Lost compiz running on top of Mate. Mate is running fine, but compiz isn’t starting. Any help will be greatly appreciated.
EDIT: OK seems i solved it myself … killing pamac, remove db lock, removing the locally newer pamac version and sudo update-grub did the trick for me … at least it is still working after a reboot.
Original post:
Well … i tried to update but now pamac ist stuck
Is it save to kill the task :(?
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64-fallback.img
Updating Grub-Bootmenu
Generating grub configuration file …
Found linux image: /boot/vmlinuz-5.12-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.12-x86_64.img
Found initrd fallback image: /boot/initramfs-5.12-x86_64-fallback.img
It’s output will be used to detect bootable binaries on them and create new boot entries.
umount: /var/lib/os-prober/mount: das Ziel wird gerade benutzt.
rmdir: konnte ‘/var/lib/os-prober/mount’ nicht entfernen: Das Gerät oder die Ressource ist belegt
After updating, my plasmashell (I think) doesn’t work. After splash screen I get black screen with no Plasma stuff, only cursor, sometimes I can open terminal over Yakuake if it starts automatically and then I can start other programs as usual, but still no task bar, workspaces desktops or anything.
plasmashell 130 ↵
plasmashell: symbol lookup error: /usr/lib/libKF5PlasmaQuick.so.5: undefined symbol: _ZN14KWindowEffects11slideWindowEP7QWindowNS_17SlideFromLocationEi
Same problem here.
Not sure where to start no this one.
~ >>> kquitapp5 plasmashell && kstart5 plasmashell
"Application plasmashell could not be found using service org.kde.plasmashell and path /MainApplication."
neofetch
OS: Manjaro Linux x86_64
Kernel: 5.11.19-1-MANJARO
Resolution: 3840x2160, 2560x1440
DE: Plasma
WM: KWin
Themes: Breeze Dark [Plasma], Breath [GTK2/3]
Icons: breeze-dark [Plasma], breeze-dark [GTK2/3]
Terminal: konsole Terminal Font: Noto Mono 10
CPU: AMD Ryzen 7 3800X (16) @ 4.200GHz
GPU: NVIDIA GeForce RTX 2060
Memory: 2827MiB / 32085MiB
I upgrade my wifi card to AX210 on my X230 Thinkpad. The card isn’t usable until I rename / remove the following file.
iwlwifi-ty-a0-gf-a0.pnvm under /usr/lib/firmware/
I am on 5.11 now and it was the same with 5.12
Well … i now killed pacman as it won’t close on its own and cancel button was disabled.
I had to delete /var/lib/pacman/db.lck now sudo pacman -Syyu results in:
Warnung: pamac-cli: Lokale Version (10.1.2-0.1) ist neuer als extra (10.0.6-2)
Warnung: pamac-common: Lokale Version (10.1.2-0.1) ist neuer als extra (10.0.6-2)
Warnung: pamac-flatpak-plugin: Lokale Version (10.1.2-0.1) ist neuer als extra (10.0.6-2)
Warnung: pamac-gtk: Lokale Version (10.1.2-0.1) ist neuer als extra (10.0.6-2)
Warnung: pamac-snap-plugin: Lokale Version (10.1.2-0.1) ist neuer als extra (10.0.6-2)
Seems i got an anhealthy pamac? I will revert to the old version.
Me neither, and when something like this happens for the 3rd time in couple of months on a computer from work, it’s a problem. I noticed someone else posted the same problem in 13-5 update, no solution yet. And only three posts about this error, we’re not getting help any time soon Search results for '_ZN14KWindowEffects11slideWindowEP7QWindowNS_17SlideFromLocationEi' - Manjaro Linux Forum
Why would you even add nvdia drivers update if it’s not ready yet. Literally spent hours fixing it, eventually ending up with nouveau.
@Manjaro team After update the reboot was necessary → my reboot stopped with black screen. I had to do 2 times (twice) Ctrl+Alt+Del in order to make reboot hapenning successfully. Should I (or could I) do something about this ?
Similar to this? [Stable Update] 2021-05-19 - Kernels, Nvidia, KDE Frameworks, Plasma, Systemd, LibreOffice, KDE Gear Mobile, FF, TB - #68 by CalibratedCabbage
Right after updating, I started getting
The window switcher installation is broken, resources are missing.
Every time I ALT+TAB’d.
Haven’t rebooted yet
EDIT: reboot made it go away it seems
@CalibratedCabbage My reboot issue does not look (to me) like yours. I had this quite minor issue only in one desktop, not in laptops. My now, after this (Ctrl+Alt+Del) was done, this does not happen any more in the desktop in question.
The amdgpu-bug causing a lockup after suspend still seems present in 5.12.2
Haven’t dared to check latest 5.11, as I will then lose 5.11.6, which is the last (known to me) working kernel from 5.11 without lockups after suspend (on my Ryzen 4600U-based laptop).
For anyone affected, 5.10.32+ seems fine, too.
Can be issue of your GTK theme, but similar one/related is already reported (if I’m not wrong).
You may downgrade pamac
to the actual repo version.
sudo pacman -Syyuu
How long did you wait with the black screen? My laptop took much longer than usual on the next boot - looks like it was running fsck - but it booted up fine…
In case it helps, I had Compiz issues (on XFCE) after updating - including no ability to run CompizConfig. Chose to rebuild it (from within Pamac [10.0.6-2] “compiz-easy-patch 0.9.14.1-4”) and it required a new/updated dependency (sorry - clicked through accidentally before noting precisely what it was!).
After that rebuild and another restart, Compiz has been working as it was before the update.
Kernel 5.10.36-2-MANJARO
XFCE
amdgpu
Can somebody help about real issues that make your routine suffer, instead of people reporting random inconveniences like “my buttons are all wrong” and burying other posts?
