Hi,
Timeshift,
Restore window became too tall, making it go beyond the bottom of the screen, unable to click buttons at the bottom of the window.
Edit:
The minimum height is fixed at 1147 pixels, can go taller though.
Hi,
Timeshift,
Edit:
And can’t you resize it from the top?
See edit…
I don’t see any issue on my side. Look into your KDE window settings/rules that you probably made, and if you can’t figure it out, open a thread for support.
Look into System Settings → Windows Management → Windows Rules
Maybe click on the Titlebar and move it to the desktop corners… to change the window size.
On XFCE, I would use a combination of the Window Manager shortcut keys to Move or Resize the window (pull the window down, resize, repeat as necessary).
They are alt-f7 or alt-left-click and alt-f8 or alt-right-clickand are displayed in the Settings Manager under Window Manager > Keyboard.
