 because of dependencies, so I forcibly uninstalled it:
sudo pacman -Rdd jack2
Then I installed pipewire-jack, lib32-pipewire-jack, and run the upgrade.
After the upgrade, I ran
sudo pacman -S manjaro-pipewire plasma
once again.
But I got some issued. I use SMPlayer (based on mpv) as my media player, and it won’t play anything anymore. It shows the following:
/usr/bin/mpv --no-config --no-quiet --terminal --no-msg-color --input-ipc-server=/tmp/smplayer-mpv-b13 --msg-level=ffmpeg/demuxer=error --video-rotate=no --no-fs --vd-lavc-threads=4 --hwdec=auto --sub-auto=fuzzy --vo=gpu, --gpu-context=x11egl --no-input-default-bindings --input-vo-keyboard=no --no-input-cursor --cursor-autohide=no --no-keepaspect --wid=4 --monitorpixelaspect=1 --osd-level=1 --osd-scale=1 --osd-bar-align-y=0.6 --sub-ass --embeddedfonts --sub-ass-line-spacing=0 --sub-scale=1 --sub-codepage=ISO-8859-1 --vid=1 --sub-pos=99 --volume=101 --cache=auto --screenshot-template=cap_%F_%p_%02n --screenshot-format=jpg --screenshot-directory=/home/alpha/Pictures/smplayer_screenshots --audio-pitch-correction=yes --volume-max=110 --term-playing-msg=MPV_VERSION=${=mpv-version:}
INFO_VIDEO_WIDTH=${=width}
INFO_VIDEO_HEIGHT=${=height}
INFO_VIDEO_ASPECT=${=video-params/aspect}
INFO_VIDEO_FPS=${=container-fps:${=fps}}
INFO_VIDEO_FORMAT=${=video-format}
INFO_VIDEO_CODEC=${=video-codec}
INFO_DEMUX_ROTATION=${=track-list/0/demux-rotation}
INFO_AUDIO_FORMAT=${=audio-codec-name}
INFO_AUDIO_CODEC=${=audio-codec}
INFO_AUDIO_RATE=${=audio-params/samplerate}
INFO_AUDIO_NCH=${=audio-params/channel-count}
INFO_LENGTH=${=duration:${=length}}
INFO_DEMUXER=${=current-demuxer:${=demuxer}}
INFO_SEEKABLE=${=seekable}
INFO_TITLES=${=disc-titles}
INFO_CHAPTERS=${=chapters}
INFO_TRACKS_COUNT=${=track-list/count}
METADATA_TITLE=${metadata/by-key/title:}
METADATA_ARTIST=${metadata/by-key/artist:}
METADATA_ALBUM=${metadata/by-key/album:}
METADATA_GENRE=${metadata/by-key/genre:}
METADATA_DATE=${metadata/by-key/date:}
METADATA_TRACK=${metadata/by-key/track:}
METADATA_COPYRIGHT=${metadata/by-key/copyright:}
INFO_MEDIA_TITLE=${=media-title:}
INFO_STREAM_PATH=${stream-path}
--audio-client-name=SMPlayer --term-status-msg=STATUS: ${=time-pos} / ${=duration:${=length:0}} P: ${=pause} B: ${=paused-for-cache} I: ${=core-idle} VB: ${=video-bitrate:0} AB: ${=audio-bitrate:0} /home/alpha/Downloads/UT2003 - - s1mple --MP3CTIGktnA.mp4
(+) Video --vid=1 (*) (h264 720x480 29.970fps)
(+) Audio --aid=1 (*) (aac 2ch 44100Hz)
[vo/gpu/x11] X11 error: BadDrawable (invalid Pixmap or Window parameter)
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 4, serial: 13
[vo/gpu/x11] Error code: 9, request code: e, minor code: 0
[vo/gpu/x11] X11 error: BadWindow (invalid Window parameter)
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 4, serial: 14
[vo/gpu/x11] Error code: 3, request code: 28, minor code: 0
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 4, serial: 1d
[vo/gpu/x11] Error code: 3, request code: 2, minor code: 0
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 4, serial: 1f
[vo/gpu/x11] Error code: 3, request code: 1, minor code: 0
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 1400002, serial: 22
[vo/gpu/x11] Error code: 3, request code: 12, minor code: 0
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 1400002, serial: 24
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 1400002, serial: 25
[vo/gpu/opengl] Could not create EGL surface!
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 1400002, serial: 27
[vo/gpu/x11] Type: 0, display: 0x7fa02c003440, resourceid: 1400002, serial: 28
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 10 (X_UnmapWindow)
Resource id in failed request: 0x1400002
Serial number of failed request: 44
Current serial number in output stream: 48
EDIT: This only happens in the wayland session, not the X11 session
My system Paste #349205 | Zeropaste
